[General] New Plat-Dev-301 Test Practice - Real Plat-Dev-301 Exams
102
【General】 New Plat-Dev-301 Test Practice - Real Plat-Dev-301 Exams
Posted at 2/3/2026 15:40:10      View:100 | Replies:1        Print      Only Author   [Copy Link] 1#
The Lead1Pass is a reliable platform that is committed to making your preparation for the Salesforce Plat-Dev-301 examination easier and more effective. To meet this objective, the Lead1Pass is offering updated and real Salesforce Certified Platform Developer II - Multiple Choice Plat-Dev-301 exam dumps. These Salesforce Plat-Dev-301 Exam Questions are approved by experts. They work together and analyze the examination content to compile most probable Plat-Dev-301 real dumps in three formats. These Salesforce Exams questions will surely appear in the next Salesforce Plat-Dev-301 test.
The web-based Plat-Dev-301 practice test frees you from the need for software installation. It is compatible with all operating systems. The web-based Salesforce Certified Platform Developer II - Multiple Choice (Plat-Dev-301) practice test of requires no special plugins to function properly. Customization of this format allows you to change settings of Plat-Dev-301 Practice Exams. This self-assessment Plat-Dev-301 practice exam tracks your progress so you overcome your mistakes.
Real Salesforce Certified Platform Developer II - Multiple Choice Test Questions - Plat-Dev-301 Actual Torrent & Salesforce Certified Platform Developer II - Multiple Choice Pdf QuestionsOur products are the accumulation of professional knowledge worthy practicing and remembering. There are so many specialists who join together and contribute to the success of our Plat-Dev-301 guide quiz just for your needs. Our responsible and patient staff who has being trained strictly before get down to business and interact with customers. Once you have practiced and experienced the quality of our Plat-Dev-301 Exam Preparation, you will remember the serviceability and usefulness of them. It explains why our Plat-Dev-301 practice materials helped over 98 percent of exam candidates get the certificate you dream of successfully. Believe me you can get it too.
Salesforce Certified Platform Developer II - Multiple Choice Sample Questions (Q108-Q113):NEW QUESTION # 108
A developer is tasked with creating a Lightning web component that is responsive on various devices, Which two components should help accomplish this goal?
Choose 2 answers
  • A. Lightning-layout
  • B. lightning-navigation
  • C. Lightning-input-location
  • D. lightning-layout--item
Lightning-layout and lightning-layout-item are components used in Lightning Web Components to create responsive grid layouts that adapt to the screen size of various devices.
Lightning Layout: Component Reference
Lightning Layout Item: Component Reference
NEW QUESTION # 109
Given the following information regarding Universal Containers (UC):
* UC represents their customers as Accounts in Salesforce.
* All customers have a unique Customer__Number_c that is unique across all of UC's systems.
* UC also has a custom Invoice c object, with a Lookup to Account, to represent invoices that are sent out from their external system.
UC wants to integrate invoice data back into Salesforce so Sales Reps can see when a customer pays their bills on time.
What is the optimal way to implement this?
  • A. Query the Account Object upon each call to insert invoice data to fetch the Salesforce ID corresponding to the Customer Number on the invoice.
  • B. Use Salesforce Connect and external data objects to seamlessly import the invoice data into Salesforce without custom code.
  • C. Ensure Customer Number cis an External ID and that a custom field Invoice Number cis an External ID and Upsert invoice data nightly.
  • D. Create a cross-reference table in the custom invoicing system with the Salesforce Account ID of each Customer and insert invoice data nightly,
The optimal way to integrate invoice data into Salesforce, allowing for the upsert operation which can insert or update records based on the presence of the External ID, is to use the External ID fields. This ensures that the invoices are associated correctly with the existing Accounts and that upsert operations can be performed efficiently.
External ID: Salesforce Help Article
Data Import: Salesforce Developer Guide
NEW QUESTION # 110
For compliance purposes, a company is required to track long-term product usage in their org. The information that they need to log will be collected from more than one object and, over time, they predict they will have hundreds of millions of records.
