[General] Free FAAA_005 Test Questions, Valid FAAA_005 Test Book
102
General Free FAAA_005 Test Questions, Valid FAAA_005 Test Book
Posted at 2/3/2026 15:32:21      View152 | Replies1        Print      Only Author   [Copy Link] 1#
P.S. Free & New FAAA_005 dumps are available on Google Drive shared by Actual4Dumps: https://drive.google.com/open?id=1RjYjPmKInZn-lZ1aS9L7ezgZexEDcqUC
There is no doubt that obtaining this FAAA_005 certification is recognition of their ability so that they can find a better job and gain the social status that they want. Most people are worried that it is not easy to obtain the certification of FAAA_005, so they dare not choose to start. We are willing to appease your troubles and comfort you. We are convinced that our FAAA_005 test material can help you solve your problems. Compared to other learning materials, our FAAA_005 exam qeustions are of higher quality and can give you access to the FAAA_005 certification that you have always dreamed of.
In this website, you can find three different versions of our FAAA_005 guide torrent which are prepared in order to cater to the different tastes of different people from different countries in the world since we are selling our FAAA_005 test torrent in the international market. Most notably, the simulation test is available in our software version. With the simulation test, all of our customers will have an access to get accustomed to the FAAA_005 Exam atmosphere and pass easily in the real FAAA_005 exam.
Valid FAAA_005 Test Book - Practice FAAA_005 Exam FeeOur FAAA_005 study guide provides free trial services, so that you can learn about some of our topics and how to open the software before purchasing. During the trial period of our FAAA_005 study materials, the PDF versions of the sample questions are available for free download, and both the pc version and the online version can be illustrated clearly. You can contact us at any time if you have any difficulties in the purchase or trial process of our FAAA_005 Exam Dumps.
Pure Storage FlashArray Architect Associate Sample Questions (Q42-Q47):NEW QUESTION # 42
A customer running FlashArray//X70R3 in production just purchased a FlashArray//C60R3 Array for a secondary site. The customer wants to have the lowest RPO (Recovery Point Objective) possible for the data.
Which FlashArray feature will meet the requirements?
  • A. ActiveCluster
  • B. ActiveDR
  • C. Async Replication
The customer wants to achieve the lowest RPO (Recovery Point Objective) possible for their data when replicating between a FlashArray//X70R3 in production and a FlashArray//C60R3 at a secondary site. The best feature to meet this requirement is ActiveDR.
Why This Matters:
ActiveDR:
ActiveDR is an asynchronous replication solution designed for disaster recovery scenarios. It provides low RPOs, typically in the range of seconds to minutes, depending on network conditions and workload characteristics.
While it is asynchronous, ActiveDR achieves much lower RPOs compared to traditional async replication methods like snapshot replication.
It also supports fast failover and failback, ensuring minimal downtime during a disaster recovery event.
Why Not the Other Options?
A). ActiveCluster:
ActiveCluster provides synchronous replication with zero RPO and near-zero RTO. However, it requires both sites to be within a low-latency range (typically <10 ms). Since the customer has not specified that the secondary site is within synchronous distance, ActiveCluster is not feasible in this scenario.
C). Async Replication:
Traditional asynchronous replication (e.g., snapshot replication) typically results in higher RPOs compared to ActiveDR. It does not provide the same level of optimization for low RPOs as ActiveDR.
Key Points:
ActiveDR: Provides the lowest RPO possible for asynchronous replication, making it ideal for geographically distant secondary sites.
Network Latency: ActiveDR is designed to work efficiently over longer distances and higher latencies compared to synchronous solutions like ActiveCluster.
Disaster Recovery: Ensures protection against site failures with minimal data loss and downtime.
Reference: Pure Storage FlashArray Documentation: "ActiveDR for Disaster Recovery" Pure Storage Whitepaper: "Meeting RPO and RTO Requirements with FlashArray" Pure Storage Knowledge Base: "Choosing the Right Replication Solution for High Latency"
NEW QUESTION # 43
What is the total amount of usable storage space consumed on this FlashArray system?
  • A. 5.58 T
  • B. 4.36 T
  • C. 1.22 T
  • D. 3.87 T
Why This Matters:
Usable Storage Space Consumed:
The "usable storage space consumed" refers to the actual physical capacity used on the array after accounting for RAID overhead but before applying data reduction techniques like deduplication and compression.
This value represents the raw space utilized by the data stored on the array, excluding any logical space savings from data reduction.
