Hardware
Valid Dumps Plat-Dev-210 Free - Free Sample Plat-Dev-210 Questions
Posted at 2/4/2026 13:33:08
View127
Replies0
Before you take the exam, you only need to spend 20 to 30 hours to practice, so you can schedule time to balance learning and other things. Of course, you care more about your passing rate. If you choose our Plat-Dev-210 exam guide, under the guidance of our Plat-Dev-210 exam torrent, we have the confidence to guarantee a passing rate of over 99%. Our Plat-Dev-210 quiz prep is compiled by experts based on the latest changes in the teaching syllabus and theories and practices. So our Plat-Dev-210 Quiz prep is quality-assured, focused, and has a high hit rate. The most important information is conveyed with the minimum number of questions, and you will not miss important knowledge. You can make full use of your usual piecemeal time to learn our Plat-Dev-210 exam torrent. You will get the best results in the shortest time. Join our study and you will have the special experience.
Salesforce Plat-Dev-210 Exam Syllabus Topics:| Topic | Details | | Topic 1 | - Omniscripts: This portion of the exam measures the skills of a Business Analyst and focuses on the use of OmniScripts to create dynamic, guided user experiences. It includes comparing and contrasting various OmniScript elements and their configurations to fulfill given use cases. The section also examines the candidate's understanding of the JSON structure that supports OmniScripts, as well as the ability to select appropriate elements and properties to address functional requirements effectively.
| | Topic 2 | - Integration Procedures: This section measures the skills of an Integration Architect and involves designing and configuring Integration Procedures to automate processes and integrate systems. It requires comparing and contrasting different elements and configurations within Integration Procedures to meet specific use cases. Candidates are also tested on selecting the correct elements and properties to satisfy functional requirements, ensuring seamless data flow and process automation.
| | Topic 3 | - Flexcards: This section of the exam measures the skills of a Solution Architect and covers the ability to design and configure FlexCards based on specific business requirements. It evaluates the candidate's knowledge in selecting appropriate card styles, defining data sources and fields, and implementing user actions across different card states. Additionally, this domain tests the understanding of constructing the underlying JSON data structure that powers the FlexCards framework, ensuring that the configured cards meet both functional and technical specifications.
2026 Valid Dumps Plat-Dev-210 Free 100% Pass | Efficient Free Sample Plat-Dev-210 Questions: Salesforce Certified Omnistudio DeveloperHowever, you should keep in mind that to get success in the Plat-Dev-210 certification exam is not a simple and easy task. A lot of effort, commitment, and in-depth Salesforce Certified Omnistudio Developer (Plat-Dev-210) exam questions preparation is required to pass this Plat-Dev-210 Exam. For the complete and comprehensive Salesforce Certified Omnistudio Developer (Plat-Dev-210) exam dumps preparation you can trust valid, updated, and Plat-Dev-210 Questions which you can download from the VCE4Plus platform quickly and easily.
Salesforce Certified Omnistudio Developer Sample Questions (Q15-Q20):NEW QUESTION # 15
A developer needs to retrieve data from an external system that stores policy data. The external system supports REST APIs to access and update the policies. Due to the volume of the policy data and peak hours of hours of business, calls to the REST APIs sometimes take longer than expected to response.
The developer creates an Integration Procedure to retrieve the policy data for use in an OmniScript.
Given the external system's known performance issues, which configuration should be used to implement the call to the external system?
Choose 2 answers
- A. Check the Chainable checkbox on the integration procedure Action in the OmniScript
- B. Configure a Remote action with timeout settings of 120000
- C. Set the Timeout property on the HTTP Action in the Integration Procedure
- D. Check the Chain on Step Check on the HTTP Action in the Integration Procedure
Setting the Timeout property on the HTTP Action in the Integration Procedure allows the developer to specify how long to wait for a response from the external system before timing out. Checking the Chain on Step Check on the HTTP Action in the Integration Procedure allows the developer to chain multiple HTTP Actions together and execute them sequentially. Configuring a Remote action with timeout settings of 120000 is not necessary, as it is already done by default in OmniStudio. Checking the Chainable checkbox on the integration procedure Action in the OmniScript has no effect on calling an external system.