What should a developer use to implement this?
  • A. Big objects
  • B. Field audit trail
  • C. Field history tracking
  • D. Setup audit trail
Big objects provide a solution for storing and managing large amounts of data within Salesforce. They are ideal for compliance purposes when tracking long-term usage data that will accumulate over time into very large record counts.
NEW QUESTION # 111
Consider the following code snippet:
Which two steps should the developer take to add flexibility to change the endpoint and credentials without needing to modify code? Choose 2 answers
  • A. Use red. setEndpoint (Label.endPointURL) ;.
  • B. Create a Named Credential, endPcint_wc, ta store the endpoint and credentials.
  • C. Store the URL of the endpoint in a custom Label named endpointuRL.
  • D. Use req. setindpoint ('callout:endFoint_NC'); within the callout request.
NEW QUESTION # 112
An org has a requirement that an Account must always have one and only one Contact listed as Primary. So selecting one Contact will de-select any others. The client wants a checkbox on the Contact called 'Is Primary' to control this feature.
The client also wants to ensure that the last name of every Contact is stored entirely in uppercase characters.
What is the optimal way to implement these requirements?
  • A. Write a single trigger on Contact for both after update and before update and callout to helper classes to handle each set of logic.
  • B. Write a Validation Rule on the Contact for the Is Primary logic and a before update trigger on Contact for the last name logic.
  • C. Write an after update trigger on Account for the Is Primary logic and a before update trigger on Contact for the last name logic.
  • D. Write an after update trigger on Contact for the Is Primary logic and a separate before update trigger on Contact for the last name logic.
A single trigger on Contact that handles both after update and before update events, utilizing helper classes for each logic set, is the most optimal implementation. It centralizes the logic for maintaining primary contacts and normalizing last names while allowing for clear separation of concerns through helper classes.
NEW QUESTION # 113
We will give you free update for 365 days after purchasing Plat-Dev-301 study guide from us, that is to say, in the following year, you don’t need to spend extra money on update version, and the latest version for Plat-Dev-301 exam dumps will be sent to your email address automatically. Furthermore, Plat-Dev-301 exam dumps are high quality and accuracy, and they can help you pass the exam just one time. In order to strengthen your confidence to Plat-Dev-301 Study Guide, we are pass guarantee and money back guarantee, if you fail to pass the exam we will give you full refund, and there is no need for you to worry about that you will waste your money.
Real Plat-Dev-301 Exams: https://www.lead1pass.com/Salesforce/Plat-Dev-301-practice-exam-dumps.html
All your transactions with Lead1Pass Real Plat-Dev-301 Exams will be safe and secure, With Plat-Dev-301 exam dumps from Lead1Pass, we provide guaranteed success rate for the Plat-Dev-301, The real Plat-Dev-301 exam environment of desktop and web-based practice exams will help you counter Salesforce Certified Platform Developer II - Multiple Choice Plat-Dev-301 pass anxiety, Salesforce New Plat-Dev-301 Test Practice Research has it that, the sense of touch can strengthen customer's confidence of his buying.
See More Color Management Titles, Coping with Certification Professionals Plat-Dev-301 CAs) Examining security occasions and also answering security occurrences, All your transactions with Lead1Pass will be safe and secure.
Free PDF 2026 Salesforce Pass-Sure Plat-Dev-301: New Salesforce Certified Platform Developer II - Multiple Choice Test PracticeWith Plat-Dev-301 Exam Dumps from Lead1Pass, we provide guaranteed success rate for the Plat-Dev-301, The real Plat-Dev-301 exam environment of desktop and web-based practice exams will help you counter Salesforce Certified Platform Developer II - Multiple Choice Plat-Dev-301 pass anxiety.
Research has it that, the sense of touch can strengthen customer's confidence of his buying, We helped more than thousands of candidates to own this Plat-Dev-301 certification.
Posted at 2/21/2026 07:07:51        Only Author  2#
I was blown away by how much I learned from it. Sharpen your IT skills with free GCIL practical information. Best of luck to everyone!