B). 5.58 T:
This value likely represents the logical capacity provisioned or consumed after applying data reduction techniques (e.g., deduplication and compression). However, the question specifically asks for the usable storage space consumed, which excludes logical space savings.
C). 1.22 T:
This value might represent the raw capacity of the drives or some other metric unrelated to the usable storage space consumed. It does not align with the definition of usable storage space.
D). 4.36 T:
This value could represent an intermediate calculation or another metric, but it does not match the usable storage space consumed as shown in the exhibit.
Key Points:
Usable Storage Space Consumed: Represents the physical capacity used on the array after RAID overhead but before data reduction.
Logical vs. Physical Capacity: Logical capacity reflects space savings from deduplication and compression, while usable storage space reflects the actual physical usage.
Exhibit Analysis: Carefully interpret the metrics provided in the exhibit to identify the correct value.
Reference: Pure Storage FlashArray Documentation: "Understanding Array Capacity Metrics" Pure Storage Whitepaper: "Capacity Management and Data Reduction" Pure Storage Knowledge Base: "What is Usable Space vs. Raw Space?"
NEW QUESTION # 44
An admin is setting up replication and has set up a Protection Group.
What are the three choices when adding Members? (Select three.)
  • A. Add Snapshots
  • B. AddHBAWWN
  • C. Add Host Groups
  • D. Add Hosts
  • E. Add Volumes
Answer: A,C,E
When setting up replication on a Pure Storage FlashArray, an admin creates a Protection Group to define which entities will be replicated to a remote FlashArray. When adding members to a Protection Group, there are three valid choices: Volumes, Snapshots, and Host Groups. Here's a breakdown of each option:
Choices for Adding Members:
Add Volumes:
Volumes are the primary entities that can be added to a Protection Group. Replication ensures that the data within these volumes is copied to the remote FlashArray.
This is the most common use case for replication, especially for protecting critical data such as databases or virtual machine disks.
Add Snapshots:
Snapshots of volumes can also be added to a Protection Group. This allows point-in-time copies of the data to be replicated to the remote array.
Snapshots are useful for disaster recovery scenarios where you need to restore data to a specific point in time.
Add Host Groups:
Host Groups can be added to a Protection Group to replicate all volumes associated with the host group. This simplifies management when multiple volumes are tied to a single application or server.
Replicating Host Groups ensures that all related volumes are protected together, maintaining consistency across the workload.
Incorrect Options:
A). Add Hosts:
Hosts themselves cannot be directly added to a Protection Group. Instead, replication focuses on the data (volumes) or logical groupings (host groups) associated with the hosts.
E). Add HBA WWN:
HBA WWNs (World Wide Names) are identifiers for Fibre Channel adapters and are not relevant to replication or Protection Groups. They are used for zoning and connectivity but do not play a role in defining replication members.
Final Recommendation:
The correct options are
B). Add Volumes ,
C). Add Snapshots, and
D). Add Host Groups, as these are the valid entities that can be added to a Protection Group for replication.
Reference: Pure Storage Protection Groups Documentation:
Provides detailed guidance on creating and managing Protection Groups.
Pure Storage Replication Best Practices:
Explains how to configure replication for volumes, snapshots, and host groups.
Pure Storage Architectural Guides:
Covers architectural considerations for replication and disaster recovery.
NEW QUESTION # 45
A customer is assessing the health of their FlashArray.
What should the customer discuss with their SE based on this information?
  • A. Adding more network ports
  • B. Upgrading the controller to the //X90R3 model
  • C. Adding a second shelf of NVMe DirectFlash modules
Based on the exhibit (referenced via the link), the customer should discuss adding a second shelf of NVMe DirectFlash modules with their SE. This recommendation is based on the assumption that the exhibit indicates the array is nearing its capacity limits or requires additional storage to accommodate future growth.
Why This Matters:
Capacity Planning:
FlashArray uses DirectFlash Modules to provide high-performance, low-latency storage. If the array is approaching its physical capacity, adding a second shelf of NVMe modules is the most effective way to expand storage without requiring a full hardware upgrade.
This approach ensures the array can continue to meet the customer's growing storage needs while maintaining performance and reliability.
Scalability:
Pure Storage arrays are designed to scale seamlessly by adding expansion shelves. This allows customers to increase capacity without disrupting operations or replacing existing hardware.
A). Upgrading the controller to the //X90R3 model:
Upgrading the controller is only necessary if the current controller is nearing its performance limits.
The exhibit does not indicate performance bottlenecks, so this step is likely unnecessary.
