高質量的最新AP-213考證|高通過率的考試材料|確保通過的AP-213:Manufacturing Cloud Accredited Professional
Posted at 2/4/2026 09:10:22
PDFExamDumpsのAP-213考古題可以讓你輕鬆地準備考試。另外,如果你是第一次參加考試,那麼你可以使用軟體版的考古題。因為這是一個完全模擬真實考試的氛圍和形式的軟體。你可以提前感受到真實的考試。這樣你在真實的考試中就不會感到緊張。用過了軟體版的考古題,你就可以在參加考試時以一種放鬆的心態來做題,有利於你正常發揮你的水準。
獲得 Salesforce Salesforce 認證對於考生而言有很多好處,相對于考生尋找工作而言,一張 Salesforce 的 AP-213 認證會讓你倍受青睞的企業信任狀,帶來更好的工作機會。要想通過此認證學習過程中要注意方法,最重要的是需要毅力,如果有相關的工作經驗,學起來可能輕鬆一點,否則的話,你需要付出更多的勞動。Salesforce 的 AP-213 證照作為全球IT領域專家 Salesforce 證照之一,是許多大中IT企業選擇人才標準的必備條件。
AP-213考古題更新 - AP-213更新獲得AP-213認證已經成為大多數IT員工獲得更好工作的一種選擇,然而,許多考生一直在努力嘗試卻失敗了。如果你選擇使用我們的Salesforce AP-213題庫產品,幫您最大程度保證取得成功。充分利用AP-213題庫你將得到不一樣的效果,這是一個針對性強,覆蓋面廣,更新快,最完整的學習資料,保證您一次通過AP-213考試。如果您想要真實的考試模擬,就選擇我們軟件版本的Salesforce AP-213題庫,安裝在電腦上進行模擬,簡單易操作。
最新的 Accredited Professional AP-213 免費考試真題 (Q136-Q141):問題 #136
A Salesforce consultant has been tasked with creating an integration user to facilitate order data from an Enterprise Resource Planning (ERP) system into Sales Agreements. The integration will require the ability to write to a custom object.
How should the consultant extend access to grant the necessary permissions for the integration user?
- A. Extend access and grant necessary permissions through the integration user profile.
- B. Create permission sets and permission set groups to extend access and grant necessary permissions, then assign it to an integration user.
- C. Use a Salesforce administrator account as an integration user and the necessary access will already be granted.
答案:B
解題說明:
For integrating order data from an ERP system into Sales Agreements in Salesforce, the best practice is to create specific permission sets and possibly permission set groups that grant the necessary permissions, including write access to custom objects. These permission sets should then be assigned to the integration user account. This approach ensures that the integration user has precisely the access needed without the broad permissions that would come with using a Salesforce administrator account. It also allows for more granular control and security by limiting permissions to only those necessary for the integration's functionality.
問題 #137
What is the proper utilization of a System Integration Testing (SIT) environment?
- A. Used as a development environment to configure and build new applications
- B. Used as a backup and archive of production configuration and data
- C. Used as an environment to perform system-to-system testing
答案:C
解題說明:
A System Integration Testing (SIT) environment is used as an environment to perform system-to-system testing. This means that the SIT environment is used to test the integration of different systems or components that are part of the Salesforce Manufacturing Cloud solution. The SIT environment allows the verification of the functionality, performance, and reliability of the integrated systems, as well as the identification and resolution of any defects or issues that may arise during the integration process. The SIT environment is typically a replica of the production environment, but with a smaller data set and lower security requirements.
The SIT environment is also used to validate the data migration and synchronization between the source and target systems, as well as the compatibility and interoperability of the APIs and web services that are used for the integration. References:
Manufacturing Cloud - Salesforce
How to Perform Automated Integration Testing in Salesforce
Automate and Test During Integration
問題 #138
At universal containers some Manufacturing cloud users have 'Delete sales agreement' profile permission.
Which two statements are correct about that permission and the entitled users ability to delete sales agreements?
- A. Only these user will see the 'Delete' option on the sales agreement record header
- B. Only non-active sales agreements can be deleted
- C. Sales agreements with any status can be deleted
- D. Account owners will see the 'Delete' option on the sales agreements record header
- E. Only sales agreements with no associated products can be deleted
答案:A,C
解題說明:
According to the Salesforce Manufacturing Cloud documentation, the 'Delete sales agreement' profile permission allows users to delete an active, approved, canceled, or expired sales agreement. However, they can only delete a sales agreement if it doesn't have any active orders associated with it. Only users with this permission will see the 'Delete' option on the sales agreement record header. Account owners or other users without this permission will not see the 'Delete' option. The status of the sales agreement does not affect the ability to delete it, as long as there are no active orders1. References: 1: Delete a Sales Agreement - Salesforce
問題 #139
Which dashboards are on the Account page by default after the system administrator installs the Analytics app?
- A. Accounts agreement performance; Forecast analytics for the selected account
- B. Accounts agreement performance; Forecast analytics for all accounts
- C. Accounts agreement performance; Pricing analytics for the selected account
答案:A
解題說明:
Upon the installation of the Analytics app, the default dashboards on the Account page include "Accounts agreement performance" and "Forecast analytics for the selected account." These dashboards provide a comprehensive overview of an account's performance in terms of sales agreements and forecast accuracy, allowing for in-depth analysis and strategic planning based on historical and current data.
問題 #140
When list views are selected for account forecasts, which two permissions options may be based on the list view so the Account managers can generate forecsats?
