Salesforce-MuleSoft-Developer-I日本語版受験参考書、Salesforce-MuleSoft-Developer-I復習過去問
135
Posted at 2/4/2026 12:24:24      View:76 | Replies:1        Print      Only Author   [Copy Link] 1#
P.S.It-PassportsがGoogle Driveで共有している無料の2026 Salesforce Salesforce-MuleSoft-Developer-Iダンプ:https://drive.google.com/open?id=18Q2tu3tvgDunlQBRmFj-fzZpql2hsOXH
SalesforceのSalesforce-MuleSoft-Developer-I認定試験に合格するのは簡単なことではありませんか。It-PassportsのSalesforceのSalesforce-MuleSoft-Developer-I試験トレーニング資料を選ぶなら、一回で認定試験に合格するの可能性は高いです。It-PassportsのSalesforceのSalesforce-MuleSoft-Developer-I試験トレーニング資料は豊富な経験を持っているIT業種の専門家が長年の研究を通じて、作成したものです。その権威性が高いと言えます。It-Passportsを選ぶなら、絶対に後悔させません。
Salesforce Salesforce-MuleSoft-Developer-I 認定試験の出題範囲:
トピック出題範囲
トピック 1
  • Transforming Data with DataWeave: It involves writing DataWeave scripts and using DataWeave functions. This topic also includes defining and using DataWeave variables, functions, and modules, and applying correct syntax.
トピック 2
  • Routing Events: It focuses on using the Choice router for conditional logic and the Scatter-Gather router to multicast events. This topic also involves validating data by using the Validation module.
トピック 3
  • Designing APIs: Designing APIs involves describing the lifecycle of the modern API and using RAML to define various aspects of an API. It includes identifying when to use query parameters vs URI parameters, and defining API parameters.
トピック 4
  • Building API Implementation Interfaces: This topic involves manually creating a RESTful interface for a Mule application and generating a REST Connector from a RAML specification. It also includes describing the features and benefits of APIkit.
トピック 5
  • Processing Records: Processing records includes methods for processing individual records in a collection and explaining how Mule events are processed by the For Each scope. It also involves using the Batch Job with Batch Steps and a Batch Aggregator.
トピック 6
  • Creating Application Networks: The topic of creating Application Networks encompasses understanding MuleSoft’s proposal for closing the IT delivery gap and describing the role and characteristics of the modern API. It also includes the purpose and roles of a Center for Enablement (C4E), and the benefits of API-led.
トピック 7
  • Deploying and Managing APIs and Integrations: It includes packaging Mule applications for deployment and deploying them to CloudHub. This topic also involves using CloudHub properties, creating and deploying API proxies, connecting an API implementation to API Manager, and applying policies to secure an API.
トピック 8
  • Handling Errors: Handling errors includes describing default error handling in Mule applications and defining custom global default error handlers. It involves comparing On Error Continue and On Error Propagate scopes, creating error handlers for a flow, using the Try scope, and mapping errors to custom application errors.
トピック 9
  • Structuring Mule Applications: Structuring Mule applications covers parameterizing an application and defining and reusing global configurations. It includes breaking an application into multiple flows using private flows, subflows, and the Flow Reference component.
トピック 10
  • Using Connectors: It focuses on retrieving data from REST services using HTTP Request or REST Connector. Moreover, the topic covers using a Web Service Consumer connector for SOAP web services and the Transform Message component.
トピック 11
  • Debugging and Troubleshooting Mule Applications: Using breakpoints to inspect a Mule event during runtime, installing missing Maven dependencies, and reading and deciphering Mule log error messages are sub-topics of this topic.
Salesforce-MuleSoft-Developer-I試験の準備方法|効果的なSalesforce-MuleSoft-Developer-I日本語版受験参考書試験|100%合格率のSalesforce Certified MuleSoft Developer (Mule-Dev-201)復習過去問顧客様と販売者の間での信頼性は苦労かつ大切なことだと良く知られます。誠意をみなぎるSalesforce Salesforce-MuleSoft-Developer-I試験備考資料は我々チームの専業化を展示されるし、最完全の質問と再詳細の解説でもって試験に合格するのを助けるます。同時的に、皆様の認可は我々仕事の一番良い評価です。
Salesforce Certified MuleSoft Developer (Mule-Dev-201) 認定 Salesforce-MuleSoft-Developer-I 試験問題 (Q212-Q217):質問 # 212
A Mule flow has three Set Variable transformers. What global data structure can be used to access the variables?
