Valid AWS-DevOps-Engineer-Professional Exam Materials & New AWS-DevOps-Engin
Posted at 2/3/2026 17:35:41
BTW, DOWNLOAD part of ExamDiscuss AWS-DevOps-Engineer-Professional dumps from Cloud Storage: https://drive.google.com/open?id=1NhG0NrwfyKSyO7M1rYdMpRvSqHBP1cGf
We have always been known as the superior after sale service provider, since we all tend to take lead of the whole process after you choose our AWS-DevOps-Engineer-Professional exam questions. So you have no need to trouble about our AWS-DevOps-Engineer-Professional study materials, if you have any questions, we will instantly response to you. Our AWS-DevOps-Engineer-Professional Training Materials will continue to pursue our passion for better performance and comprehensive service of AWS-DevOps-Engineer-Professional exam.
Exam TopicsBefore you start your preparation phase, you need to know which details to learn and what to expect from the exam. That is why it is recommended to observe all the topics that are included in the Amazon DOP-C01 content. All in all, these subject areas are highlighted as follows:
SDLC Automation (22%)
- Defining the strategies for source control;
- Applying the concepts for integrating and automating testing;
- Applying the concepts required for automating a CD/CI pipeline.
- Applying the concepts for managing and building artifacts securely;
- Determining the deployment strategies;
The Best Valid AWS-DevOps-Engineer-Professional Exam Materials & Leader in Certification Exams Materials & Fantastic New AWS-DevOps-Engineer-Professional Test RegistrationUnlike other question banks that are available on the market, our AWS-DevOps-Engineer-Professional guide dumps specially proposed different versions to allow you to learn not only on paper, but also to use mobile phones to learn. This greatly improves the students' availability of fragmented time. You can choose the version of AWS-DevOps-Engineer-Professional Learning Materials according to your interests and habits. And if you buy all of the three versions, the price is quite preferential and you can enjoy all of the AWS-DevOps-Engineer-Professional study experiences.
The AWS Certified DevOps Engineer - Professional (DOP-C01) certification exam is a challenging but rewarding opportunity for IT professionals who want to demonstrate their expertise in DevOps on AWS. By passing AWS-DevOps-Engineer-Professional Exam, candidates can validate their skills and knowledge, increase their earning potential, and take their careers to the next level.
Amazon AWS Certified DevOps Engineer - Professional Sample Questions (Q196-Q201):NEW QUESTION # 196
A company wants to use Amazon DynamoDB for maintaining metadata on its forums. See the sample data set in the image below.
A DevOps Engineer is required to define the table schema with the partition key, the sort key, the local secondary index, projected attributes, and fetch operations. The schema should support the following example searches using the least provisioned read capacity units to minimize cost.
- Search within ForumName for items where the subject starts with `a'.
- Search forums within the given LastPostDateTime time frame.
- Return the thread value where LastPostDateTime is within the last
three months.
Which schema meets the requirements?
- A. Use ForumName as the primary key and Subject as the sort key. Have LSI with LastPostDateTime as the sort key and the projected attribute thread.
- B. Use ForumName as the primary key and Subject as the sort key. Have LSI with Thread as the sort key and the projected attribute LastPostDateTime.
- C. Use Subject as the primary key and ForumName as the sort key. Have LSI with LastPostDateTime as the sort key and fetch operations for thread.
- D. Use Subject as the primary key and ForumName as the sort key. Have LSI with Thread as the sort key and fetch operations for LastPostDateTime.
https://docs.aws.amazon.com/amaz ... loperguide/LSI.html project the Replies attribute, sort key (Subject), local secondary indexes on non-key attributes LastPostDateTime.
NEW QUESTION # 197
You have been asked to de-risk deployments at your company. Specifically, the CEO is concerned about outages that occur because of accidental inconsistencies between Staging and Production, which sometimes cause unexpected behaviors in Production even when Staging tests pass. You already use Docker to get high consistency between Staging and Production for the application environment on your EC2 instances. How do you further de-risk the rest of the execution environment, since in AWS, there are many service components you may use beyond EC2 virtual machines?
- A. Develop models of your entire cloud system in CloudFormation. Use this model in Staging and Production to achieve greater parity.
- B. Use AMIs to ensure the whole machine, including the kernel of the virual machines, is consistent, since Docker uses Linux Container (LXC) technology, and we need to make sure the container environment is consistent.
- C. Use AWS Config to force the Staging and Production stacks to have configuration parity. Any differences will be detected for you so you are aware of risks.
- D. Use AWS ECS and Docker clustering. This will make sure that the AMIs and machine sizes are the same across both environments.
