AP-202 Dumps Discount - Test AP-202 Dates
Posted at 2/4/2026 14:25:31
Maybe you have desired the AP-202 certification for a long time but don't have time or good methods to study. Maybe you always thought study was too boring for you. Our AP-202 study materials will change your mind. With our AP-202 exam questions, you will soon feel the happiness of study. Just look at the three different versions of our AP-202 learning quiz: the PDF, Software and APP online which can apply to study not only on the paper, but also can apply to study on IPAD, phone or laptop.
The AP-202 Exam Questions is of the highest quality, and it enables participants to pass the AP-202 exam on their first try. For successful preparation, it is essential to have good AP-202 exam dumps and to prepare questions that may come up in the exam. ValidBraindumps helps candidates overcome all the difficulties they may encounter in their exam preparation. To ensure the candidates' satisfaction, ValidBraindumps has a support team that is available 24/7 to assist with a wide range of issues.
Salesforce AP-202 Exam | AP-202 Dumps Discount - 365 Days Free Updates of Test AP-202 DatesAll these AP-202 exam questions formats contain the real B2B Commerce for Developers Accredited Professional (AP-202) exam practice test questions that assist you in preparation and you will feel condiment to pass the final Salesforce AP-202 exam easily. The Salesforce AP-202 desktop practice test software and web-based practice test software, both are the mock B2B Commerce for Developers Accredited Professional (AP-202) exam that provides you real-time AP-202 exam environment for quick and complete preparation.
Salesforce B2B Commerce for Developers Accredited Professional Sample Questions (Q213-Q218):NEW QUESTION # 213
What does a developer need to do to modify the out-of-the-box checkout flow template?
- A. Modify directly and save to activate
- B. Clone, modify and rename to Checkout Flow
- C. Clone, modify, activate and refer in Experience Builder
- D. Create each flow from scratch
To modify the out-of-the-box checkout flow template in Salesforce B2B Commerce, a developer should clone the existing template, make the necessary modifications, activate the modified template, and then reference it in the Experience Builder. This approach ensures that the original template remains intact and provides a fallback option. Salesforce documentation on customizing the checkout flow in B2B Commerce emphasizes the importance of using the Experience Builder for such customizations, providing a visual interface to manage and reference different checkout flow templates.
NEW QUESTION # 214
A developer is building a custom component in Lightning web components (LWC) that needs to fetch data from an API.
Which lifecycle hook should the developer use to make the API call?
- A. errorCallback
- B. renderedCallback
- C. disconnectedCallback
- D. connectedCallback
To make an API call in a Lightning web component (LWC), a developer should use the connectedCallback lifecycle hook. The connectedCallback lifecycle hook is invoked when the component is inserted into the DOM. This is the ideal time to make an API call, as the component is ready to receive and display data. The developer can use the fetch API or a third-party library, such as axios, to make the API call and handle the response. The renderedCallback lifecycle hook is not a good choice for making an API call, as it is invoked every time the component is rendered or rerendered. This can cause unnecessary or repeated API calls and affect performance. The errorCallback lifecycle hook is not a good choice either, as it is invoked when an error occurs in the component or in one of its children. This is not related to making an API call, but rather to handling errors. The disconnectedCallback lifecycle hook is not a good choice either, as it is invoked when the component is removed from the DOM. This is not a suitable time to make an API call, as the component is no longer visible or active. Salesforce Lightning Web Components Developer Guide: Lifecycle Hooks,Lightning Web Components Developer Guide: Call an Apex Method Imperatively
NEW QUESTION # 215
What are two ways a developer should ensure that a store verifies changes by using an external service?
- A. Create an Apex class implementing the sfdc_checkout.CartShippingCharges interface to retrieve shipping charges from an external service and register it as the .. calculation integration in the store administration.
- B. Create an Apex class to retrieve shipping charges from an external service and update the Cart Delivery Group Method.
- C. Create a flow using an action to retrieve shipping charges from an external service and update the Cart Delivery Group Methods.
- D. Create a trigger to retrieve shipping charges from an external service and update the Cart Delivery, Group Methods
To verify changes by using an external service, a developer can use either of these two ways:
Create an Apex class that implements the sfdc_checkout.CartShippingCharges interface and defines the getShippingCharges method. This method takes a Cart object as an input parameter and returns a list of CartDeliveryGroupMethod objects with the updated shipping charges. The developer then needs to register the Apex class as the Shipping Calculation Integration in the store administration. This way, the store can call the external service to calculate the shipping charges for each delivery group in the cart.
