JN0-637 Exam Quiz - Certification JN0-637 Cost
Posted at 6 day before
2026 Latest ITexamReview JN0-637 PDF Dumps and JN0-637 Exam Engine Free Share: https://drive.google.com/open?id=1aDFAIHGRYcjuczhUAzK0cLyV9sX8JhPe
A lot of students have used our product and prepared successfully for the test. Every user has rated study material positively and passed the JN0-637 Exam. ITexamReview gives a guarantee to the customers that if they fail to pass the Security, Professional (JNCIP-SEC) (JN0-637) certification on the very first try despite all their efforts they can claim their money back according to terms and conditions. A team of experts is working day and night in order to make the product successful day by day and provide the customers with the best experience.
Juniper JN0-637 Exam Syllabus Topics:| Topic | Details | | Topic 1 | - Advanced IPsec VPNs: Focusing on networking professionals, this part covers advanced IPsec VPN concepts and requires candidates to demonstrate their skills in real-world applications.
| | Topic 2 | - Advanced Policy-Based Routing (APBR): This topic emphasizes on advanced policy-based routing concepts and practical configuration or monitoring tasks.
| | Topic 3 | - Layer 2 Security: It covers Layer 2 Security concepts and requires candidates to configure or monitor related scenarios.
| | Topic 4 | - Troubleshooting Security Policies and Security Zones: This topic assesses the skills of networking professionals in troubleshooting and monitoring security policies and zones using tools like logging and tracing.
Exact Inside JN0-637 Exam Quiz Questions and AnswersThe paper materials students buy on the market are often not able to reuse. After all the exercises have been done once, if you want to do it again you will need to buy it again. But with JN0-637 test question, you will not have this problem. All customers who purchased JN0-637 Study Tool can use the learning materials without restrictions, and there is no case of duplicate charges. For the PDF version of JN0-637 test question, you can print multiple times, practice multiple times, and repeatedly reinforce your unfamiliar knowledge.
Juniper Security, Professional (JNCIP-SEC) Sample Questions (Q101-Q106):NEW QUESTION # 101
Exhibit
Referring to the exhibit, an internal host is sending traffic to an Internet host using the 203.0.113.1 reflexive address with source port 54311.
Which statement is correct in this situation?
- A. Any host on the Internet can initiate traffic to reach the internal host using the 203.0.113.1 address, source port 54311, and a random destination port.
- B. Only the Internet host that the internal host originally communicated with can initiate traffic to reach the internal host using the 203.0.113.1 address, source port 54311, and a random destination port.
- C. Only the Internet host that the internal host originally communicated with can initiate traffic to reach the internal host using the 203.0 113.1 address, a random source port, and destination port 54311.
- D. Any host on the Internet can initiate traffic to reach the internal host using the 203.0.113.1 address, a random source port, and destination port54311.
NEW QUESTION # 102
Which two modes are supported on Juniper ATP Cloud? (Choose two.)
- A. global mode
- B. private mode
- C. Layer 3 mode
- D. transparent mode
NEW QUESTION # 103
Refer to the exhibit,
which two potential violations will generate alarm ? (Choose Two)
- A. the number of policy violation by a destination TCP port
- B. the number of policy violation to an application within a specified period
- C. the ratio of policy violation traffic compared to accepted traffic.
- D. the number of policy violations by a source network identifier
The exhibit shows a security policy configuration with a threshold of 1000 policy violations by a source network identifier and a threshold of 10 policy violations to an application within a specified period. If either of these thresholds are exceeded, an alarm will be generated. Therefore, the correct answer is A and D. The other options are incorrect because:
B) The ratio of policy violation traffic compared to accepted traffic is not a criterion for triggering an alarm.
The security policy configuration does not specify any ratio or percentage of policy violation traffic that would cause an alarm.
C) The number of policy violation by a destination TCP port is also not a criterion for triggering an alarm.
The security policy configuration does not specify any threshold or duration for policy violation by a destination TCP port.
Reference: policy (Security Alarms)
Monitoring Security Policy Violations
NEW QUESTION # 104
Exhibit:
Referring to the exhibit, which two statements are correct? (Choose two.)
- A. The device cannot pass Layer 2 and Layer 3 traffic at the same time.
