NCA-6.10最新考古題 - NCA-6.10考題寶典
123
Posted at 2/4/2026 07:43:27      View:83 | Replies:1        Print      Only Author   [Copy Link] 1#
Fast2test是一家專業的網站,它給每位元考生提供優質的服務,包括售前服務和售後服務兩種,如果你需要我們Fast2test Nutanix的NCA-6.10考試培訓資料,你可以先使用我們的免費試用的部分考題及答案,看看適不適合你,這樣你可以親自檢查了我們Fast2test Nutanix的NCA-6.10考試培訓資料的品質,再決定購買使用。假如你很不幸的沒通過,我們將退還你購買的全部費用,並提供一年的免費更新,直到你通過為止。
NCA-6.10考古題被大多數考生證明是有效的,通過很多IT認證考試的考生使用之后得出,能使考生在短時間內掌握最新的Nutanix NCA-6.10考試相關知識。由高級認證專家不斷完善出最新版的NCA-6.10考古題資料,他們的研究結果可以100%保證您成功通過NCA-6.10考試,獲得認證,這是非常有效的題庫資料。一些通過NCA-6.10考試的考生成為了我們的回頭客,他們說選擇Fast2test就意味著選擇成功。
NCA-6.10考題寶典,NCA-6.10真題材料Fast2test是唯一能供給你們需求的全部的Nutanix NCA-6.10 認證考試相關資料的網站。利用Fast2test提供的資料通過Nutanix NCA-6.10 認證考試是不成問題的,而且你可以以很高的分數通過考試得到相關認證。
最新的 Nutanix Certified Associate NCA-6.10 免費考試真題 (Q63-Q68):問題 #63
An administrator needs to automate the migration of a VM from ESXi to AHV.
Which utility should the administrator use?
  • A. Flow
  • B. acli
  • C. Ncli
  • D. Move
答案:A
問題 #64
An administrator needs to configure a solution that ensures VMs automatically power on in a specific order at the DR site in the event of a disaster.
Which feature will achieve this?
  • A. Recovery Plan
  • B. Resource Scheduling
  • C. Category
  • D. Protection Policy
答案:A
問題 #65
What is the purpose of the OpLog?
  • A. Persistent data storage
  • B. Dynamic read cache
  • C. Persistent write buffer
  • D. Global metadata
答案:C
解題說明:
The OpLog (Operational Log) in Nutanix serves as apersistent write bufferfor incoming I/O operations. It temporarily stores write requests to ensure fast acknowledgment to clients and better performance. The data is later coalesced and written to the Extent Store for long-term storage.
* A. Persistent write buffer:Correct, as the OpLog optimizes write performance by buffering writes temporarily.
* B. Persistent data storage:Incorrect, as this describes the Extent Store, not the OpLog.
* C. Global metadata:Incorrect, as metadata operations are handled by the Metadata Store.
* D. Dynamic read cache:Incorrect, as read caching is managed separately, often involving SSD-based caches.
Nutanix Bible: Explanation of OpLog and Extent Store.
Nutanix University: NCP Certification Study Materials.
問題 #66
Which is the default native Linux bridge in AHV?
  • A. bridge0
  • B. virbro
  • C. br0
  • D. vs0
答案:C
解題說明:
The correct answer isA. br0.
InAHV (Acropolis Hypervisor),br0is thedefault native Linux bridgecreated on each hypervisor host. It is used for VM traffic and external communication. AHV leveragesOpen vSwitch (OVS)to manage virtual networking, but the bridge is exposed as br0 in the host's network configuration.
Key points:
* br0connects VM virtual NICs (vNICs) to the physical network via the host's uplinks.
* It is pre-configured during Foundation or cluster deployment.
* virbr0is typical in KVM environments but isnot usedin AHV.
Official Reference:
* Nutanix AHV Networking Guide
* Nutanix KB #2027 - AHV Host Networking
* Excerpt: "AHV uses br0 as the default bridge on the host, configured by Open vSwitch for guest VM networking."
問題 #67
An administrator is conducting updates in a Nutanix cluster and is being prompted for handling non- migratable VMs.