Create an Apex class that defines a method to retrieve the shipping charges from an external service and update the Cart Delivery Group Method object. The developer then needs to invoke this method from a trigger on the Cart Delivery Group Method object. This way, the store can update the shipping charges whenever the delivery group method is inserted or updated.
The other options are not valid ways to verify changes by using an external service. Creating a flow using an action is not supported for B2B Commerce, and creating a trigger on the Cart Delivery Group object will not update the shipping charges for each delivery group method.Reference:
Integrate with External Services
CartShippingCharges Interface
CartDeliveryGroupMethod Object
NEW QUESTION # 216
Which two guidelines should a developer consider when migrating aura components to LWC?
- A. Start with simple components that only render Ul
- B. Migrate one component and then determine whether additional effort would make sense
- C. Force all developers to write any new components using Lightning web components
- D. Start with migrating trees of components (components within components)
When migrating aura components to LWC, a developer should consider two guidelines: migrate one component and then determine whether additional effort would make sense and start with simple components that only render UI. Migrating one component and then determining whether additional effort would make sense allows the developer to evaluate the benefits and costs of migration and decide whether to continue or stop. Migrating simple components that only render UI allows the developer to leverage the performance and modern features of LWC without much complexity or dependency on other components or services. Starting with migrating trees of components (components within components) is not a good guideline, as it can introduce more challenges and dependencies that can complicate the migration process. Forcing all developers to write any new components using Lightning web components is not a good guideline either, as it can create inconsistency and confusion among developers and users. Salesforce [Lightning Web Components Developer Guide: Migrate Aura Components to Lightning Web Components], [Lightning Web Components Developer Guide: Migration Considerations]
NEW QUESTION # 217
In a B2B Commerce store, which three tasks must a developer complete to implement the use of a third-party service for either tax, shipping, or pricing calculation?
- A. Create an Apex class implementing the appropriate interface.
- B. Create a flow to call the external service directly
- C. Register an Apex class as the integration in the store administration
- D. Create an Apex class with an invocable method
- E. Create a named credential for authentication with an external service
Answer: A,C,E
To implement the use of a third-party service for either tax, shipping, or pricing calculation in a B2B Commerce store, a developer must complete these three tasks:
Create an Apex class that implements the appropriate interface for the calculation type. For example, for tax calculation, the developer must implement the sfdc_checkout.CartTax interface and define the getTax method. This method takes a Cart object as an input parameter and returns a list of CartTax objects with the calculated tax amounts.
Create a named credential for authentication with the external service. A named credential specifies the URL of a callout endpoint and its required authentication parameters. The developer can use the named credential in the Apex class to make the callout to the external service and handle the response.
Register the Apex class as the integration in the store administration. The developer must specify the Apex class name in the corresponding field for the calculation type. For example, for tax calculation, the developer must enter the Apex class name in the Tax Calculation Integration field. This way, the store can invoke the Apex class to perform the calculation for each cart.
The other options are not valid tasks for implementing the use of a third-party service. Creating a flow to call the external service directly is not supported for B2B Commerce, and creating an Apex class with an invocable method is not required for the calculation integration.Reference:
CartTax Interface
Named Credentials
[Store Administration]
NEW QUESTION # 218
Our company employs a professional service team which traces and records the popular trend among the industry and the latest update of the knowledge about the AP-202 exam reference. We give priority to keeping pace with the times and providing the advanced views to the clients. We keep a close watch at the most advanced social views about the knowledge of the test AP-202 Certification. Our experts will renovate the test bank with the latest AP-202 exam practice question and compile the latest knowledge and information into the questions and answers.
Test AP-202 Dates: https://www.validbraindumps.com/AP-202-exam-prep.html
Make sure that you are using all of our AP-202 Test Engine questions and complete go through of our AP-202 cheat sheet multiple times to ensure your success in the final B2B Commerce for Developers Accredited Professional test questions, We have been specializing AP-202 exam dumps many years and have a great deal of long-term old clients, and we would like to be a reliable cooperator on your learning path and in your further development, The AP-202 PDF is a printable format and is extremely portable.
