2V0-11.25 Unterlagen mit echte Prüfungsfragen der VMware Zertifizierung
Posted at 2/4/2026 09:22:34
P.S. Kostenlose und neue 2V0-11.25 Prüfungsfragen sind auf Google Drive freigegeben von It-Pruefung verfügbar: https://drive.google.com/open?id=1navuCXDJkJ0yGXbXr_ijkGIq1C0hYf1J
Unsere Prüfungsunterlage zu VMware 2V0-11.25(VMware Cloud Foundation 5.2 Administrator)enthältet alle echten, originalen und richtigen Fragen und Antworten. Die Abdeckungsrate unserer Unterlage (Fragen und Antworten) zu VMware 2V0-11.25(VMware Cloud Foundation 5.2 Administrator)ist normalerweise mehr als 98%.
VMware 2V0-11.25 Prüfungsplan:| Thema | Einzelheiten | | Thema 1 | - VMware by Broadcom Solution: This section of the exam measures skills of the cloud administrator and covers identifying VMware Cloud Foundation components like vSphere, vSAN, and NSX, as well as their architecture, including stretched configurations. It also assesses knowledge of requirements for implementing private cloud solutions, use cases for VMware Aria Suite components, vSphere IaaS control plane, Data Services Manager, and VMware Cloud Foundation Add-Ons. The focus is on the ability to recognize and apply the correct VMware solutions for various enterprise scenarios.
| | Thema 2 | - IT Architectures, Technologies, Standards: There are no testable objectives in this section. However, this area establishes the foundational knowledge expected of cloud administrators, such as understanding basic IT infrastructure, virtualization, and cloud models. This section is relevant for cloud administrators and infrastructure engineers.
| | Thema 3 | - Plan and Design the VMware by Broadcom Solution: There are no testable objectives in this section. Still, it is intended for solution architects who need to plan and design VMware Cloud Foundation deployments, focusing on sizing, architecture selection, and network
- storage design.
| | Thema 4 | - Troubleshoot and Optimize the VMware by Broadcom Solution: This section of the exam measures skills of the cloud infrastructure support engineer and covers diagnosing and resolving technical issues related to VMware Cloud Foundation deployment and operations. It includes troubleshooting the deployment process, vSphere, networking, vSAN, SDDC Manager, and Aria Suite. The section also evaluates the ability to optimize infrastructure performance, manage resources, and ensure efficient operation, focusing on the practical aspects of maintaining and enhancing VMware Cloud Foundation environments.
| | Thema 5 | - Install, Configure, Administrate the VMware by Broadcom Solution: This section of the exam measures skills of the VMware Cloud Foundation administrator and covers the installation and configuration processes for VMware Cloud Foundation components, deploying and configuring management domains, NSX Edge Clusters, and the VMware Aria Suite Lifecycle. It assesses the ability to deploy workload domains, enable vSphere IaaS control plane, create vSphere namespaces, manage stretched clusters, and use VMware Cloud Foundation APIs. Candidates are also tested on scaling deployments, performing Day 2 operations like backup, recovery, lifecycle management, VM lifecycle management, configuring networking and storage, managing ESXi hosts, implementing encryption, and operationalizing VMware NSX, vSAN, and Aria Suite. The section is comprehensive, targeting those responsible for the ongoing administration and optimization of VMware environments.
2V0-11.25: VMware Cloud Foundation 5.2 Administrator Dumps & PassGuide 2V0-11.25 ExamenDie VMware 2V0-11.25 Zertifizierung ist den IT-Fachleute eine unentbehrliche Prüfung, weil sie ihres Schicksal bestimmt. Die Fragenkataloge zur VMware 2V0-11.25 Prüfung brauchen alle Kandidaten. Mit ihr kann der Kandidat sich gut auf die 2V0-11.25 Prüfung vorbereiten und nicht so sehr unter Druck stehen. Und die Fragenkataloge in It-Pruefung sind einzigartig. Mit ihr können Sie die VMware 2V0-11.25 Prüfung ganz mühlos bestehen.
VMware Cloud Foundation 5.2 Administrator 2V0-11.25 Prüfungsfragen mit Lösungen (Q36-Q41):36. Frage
An administrator has been tasked with adding a new VI workload Domain to an instance of VMware Cloud Foundation (VCF).
The administrator only has two prepared ESXi host servers showing in SDDC Manager.
The new VI Workload Domain must use vSphere Lifecycle Images.
Which three supported principal storage options are available to the administrator when configuring the new VI Workload Domain? (Choose three.)
- A. vVols
- B. VMFS on FC
- C. VSAN
- D. NFS v3
- E. iSCSI
- F. VMFS on local disk
Antwort: A,B,D
37. Frage
What three steps are required to commission a new host into the SDDC Manager inventory? (Choose three.)