NEW QUESTION # 16
Which calculation procedure version in the list would execute on 2/15/2020at 12:00 PM?
- A. Version Number 1
- B. Version Number 2
- C. Version Number 3
- D. Version Number 4
the calculation procedure version that would execute on 2/15/2020 at 12:00 PM is the one that has the start date time and end date time that include that date and time, and also has the highest priority among the enabled versions. In this case, only version number 4 meets these criteria, as it has a start date time of 2/1
/2020 12:00 AM, an end date time of 4/1/2020 12:00 AM, a priority of 1, and is enabled. The other versions either have a different start or end date time, a lower priority, or are not enabled.
NEW QUESTION # 17
A developer needs to use the COUNTIF function to process data entered by the user in an OmniScript.
The output of the function needs to be displayed to the user immediately in the current step.
Based on best practice, which element should the developer use this function in?
- A. Range element
- B. Set Values element
- C. Formula element
In OmniScripts, if you need to apply a function (like COUNTIF) to dynamic data and show the result immediately, the Formula element is the correct choice.
* B. Formula element - The Formula element supports real-time calculation using OmniStudio expression functions (like COUNTIF, SUM, etc.) and updates values instantly on the screen without the need for server calls.
Incorrect Options:
* A. Set Values element is used to set static or conditional values but doesn't support formula evaluation.
* C. Range element is used for value comparisons and conditions, not for calculations.
Salesforce OmniStudio Developer Guide # OmniScript Formula Element
NEW QUESTION # 18
A developer needs to transform contact data into a JSON array.
Given the input JSON shown above, what are two ways a developer could configure a DATA Raptor transform to achieve the expected Output JSON? Choose 2 answers
- A. Set the Input JSON path as List(Contact) and the Output JSON Path as Contact.
- B. Use a formula LIST(Contact), and add the output of the formula as the input in the Transform tab.
- C. Set the Input JSON Path as Contact the out JSON Path as Contact and the output Data type as List.
- D. Set the input JSON Path as Contact and the OutPut JSON Path as List (Contact)
A DataRaptor Transform can be used to transform data from one format to another, such as JSON, XML, or CSV. The developer can specify the input and output paths for each field in the Transform tab. The developer can also use formulas to manipulate data in the Formula tab1. To transform contact data into a JSON array, the developer can use either of these methods:
* Use a formula LIST(Contact), and add the output of the formula as the input in the Transform tab. This will create a list of contact objects from the input JSON and output it as a JSON array.
* Set the Input JSON Path as Contact, the Output JSON Path as Contact, and the Output Data Type as List. This will output each contact object as an element of a JSON array.
NEW QUESTION # 19
Which JSON from the DRGetAccountDetails action would display all six values correctly in the Omniscript structure shown?
BlkContacts is a Repeat Block.
- A. Option C
- B. Option A
- C. Option D
- D. Option B
From the OmniStudio OmniScript Documentation:
* A Repeat Block (like BlkContacts) expects an array of objects.
* Each item in the array must contain fields that exactly match the UI elements inside the block.
* The parent JSON must include any top-level values used by individual input fields (like AccountName, AccountPhone).
Why the Other Options Are Incorrect:
* B. Uses Contacts instead of BlkContacts, and is incomplete/malformed.
* C. Repeats keys at the same level instead of using an array structure. This causes the data to overwrite and fail to display properly.
* D. Uses incorrect keys like "Name" and " hone" instead of expected "ContactName" and
"ContactPhone", breaking field binding.
Salesforce OmniStudio Developer Guide # OmniScript Repeat Blocks & Data JSON Structure DataRaptor Extract Output # Mapping JSON for OmniScripts
NEW QUESTION # 20
Our Plat-Dev-210 learning guide allows you to study anytime, anywhere. If you are concerned that your study time cannot be guaranteed, then our Plat-Dev-210 learning guide is your best choice because it allows you to learn from time to time and make full use of all the time available for learning. Our Plat-Dev-210 learning guide is for the world and users are very extensive. In order to give users a better experience, we have been constantly improving. The high quality and efficiency of Plat-Dev-210 Test Guide has been recognized by users. The high passing rate of Plat-Dev-210 exam training is its biggest feature. As long as you use Plat-Dev-210 test guide, you can certainly harvest what you want thing.
