Prominent Features of DumpsFree CMMC-CCA Practice Test Questions
Posted at 2/3/2026 21:23:07
View126
Replies0
What's more, part of that DumpsFree CMMC-CCA dumps now are free: https://drive.google.com/open?id=1LTUdryHMQLXN6QGMpSDSvM7BLkvQDPZG
These CMMC-CCA practice exams train you to manage time so that you can solve questions of the CMMC-CCA real test on time. DumpsFree offers Cyber AB practice tests which provide you with real examination scenarios. By practicing under the pressure of CMMC-CCA real test again and again, you can overcome your Certified CMMC Assessor (CCA) Exam exam anxiety. Taking CMMC-CCA these practice exams is important for you to attempt Cyber AB real dumps questions and pass CMMC-CCA certification exam test on the first take.
Cyber AB CMMC-CCA Exam Syllabus Topics:| Topic | Details | | Topic 1 | - Evaluating Organizations Seeking Certification (OSC) against CMMC Level 2 Requirements: This section of the exam measures skills of cybersecurity assessors and focuses on evaluating the environments of organizations seeking certification at CMMC Level 2. It covers understanding differences between logical and physical settings, recognizing constraints in cloud, hybrid, on-premises, single, and multi-site environments, and knowing what environmental exclusions apply for Level 2 assessments.
| | Topic 2 | - CMMC Level 2 Assessment Scoping: This section of the exam measures skills of cybersecurity assessors and revolves around determining the proper scope of a CMMC assessment. It involves analyzing and categorizing Controlled Unclassified Information (CUI) assets, interpreting the Level 2 scoping guidelines, and making accurate judgments in scenario-based exercises to define what assets and systems fall within assessment boundaries.
| | Topic 3 | - CMMC Assessment Process (CAP): This section of the exam measures skills of compliance professionals and tests knowledge of the full assessment lifecycle. It covers the steps needed to plan, prepare, conduct, and report on a CMMC Level 2 assessment, including the phases of execution and how to document and follow up on findings in alignment with DoD and CMMC-AB expectations.
| | Topic 4 | - Assessing CMMC Level 2 Practices: This section of the exam measures skills of cybersecurity assessors in evaluating whether organizations meet the required practices of CMMC Level 2. It emphasizes applying CMMC model constructs, understanding model levels, domains, and implementation, and using evidence to determine compliance with established cybersecurity practices.
Hot Dumps CMMC-CCA Download | Professional Sample CMMC-CCA Questions Answers: Certified CMMC Assessor (CCA) Exam 100% PassThe web-based Cyber AB CMMC-CCA practice test software can be used through browsers like Firefox, Safari, and Google Chrome. The customers don't need to download or install any excessive plugins or software in order to use the web-based Cyber AB CMMC-CCA Practice Exam format. The web-based CMMC-CCA practice test software format is supported by different operating systems like Mac, iOS, Linux, Windows, and Android.
Cyber AB Certified CMMC Assessor (CCA) Exam Sample Questions (Q101-Q106):NEW QUESTION # 101
A company is seeking Level 2 CMMC certification. During the Limited Practice Deficiency Correction Evaluation, the Lead Assessor is deciding whether the company can be moved to a POA&M Close-Out. What condition will result if a POA&M Close-Out option cannot be utilized?
- A. The OSC will be granted a provisional status until it can meet all the practices.
- B. The assessment will be paused until the OSC can meet all practices.
- C. The Lead Assessor will ask the OSC to justify not meeting all the practices.
- D. The Lead Assessor will not recommend the OSC for CMMC Level 2 certification.
If the OSC cannot remediate deficiencies during the POA&M Close-Out process, the Lead Assessor must issue a recommendation of NOT MET, and the OSC will not be certified. CMMC requires all Level 2 practices to be MET (with limited exceptions under defined POA&M close-out rules).
Exact Extracts:
* CMMC Assessment Guide: "If practices cannot be met within the POA&M Close-Out process, the Lead Assessor must not recommend certification."
* DoD policy: "CMMC Level 2 requires that all 110 practices be met. A failed POA&M Close-Out results in a final determination of NOT MET."
* "There is no provisional certification status in CMMC."
Why the other options are not correct:
* A: Assessments are not paused indefinitely; unresolved deficiencies result in NOT MET.
* B: Justification alone does not satisfy requirements.
* C: Provisional status does not exist in CMMC.
CMMC Assessment Guide - Level 2, Version 2.13: POA&M Close-Out procedures (pp. 14-16).
DoD CMMC Program Documentation: Requirement for all practices to be MET for certification.
NEW QUESTION # 102
An OSC has an established password policy. The OSC wants to improve its password protection security by implementing a single change. Which of the following is an acceptable element to add to the OSC's password policy?
- A. Require passwords to be 5 to 7 characters long.
- B. Add the use of salted two-way cryptographic hashes of passwords.
- C. Add the use of salted one-way cryptographic hashes of passwords, where possible.
- D. Require passwords to be changed every 18 months.
