[General] 2026 CDCP Exam Course - Realistic EXIN Certified Data Centre Professional (CDCP)
86
【General】 2026 CDCP Exam Course - Realistic EXIN Certified Data Centre Professional (CDCP)
Posted at 2/4/2026 10:26:11      View:168 | Replies:1        Print      Only Author   [Copy Link] 1#
P.S. Free & New CDCP dumps are available on Google Drive shared by Pass4sureCert: https://drive.google.com/open?id=1rf4KXK9YqYxRCEByt7PagEsMCniCawoZ
You can find yourself sitting in your dream office and enjoying the new opportunity. So, don't wait, get the EXIN CDCP certification by preparing through Pass4sureCert EXIN CDCP exam questions that will help you crack the EXIN CDCP Exam. Pass4sureCert will provide you with all the EXIN CDCP exam dumps, practice exams, and other necessary documentation that will help you understand the EXIN CDCP exam questions and pass the EXIN CDCP exam.
EXIN CDCP Exam Syllabus Topics:
  • Cooling Infrastructure: The topic focuses on liquid immersion cooling, supplemental cooling options, sensible and latent heat definitions, and temperature and humidity recommendations.
  • Electro Magnetic Fields: The topic deals with effects of EMF on human health and equipment (H)EMP, standards, and EMF shielding solutions.
  • Light: This topic covers light fixture types and placement, emergency lighting, and emergency Power Supply (EPS).
  • Auxiliary Systems: The topic covers water leak detection systems, data centre monitoring requirements, EMS, BMS and DCIM.
Topic 5
  • Data Centre Location, Building and Construction: It focuses on appropriate sites and components of an effective data centre and supporting facilities setup.
Topic 6
  • Designing a Scalable Network Infrastructure: It covers ANSI
  • TIA-942 cabling hierarchy, network redundancy, structured Cabling System, and planning considerations.
100% Pass 2026 EXIN CDCP: Certified Data Centre Professional (CDCP) Fantastic Exam CourseThere is no doubt they are clear-cut and easy to understand to fulfill your any confusion about the exam. Our Certified Data Centre Professional (CDCP) exam question is applicable to all kinds of exam candidates who eager to pass the exam. Last but not the least, they help our company develop brand image as well as help a great deal of exam candidates pass the exam with passing rate over 98 percent of our CDCP real exam materials. Considering many exam candidates are in a state of anguished mood to prepare for the Certified Data Centre Professional (CDCP) exam, our company made three versions of CDCP Real Exam materials to offer help. All these variants due to our customer-oriented tenets. As a responsible company over ten years, we are trustworthy. In the competitive economy, this company cannot remain in the business for long.
EXIN Certified Data Centre Professional (CDCP) Sample Questions (Q74-Q79):NEW QUESTION # 74
Escape route signage should be placed where?
  • A. Only at emergency escape doors
  • B. Only at the main entrance of the data centre building
  • C. At every door providing a pathway
  • D. At every door including riser doors, doors of storage closets etc.
Escape route signage should be placed at every door providing a pathway to the exit or the assembly area, according to the CDCP Preparation Guide1 and the EU Safety/Health Signs Directive2. Escape route signage is used to guide the occupants of the data centre fromwherever they are in the building, via a place of relative safety (the escape route), to the place of ultimate safety (the assembly area). Escape route signage should not be limited to only emergency escape doors or the main entrance of the data centre building, as these may not be accessible or visible from all locations. Escape route signage should also not include doors that do not lead to the exit or the assembly area, such as riser doors, doors of storage closets, or doors of other rooms, as these may confuse or mislead the occupants. Escape route signage should be placed at every door that provides a pathway to the exit or the assembly area, and should indicate the direction and distance of the escape route using pictograms, arrows, and words. Escape route signage should also be designed and installed in accordance with the relevant standards and codes, such as BS 5499 and ISO 7010.
1: CDCP Preparation Guide, page 24, section 2.4.3 2: EU Safety/Health Signs Directive3, page 1, section 1
NEW QUESTION # 75
What is the main advantage of busbar trunking compared to stand electrical cabling?
  • A. Busbar trunking can be located both overhead and under the raised floor.
  • B. Busbar trunking has a fixed power rating.
  • C. Busbar trunking is less expensive.
  • D. Busbar trunking allows for flexibility.
Busbar trunking systems are a method of power distribution using rigid copper or aluminium conductors to distribute the power around a building. Busbar trunking systems have many advantages over cables, such as lower space requirements, higher short-circuit strength, lower fire load, and easier installation. One of the main advantages of busbar trunking is that it allows for flexibility in terms of power transmission and distribution. Busbar trunking systems can be easily relocated, modified, or expanded to accommodate changes in the building layout or load demand. Busbar trunking systems can also be fitted with various components, such as tap-off units, elbows, tees, and end feed units, to provide power to different locations and consumers.