- A. Share list view with group of users
- B. All users above hierarchy can see this list views
- C. All users can see the list views
- D. Share list view with account owners
答案:A,C
解題說明:
To ensure key account managers can generate forecasts using list views for account forecasts, it's crucial that either "All users can see this list view" or "Share list view with groups of users" is selected for the list views.
This setting allows for the appropriate visibility and access required for generating accurate and comprehensive forecasts. This is essential for maintaining the integrity and effectiveness of the forecasting process within Salesforce Manufacturing Cloud .
問題 #141
您選擇我們的PDFExamDumps來幫助你通過Salesforce AP-213 認證考試試是一個明智的選擇。你可以先線上免費下載PDFExamDumps為你提供的關於Salesforce AP-213 認證考試練習題及答案的試用版本作為嘗試,那樣你會更有信心選擇我們PDFExamDumps的產品來準備Salesforce AP-213 認證考試。如果你考試失敗,我們會全額退款給你。
AP-213考古題更新: https://www.pdfexamdumps.com/AP-213_valid-braindumps.html
我們網站為你準備了你需要的一切的Salesforce Manufacturing Cloud Accredited Professional - AP-213考試培訓資料,和實際認證考試一樣,選擇題(多選題)有效的幫助你通過考試,我們的AP-213認證考試學習資料的問題和答案包含了所有的考試題目和課程大綱內容,讓您輕松獲取AP-213證書,這是最新最全面的 AP-213 考試資料,一定可以給您通過 Salesforce 考試的勇氣與自信,我們承諾使用本網站的Salesforce學習資料的考生可以一次通過相關考試,輕松獲得AP-213證書,對于一次不過的全額退款,避免您的後顧之憂,Salesforce AP-213 的難度比較高所以通過率也比較低,Salesforce AP-213考古題更新 AP-213考古題更新認證考試,學習資料下載,考試認證題庫_PDFExamDumps AP-213考古題更新。
炎月兒立即警覺,露出戒備之色望向四周,剛才,差點麒麟血脈都要暴走了,我們網站為你準備了你需要的一切的Salesforce Manufacturing Cloud Accredited Professional - AP-213考試培訓資料,和實際認證考試一樣,選擇題(多選題)有效的幫助你通過考試。
100%合格率最新AP-213考證以及資格考試領先提供平臺和優質的AP-213:Manufacturing Cloud Accredited Professional我們的AP-213認證考試學習資料的問題和答案包含了所有的考試題目和課程大綱內容,讓您輕松獲取AP-213證書,這是最新最全面的 AP-213 考試資料,一定可以給您通過 Salesforce 考試的勇氣與自信,我們承諾使用本網站的Salesforce學習資料的考生可以一次通過相關考試,輕松獲得AP-213證書,對于一次不過的全額退款,避免您的後顧之憂。
Salesforce AP-213 的難度比較高所以通過率也比較低。
- 我們的最新AP-213考證-Manufacturing Cloud Accredited Professional AP-213更容易通過 🚠 免費下載⇛ AP-213 ⇚只需進入[ [url]www.vcesoft.com ]網站新版AP-213考古題[/url]
- 最好的最新AP-213考證,提前為Manufacturing Cloud Accredited Professional AP-213考試做好準備 ☀ 免費下載{ AP-213 }只需在☀ [url]www.newdumpspdf.com ️☀️上搜索AP-213熱門證照[/url]
- AP-213考試心得 ☮ AP-213在線題庫 🍟 AP-213熱門考題 🚈 免費下載《 AP-213 》只需在➥ [url]www.newdumpspdf.com 🡄上搜索AP-213考試指南[/url]
- 高質量的最新AP-213考證 |高通過率的考試材料|確保通過的AP-213:Manufacturing Cloud Accredited Professional 🚅 進入☀ [url]www.newdumpspdf.com ️☀️搜尋➥ AP-213 🡄免費下載AP-213考試資訊[/url]
- AP-213在線題庫 🐥 AP-213考題寶典 🎺 AP-213更新 🥬 立即到“ tw.fast2test.com ”上搜索⇛ AP-213 ⇚以獲取免費下載AP-213熱門考題
- AP-213證照 🟦 AP-213真題 🟩 AP-213熱門題庫 👾 請在《 [url]www.newdumpspdf.com 》網站上免費下載⇛ AP-213 ⇚題庫AP-213熱門證照[/url]
- 高質量的最新AP-213考證 |高通過率的考試材料|確保通過的AP-213:Manufacturing Cloud Accredited Professional 🏺 立即在{ [url]www.newdumpspdf.com }上搜尋⏩ AP-213 ⏪並免費下載AP-213最新題庫[/url]
- 高質量的最新AP-213考證 |高通過率的考試材料|確保通過的AP-213:Manufacturing Cloud Accredited Professional 🛺 請在【 [url]www.newdumpspdf.com 】網站上免費下載➥ AP-213 🡄題庫AP-213證照[/url]
- AP-213測試題庫 🤥 AP-213證照指南 🏙 AP-213真題 📬 ➥ [url]www.newdumpspdf.com 🡄提供免費( AP-213 )問題收集AP-213題庫資料[/url]
- 高質量的最新AP-213考證 |高通過率的考試材料|確保通過的AP-213:Manufacturing Cloud Accredited Professional 🍔 { [url]www.newdumpspdf.com }提供免費⇛ AP-213 ⇚問題收集AP-213考試重點[/url]
- AP-213考試指南 🦜 AP-213最新題庫 😍 新版AP-213考古題 🐒 複製網址⮆ [url]www.newdumpspdf.com ⮄打開並搜索☀ AP-213 ️☀️免費下載AP-213考試重點[/url]
- www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, writeablog.net, anonup.com, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, Disposable vapes