Kent Beck, author of Extreme Programming Explained: Embrace Change, AP-202 drag them from the Finder directly into the window, or use the Add and Remove buttons to edit the list of data sources.
Make sure that you are using all of our AP-202 Test Engine questions and complete go through of our AP-202 cheat sheet multiple times to ensure your success in the final B2B Commerce for Developers Accredited Professional test questions.
AP-202 Practice Test - AP-202 Training Torrent: B2B Commerce for Developers Accredited Professional - AP-202 Study GuideWe have been specializing AP-202 exam dumps many years and have a great deal of long-term old clients, and we would like to be a reliable cooperator on your learning path and in your further development.
The AP-202 PDF is a printable format and is extremely portable, You can also set the number of Salesforce AP-202 dumps questions to attempt in the practice test and time as well.
Probably you've never imagined that preparing for your upcoming AP-202 exam could be so easy.
- Free PDF 2026 Authoritative Salesforce AP-202: B2B Commerce for Developers Accredited Professional Dumps Discount 📠 Immediately open 「 [url]www.vce4dumps.com 」 and search for 「 AP-202 」 to obtain a free download 🌷AP-202 Latest Dumps Ebook[/url]
- AP-202 Reliable Braindumps Files 🤩 AP-202 Valid Dump 🧧 AP-202 Exam Objectives 🍞 Search for ▶ AP-202 ◀ and download exam materials for free through “ [url]www.pdfvce.com ” 🍳AP-202 Exam Forum[/url]
- AP-202 Reliable Braindumps Files 🍁 AP-202 Exam Forum 💘 Valid Braindumps AP-202 Questions 🎿 Copy URL ( [url]www.dumpsquestion.com ) open and search for ▶ AP-202 ◀ to download for free 🎓AP-202 Valid Exam Book[/url]
- Three High in Demand Salesforce AP-202 Exam Questions Formats 🧹 Search for ➤ AP-202 ⮘ and download it for free on ( [url]www.pdfvce.com ) website 🌱AP-202 Valid Exam Vce Free[/url]
- AP-202 Valid Test Topics 👐 Valuable AP-202 Feedback 👺 New AP-202 Test Bootcamp ↪ Go to website 《 [url]www.pdfdumps.com 》 open and search for ▶ AP-202 ◀ to download for free 🥍AP-202 Valid Exam Book[/url]
- Free PDF 2026 Authoritative Salesforce AP-202: B2B Commerce for Developers Accredited Professional Dumps Discount 🟦 Immediately open ⏩ [url]www.pdfvce.com ⏪ and search for ⇛ AP-202 ⇚ to obtain a free download 🎯New AP-202 Test Bootcamp[/url]
- AP-202 Valid Test Topics 🦎 AP-202 Real Dumps Free 🔎 AP-202 Valid Exam Vce Free 🤤 Search on ▷ [url]www.verifieddumps.com ◁ for ▶ AP-202 ◀ to obtain exam materials for free download 💠AP-202 Reliable Braindumps Files[/url]
- Valid Braindumps AP-202 Questions 🔈 AP-202 Valid Test Topics 📀 AP-202 Exam Forum 💘 Search for 【 AP-202 】 and download exam materials for free through ➥ [url]www.pdfvce.com 🡄 🎻Exam AP-202 Exercise[/url]
- AP-202 Latest Dumps Ebook 🌂 AP-202 Braindumps 🔀 AP-202 Valid Test Topics 🧆 Search for ✔ AP-202 ️✔️ and download it for free on ➠ [url]www.troytecdumps.com 🠰 website 🕧AP-202 Valid Exam Book[/url]
- Exam AP-202 Exercise 🔎 AP-202 Latest Dumps Ebook 🧚 AP-202 Braindumps 🤘 Copy URL ☀ [url]www.pdfvce.com ️☀️ open and search for 《 AP-202 》 to download for free 🎸AP-202 Braindumps Pdf[/url]
- New AP-202 Test Bootcamp 🥔 Valid Braindumps AP-202 Questions 🧣 AP-202 Reliable Braindumps Files 🔵 Open “ [url]www.validtorrent.com ” and search for 《 AP-202 》 to download exam materials for free 🦞AP-202 Valid Dump[/url]
- www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.notebook.ai, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, camp-fire.jp, Disposable vapes