C). Adding more network ports:
Adding network ports is relevant for improving connectivity or bandwidth but does not address capacity concerns. If the array is running out of storage space, adding network ports will not resolve the issue.
Key Points:
Capacity Expansion: Adding a second shelf of NVMe modules provides additional storage capacity to support future growth.
Non-Disruptive Scaling: Expansion shelves can be added without downtime, ensuring continuous availability.
Cost Efficiency: Avoids unnecessary upgrades or replacements, optimizing costs while meeting capacity requirements.
Reference: Pure Storage FlashArray Documentation: "Expanding FlashArray Capacity with DirectFlash Modules" Pure Storage Whitepaper: "Scaling Storage with FlashArray Expansion Shelves" Pure Storage Knowledge Base: "Best Practices for Capacity Planning and Expansion"
NEW QUESTION # 46
Which two features are specific to the Evergreen//Forever Program and are NOT included with Evergreen//Foundation? (Choose two.)
  • A. Controller Upgrades
  • B. Upgrade Always
  • C. Capacity Consolidation
  • D. Pro Deployment
The Evergreen//Forever program is Pure Storage's premium subscription offering, providing continuous upgrades and enhancements to ensure customers always have access to the latest technology. In contrast, Evergreen//Foundation is a lower-tier subscription with limited benefits.
Here's an analysis of the features:
Correct Features:
A). Controller Upgrades:
Controller upgrades are a key feature of Evergreen//Forever, allowing customers to upgrade their FlashArray controllers non-disruptively to newer generations.
This feature is not included in Evergreen//Foundation.
D). Upgrade Always:
"Upgrade Always" ensures that customers can continuously upgrade their hardware and software without additional costs.
This is a hallmark of Evergreen//Forever and is not available in Evergreen//Foundation.
Incorrect Features:
B). Pro Deployment:
Pro Deployment services are available across all Evergreen tiers, including Evergreen//Foundation. Therefore, this is not specific to Evergreen//Forever.
C). Capacity Consolidation:
Capacity consolidation is a general benefit of Pure Storage arrays and is not exclusive to Evergreen//Forever.
It is also available in Evergreen//Foundation.
The correct answers are
A). Controller Upgrades and
D). Upgrade Always, as these are specific to Evergreen//Forever and not included in Evergreen//Foundation.
Reference: Evergreen//Forever Program Overview:
Evergreen//Forever
Explains the benefits and features of Evergreen//Forever.
Evergreen Subscription Tiers Comparison:
Evergreen Tiers
Compares the features of Evergreen//Forever and Evergreen//Foundation.
NEW QUESTION # 47
To attempt the Pure Storage FAAA_005 exam optimally and ace it on the first attempt, proper exam planning is crucial. Since the Pure Storage FAAA_005 exam demands a lot of time and effort, we designed the Pure Storage FAAA_005 Exam Dumps in such a way that you would not have to go through sleepless study nights or disturb your schedule.
Valid FAAA_005 Test Book: https://www.actual4dumps.com/FAAA_005-study-material.html
FAAA_005 certification can demonstrate your mastery of certain areas of knowledge, which is internationally recognized and accepted by the general public as a certification, Pure Storage Free FAAA_005 Test Questions Download one exam or all the exams - its up to you, We guarantee Pure Storage Valid FAAA_005 Test Book exam dump 100% useful, Pure Storage Free FAAA_005 Test Questions We totally understand your needs and believe the unpleasant failure will be annoying.
Java has eight primitive types that should look familiar to you from other languages: Valid FAAA_005 Test Book `boolean`, In fact, for any character animation it's wise to make your own hierarchies and avoid the use of groups entirely, whenever possible.
Free PDF Unparalleled FAAA_005 - Free Pure Storage FlashArray Architect Associate Test QuestionsFAAA_005 Certification can demonstrate your mastery of certain areas of knowledge, which is internationally recognized and accepted by the general public as a certification.
Download one exam or all the exams - its up to you, We guarantee FAAA_005 Pure Storage exam dump 100% useful, We totally understand your needs and believe the unpleasant failure will be annoying.
We will offer different discount when it is festival day.
BONUS!!! Download part of Actual4Dumps FAAA_005 dumps for free: https://drive.google.com/open?id=1RjYjPmKInZn-lZ1aS9L7ezgZexEDcqUC
Posted at 2/9/2026 02:07:10        Only Author  2#
Your article is breathtaking, thank you for sharing! Im sharing Latest API-1169 test registration resources for free. Wishing you all the best!
