[General] 2V0-16.25 Learning Mode - Latest 2V0-16.25 Test Voucher
99
【General】 2V0-16.25 Learning Mode - Latest 2V0-16.25 Test Voucher
Posted at 2/3/2026 14:42:05      View:124 | Replies:0        Print      Only Author   [Copy Link] 1#
BTW, DOWNLOAD part of RealValidExam 2V0-16.25 dumps from Cloud Storage: https://drive.google.com/open?id=10_D-PyhTtPj688URvS-PCq9yMDNTxfCh
Perhaps you are in a bad condition and need help to solve all the troubles. Don’t worry, once you realize economic freedom, nothing can disturb your life. Our 2V0-16.25 study materials can help you out. Learning is the best way to make money. So you need to learn our 2V0-16.25 study materials carefully after you have paid for them. As long as you are determined to change your current condition, nothing can stop you. Once you get the 2V0-16.25 certificate, all things around you will turn positive changes. Never give up yourself. You have the right to own a bright future.
VMware 2V0-16.25 Exam Syllabus Topics:
  • Plan and Design the VMware by Broadcom Solution: This section of the exam measures the ability of VMware Solution Architects to plan and design solutions. While there are no specific testable objectives included, the focus is on preparing professionals to design VMware-based solutions that align with organizational goals and best practices.
  • VMware vSphere Foundation Fundamentals: This section of the exam measures the skills of Virtualization Engineers and focuses on the essentials of virtualization technology. It introduces the principles of virtualization, explores use cases, and highlights the value it brings to businesses. Candidates are expected to demonstrate knowledge of VMware compute components such as vCenter and ESX, cluster configuration, and lifecycle management of virtual machines. It also covers secure workload operations, encryption, and managing resources with content libraries. In addition, storage fundamentals are examined through configuring vSphere storage, deploying VMware vSAN clusters, defining storage policies, and ensuring data availability. Networking fundamentals are also introduced, requiring the ability to differentiate between VMware vSphere networking components.
  • IT Architectures, Technologies, Standards: This section of the exam measures the understanding of IT Infrastructure Architects and covers foundational concepts of architectures, emerging technologies, and industry standards. Although no testable objectives are listed here, it establishes the baseline knowledge needed to interpret and design VMware-related environments effectively.
  • Troubleshoot and Optimize the VMware Solution: This section of the exam measures the ability of Systems Engineers to troubleshoot and optimize VMware-based environments. While no explicit testable objectives are listed, candidates are expected to apply their problem-solving skills to diagnose, resolve, and enhance VMware solutions for improved reliability and performance.
Topic 5
  • Deploy, Configure, and Operate VMware vSphere Foundation (VVF): This section of the exam measures the expertise of Data Center Administrators and emphasizes hands-on skills in deploying and configuring VMware vSphere Foundation environments. Candidates must understand the components of a VVF deployment, configure Supervisors within clusters, and manage identity, access control, licensing, and certificate management. The objectives also extend to lifecycle management within the vSphere Foundation. Furthermore, it explores operational tasks including monitoring and analyzing logs, configuring alerting, managing dashboards, and integrating with VMware Cloud Foundation (VCF) Operations. Candidates will also be tested on cost and pricing configuration, compliance monitoring, and security hardening practices. Finally, automation skills are validated through deploying services with Supervisors, running Kubernetes workloads, using VM services, and integrating VCF Operations Orchestrator to support enterprise automation.
Latest 2V0-16.25 Test Voucher - 2V0-16.25 New Dumps FilesProfessionals who hold 2V0-16.25 certification demonstrate to their employers and clients that they have the knowledge and skills necessary to succeed in the industry. To meet the growing demand for VMware 2V0-16.25 certification exam, preparation platforms have emerged in recent years. RealValidExam offers candidates actual 2V0-16.25 Questions Pdf, practice exams, and 24/7 support to ensure they have the best possible preparation for the exam.
VMware vSphere Foundation 9.0 Administrator Sample Questions (Q47-Q52):NEW QUESTION # 47
An administrator is tasked to implement a new iSCSI storage for a new cluster.