- B. The device can pass Layer 2 and Layer 3 traffic at the same time.
- C. You can secure inter-VLAN traffic with a security policy on this device.
- D. You cannot secure intra-VLAN traffic with a security policy on this device.
The exhibit provides information about an SRX Series device operating in transparent mode (Layer 2) and Layer 3 routing at the same time.
The SRX device can secure inter-VLAN traffic because it supports security policies for Layer 3 traffic between different VLANs. In this case, traffic moving between different VLANs (i.e., Layer 3 traffic) can be processed and controlled using security policies.
The SRX device can handle both Layer 2 and Layer 3 traffic simultaneously. In mixed mode, the device is capable of switching traffic at Layer 2 (intra-VLAN) while also routing traffic at Layer 3 (inter-VLAN). This is evident from the global configuration showing transparent bridge mode and Layer 3 interfaces.
NEW QUESTION # 105
You must setup a Ddos solution for your ISP. The solution must be agile and not block legitimate traffic.
Which two products will accomplish this task? (Choose two.)
- A. Corero Smartwall TDD
- B. SRX Series device
- C. Contrail Insights
- D. MX Series device
You must set up a DDoS solution for your ISP. The solution must be agile and not block legitimate traffic.
The two products that will accomplish this task are:
B) MX Series device. MX Series devices are high-performance routers that can provide DDoS protection at the network edge by integrating with Corero SmartWall Threat Defense Director (TDD) software. MX Series devices can leverage the packet processing capabilities of the MX-SPC3 Services Card to perform real-time DDoS detection and mitigation at line rate, scaling from 50 Gbps to 40 Tbps. MX Series devices can also use Juniper Networks Security Intelligence (SecIntel) to receive threat intelligence feeds from Juniper ATP Cloud or Juniper Threat Labs and apply them to the security policies.
MX Series devices can provide an agile and effective DDoS solution for your ISP without blocking legitimate traffic12.
C) Corero SmartWall TDD. Corero SmartWall TDD is a software solution that runs on MX Series devices and PTX Series devices to provide DDoS protection at the network edge. Corero SmartWall TDD uses behavioral analytics and detailed network visibility to detect and block DDoS attacks in seconds, without affecting the normal traffic. Corero SmartWall TDD can also provide advanced protection from "carpet bombing" attacks, 5G DDoS visibility, and multi-tenant portal for as-a-service offerings or views by department within an enterprise. Corero SmartWall TDD can provide an agile and effective DDoS solution for your ISP without blocking legitimate traffic34.
A) Contrail Insights. Contrail Insights is a software solution that provides network analytics and visibility for cloud and data center environments. Contrail Insights can help you monitor, troubleshoot, and optimize the performance and security of your network, but it does not provide DDoS protection by itself.
Contrail Insights can integrate with other Juniper products, such as Contrail Enterprise Multicloud, Contrail Service Orchestration, and AppFormix, to provide a comprehensive network management solution, but it is not a DDoS solution for your ISP5.
D) SRX Series device. SRX Series devices are high-performance firewalls that can provide DDoS protection at the network perimeter by integrating with Juniper ATP Cloud and Juniper Threat Labs. SRX Series devices can use SecIntel to receive threat intelligence feeds from Juniper ATP Cloud or Juniper Threat Labs and apply them to the security policies. SRX Series devices can also use IDP to detect and prevent application-level attacks, such as SQL injection, cross-site scripting, and buffer overflow. SRX Series devices can provide a robust and effective DDoS solution for your network, but they are not designed to handle high-volume DDoS attacks at the network edge, as MX Series devices and Corero SmartWall TDD are.
Reference: Juniper and Corero Joint DDoS Protection Solution MX-SPC3 Services Card Overview Corero SmartWall Threat Defense Director (TDD) Juniper Networks and Corero: A Modern Approach to DDoS Protection at Scale Contrail Insights Overview
[SRX Series Services Gateways]
[Juniper Networks Security Intelligence (SecIntel)]
NEW QUESTION # 106
To make your success a certainty, ITexamReview offers free updates on our Juniper JN0-637 real dumps for up to three months. It means all users get the latest and updated Juniper JN0-637 practice material to clear the Security, Professional (JNCIP-SEC) JN0-637 certification test on the first try. We are a genuine brand working to smoothen up your JN0-637 exam preparation. ITexamReview allows all visitors to try a free demo of JN0-637 pdf questions and practice tests to assess the quality of our JN0-637 Study Material. Your money is 100% secure as we will ensure that you crack the Juniper JN0-637 test on the first attempt. You will also enjoy 24/7 efficient support from our customer support team before and after the purchase of Juniper JN0-637 exam dumps. If you face any issues while using our JN0-637 PDF dumps or JN0-637 practice exam software (desktop and web-based), contact ITexamReview customer service for guidance.
