Exam Cram Salesforce FS-Con-101 Pdf | 100% FS-Con-101 Correct Answers
115
Posted at 2/4/2026 11:50:24      View:101 | Replies:1        Print      Only Author   [Copy Link] 1#
So we can say that the Salesforce Certified Field Service Consultant (FS-Con-101) practice test questions are real, valid, and updated and these will greatly help you in FS-Con-101 exam preparation. The availability of Salesforce Certified Field Service Consultant (FS-Con-101) exam questions in three different formats, free demo download facility, affordable price, free three months updated FS-Con-101 Exam Questions download facility, and verified and real Salesforce Certified Field Service Consultant (FS-Con-101) exam questions are the top features of Dumpexams FS-Con-101 exam questions.
Dumpexams made an FS-Con-101 Questions for the students so that they don't get confused to prepare for Salesforce Certified Field Service Consultant (FS-Con-101) certification exam successfully in a short time. Dumpexams has designed the real FS-Con-101 exam dumps after consulting many professionals and receiving positive feedback. The Salesforce Certified Field Service Consultant (FS-Con-101) questions have many premium features, so you don't face any hurdles while preparing for Salesforce Certified Field Service Consultant (FS-Con-101) exam and pass it with good grades.
FS-Con-101 Sure Pass Test & FS-Con-101 Training Vce Pdf & FS-Con-101 Free Pdf TrainingThe web-based Salesforce FS-Con-101 practice test software can be used through browsers like Firefox, Safari, and Google Chrome. The customers don't need to download or install any excessive plugins or software in order to use the web-based Salesforce FS-Con-101 Practice Exam format. The web-based FS-Con-101 practice test software format is supported by different operating systems like Mac, iOS, Linux, Windows, and Android.
Salesforce Certified Field Service Consultant Sample Questions (Q58-Q63):NEW QUESTION # 58
Service resources at Universal Containers (UC) frequently work in more than one service territory.
The current scheduling policy looks only at primary territory. While UC still wants the optimizer to use the service resource's primary territory when scheduling, UC also wants the scheduling policy to look at the resource''s secondary service territories.
Which two scheduling policy changes should a Consultant recommend?
Choose 2 answers
  • A. Select Working Location Enable Primary on theWorking Territories Work Rule:
  • B. Remove the Match Territory Work Rule.
  • C. Include the Mateh Territory Work Rule.
  • D. Deselect Working Location Enable Primary on the Working Territories Work Rule.
Working Location Enable Primary is a setting on the Working Territories work rule that defines whether resources should be matched with service appointments based on their primary territory only or any territory they belong to[186]. Match Territory is a work rule that defines whether resources shouldbe matched with service appointments based on their territories[187]. Selecting Working Location Enable Primary on the Working Territories Work Rule and including the Match Territory Work Rule would allow Universal Containers' scheduling policy to look atboth primary and secondary service territories by enabling matching resources with service appointments based on any territory they belong to and prioritizing matching resources with service appointments based on their territories. Removing the Match Territory Work Rule would not allow Universal Containers' scheduling policy to look at both primary and secondary service territories because it would disable matching resources with service appointments based on their territories. Deselecting Working LocationEnable Primary on the Working Territories Work Rule would not affect Universal Containers' scheduling policy because it is already deselected by default. References: https://help.salesforce.
com/s/articleView?id=sf.fs_scheduling_policies_work_rules_working_territories.htm&type=5 https://help.
salesforce.com/s/articleView?id=sf.fs_scheduling_policies_work_rules_match_territory.htm&type=5
NEW QUESTION # 59
Universal Containers tracks customer issues in its call center. Sometimes a Technician is required at the customer's location to resolve the issue.
Which sequence of steps should a Consultant recommend to dispatch the Technician?
  • A. Create Work Order, Create Case, Dispatch Work Order, Create ServiceAppointment.
  • B. Create Service Appointment, Create Work Order, Create Case, Dispatch Service Appointment.
  • C. Create Case, Create Work Order, Create Service Appointment, Dispatch Service Appointment.
  • D. Create Case, Create Service Appointment, Create Work Order, Dispatch Service Appointment.
This is the recommended sequence of steps to dispatch a technician for a customer issue. A case is created to track the customer issue, a work order is created to track the work that needs to be done, a service appointment is created to schedule the work, and a service appointment is dispatched to assign it to a technician.
References: https://trailhead.salesforce.com ... ield_service_basics
/field_service_work_orders
NEW QUESTION # 60
Universal Containers just started its Field Service Implementation and is configuring Service Territories and Locations. The Locations need to be associated to Territories.
In which two ways should the Consultant show this relationship?
Choose ? answers
  • A. Add the Service Territory Location Related List on the Location page layout.