The Identification and Authentication (IA) practices require that passwords be protected using strong methods. Storing passwords with salted one-way hashes ensures they cannot be reversed, providing strong protection.
Extract from IA.L2-3.5.10:
"Passwords must be stored and transmitted in a form that is resistant to compromise, typically using salted one-way cryptographic hashes." Options A and B do not align with modern password guidance, and option C (two-way cryptographic hashing) is insecure because it allows reversal.
Reference: CMMC Assessment Guide - Level 2, IA.L2-3.5.10.
NEW QUESTION # 103
While assessing a company, the CCA is determining whether the company controls and manages connections between its corporate network and all external networks. The company has: (1) a strict employee policy prohibiting personal Internet use and personal email on company computers, and (2) firewalls plus a connection allow-list so only authorized external networks can connect to the company network. Are these safeguards sufficient to meet the applicable CMMC requirement?
- A. Yes. The company's firewalls and connection allow-lists are appropriate technical controls to meet the requirement.
- B. No. The company must isolate its system from all external connections to meet the requirement.
- C. Yes. The company's strict employee policy is the best practice for meeting the requirement.
- D. No. The company needs full control over all external systems it interfaces with to meet the requirement.
* Applicable CMMC/NIST Requirement: AC.L2-3.1.20 - "Verify and control/limit connections to and use of external systems."
* Isolation Not Required (refutes B): The requirement acknowledges that individuals using external systems (e.g., contractors, partners) may need to access organizational systems. In such cases, organizations must ensure those connections do not compromise or harm organizational systems.
Therefore, complete isolation from all external systems is not mandated.
* Policy Alone is Insufficient (refutes A): Assessment guidance requires mechanisms that technically enforce terms and conditions for use of external systems. A written employee policy by itself does not satisfy the requirement unless paired with technical enforcement (e.g., firewalls, connection rules).
* Allow-lists & Firewalls are Best Practice (supports C): Assessment considerations specify that organizations should restrict external systems to an approved list, such as by using firewalls, VPNs, IP restrictions, or certificates. The company's use of firewalls and a connection allow-list directly addresses this requirement.
* Full Control of External Systems Not Required (refutes D): The definition of "external systems" clarifies that organizations typically do not have direct supervision or authority over those systems. The requirement is to limit and control connections to such systems, not to own or fully manage them.
* Assessment Objectives for AC.L2-3.1.20 (from NIST SP 800-171A):
* Connections to external systems are identified.
* Use of external systems is identified.
* Connections to external systems are verified.
* Use of external systems is verified.
* Connections to external systems are controlled/limited.
* Use of external systems is controlled/limited.
Firewalls and allow-lists satisfy these verification and limitation requirements, enabling a CCA to mark the practice MET if evidence is present.
References (CCA Official Sources):
* NIST SP 800-171 Rev. 2 - 3.1.20 (Discussion)
* NIST SP 800-171A - 3.1.20 (Assessment Objectives & Methods)
* CMMC Assessment Guide - Level 2, Version 2.13 - AC.L2-3.1.20 (External Connections [CUI Data], including "Potential Assessment Considerations")
NEW QUESTION # 104
The Cyber AB is the sole authorized certification and accreditation partner for the DoD in its CMMC program. It is responsible for overseeing and establishing a trained, qualified, and high-fidelity community of assessors, including C3PAOs and CCAs. What is the main requirement before The Cyber AB can accredit an Assessor?
- A. The Cyber AB must achieve and maintain ISO/IEC 17011 accreditation standard.
- B. The Cyber AB must be DFARS 7012 compliant.
- C. The Cyber AB must be compliant at a FISMA moderate level.
- D. The Cyber AB must be approved by the DoD.
Comprehensive and Detailed in Depth Explanation:
The Cyber AB's authority to accredit assessors hinges on its compliance with international standards, specifically ISO/IEC 17011, which governs conformity assessment bodies accrediting other organizations.
This standard ensures impartiality, consistency, and competence in the accreditation process, critical for maintaining the integrity of the CMMC ecosystem. Option A (DFARS 7012 compliance) applies to contractors handling CUI, not accreditation bodies. Option B (FISMA moderate compliance) is a federal IT security standard irrelevant to Cyber AB's accreditation role. Option D (DoD approval) is a prerequisite but not the "main requirement" for accrediting assessors, as ISO/IEC 17011 is the operational standard. Option C is the correct answer per Cyber AB's documented requirements.
Extract from Official Document (CAP v1.0):
* Section 1.1 - Purpose (pg. 7):"The Cyber AB must achieve compliance with the ISO/IEC 17011 Conformity Assessment to oversee the certification process and provide necessary accreditations to the trained CMMC ecosystem." References:
CMMC Assessment Process (CAP) v1.0, Section 1.1.
NEW QUESTION # 105
A CCA receives a notification from the Cyber AB that they are being investigated for a potential violation of the CoPC. They are concerned about the potential consequences and want to understand the process better.
Who has the final authority to determine the corrective action taken against a CCA, if any?
