Download Real Microsoft SC-100 Exam Questions And Start Your Preparation
126
Posted at 2/3/2026 17:56:17      View:81 | Replies:1        Print      Only Author   [Copy Link] 1#
BONUS!!! Download part of Prep4SureReview SC-100 dumps for free: https://drive.google.com/open?id=16OJhTnKCVzy3HT8R_U4AEJUXAAHeOA-j
Our SC-100 study guide provides free trial services, so that you can learn about some of our topics and how to open the software before purchasing. During the trial period of our SC-100 study materials, the PDF versions of the sample questions are available for free download, and both the pc version and the online version can be illustrated clearly. You can contact us at any time if you have any difficulties in the purchase or trial process of our SC-100 Exam Dumps.
Microsoft Cybersecurity Architect SC-100 You can use Real Questions to guide your search for a Microsoft. SC-100 You can get ready for the Microsoft Cybersecurity Architect SC-100 test with the aid of Exam Dumps. the exam code Consider the inquiries. The Microsoft Cybersecurity Architect SC-100 practise test software is valid for Microsoft Cybersecurity Architect SC-100. the exam code Exam simulation practise tests, Microsoft Cybersecurity Architect SC-100 the exam code Final Microsoft Cybersecurity Architect SC-100 Dumps for Exam success requires familiarity with the most recent question types and effective time management.
Valid SC-100 Exam Test - Reliable SC-100 Study GuideWe provide the Microsoft SC-100 exam questions in a variety of formats, including a web-based practice test, desktop practice exam software, and downloadable PDF files. Prep4SureReview provides proprietary preparation guides for the certification exam offered by the Microsoft Cybersecurity Architect (SC-100) exam dumps. In addition to containing numerous questions similar to the Microsoft Cybersecurity Architect (SC-100) exam, the Microsoft Cybersecurity Architect (SC-100) exam questions are a great way to prepare for the Microsoft SC-100 exam dumps.
Microsoft SC-100 exam is intended for individuals who have experience in IT security, including security professionals, system administrators, network administrators, and security architects. SC-100 Exam is aimed at individuals who are responsible for designing, implementing, and maintaining security solutions in organizations that use Microsoft technologies.
Microsoft Cybersecurity Architect Sample Questions (Q285-Q290):NEW QUESTION # 285
Your on-premises network contains an e-commerce web app that was developed in Angular and Node.js. The web app uses a MongoDB database. You plan to migrate the web app to Azure. The solution architecture team proposes the following architecture as an Azure landing zone.
You need to provide recommendations to secure the connection between the web app and the database. The solution must follow the Zero Trust model.
Solution: You recommend implementing Azure Front Door with Azure Web Application Firewall (WAF).
Does this meet the goal?
  • A. No
  • B. Yes
https://www.varonis.com/blog/securing-access-azure-webapps
NEW QUESTION # 286
Hotspot Question
You have an Azure subscription that contains a Microsoft Sentinel workspace named WS1.
You need to configure WS1 to meet the following requirements:
- Create custom dashboards to visualize the workload of security
analysts that use Microsoft Sentinel.
- Enable automated responses for the security alerts generated by
Microsoft Sentinel analytics rules.
What should you use for each requirement? To answer, select the options in the answer area.
NOTE: Each correct answer is worth one point.
Box 1: Workbooks
Create custom dashboards to visualize the workload of security analysts that use Microsoft Sentinel.
Visualize and monitor your data by using workbooks in Microsoft Sentinel After you connect your data sources to Microsoft Sentinel, visualize and monitor the data using workbooks in Microsoft Sentinel. Microsoft Sentinel workbooks are based on Azure Monitor workbooks, and add tables and charts with analytics for your logs and queries to the tools already available in Azure.
Box 2: Playbooks
Enable automated responses for the security alerts generated by Microsoft Sentinel analytics rules.
You can create and use Microsoft Sentinel automation rules to manage response Design your automation rule Before you create your automation rule, we recommend that you determine its scope and design, including the trigger, conditions, and actions that make up your rule.
Add actions
Choose the actions you want this automation rule to take. Available actions include Assign owner, Change status, Change severity, Add tags, and Run playbook. You can add as many actions as you like.
Note
Only the Run playbook action is available in automation rules using the alert trigger.
https://learn.microsoft.com/en-u ... l/monitor-your-data
NEW QUESTION # 287
You are designing security for a runbook in an Azure Automation account. The runbook will copy data to Azure Data Lake Storage Gen2.
You need to recommend a solution to secure the components of the copy process.
What should you include in the recommendation for each component? To answer, select the appropriate options in the answer area. NOTE: Each correct selection is worth one point.
Graphical user interface, text, application Description automatically generated
NEW QUESTION # 288
You have a Microsoft 365 tenant.
You need to recommend a Microsoft 365 Defender solution to enhance security for the tenant. The solution must meet the following requirements:
* Identify users that are downloading an unusually high number of files from Microsoft SharePoint Online sites and are possibly involved in a data exfiltration attempt.
* Block Microsoft Teams messages that contain potentially malicious content by using zero-hour auto purge (ZAP).
What should you recommend for each requirement? To answer, select the appropriate options in the answer area. NOTE: Each correct selection is worth one point.
NEW QUESTION # 289
Your company has a multi-cloud environment that contains a Microsoft 365 subscription, an Azure subscription, and Amazon Web Services (AWS) implementation. You need to recommend a security posture management solution for the following components:
* Azure loT Edge devices
* AWS EC2 instances
Which services should you include in the recommendation? To answer, select the appropriate options in the answer area. NOTE: Each correct selection is worth one point.
NEW QUESTION # 290
The page of our SC-100 simulating materials provides demo which are sample questions. The purpose of providing demo is to let customers understand our part of the topic and what is the form of our SC-100 study materials when it is opened? In our minds, these two things are that customers who care about the SC-100 Exam may be concerned about most. We will give you our software which is a clickable website that you can visit the product page.
Valid SC-100 Exam Test: https://www.prep4surereview.com/SC-100-latest-braindumps.html
P.S. Free 2026 Microsoft SC-100 dumps are available on Google Drive shared by Prep4SureReview: https://drive.google.com/open?id=16OJhTnKCVzy3HT8R_U4AEJUXAAHeOA-j
Posted at 2/7/2026 19:06:52        Only Author  2#
This article truly broadened my horizons; thank you for sharing! Free Reliable JN0-336 exam online resources—unlock promotions and salary increases today!