The following information was provided to the administrator:
* iSCSI storage controller IPs are all in the same subnet.
* Multipathing should be used.
* Storage supports Asymmetric Logical Unit Access (ALUA).
* Should be configured for high performance.
Which are the four required steps to configure this on an ESX host? (Choose four.)
  • A. Add iSCSI software adapter.
  • B. Add NVMe over TCP software adapter.
  • C. Configure two unbound VMkernel ports.
  • D. Configure two bound VMkernel ports.
  • E. Set Path Selection Policy (PSP) to Most Recently Used (MRU).
  • F. Configure 2 vSwitch with 1 Uplink.
  • G. Set Path Selection Policy (PSP) to Round Robin (RR).
  • H. Configure 1 vSwitch with 2 Uplinks.
Answer: A,D,G,H
ForiSCSI multipathing with ALUAandhigh performancein ESXi:
* 1 vSwitch with 2 Uplinks# Standard design for redundancy and multipathing. (B)
* Add iSCSI software adapter# Required to connect to storage. (E)
* Configure two bound VMkernel ports# Ensures multipathing (one per uplink). (G)
* Set PSP to Round Robin (RR)# Optimizes I/O balancing across multiple paths. (F) Other options:
* A. 2 vSwitches with 1 Uplink each# Not recommended, complicates multipathing.
* C. NVMe over TCP# Not relevant, storage is iSCSI.
* D. MRU policy# Legacy, not high performance.
* H. Unbound VMkernel ports# Used for software iSCSI port binding, but "bound" VMkernel ports are required for multipathing.
VMware vSphere 9.0 -iSCSI Configuration with Multipathing
VMware KB 2038869 -Configuring Round Robin PSP with iSCSI
NEW QUESTION # 48
An administrator has been tasked to create a virtual machine (VM) into a VMware vCenter Supervisor Namespace in an existing VMware vSphere Foundation (VVF) deployment.
How would the administrator create the VM?
  • A. Use VCF CLI to deploy the VM.
  • B. Create a YAML file and deploy using kubectl.
  • C. Deploy using the vSphere Client.
  • D. Log in to VCF Automation Service Broker and select the "Create a VM" catalog item.
In aVMware vSphere Foundation (VVF) deploymentwithvCenter Supervisor Namespaces enabled, the method for creating VMs inside a Supervisor Namespace relies on thevSphere VM Service.
* TheVM Serviceexposes VMs as Kubernetes-native objects that are managed usingkubectl.
* Administrators (or DevOps engineers with appropriate permissions) must write aVM YAML manifest file, which specifies parameters such as apiVersion, kind: VirtualMachine, spec.imageName, spec.
className, spec.storageClass, and spec.networkInterfaces.
* The YAML manifest is thenapplied with kubectlto the Supervisor context.
This approach is documented as the supported method:
"As a DevOps engineer, provision a VM and its guest OS in a declarative manner by writing VM deployment specifications in a Kubernetes YAML file." Why the other options are incorrect:
* B. Deploy using the vSphere Client##The vSphere Client is used to configure Namespaces, permissions, and VM classes, butactual VM creation in Supervisor Namespaces is done via kubectl
+ YAML.
* C. Use VCF CLI to deploy the VM##VCF CLI (kubectl vsphere login) is used only to authenticate and obtain context, not to create VMs.
* D. Log in to VCF Automation Service Broker##This is used for vRealize Automation/Aria Automation integration, not for direct Supervisor Namespace VM creation.
VMware Cloud Foundation 9.0.4 Documentation -Deploy a Virtual Machine on a Namespace in a Supervisor VMware Cloud Foundation 9.0.4 Documentation -Prepare a VM YAML file for Supervisor VMware Docs: VM Service in vSphere with Tanzu
NEW QUESTION # 49
An organization requires a centralized platform to monitor the performance, health, and capacity of their entire VMware vSphere Foundation (VVF) environment.
Which two components would provide this capability? (Choose two.)
  • A. VCF Operations
  • B. vSphere Supervisor
  • C. VCF Operations for Networks
  • D. VCF Operations for Logs
The requirement is for acentralized platformto monitorperformance, health, and capacityacross theentire VMware vSphere Foundation (VVF) environment.