- A. The Lead Assessor.
- B. The investigator assigned to the CCA's case.
- C. The C3PAO.
- D. The CMMC Accreditation Body (the Cyber AB).
The CoPC grants Cyber AB final authority over corrective actions, though Industry Working Groups may decide in some cases. Options A, C, and D lack this authority.
Extract from Official Document (CoPC):
* Paragraph 4.1(4)(a) - Violation Resolution (pg. 10):"The CMMC Accreditation Body has sole authority to determine corrective action." References:
CMMC Code of Professional Conduct, Paragraph 4.1(4)(a).
NEW QUESTION # 106
It is a common sense that in terms of a kind of CMMC-CCA test torrent, the pass rate would be the best advertisement, since only the pass rate can be the most powerful evidence to show whether the CMMC-CCA guide torrent is effective and useful or not. We are so proud to tell you that according to the statistics from the feedback of all of our customers, the pass rate of our CMMC-CCA Exam Questions among our customers who prepared for the exam under the guidance of our CMMC-CCA test torrent has reached as high as 98%to 100%.
Sample CMMC-CCA Questions Answers: https://www.dumpsfree.com/CMMC-CCA-valid-exam.html
- CMMC-CCA Pass Rate ⚠ New Study CMMC-CCA Questions ⚓ CMMC-CCA Pdf Free 🥁 Search for ➥ CMMC-CCA 🡄 on ▷ [url]www.troytecdumps.com ◁ immediately to obtain a free download 😨CMMC-CCA New Exam Materials[/url]
- High Pass Rate CMMC-CCA Study Materials Tool Helps You Get the CMMC-CCA Certification 😮 The page for free download of ➤ CMMC-CCA ⮘ on [url]www.pdfvce.com will open immediately 🎍Test CMMC-CCA Questions Answers[/url]
- 2026 Dumps CMMC-CCA Download - High Pass-Rate Cyber AB Sample CMMC-CCA Questions Answers: Certified CMMC Assessor (CCA) Exam 🔫 [url]www.practicevce.com is best website to obtain CMMC-CCA for free download 🦃CMMC-CCA Updated CBT[/url]
- CMMC-CCA Actual Torrent - CMMC-CCA Pass-King Materials - CMMC-CCA Actual Exam 📀 Open [url]www.pdfvce.com enter CMMC-CCA and obtain a free download 🔊CMMC-CCA Relevant Questions[/url]
- Online CMMC-CCA Training Materials ▶ CMMC-CCA Reliable Dump 📁 CMMC-CCA Reliable Braindumps Sheet 🛕 Search for CMMC-CCA and download exam materials for free through { [url]www.prep4sures.top } ⏮Valid CMMC-CCA Test Pattern[/url]
- Latest updated Dumps CMMC-CCA Download - High-quality Sample CMMC-CCA Questions Answers: Certified CMMC Assessor (CCA) Exam 🌋 Search for ▶ CMMC-CCA ◀ and easily obtain a free download on [url]www.pdfvce.com 🕣CMMC-CCA New Braindumps Questions[/url]
- 2026 Dumps CMMC-CCA Download - High Pass-Rate Cyber AB Sample CMMC-CCA Questions Answers: Certified CMMC Assessor (CCA) Exam 🚉 Search for ➽ CMMC-CCA 🢪 on [url]www.prepawayete.com immediately to obtain a free download 🎼Valid CMMC-CCA Test Pattern[/url]
- 2026 CMMC-CCA: Certified CMMC Assessor (CCA) Exam Realistic Dumps Download 100% Pass Quiz 🚞 Copy URL ✔ [url]www.pdfvce.com ️✔️ open and search for ▶ CMMC-CCA ◀ to download for free 🍝CMMC-CCA Pdf Free[/url]
- Valid Cyber AB CMMC-CCA Questions: 100% Authentic [2026] 🤐 Search for ➥ CMMC-CCA 🡄 and download it for free on ▷ [url]www.examdiscuss.com ◁ website 🖖Reliable CMMC-CCA Test Sims[/url]
- Latest Cyber AB CMMC-CCA Questions - The Fast Track To Get Exam Success 🔌 Immediately open ➤ [url]www.pdfvce.com ⮘ and search for CMMC-CCA to obtain a free download 💲CMMC-CCA Pass Rate[/url]
- 2026 Dumps CMMC-CCA Download - High Pass-Rate Cyber AB Sample CMMC-CCA Questions Answers: Certified CMMC Assessor (CCA) Exam 🧍 Search for ⮆ CMMC-CCA ⮄ and download it for free immediately on ⮆ [url]www.practicevce.com ⮄ ❤Reliable CMMC-CCA Guide Files[/url]
- www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, bbs.t-firefly.com, www.stes.tyc.edu.tw, Disposable vapes
DOWNLOAD the newest DumpsFree CMMC-CCA PDF dumps from Cloud Storage for free: https://drive.google.com/open?id=1LTUdryHMQLXN6QGMpSDSvM7BLkvQDPZG
