[Hardware] Online CDCS Training, CDCS Upgrade Dumps
79
Hardware Online CDCS Training, CDCS Upgrade Dumps
Posted at 2/3/2026 21:43:17      View100 | Replies0        Print      Only Author   [Copy Link] 1#
P.S. Free 2026 EXIN CDCS dumps are available on Google Drive shared by BraindumpsPass: https://drive.google.com/open?id=10rV7mhNc9QsUVby53vEQvlyUapzMmBE1
We have three versions of our CDCS study materials, and they are PDF version, software version and online version. With the PDF version, you can print our materials onto paper and learn our CDCS study materials in a more handy way as you can take notes whenever you want to, and you can mark out whatever you need to review later. With the software version, you are allowed to install our CDCS study materials in all computers that operate in windows system. Besides, the software version can simulate the real test environment, which is favorable for people to better adapt to the examination atmosphere. With the online version, you can study the CDCS Study Materials wherever you like, and you still have access to the materials even if there is no internet available on the premise that you have studied the CDCS study materials online once before.
EXIN CDCS Exam Syllabus Topics:
  • Data Centre Life Cycle and Standards: This section of the exam measures the skills of data center professionals and covers the various stages involved in the life cycle of a data center, from planning and design to implementation and decommissioning.
  • Data Centre Environmental Considerations and Efficiency: This section evaluates the proficiency of data center professionals in addressing environmental factors and promoting efficiency within data center operations. The target audience, including data center managers and engineers, will be tested on their ability to identify and implement measures that enhance energy efficiency, cooling management, and sustainable practices.
  • Designing and Implementing a Data Centre: In this module, the exam assesses the knowledge of Exin data center professionals tasked with the design and implementation of data centers. Candidates will learn the key principles of creating an efficient data center layout, including considerations for scalability, redundancy, and security.
100% Pass Quiz 2026 EXIN CDCS C Efficient Online TrainingEvery EXIN aspirant wants to pass the EXIN CDCS exam to achieve high-paying jobs and promotions. The biggest issue CDCS exam applicants face is that they don't find credible platforms to buy real CDCS exam dumps. When candidates don't locate actual EXIN EPI Certified Data Centre Specialist (CDCS) exam questions they prepare from outdated material and ultimately lose resources. If you are also facing the same problem then you are at the trusted spot.
EXIN EPI Certified Data Centre Specialist Sample Questions (Q63-Q68):NEW QUESTION # 63
What is the minimum requirement for power feeds to a Rated-4 data center (ANSI/TIA-942)?
  • A. One feed split into two distribution boards
  • B. Two feeds from two different substations, one power company not acceptable
  • C. Two feeds from two different substations, one power company acceptable
  • D. Two feeds from one substation
A Rated-4 facility requires dual active utility feeds, each from an independent substation, but they may come from the same utility provider if substations are geographically separate and independent.
* Option A is too strict; ANSI/TIA-942 does not mandate two different companies.
* Options C and D do not provide true independence and would fail Rated-4 requirements.
Thus, the minimum is two substations, possibly same provider.
References: ANSI/TIA-942-B 6.2 (Utility Service Requirements).
NEW QUESTION # 64
The pipes of a VESDA smoke detection system are installed at the air intake of the air conditioner inside the computer room.
Is this a good practice from an early smoke detection point of view?
  • A. No, it will give a longer reaction time for the smoke detection system and there might also be bypass airflow.
  • B. It depends on the type of gas-based fire suppression which will be installed.
  • C. Yes, as this reduces the amount of piping to be installed in the data center, as all air will go through the air conditioner.
  • D. No, the piping should be installed at the air exhaust of the air conditioner, as there can also be a fire inside the air conditioner itself.
For optimal early smoke detection in a data center, it is crucial that the Very Early Smoke Detection Apparatus (VESDA) system be installed at locations where smoke will be detected as soon as it appears. Positioning the VESDA pipes at the air intake of the air conditioner inside the computer room is not ideal. This placement could result in a delayed detection response and the potential for bypass airflow to occur, which would impede the system's ability to detect smoke effectively.
Detailed Explanation:
When VESDA pipes are installed at the air intake, the detection system relies on the smoke to be drawn into the air conditioning unit before detection can occur. This setup increases the reaction time as the smoke has to travel through the intake and get processed by the air conditioner. Furthermore, bypass airflow-a phenomenon where not all the air containing smoke particles passes through the VESDA pipes-could also delay or even prevent the system from detecting smoke early.