Certification JN0-637 Cost: https://www.itexamreview.com/JN0-637-exam-dumps.html
- JN0-637 latest study torrent - JN0-637 practice download pdf 📊 Immediately open ➤ [url]www.exam4labs.com ⮘ and search for 「 JN0-637 」 to obtain a free download 🕷JN0-637 Learning Materials[/url]
- Security, Professional (JNCIP-SEC) latest study material - JN0-637 valid vce exam - Security, Professional (JNCIP-SEC) pdf vce demo 🍴 Search for ➡ JN0-637 ️⬅️ on ➥ [url]www.pdfvce.com 🡄 immediately to obtain a free download 🤥Reliable JN0-637 Exam Test[/url]
- JN0-637 latest study torrent - JN0-637 practice download pdf 📌 Search for [ JN0-637 ] and obtain a free download on “ [url]www.practicevce.com ” 🍭High JN0-637 Passing Score[/url]
- Valid JN0-637 Vce Dumps 〰 Valid JN0-637 Vce Dumps 💌 Reliable JN0-637 Exam Test 🐼 Download “ JN0-637 ” for free by simply searching on ( [url]www.pdfvce.com ) 🔄JN0-637 Test Cram Review[/url]
- JN0-637 Valid Test Labs 🍭 JN0-637 Free Dump Download 🤗 Valid JN0-637 Exam Guide 🚧 Download ➥ JN0-637 🡄 for free by simply searching on ▶ [url]www.prep4sures.top ◀ ♣JN0-637 Free Dump Download[/url]
- JN0-637 Pass4sure vce - JN0-637 Updated Training - JN0-637 prep practice 📉 Open ⮆ [url]www.pdfvce.com ⮄ enter ➽ JN0-637 🢪 and obtain a free download 🔀JN0-637 Actual Exams[/url]
- JN0-637 Reliable Exam Book 👒 JN0-637 Valid Test Labs 💷 Reliable JN0-637 Exam Test 🤛 Search on ⇛ [url]www.pdfdumps.com ⇚ for ▷ JN0-637 ◁ to obtain exam materials for free download 🙈Valid JN0-637 Vce Dumps[/url]
- Get an Edge in Your Exam Preparation with Online Juniper JN0-637 Practice Test Engine Crafted by Experts 🏦 Easily obtain free download of ▷ JN0-637 ◁ by searching on ➠ [url]www.pdfvce.com 🠰 ⭐High JN0-637 Passing Score[/url]
- JN0-637 latest study torrent - JN0-637 practice download pdf ⚓ Easily obtain ➡ JN0-637 ️⬅️ for free download through ▷ [url]www.torrentvce.com ◁ ⛪JN0-637 Test Cram Review[/url]
- JN0-637 Exam Exam Quiz - Valid Certification JN0-637 Cost Pass Success 💘 ⮆ [url]www.pdfvce.com ⮄ is best website to obtain { JN0-637 } for free download 🟫Valid JN0-637 Vce Dumps[/url]
- JN0-637 Pass4sure Study Materials 💯 JN0-637 Pass4sure Study Materials 👄 JN0-637 Trustworthy Source 🍷 Search for ( JN0-637 ) on ▷ [url]www.testkingpass.com ◁ immediately to obtain a free download 🪀JN0-637 Free Learning Cram[/url]
- camp-fire.jp, hhi.instructure.com, www.dibiz.com, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, dl.instructure.com, Disposable vapes
BTW, DOWNLOAD part of ITexamReview JN0-637 dumps from Cloud Storage: https://drive.google.com/open?id=1aDFAIHGRYcjuczhUAzK0cLyV9sX8JhPe