Free Sample Plat-Dev-210 Questions: https://www.vce4plus.com/Salesforce/Plat-Dev-210-valid-vce-dumps.html
- Plat-Dev-210 Training Pdf 😁 Plat-Dev-210 Valid Study Guide ⛺ Plat-Dev-210 Exam Dumps Collection 🐼 Easily obtain free download of ➠ Plat-Dev-210 🠰 by searching on ▷ [url]www.dumpsmaterials.com ◁ 🤛Training Plat-Dev-210 Online[/url]
- Learning Plat-Dev-210 Materials 🆓 Plat-Dev-210 Valid Study Guide 🧸 Plat-Dev-210 New Braindumps Ebook 🧶 Easily obtain free download of ☀ Plat-Dev-210 ️☀️ by searching on [url]www.pdfvce.com 😕
lat-Dev-210 New Braindumps Ebook[/url] - Updated Salesforce Valid Dumps Plat-Dev-210 Free With Interarctive Test Engine - Trustable Free Sample Plat-Dev-210 Questions 📬 Search for Plat-Dev-210 and download it for free immediately on ➤ [url]www.prepawaypdf.com ⮘ 🐳Reliable Plat-Dev-210 Test Preparation[/url]
- Latest Plat-Dev-210 Exam Cram 💈 Training Plat-Dev-210 Online 💹 Interactive Plat-Dev-210 EBook 📩 Simply search for ➥ Plat-Dev-210 🡄 for free download on ➽ [url]www.pdfvce.com 🢪 🍚Reliable Plat-Dev-210 Braindumps Questions[/url]
- New Plat-Dev-210 Test Braindumps 🤖 Free Plat-Dev-210 Exam 🤾 Real Plat-Dev-210 Exam Dumps 📥 Open [url]www.troytecdumps.com enter Plat-Dev-210 and obtain a free download 👛
lat-Dev-210 Reliable Test Sample[/url] - Reliable Plat-Dev-210 Test Preparation 🕣 Valid Plat-Dev-210 Exam Voucher 🤴 Valid Plat-Dev-210 Exam Voucher 🗯 Download ✔ Plat-Dev-210 ️✔️ for free by simply searching on ▛ [url]www.pdfvce.com ▟ 🐠Learning Plat-Dev-210 Materials[/url]
- Plat-Dev-210 Exam Dumps Collection 👦 Interactive Plat-Dev-210 EBook 👉 Learning Plat-Dev-210 Materials 🪁 Search for [ Plat-Dev-210 ] on ▛ [url]www.examcollectionpass.com ▟ immediately to obtain a free download 🚓
lat-Dev-210 Training Pdf[/url] - Plat-Dev-210 New Braindumps Ebook 📐 Free Plat-Dev-210 Exam 🕔 Valid Exam Plat-Dev-210 Practice 🌜 Immediately open { [url]www.pdfvce.com } and search for ⏩ Plat-Dev-210 ⏪ to obtain a free download 🥨Valid Plat-Dev-210 Exam Voucher[/url]
- Reliable Plat-Dev-210 Braindumps Questions 😪 Free Plat-Dev-210 Exam 🛤 Plat-Dev-210 New Braindumps Ebook 🔭 Easily obtain free download of [ Plat-Dev-210 ] by searching on [url]www.vceengine.com 🟠Learning Plat-Dev-210 Materials[/url]
- Plat-Dev-210 Reliable Test Sample 🍇 New Plat-Dev-210 Test Braindumps 🅱 Plat-Dev-210 Flexible Learning Mode 🤲 Open [url]www.pdfvce.com and search for ✔ Plat-Dev-210 ️✔️ to download exam materials for free 😸Training Plat-Dev-210 Online[/url]
- What Makes Salesforce Plat-Dev-210 Exam Dumps Different? 📇 Open ➽ [url]www.vceengine.com 🢪 and search for [ Plat-Dev-210 ] to download exam materials for free 🟫Real Plat-Dev-210 Exam Dumps[/url]
- www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.notebook.ai, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, writeablog.net, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, Disposable vapes