Busbar trunking systems can also be installed both overhead and under the raised floor, depending on the design and preference of the building.
References: Why I prefer busbar trunking systems more than cables | EEP, Why should you choose Busbar over Cable? - E+I Eng, Busbar VS Cables for Riser Applications - An Electrical Engineer.
NEW QUESTION # 76
What is a requirement for both CCTV cameras and recording equipment?
  • A. CCTV cameras can only be used to cover the outside of the building, where as the recording equipment needs to be located in a secure area.
  • B. Both must be connected to a UPS.
  • C. Both must be placed inside the Computer room.
  • D. They must be of the same brand.
A UPS (Uninterruptible Power Supply) is a device that provides backup power to electrical equipment in case of a power outage or fluctuation. A UPS is essential for both CCTV cameras and recording equipment, as it ensures that the surveillance system can continue to operate and record without interruption or data loss. A UPS can also protect the CCTV cameras and recording equipment from damage caused by power surges or spikes. Connecting both CCTV cameras and recording equipment to a UPS is a requirement for data centres, as it enhances the security and reliability of the surveillance system.
References: Technical Specification - GeM, [What is a UPS? | Uninterruptible Power Supply | APC by Schneider Electric], [Why You Need a UPS for Your CCTV System - CCTV Camera World].
NEW QUESTION # 77
What factor should be considered when placing fluorescent lighting in the data centre?
  • A. Fluorescent lights should not be connected to the same UPS that supports the ICT equipment.
  • B. Fluorescent lights should only be installed in equipment supporting areas and not in the Computer
    /Server room.
  • C. Fluorescent lights should not be connected to the back-up generator.
  • D. Fluorescent lights should not be connected to the mains power supply.
The UPS (uninterruptible power supply) is a device that provides backup power to the ICT equipment in case of a power outage or a power quality issue. The UPS should be dedicated to the ICT equipment only, and not to other loads, such as lighting, cooling, or security systems. This is because connecting fluorescent lights to the same UPS as the ICT equipment can cause several problems, such as:
*Reducing the battery runtime of the UPS, which may not be enough to support the ICT equipment until the backup generator kicks in or the utility power is restored.
*Increasing the harmonic distortion of the UPS output, which can affect the performance and reliability of the ICT equipment and the UPS itself.
*Creating electromagnetic interference (EMI) or radio frequency interference (RFI), which can disrupt the communication and data transmission of the ICT equipment.
*Triggering false alarms or tripping the circuit breakers of the UPS, which can cause downtime or data loss.
Therefore, fluorescent lights should not be connected to the same UPS that supports the ICT equipment.
Instead, they should be connected to a separate power source, such as the utility power, the backup generator, or a different UPS.
1: CDCP Preparation Guide, page 17, section 2.3.1 2: Data Center Lighting Design Considerations3, page 1, section 3 4: Data Center Lighting Solutions5, page 1, section 1 6: Going beyond energy savings in data centers with LEDs7, page 1, section 2
NEW QUESTION # 78
Mean time between failures is best considered a measure of:
  • A. Duration
  • B. Cost
  • C. Size
  • D. Reliability
Mean time between failures (MTBF) is a measure of the reliability of a system or component. It represents the average time that a system or component will operate before it fails. The higher the MTBF, the more reliable the system or component is. MTBF is calculated by dividing the total time of operation by the number of failures that occur during that time. MTBF is used to compare the reliability of similar systems or components, and to help with maintenance planning, inventory management, and system design.
References: EPI Data Centre Training Framework, CDCP Preparation Guide, Reliability Metrics 101: Mean Time Between Failure (MTBF)
NEW QUESTION # 79
One of the main unique qualities of Pass4sureCert Certified Data Centre Professional (CDCP) Exam Questions is its ease of use. Our practice exam simulators are user and beginner friendly. You can use Certified Data Centre Professional (CDCP) (CDCP) PDF dumps and Web-based software without installation. EXIN CDCP PDF Questions work on all the devices like smartphones, Macs, tablets, Windows, etc. We know that it is hard to stay and study for the Certified Data Centre Professional (CDCP) (CDCP) exam dumps in one place for a long time.
CDCP New Question: https://www.pass4surecert.com/EXIN/CDCP-practice-exam-dumps.html
P.S. Free 2026 EXIN CDCP dumps are available on Google Drive shared by Pass4sureCert: https://drive.google.com/open?id=1rf4KXK9YqYxRCEByt7PagEsMCniCawoZ
Posted at 2/19/2026 12:11:04        Only Author  2#
I’m really enjoying this content, definitely hitting like. Here's the Latest free LEED-AP-Homes study guide exam that played a significant role in my promotion and salary increase. It’s free for everyone today. Good luck!