- A. Delete all disk partitions on HDD/SSD.
- B. Manually import the host into the vCenter Server inventory and assign it to a cluster.
- C. A supported version of ESXi installed on the host.
- D. Update the DNS records and add the host directly to the SDDC Manager appliance using the root credentials.
- E. Four NIC ports with a minimum 10 Gbps speed.
- F. Self-signed certificate regenerated based on FQDN of host.
Antwort: A,C,F
Begründung:
As documented in the official VMware Cloud Foundation Administration Guide for Host Commissioning:
A . Self-signed certificate regenerated based on FQDN of host.
Exact Extract:
"During the commissioning process, SDDC Manager regenerates a self-signed certificate for the host based on its FQDN to ensure secure communications and integration with the management domain." C . Delete all disk partitions on HDD/SSD.
Exact Extract:
"Before commissioning, all partitions must be deleted from the host's disks to allow SDDC Manager to claim storage for vSAN or other use. Failure to remove partitions can cause the commissioning workflow to fail." F . A supported version of ESXi installed on the host.
Exact Extract:
"The host must be installed with a version of ESXi that is supported by the current release of VMware Cloud Foundation. Unsupported versions will cause the commissioning operation to fail." Why Not the Other Options?
B: While having multiple 10Gbps NICs is recommended, it is not a strict commissioning requirement for all host profiles.
D: Updating DNS is necessary, but the step of "adding the host directly to SDDC Manager using root credentials" is incomplete, as SDDC Manager itself performs the addition and validation steps.
E: Manually adding hosts to vCenter is not permitted; SDDC Manager must orchestrate the entire host onboarding process.
Summary:
The three required steps to commission a new host into the SDDC Manager inventory are:
A . Regenerate the self-signed certificate based on the FQDN,
C . Delete all disk partitions on HDD/SSD,
F . Ensure a supported version of ESXi is installed.
These steps are explicitly outlined in the VMware Cloud Foundation host commissioning documentation.
38. Frage
What is the primary use case for Aria Operations within VMware Cloud Foundation (VCF)?
- A. To provide comprehensive monitoring, analytics, and performance management of the cloud infrastructure
- B. To manage and analyze loo data from various sources
- C. To enable network virtualization and security
- D. To automate workload deployments across multiple cloud environments
Antwort: A
Begründung:
Aria Operations delivers unified monitoring, capacity planning, and predictive analytics for the VCF infrastructure, ensuring health and performance visibility across all components.
39. Frage
Which step must an administrator take to configure Application Virtual Networks (AVNs) from SDDC Manager while preparing to deploy VMware Aria Suite Lifecycle?
- A. Assign AVNs to specific ESXi hosts.
- B. Deploy NSX Edge Cluster.
- C. Enable AVNs in the vCenter Server.
- D. Ensure that an NSX load balancer is available.
Antwort: B
Begründung:
Before configuring Application Virtual Networks (AVNs) from SDDC Manager, the administrator mustdeploy an NSX Edge Cluster. The official VMware Cloud Foundation documentation specifies that an NSX Edge Cluster is required to provide the necessary network services and routing capabilities for AVNs, which are used to support management components such as VMware Aria Suite Lifecycle. Without the NSX Edge Cluster, AVN creation and related network functionalities cannot be configured or used from SDDC Manager. Steps such as enabling AVNs in vCenter Server, ensuring a load balancer, or assigning AVNs to specific ESXi hosts are not the prerequisites required by the workflow.
40. Frage
An administrator can set resource limits and container defaults on a vSphere Namespace.
Which three resource limits can be set? (Choose three.)
- A. Number of containersF Network
- B. StorageB Memory
- C. CPU
Antwort: A,B,C
Begründung:
vSphere Namespaces allow defining resource limits for Memory and CPU, as well as Storage capacity, which govern the allocation available to workloads within the namespace.
https://techdocs.broadcom.com/us ... vsphere-supervisor- services-and-workloads-8-0/configuring-and-managing-vsphere-namespaces/set-resource-limits-to-a-vsphere- namespace.html
41. Frage
Einige Websites bieten auch die neuesten Lernmaterialien zur VMware 2V0-11.25 Prüfung im Internet. Aber sie haben keine zuverlässigen Garatie. Ich würde hier sagen, dass It-Pruefung einen Grundwert hat. Alle VMware-Prüfungen sind sehr wichtig. Im Zeitalter der rasanten entwickelten Informationstechnologie ist It-Pruefung nur eine von den vielen. Warum wählen die meisten Menschen It-Pruefung? Dies liegt darin, die von It-Pruefung gebotenen Prüfungsfragen und Antworten wird Sie sicherlich in die Lage bringen, das Exam zu bestehen. wieso? Weil es die neuerlich aktualisierten Materialien bietet. Diese haben die Mehrheit der Kandidaten schon bewiesen.