Which VM type is non-migratable?
  • A. VMs O VMs with attached Volume Groups
  • B. Memory Overcommitted
  • C. VMs without NGT
  • D. VMs marked as an Agent
答案:A
解題說明:
Non-migratable VMs in a Nutanix cluster typically include those with attached Volume Groups. This is because such VMs leverage direct-attached storage via iSCSI, which ties them to a specific host, preventing live migration to another host. Volume Groups provide block storage to applications, and the iSCSI protocol does not support live migration of such connections.
Here's a breakdown of the options:
* A. VMs without NGT:Nutanix Guest Tools (NGT) are used for guest-level integration but do not affect VM migratability.
* B. VMs marked as an Agent:This setting does not inherently make VMs non-migratable. It primarily affects roles and tasks within certain configurations.
* C. Memory Overcommitted:While memory overcommitment can affect performance, it does not make VMs non-migratable. Nutanix AHV handles memory allocation dynamically.
* D. VMs with attached Volume Groups:Correct answer, as the iSCSI connections used by Volume Groups are host-specific and cannot migrate seamlessly.
Nutanix AHV Administration Guide: Nutanix Documentation
Nutanix Support KB Article on Volume Groups and VM Migration Limitations.
Nutanix University Certification Materials, NCP and NCM course modules.
問題 #68
Fast2test就是一個能使Nutanix NCA-6.10認證考試的通過率提高的一個網站。Fast2test的資深IT專家在不斷研究出各種成功通過Nutanix NCA-6.10認證考試的方案,他們的研究成果可以100%保證一次性通過Nutanix NCA-6.10 認證考試。。Fast2test提供的培訓工具是很有效的,有很多已經通過了一些IT認證考試的人就是用了Fast2test提供的練習題和答案,其中也有通過Nutanix NCA-6.10認證考試,他們也是利用的Fast2test提供的便利。選擇Fast2test就選擇了成功。
NCA-6.10考題寶典: https://tw.fast2test.com/NCA-6.10-premium-file.html
在我們的網站上,您將獲得我們提供的Nutanix NCA-6.10免費的PDF版本的DEMO試用,您會發現這絕對是最值得信賴的學習資料,Nutanix NCA-6.10最新考古題 我們保證給你提供最優秀的參考資料讓你一次通過考試,所以,我們需要適時的回歸NCA-6.10書本,去深刻思考相關的知識點,而不是對知識點有了一定程度的掌握之後就完全捨棄了NCA-6.10書本,Nutanix NCA-6.10最新考古題 我們都清楚地知道,IT行業的一個主要問題就是缺乏高質量的學習材料,Nutanix NCA-6.10最新考古題 你購買了考古題以後還可以得到一年的免費更新服務,一年之內,只要你想更新你擁有的資料,那麼你就可以得到最新版,所以,我們需在在掌握NCA-6.10問題集中的所有考題的基礎上,再去練習一部分其他的NCA-6.10問題集,以此來拓寬自己的知識面,在時間足夠充足的前提之下。
而我,只用了不到三分鐘,他在尋找跟自身實力相差不多的生物,為的就是試試他的實力,在我們的網站上,您將獲得我們提供的Nutanix NCA-6.10免費的PDF版本的DEMO試用,您會發現這絕對是最值得信賴的學習資料,我們保證給你提供最優秀的參考資料讓你一次通過考試。
完美的NCA-6.10最新考古題和資格考試的領導者和最新更新的Nutanix Nutanix Certified Associate v6.10所以,我們需要適時的回歸NCA-6.10書本,去深刻思考相關的知識點,而不是對知識點有了一定程度的掌握之後就完全捨棄了NCA-6.10書本,我們都清楚地知道,IT行業的一個主要問題就是缺乏高質量的學習材料,你購買了考古題以後還可以得到一年的免費更新服務,一年之內,只要你想更新你擁有的資料,那麼你就可以得到最新版。
Posted at 2/18/2026 02:26:49        Only Author  2#
I’m so thankful for your article, it left a significant mark on me. The 1z0-1046-25 reliable exam lab questions questions are free for everyone. Good luck on your exams!