  • B. Add the Service Territory Location Related List on the Service Territory page layout.
  • C. Create the Service Territory Location as a Location lookup field.
  • D. Create the Service Territory Location as a Service Territory lookup field.
Service Territory Location is a junction object that links Service Territory and Location objects[236]. Related Lists are components on page layouts that show records that are related to a record through a lookup or master- detail relationship[237]. Adding the Service Territory Location Related List on the Service Territory page layout and adding the Service Territory Location Related List on the Location page layout would allow Universal Containers to show howLocations are associated to Territories by displaying a list of Service Territory Locations on each record[238]. Creating the Service Territory Location as a Service Territory lookup field or creating the Service Territory Location as a Location lookup field would not work because they are not valid fields on either object. References: https://developer.salesforce.com/docs/atlas.en-us.api.
meta/api/sforce_api_objects_serviceterritorylocation.htm https://help.salesforce.com/s/articleView?id=sf.
customize_related_lists.htm&type=5https://help.salesforce.com/s/articleView?id=sf.
fs_service_territory_locations_overview.htm&type=5
NEW QUESTION # 61
Technicians earn certifications that must be renewed periodically to ensure their skills remain up to date.
How can these certifications be managed on the Resource?
  • A. Add the Resource Skill and set the End Date.
  • B. Add the Resource Skill and track certification using reminder.
  • C. Add the Resource Skill and remove from the Service Territory once expired.
  • D. Add the Resource Skill and create Absence onceexpired.
This option allows the Resource Skill to expire when the certification expires, and prevents the resource from being scheduled for jobs that require that skill. References:https://help.salesforce.com/s/articleView?id=sf.
fs_resource_skills.htm&type=5
NEW QUESTION # 62
Universal Containers (UC) wants to schedule Work Orders only if Technicians have the necessary qualifications to complete the designated work.
In which two ways can UC achieve this?
Choose ? answers
  • A. a Create Skills that relate to qualifications from theSkills tab and assign them to a Service Resource.
  • B. Leverage the Match Skills Scheduling Policy when scheduling appointments.
  • C. Create Skills that relate to qualifications from Setup and assign them to a Service Resource.
  • D. Leverage the Match Skills Work Rule when scheduling appointments.
These two options allow creating skills that represent qualifications and assigning them to service resources and work orders, and using a work rule to match skills when scheduling appointments. References:https://help.
salesforce.com/s/articleView?id=sf.fs_skills.htm&type=5
NEW QUESTION # 63
In this hustling society, our FS-Con-101 practice materials are highly beneficial existence which can not only help you master effective knowledge but pass the exam effectively. They have a prominent role to improve your soft-power of personal capacity and boost your confidence of conquering the exam with efficiency. You will be cast in light of career acceptance and put individual ability to display. When you apply for a job you could have more opportunities than others. What is more, there is no interminable cover charge for our FS-Con-101 practice materials priced with reasonable prices for your information. Considering about all benefits mentioned above, you must have huge interest to them.
100% FS-Con-101 Correct Answers: https://www.dumpexams.com/FS-Con-101-real-answers.html
Salesforce Exam Cram FS-Con-101 Pdf Trust us, and you will not regret it, Users who use our FS-Con-101 real questions already have an advantage over those who don't prepare for the exam, The advantages of our FS-Con-101 guide dumps are too many to count, FS-Con-101 test dumps are verified by the specialists of the business, therefore the quality is ensured, Any software that is made available to download from this web site/server (the "Software") is the copyrighted work of Dumpexams 100% FS-Con-101 Correct Answers Inc, and the use of all Software is governed strictly by the terms and conditions set forth in the license agreement that accompanies and/or is included with the Software (the "License Agreement").
Applying machine learning to classify, recommend, FS-Con-101 and predict incoming information, Of course, this example is trivial, Trust us, and you will not regret it, Users who use our FS-Con-101 Real Questions already have an advantage over those who don't prepare for the exam.
Free PDF Quiz 2026 Salesforce Professional FS-Con-101: Exam Cram Salesforce Certified Field Service Consultant PdfThe advantages of our FS-Con-101 guide dumps are too many to count, FS-Con-101 test dumps are verified by the specialists of the business, therefore the quality is ensured.
Any software that is made available to download from this Dump FS-Con-101 File web site/server (the "Software") is the copyrighted work of Dumpexams Inc, and the use of all Software is governed strictly by the terms and conditions set forth Exam Cram FS-Con-101 Pdf in the license agreement that accompanies and/or is included with the Software (the "License Agreement").
Posted at 2/21/2026 20:25:53        Only Author  2#
Your article is outstanding, thank you for sharing! L4M1 latest exam camp pdf exam papers are shared for free. Wishing you success in your exam!