Only CloudFormation's JSON Templates allow declarative version control of repeatably deployable models of entire AWS clouds.
https://blogs.aws.amazon.com/app ... gory/Best+practices
NEW QUESTION # 198
Your serverless architecture using AWS API Gateway, AWS Lambda, and AWS DynamoDB experienced
a large increase in traffic to a sustained 400 requests per second, and dramatically increased in failure
rates. Your requests, during normal operation, last 500 milliseconds on average. Your DynamoDB table
did not exceed 50% of provisioned throughput, and Table primary keys are designed correctly. What is
the most likely issue?
- A. Your API Gateway deployment is throttling your requests.
- B. Your AWS API Gateway Deployment is bottlenecking on request (de)serialization.
- C. You did not request a limit increase on concurrent Lambda function executions.
- D. You used Consistent Read requests on DynamoDB and are experiencing semaphore lock.
AWS API Gateway by default throttles at 500 requests per second steady-state, and 1000 requests per
second at spike. Lambda, by default, throttles at 100 concurrent requests for safety. At 500 milliseconds
(half of a second) per request, you can expect to support 200 requests per second at 100 concurrency.
This is less than the 400 requests per second your system now requires. Make a limit increase request via
the AWS Support Console.
AWS Lambda: Concurrent requests safety throttle per account -> 100
Reference: http://docs.aws.amazon.com/gener ... .html#limits_lambda
NEW QUESTION # 199
A Development team is building more than 40 applications. Each app is a three-tiered web application based on an ELB Application Load Balancer, Amazon EC2, and Amazon RDS. Because the applications will be used internally, the Security team wants to allow access to the 40 applications only from the corporate network and block access from external IP addresses. The corporate network reaches the internet through proxy servers. The proxy servers have 12 proxy IP addresses that are being changed one or two times per month. The Network Infrastructure team manages the proxy servers; they upload the file that contains the latest proxy IP addresses into an Amazon S3 bucket. The DevOps Engineer must build a solution to ensure that the applications are accessible from the corporate network.
Which solution achieves these requirements with MINIMAL impact to application development, MINIMAL operational effort, and the LOWEST infrastructure cost?
- A. Implement an AWS Lambda function to read the list of proxy IP addresses from the S3 object and to update the ELB security groups to allow HTTPS only from the given IP addresses. Configure the S3 bucket to invoke the Lambda function when the object is updated. Save the IP address list to the S3 bucket when they are changed.
- B. Ensure that all the applications are hosted in the same Virtual Private Cloud (VPC). Otherwise, consolidate the applications into a single VPC. Establish an AWS Direct Connect connection with an active/standby configuration. Change the ELB security groups to allow only inbound HTTPS connections from the corporate network IP addresses.
- C. Implement a Python script with the AWS SDK for Python (Boto), which downloads the S3 object that contains the proxy IP addresses, scans the ELB security groups, and updates them to allow only HTTPS inbound from the given IP addresses. Launch an EC2 instance and store the script in the instance. Use a cron job to execute the script daily.
- D. Enable ELB security groups to allow HTTPS inbound access from the Internet. Use Amazon Cognito to integrate the company's Active Directory as the identity provider. Change the 40 applications to integrate with Amazon Cognito so that only company employees can log into the application. Save the user access logs to Amazon CloudWatch Logs to record user access activities
NEW QUESTION # 200
Which of the following services can be used to implement DevOps in your company.
- A. All of the above
- B. AWSOpswork
- C. AWS Elastic Beanstalk
- D. AWS Cloudformation
All of the services can be used to implement Devops in your company
1) AWS Elastic Beanstalk, an easy-to-use service for deploying and scaling web applications and services
developed with Java, .NET, PHP, Node.js, Python, Ruby, Go, and Docker on servers such as Apache, Nginx,
Passenger, and I IS.
2) AWS Ops Works, a configuration management service that helps you configure and operate applications of
all shapes and sizes using Chef
3) AWS Cloud Formation, which is an easy way to create and manage a collection of related AWS resources,
provisioning and updating them in an orderly and predictable fashion.