2V0-11.25 Zertifikatsfragen: https://www.it-pruefung.com/2V0-11.25.html
- 2V0-11.25 VMware Cloud Foundation 5.2 Administrator neueste Studie Torrent - 2V0-11.25 tatsächliche prep Prüfung 🔼 Suchen Sie einfach auf ⮆ [url]www.pass4test.de ⮄ nach kostenloser Download von ⇛ 2V0-11.25 ⇚ 🤰2V0-11.25 Originale Fragen[/url]
- Die seit kurzem aktuellsten VMware 2V0-11.25 Prüfungsinformationen, 100% Garantie für Ihen Erfolg in der Prüfungen! 🦛 【 [url]www.itzert.com 】 ist die beste Webseite um den kostenlosen Download von 「 2V0-11.25 」 zu erhalten 🤿2V0-11.25 Testengine[/url]
- 2V0-11.25 PDF 🎼 2V0-11.25 Zertifizierung 😻 2V0-11.25 Fragenpool 🔨 Suchen Sie auf ➠ [url]www.pass4test.de 🠰 nach 【 2V0-11.25 】 und erhalten Sie den kostenlosen Download mühelos 🦞2V0-11.25 Vorbereitung[/url]
- 2V0-11.25 Übungsmaterialien - 2V0-11.25 Lernressourcen - 2V0-11.25 Prüfungsfragen 🅰 Suchen Sie einfach auf 《 [url]www.itzert.com 》 nach kostenloser Download von ➥ 2V0-11.25 🡄 🧥2V0-11.25 Testengine[/url]
- 2V0-11.25 VMware Cloud Foundation 5.2 Administrator neueste Studie Torrent - 2V0-11.25 tatsächliche prep Prüfung 🚟 Suchen Sie auf 【 [url]www.pass4test.de 】 nach kostenlosem Download von ☀ 2V0-11.25 ️☀️ 🪁2V0-11.25 Übungsmaterialien[/url]
- 2V0-11.25 Fragen Beantworten 🧩 2V0-11.25 Originale Fragen 🧮 2V0-11.25 PDF Demo 🐶 URL kopieren ➤ [url]www.itzert.com ⮘ Öffnen und suchen Sie 【 2V0-11.25 】 Kostenloser Download 💋2V0-11.25 Zertifizierungsfragen[/url]
- 2V0-11.25 Fragen - Antworten - 2V0-11.25 Studienführer - 2V0-11.25 Prüfungsvorbereitung 🚛 Suchen Sie jetzt auf ▶ [url]www.it-pruefung.com ◀ nach { 2V0-11.25 } und laden Sie es kostenlos herunter 🎣2V0-11.25 PDF Demo[/url]
- 2V0-11.25 Demotesten 📲 2V0-11.25 Zertifizierung 😾 2V0-11.25 Zertifizierung 🚈 Suchen Sie auf ⮆ [url]www.itzert.com ⮄ nach kostenlosem Download von 《 2V0-11.25 》 😹2V0-11.25 Testengine[/url]
- 2V0-11.25 Übungsmaterialien 🎢 2V0-11.25 Simulationsfragen 🐧 2V0-11.25 Demotesten 🧉 Suchen Sie auf 「 [url]www.it-pruefung.com 」 nach ( 2V0-11.25 ) und erhalten Sie den kostenlosen Download mühelos 😊2V0-11.25 Examsfragen[/url]
- Hilfsreiche Prüfungsunterlagen verwirklicht Ihren Wunsch nach der Zertifikat der VMware Cloud Foundation 5.2 Administrator 🚊 Öffnen Sie die Webseite 《 [url]www.itzert.com 》 und suchen Sie nach kostenloser Download von ▶ 2V0-11.25 ◀ 💘2V0-11.25 Zertifizierung[/url]
- Die seit kurzem aktuellsten VMware 2V0-11.25 Prüfungsinformationen, 100% Garantie für Ihen Erfolg in der Prüfungen! 🚶 Suchen Sie jetzt auf “ [url]www.deutschpruefung.com ” nach ▛ 2V0-11.25 ▟ um den kostenlosen Download zu erhalten 🍡2V0-11.25 Testengine[/url]
Übrigens, Sie können die vollständige Version der It-Pruefung 2V0-11.25 Prüfungsfragen aus dem Cloud-Speicher herunterladen: https://drive.google.com/open?id=1navuCXDJkJ0yGXbXr_ijkGIq1C0hYf1J
