[Hardware] Technical CPC Training, Exam CPC Sample
103
【Hardware】 Technical CPC Training, Exam CPC Sample
Posted at 2/4/2026 02:12:24      View:118 | Replies:0        Print      Only Author   [Copy Link] 1#
P.S. Free 2026 AAPC CPC dumps are available on Google Drive shared by DumpsMaterials: https://drive.google.com/open?id=1oPO5emnjzNNWCltPFHbmXnzk4yNWgZPq
This way you can save money even if AAPC CPC introduces fresh AAPC CPC exam updates. So why are you delaying? Purchase the AAPC CPC Preparation material to get certified on the first attempt.
People who study with questions which aren't updated remain unsuccessful in the certification test and waste their valuable resources. You can avoid this loss, by preparing with real CPC Exam Questions of DumpsMaterials which are real and updated. We know that the registration fee for the Certified Professional Coder (CPC) Exam CPC test is not cheap. Therefore, we offer Certified Professional Coder (CPC) Exam CPC real exam questions that can help you pass the test on the first attempt. Thus, we save you money and time.
Pass-Sure Technical CPC Training for Real ExamWith the development of society and the perfection of relative laws and regulations, the CPC certificate in our career field becomes a necessity for our country. Passing the CPC and obtaining the certificate may be the fastest and most direct way to change your position and achieve your goal. And we are just right here to give you help to pass the CPC Exam. Being considered the most authentic brand in this career, our professional experts are making unremitting efforts to provide our customers the latest and valid CPC exam simulation.
AAPC Certified Professional Coder (CPC) Exam Sample Questions (Q327-Q332):NEW QUESTION # 327
A patient with a history of a right-hand mass presents for outpatient surgical excision. The surgeon excises the 1.5 cm mass with margins using a scalpel with dissection extending through the dermis into the subcutaneous tissue. Hemostasis is achieved with electrocautery, and the wound is closed. Final pathology confirms the mass is a subcutaneous arteriovenous hemangioma.
Which CPT and ICD-10-CM codes are reported?
  • A. 26115, D18.01
  • B. 26111, D18.01
  • C. 26111, D21.01
  • D. 26115, D21.11
CPT: The documentation supports excision of a subcutaneous soft tissue tumor of the hand, size 1.5 cm.
26111 = Excision of tumor/soft tissue of hand or finger, subcutaneous, 1.5 cm or less
26115 would be for a larger size range (not supported by "1.5 cm" in the question).
ICD-10-CM: Pathology confirms subcutaneous hemangioma (benign vascular tumor).
D18.01 = Hemangioma of skin and subcutaneous tissueCodes D21.01/D21.11 are benign neoplasm of connective/soft tissue categories, but the most accurate match here (and the one reflected in the answer choices) is D18.01 for hemangioma of skin/subcutaneous tissue.
Typing correction applied: the options showed "018.01"; the correct ICD-10-CM format is D18.01.
NEW QUESTION # 328
What is the ICD-10-CM code for a medial meniscus tear of the left knee due to a recent football injury?
  • A. M23.204
  • B. M23.202
  • C. S83.232A
  • D. S83.242A
Acute traumatic injuries are coded from Chapter 19 (S-codes).
S83.242A = Tear of medial meniscus, left knee, current injury, initial encounter.
M23 codes are for old or degenerative conditions.
NEW QUESTION # 329
Which one of the following activities, when performed, is NOT considered when selecting an E/M service level based on time?
  • A. Preparing to see the patient (e.g., review of tests).
  • B. Ordering medications, tests, and/or procedures.
  • C. Time spent on other services that are reported separately.
  • D. Documenting clinical information in the patient's medical record.
Per CPT E/M guidelines, time spent on separately reported services is excluded from total E/M time calculations.
NEW QUESTION # 330
Dr. Meredith sees Mr. Hollis (new patient) for the first time In the Community Rest Home. She documents a visit with medical decision making of moderate complexity. She spends 20 minutes of additional time discussing physical therapy and going over medications. Dr. Meredith spends a total of 90 minutes on that patient that day.
What CPT coding does Dr. Meredith report?
  • A. 0
  • B. 99345,99417
  • C. 99344,99417
  • D. 1
New patient in community residential facility
Moderate MDM → 99344
Total time = 90 minutes
Base time exceeded → 99417 appropriate
Why others are incorrect:
99345 - High MDM (not documented)
Missing prolonged service code
NEW QUESTION # 331
A 3-day-old died in her sleep. The pediatrician determined this was the result of crib death syndrome. The parents give permission to refer the newborn for a necropsy. The pathologist receives the newborn with her brain and performs a gross and microscopic examination. The physician issues the findings and reports they are consistent with a normal female newborn.
What CPT code is reported?
  • A. 0
  • B. 1
  • C. 2
  • D. 3
Procedure: Gross and microscopic examination of a newborn autopsy.
CPT Code:
88028: This code is for the autopsy, gross and microscopic examination of a stillborn or newborn.
Code Selection Justification: The procedure described matches the comprehensive postmortem examination of a newborn.
AMA CPT Professional Edition (current year)
ICD-10-CM (current year)
HCPCS Level II (current year)
NEW QUESTION # 332
Each of the formats is unique in its own way and helps every AAPC certification exam applicant prepare according to his style. All of these formats are user-friendly and very helpful to clear the AAPC CPC Exam exam on the first try. AAPC CPC dumps are packed with multiple benefits that will help you prepare AAPC CPC Exam successfully in a short time. In case of new updates, AAPC CPC dumps will immediately provide you with up to 1 year of free questions updates. These free updates will save your time in case of AAPC CPC Exam real exam changes.
Exam CPC Sample: https://www.dumpsmaterials.com/CPC-real-torrent.html
We will definitely guarantee the quality of our CPC pass4sure pdf and services, so don't worry about it, AAPC Technical CPC Training We do not warrant that the servers that make this website available will be error, virus or bug free and you accept that it is your responsibility to make adequate provision for protection against such threats, When it refers to our CPC quiz bootcamp materials, there is always a series of advantages accompanied by.
Visit and download AAPC CPC updated exam questions right away to start the process of cracking your test in one go, Building native apps is challenging, especially when your app targets multiple system types—i.e.
Pass Guaranteed AAPC - Pass-Sure CPC - Technical Certified Professional Coder (CPC) Exam TrainingWe will definitely guarantee the quality of our CPC Pass4sure pdf and services, so don't worry about it, We do not warrant that the servers that make thiswebsite available will be error, virus or bug free and CPC you accept that it is your responsibility to make adequate provision for protection against such threats.
When it refers to our CPC quiz bootcamp materials, there is always a series of advantages accompanied by, So to exam candidates of AAPC area, it is the same situation.
As far as the top features of CPC exam dumps are concerned, these AAPC CPC latest questions are real and verified by AAPC CPC certification exam experts.
BONUS!!! Download part of DumpsMaterials CPC dumps for free: https://drive.google.com/open?id=1oPO5emnjzNNWCltPFHbmXnzk4yNWgZPq