* VCF Operations
* Providesend-to-end performance monitoring, capacity management, and health analytics across vCenter, ESXi, vSAN, and NSX.
* IncludesFinOps and Capacity Planning,performance diagnostics, andAI-driven troubleshootingfor faster remediation.
* This is the primary component for monitoring theentire VCF environment.
* VCF Operations for Networks
* Extends observability tonetwork operationsby monitoring NSX health, VPCs, and network flows.
* Providestraffic summaries, alerts, and network capacity metrics.
* Integrated with VCF Operations to ensure acomplete platform-wide viewof health and performance.
* Why not the others?
* VCF Operations for Logs# Focused onlog management, troubleshooting, and diagnostics(not holistic performance/capacity monitoring).
* vSphere Supervisor# ProvidesKubernetes namespace and workload management, not centralized performance/capacity monitoring.
VMware Cloud Foundation 9.0.1 -Performance Monitoring and Capacity in VCF Operations VMware Cloud Foundation 9.0.1 -VCF Health and Diagnostics in Operations VMware Cloud Foundation 9.0.1 -Network Operations with VCF Operations for Networks VMware Cloud Foundation 9.0.3 -Integration of Network Alerts into VCF Operations
NEW QUESTION # 50
What is the purpose of a port group on a Distributed Switch?
  • A. To manage storage I/O performance.
  • B. To define a logical grouping of virtual ports for network traffic segmentation.
  • C. To allocate CPU and memory resources to virtual machines.
  • D. To enable vSAN connectivity.
Aport groupon avSphere Distributed Switch (VDS)provides:
* Logical grouping of virtual ports.
* Definesnetwork policiessuch as VLAN IDs, traffic shaping, security policies, and teaming.
* Used for segmenting traffic types (vMotion, vSAN, management, VM traffic).
Other options:
* A. Enable vSAN connectivity# Achieved by assigning vSAN traffic to a port group, but not the main definition.
* B. Allocate CPU/memory resources# Done via resource pools, not port groups.
* D. Manage storage I/O performance# Done with Storage I/O Control, not port groups.
VMware vSphere 9.0 -vSphere Networking Basics
VMware Docs: Port Groups on Distributed Switch
NEW QUESTION # 51
An administrator is following the concept of least privilege and must configure permissions in a vSphere environment granting members of the group corpVM-Managers the following abilities:
* Power on/off virtual machines
* Open consoles
* Create snapshots
Which out-of-the-box role satisfies these access control requirements?
  • A. Administrator
  • B. Virtual Machine Power User
  • C. Virtual Machine User
  • D. Virtual Machine Console User
The requirement is to followleast privilegewhile granting specific VM operations:
* Open consoles
* Create snapshots
TheVirtual Machine Power Userrole is the correct out-of-the-box role, as it includes all these privileges without granting unnecessary administrative access.
Other roles:
* Administrator (A):Grants full environment control # too broad.
* Virtual Machine Console User (B)imited to console access, cannot power on/off or snapshot.
* Virtual Machine User (C):Can interact with VMs but lacks snapshot privileges.
VMware vSphere 9.0 Documentation -Default Roles and Permissions
VMware KB 1033138 -Privileges for VM Roles
NEW QUESTION # 52
The RealValidExam 2V0-16.25 PDF file is a collection of real, valid, and updated VMware vSphere Foundation 9.0 Administrator (2V0-16.25) exam questions. It is very easy to download and install on laptops, and tablets. You can even use 2V0-16.25 Pdf Format on your smartphones. Just download the RealValidExam 2V0-16.25 PDF questions and start VMware vSphere Foundation 9.0 Administrator (2V0-16.25) exam preparation anywhere and anytime.
Latest 2V0-16.25 Test Voucher: https://www.realvalidexam.com/2V0-16.25-real-exam-dumps.html
DOWNLOAD the newest RealValidExam 2V0-16.25 PDF dumps from Cloud Storage for free: https://drive.google.com/open?id=10_D-PyhTtPj688URvS-PCq9yMDNTxfCh