  • A. Mule event message
  • B. Mule event attributes
  • C. Mule application properties
  • D. Mule event
Mule event is correct answer. Mule event has two parts which are as follows
1) Message (which contains payload and attributes like headers and query/uri parameters
2) Variables
Diagram Description automatically generated
質問 # 213
As a part of requirement , application property defined below needs to be accessed as dataweave expression.
What is the correct expression to map it to port value?
  • A. { port : {db:port}}
  • B. Application property cannot be accessed in Dataweave
  • C. { port : p['db.port']}
  • D. { port : p('db.port')}
Option 1 is the correct syntax
質問 # 214
According to MuleSoft. what is the first step to create a Modern API?
  • A. Performance tune and optimize the backend systems and network
  • B. Gather a list of requirements to secure the API
  • C. Create a prototype of the API implementation
  • D. Create an API specification and get feedback from stakeholders
First step in creating Modern API is to create an API specification and get feedback from stakeholders so that any future issues can be identified at early stage thereby reducing overall delivery time
質問 # 215
A
web client submits a request to http://localhost:8081?accountType=personal. The query parameter is captured using a Set Variable transformer to a variable named accountType.
What is the correct DataWeave expression to log accountType?
  • A. Account Type: #[message.inboundProperties.accountType]
  • B. Account Type: #[vars.accountType]
  • C. Account Type: #[flowVars.accountType]
  • D. Account Type: # [attributes.accountType]
vars: Keyword for accessing a variable, for example, through aDataWeave expression in a Mule component, such as the Logger, or from an Input or Output parameter of an operation. If the name of your variable is myVar, you can access it like this: vars.myVar Hence correct answer is Account Type: #[vars.accountType]
質問 # 216
The Mule application's connectors are configured with property placeholders whose values are set in the config.yaml file What must be added to the Mule application to link the config.yaml file's values with the property placeholders?
  • A. A file-config element in the acrne-app xml file
  • B. A propertiesFile key/value pair in the mule-artifact json file
  • C. A dependency element in the pom xml file
  • D. A configuration-properties element in the acme-app xml file
質問 # 217
弊社It-PassportsのSalesforce-MuleSoft-Developer-Iテストブレインダンプを習得するのに20〜30時間しかかからず、試験に参加すれば、Salesforce-MuleSoft-Developer-I試験に合格する可能性が非常に高くなります。多くの人々にとって、彼らは現役のスタッフであろうと学生であろうと、仕事や家族生活などで忙しいのです。ただし、Salesforce-MuleSoft-Developer-I準備トレントを購入すると、主に仕事、学習、または家族の生活に時間とエネルギーを費やすことができ、毎日Salesforce Certified MuleSoft Developer (Mule-Dev-201)試験トレントを学ぶことができます。また、Salesforce-MuleSoft-Developer-I試験の質問で簡単にSalesforce-MuleSoft-Developer-I試験に合格できます。
Salesforce-MuleSoft-Developer-I復習過去問: https://www.it-passports.com/Salesforce-MuleSoft-Developer-I.html
Posted at 3/7/2026 08:26:31        Only Author  2#
一つの試験だけでは多くの時間を無駄にする必要がありません。COF-C03認定試験が大変難しいと感じて、多くの時間を取らなければならないとしたら、ツールとしてIt-PassportsのCOF-C03問題集を利用したほうがいいです。この問題集はあなたに時間を節約させることができますから。もっと重要なのは、この問題集はあなたが試験に合格することを保証できますから。この問題集よりもっと良いツールは何一つありません。試験の準備をするのにたくさんの時間を無駄にするより、そんな時間を利用してもっと有意義なことをしたほうがいいです。ですから、はやくIt-Passportsのサイトに行ってもっと多くの情報を読みましょう。この素晴らしきチャンスを逃したらきっと後悔しますよ。