Ideally, VESDA pipes should be positioned where smoke is likely to accumulate first, such as near the ceiling or in the return airflow path to detect smoke at the earliest possible stage. This ensures that the detection system can quickly trigger alarms, providing more time to address potential fire hazards.
EPI Data Center Specialist References:
EPI Data Center Specialist training highlights that smoke detection should prioritize early response capabilities to maximize safety. The preferred installation for VESDA pipes is generally at points where smoke would naturally accumulate, rather than relying on air conditioning intakes where airflow can vary and delay detection. In their course materials, EPI emphasizes minimizing reaction time and reducing the impact of airflow dynamics on smoke detection efficiency.
NEW QUESTION # 65
You are allowed to use a calculator for this question. The total power consumption of the ICT equipment in a rack is 6 kW. The equipment is traditional ICT equipment with a Delta-T of approximately 11 C / 20 F.
Calculate the approximate CFM required to cool the equipment in the rack.
  • A. Approximately 160 CFM
  • B. Approximately 1,000 CFM
  • C. Approximately 1,500 CFM
  • D. Approximately 500 CFM
To calculate the cooling airflow requirement for ICT equipment, you can use the formula:
CFM=Power (kW)3160#T(F)        ext{CFM} = rac{        ext{Power (kW)}         imes 3160}{Delta T (        ext{F})} CFM=#T(F)Power (kW)3160 For equipment consuming 6 kW with a Delta-T of 20F:
CFM=6316020=948#1,000 CFM        ext{CFM} = rac{6         imes 3160}{20} = 948 approx 1,000 ,         ext{CFM} CFM=2063160=948#1,000CFM Detailed Explanation:
This formula provides an estimate of the cubic feet per minute (CFM) of air required to cool the equipment based on its power consumption and the temperature difference (Delta-T) between intake and exhaust. The Delta-T represents the cooling effectiveness of the airflow.
EPI recommends using this calculation for determining airflow requirements in data centers, ensuring that cooling systems are adequately sized to maintain equipment within safe temperature limits.
NEW QUESTION # 66
From the options indicated, what is the correct starting point for the raised floor installation?
  • A. Point B
  • B. Point D
  • C. Point C
  • D. Point A
When installing a raised floor, the best starting point is typically from the farthest corner away from the entrance, in this case, Point B. This method allows for the floor installation to progress towards the entrance, ensuring that workers can avoid walking over the newly installed tiles, thus minimizing the risk of damage and maintaining cleanliness during installation.
Starting at the farthest corner (Point B) and working towards the entrance (Point A) is a standard practice in raised floor installation. This approach ensures that installers do not walk over freshly laid tiles, which could lead to shifting or misalignment. Additionally, it allows for more controlled placement and alignment, as well as convenient egress when installation is complete.
EPI guidelines for raised floor installation emphasize beginning at the farthest point from the entrance and working back towards it, which aligns with industry best practices for efficiency and quality assurance. This method reduces potential damage and supports precise alignment across the floor area.
NEW QUESTION # 67
A data center is in an area where utility power is highly available-only a few outages per year, typically <1 hour per event and <50 hours/year not available. What type of generators should be installed?
  • A. Standby generators, ideally in an N+1 configuration
  • B. A combination of standby, prime, and continuous sized to 500% of the load
  • C. Standby generators; no N+1 needed as the risk of a failure to start is negligible
  • D. Continuous generators in at least N+1
With infrequent/short outages, Standby (Emergency Standby Power, ESP) generators are appropriate; N+1 mitigates failure-to-start risk and supports concurrently maintainable designs.
References: ISO 8528-1 (generator rating definitions: ESP/PRP/Continuous), ANSI/TIA-942-B 6.2 (electrical redundancy).
NEW QUESTION # 68
Are you aware of the importance of the CDCS certification? If your answer is not, you may place yourself at the risk of be eliminated by the labor market. As we know, the CDCS certification is the main reflection of your ability. If you want to maintain your job or get a better job for making a living for your family, it is urgent for you to try your best to get the CDCS Certification. We are glad to help you get the certification with our best CDCS study materials successfully.
CDCS Upgrade Dumps: https://www.braindumpspass.com/EXIN/CDCS-practice-exam-dumps.html
BONUS!!! Download part of BraindumpsPass CDCS dumps for free: https://drive.google.com/open?id=10rV7mhNc9QsUVby53vEQvlyUapzMmBE1