For more information on AWS Devops please refer to the below link:
* http://docs.aws.amazon.com/devops/latest/gsg/welcome.html
NEW QUESTION # 201
New AWS-DevOps-Engineer-Professional Test Registration: https://www.examdiscuss.com/Amazon/exam/AWS-DevOps-Engineer-Professional/
- Realistic Valid AWS-DevOps-Engineer-Professional Exam Materials - New AWS Certified DevOps Engineer - Professional Test Registration 🖌 Open website { [url]www.easy4engine.com } and search for ⮆ AWS-DevOps-Engineer-Professional ⮄ for free download 📹Valid AWS-DevOps-Engineer-Professional Test Practice[/url]
- Positive AWS-DevOps-Engineer-Professional Feedback ☂ AWS-DevOps-Engineer-Professional Premium Files 🥧 Dump AWS-DevOps-Engineer-Professional File 🚏 Open ➥ [url]www.pdfvce.com 🡄 enter ▶ AWS-DevOps-Engineer-Professional ◀ and obtain a free download 💯Detailed AWS-DevOps-Engineer-Professional Answers[/url]
- Realistic Valid AWS-DevOps-Engineer-Professional Exam Materials - New AWS Certified DevOps Engineer - Professional Test Registration 🧷 Search for ▛ AWS-DevOps-Engineer-Professional ▟ and easily obtain a free download on ☀ [url]www.dumpsquestion.com ️☀️ 🚋Detailed AWS-DevOps-Engineer-Professional Answers[/url]
- Positive AWS-DevOps-Engineer-Professional Feedback 🔂 AWS-DevOps-Engineer-Professional Certification Exam 🖊 AWS-DevOps-Engineer-Professional Test Questions Answers 👡 ➥ [url]www.pdfvce.com 🡄 is best website to obtain 【 AWS-DevOps-Engineer-Professional 】 for free download 🔆AWS-DevOps-Engineer-Professional Study Group[/url]
- Latest AWS-DevOps-Engineer-Professional Dumps Files 👟 Positive AWS-DevOps-Engineer-Professional Feedback 🚖 Valid AWS-DevOps-Engineer-Professional Test Book ⛲ Easily obtain free download of 《 AWS-DevOps-Engineer-Professional 》 by searching on 【 [url]www.vceengine.com 】 🕉AWS-DevOps-Engineer-Professional Discount[/url]
- 100% Pass Quiz High Pass-Rate Amazon - AWS-DevOps-Engineer-Professional - Valid AWS Certified DevOps Engineer - Professional Exam Materials 😛 ➽ [url]www.pdfvce.com 🢪 is best website to obtain ☀ AWS-DevOps-Engineer-Professional ️☀️ for free download 🎓Test AWS-DevOps-Engineer-Professional Dump[/url]
- Amazon AWS-DevOps-Engineer-Professional Exam Dumps - Excellent Tips To Pass Exam 🦮 Search for ✔ AWS-DevOps-Engineer-Professional ️✔️ and easily obtain a free download on ➽ [url]www.pass4test.com 🢪 ✈AWS-DevOps-Engineer-Professional Premium Files[/url]
- Amazon AWS-DevOps-Engineer-Professional Exam Dumps - Excellent Tips To Pass Exam 🤧 Download { AWS-DevOps-Engineer-Professional } for free by simply searching on “ [url]www.pdfvce.com ” 💽AWS-DevOps-Engineer-Professional Test Questions Answers[/url]
- Amazon AWS-DevOps-Engineer-Professional Exam Dumps - Excellent Tips To Pass Exam 🍃 Immediately open ⏩ [url]www.practicevce.com ⏪ and search for 《 AWS-DevOps-Engineer-Professional 》 to obtain a free download 🌐Test AWS-DevOps-Engineer-Professional Dump[/url]
- Latest AWS-DevOps-Engineer-Professional Mock Exam 🔐 AWS-DevOps-Engineer-Professional Study Group 👋 Reliable AWS-DevOps-Engineer-Professional Dumps Ebook 🏙 Open website ➽ [url]www.pdfvce.com 🢪 and search for 【 AWS-DevOps-Engineer-Professional 】 for free download 🦛AWS-DevOps-Engineer-Professional Premium Files[/url]
- Dump AWS-DevOps-Engineer-Professional File ✈ AWS-DevOps-Engineer-Professional Practice Test 🍢 Exam Dumps AWS-DevOps-Engineer-Professional Collection 🖐 Search for ⇛ AWS-DevOps-Engineer-Professional ⇚ and obtain a free download on ▛ [url]www.pdfdumps.com ▟ 🧊Latest AWS-DevOps-Engineer-Professional Dumps Files[/url]
- www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, app.parler.com, www.stes.tyc.edu.tw, Disposable vapes
P.S. Free 2026 Amazon AWS-DevOps-Engineer-Professional dumps are available on Google Drive shared by ExamDiscuss: https://drive.google.com/open?id=1NhG0NrwfyKSyO7M1rYdMpRvSqHBP1cGf
