[General] PT-AM-CPE Practice Exams, Latest Edition Test Engine
94
【General】 PT-AM-CPE Practice Exams, Latest Edition Test Engine
Posted at 2/4/2026 14:32:53      View:149 | Replies:2        Print      Only Author   [Copy Link] 1#
The users can instantly access the product after purchasing it from Real4dumps, so they don't have to wait to prepare for the PT-AM-CPE Exams. The 24/7 support system is available for the customers, so they can contact the support whenever they face any issue, and it will provide them with the solution. Furthermore, Real4dumps offers up to 1 year of free updates and free demos of the product.
Our PT-AM-CPE learning guide are developed in three versions which are the PDF, Software and APP online versions. The PDF version of PT-AM-CPE training materials is convenient for you to print, the software version can provide practice test for you and the online version of our PT-AM-CPE Study Materials is for you to read anywhere at any time. If you are hesitating about which version should you choose, you can download our PT-AM-CPE free demo first to get a firsthand experience before you make any decision.
Exam PT-AM-CPE Quick Prep, Valid Dumps PT-AM-CPE QuestionsPing Identity PT-AM-CPE can ensure your success. So here comes Ping Identity, who provides you with the Ping Identity PT-AM-CPE exam dumps to get your dream Ping Identity PT-AM-CPE certification with no hassle. Ping Identity PT-AM-CPE Certification will add up to your excellence in your field and leave no space for any doubts in the mind of the hiring team.
Ping Identity Certified Professional - PingAM Exam Sample Questions (Q74-Q79):NEW QUESTION # 74
When making a request to the /oauth2/access_token endpoint using the JWT profile client authentication method, which parameter is used to provide the JWT value?
  • A. client_id
  • B. client_token_value
  • C. client_credentials
  • D. client_assertion
PingAM 8.0.2 supports advanced client authentication methods defined in the OpenID Connect and OAuth 2.0 specifications, including private_key_jwt and client_secret_jwt. These methods allow a client to authenticate without sending a static password/secret in the request. Instead, the client generates and signs a JSON Web Token (JWT).
According to the "OAuth 2.0 Client Authentication" and "JWT Profile for Client Authentication" (RFC 7523) documentation, when a client sends this JWT to the /oauth2/access_token endpoint, it must use the client_assertion parameter.
The request must also include the client_assertion_type parameter, which must be set to the constant value: urn:ietf:paramsauth:client-assertion-type:jwt-bearer.
Option A (client_credentials) is a grant type, not a parameter for providing a JWT.
Option B (client_token_value) is not a standard OAuth2 parameter name.
Option C (client_id) is often included in the request, but it is the identifier of the client, not the container for the cryptographic assertion itself.
When PingAM receives a request with a client_assertion, it extracts the JWT, verifies the signature using the client's public key (stored in the client's profile or retrieved via a JWKS URI), and validates the standard claims (iss, sub, aud, exp). This method is significantly more secure than simple secrets because it proves the client possesses the private key and limits the window for replay attacks through the token's expiration claim.
NEW QUESTION # 75
Which statement differentiates the ForgeOps Cloud Deployment Model (CDM) from the Cloud Developer Kit (CDK) deployment?
  • A. Fully integrated PingAM, PingIDM, and PingDS installations
  • B. Provides replicated directory services
  • C. Supports deployment with Google Kubernetes Engine (GKE), Amazon Elastic Kubernetes Service (EKS), or Azure Kubernetes Service (AKS) clusters
  • D. Deployment generates random secrets
In the Ping Identity ForgeOps methodology for version 8.0.2, there are two primary deployment patterns used in Kubernetes: the Cloud Developer Kit (CDK) and the Cloud Deployment Model (CDM).
CDK (Cloud Developer Kit): This is intended for development and demonstration purposes. It is a "minimized" version of the platform. Crucially, in the CDK, the PingDS (directory service) is typically deployed as a single instance. It lacks the redundancy and replication required for production, as the goal is to reduce resource consumption on a developer's machine or a small test cluster.
CDM (Cloud Deployment Model): This is the reference architecture for production-grade environments. The CDM is designed for high availability and scale. According to the "ForgeOps Documentation," the primary differentiator is that the CDM provides replicated directory services. In a CDM deployment, PingDS is deployed in a multi-instance, replicated state (using a Kubernetes StateFulSet) to ensure that if one DS pod fails, the session and configuration data remain available.
While both models support major cloud providers like GKE, EKS, and AKS (Option B), generate random secrets (Option A), and provide integrated AM/IDM/DS stacks (Option D), the presence of multi-node replication in the directory layer is the definitive technical boundary between the "Developer" kit and the "roduction" model.
NEW QUESTION # 76
Which is the correct simplified TLS handshake sequence needed to authenticate clients using a mutual TLS exchange?
  • A. 1. Client sends a request to a server to establish a secure connection
    2. The client sends its certificate to the server
    3. The server presents its certificate in a response to the client
    4. The client sends its session key to the server
    5. The mutually secure connection is established and the client is authenticated
  • B. 1. Client sends a request to a server to establish a secure connection
    2. The server requests the client certificate
    3. The client sends its certificate and the session key to the server
    4. The server sends its certificate to the client if the client certificate and key are valid
  • C. 1. Client sends a request to a server to establish a secure connection
    2. The server presents its certificate in a response to the client
    3. The client sends its certificate to the server
    4. The mutually secure connection is established and the client is authenticated
  • D. 1. Client sends a certificate in the request to a server to establish a secure connection
    2. The client sends its session key to the server
Mutual TLS (mTLS) is a security enhancement where both the client and the server provide X.509 certificates to prove their identities.9 In PingAM 8.0.2, mTLS is frequently used for secure "Machine-to-Machine" (M2M) communication, such as between an OAuth2 client and the token endpoint, or between AM and a Directory Server (PingDS).
According to the PingAM documentation on "Secure Network Communication" and "mTLS for OAuth2," the handshake sequence for mTLS follows these logical steps:
Client Hello: The client initiates the request to the server.10
Server Hello & Certificate: The server responds by presenting its own certificate (verifying the server's identity to the client).11 In an mTLS scenario, the server also includes a CertificateRequest message.12 Client Certificate & Key Exchange: The client validates the server's certificate. If valid, the client then sends its own Client Certificate to the server, along with the encrypted pre-master secret or key exchange data.
Verification and Establishment: The server validates the client's certificate against its truststore. If the certificate is trusted and the cryptographic signatures match, the mutually secure connection is established.
Option D represents the most accurate "simplified" sequence. Option A is incorrect because the server presents its certificate before the client sends its own certificate. Option B and C are incorrect because the server always responds to the initial "Client Hello" with its own identity (Server Certificate) before the client proceeds with identity submission. This "handshake" ensures that no data is transmitted until both parties have cryptographically verified each other.
NEW QUESTION # 77
To protect against cross-site request forgery attacks, a default PingAM installation requires that some requests, such as POST requests, include:
  • A. X-OpenAM-Password header
  • B. X-Requested-With or Accept-API-Version header
  • C. X-OpenAM-Username header
  • D. If-Match: _rev header
Cross-Site Request Forgery (CSRF) is an attack where a malicious site sends a request to PingAM using the victim's authenticated browser session. Because standard HTML forms and cross-site requests cannot easily set custom HTTP headers, requiring a specific header is an effective defense for REST APIs.
According to the PingAM "Security" documentation and the "REST API" reference:
By default, PingAM 8.0.2 enforces a CSRF filter on its REST endpoints (such as /json/authenticate or /json/users). For any "state-changing" request (like a POST, PUT, or DELETE), the client must prove the request is intentional and not a forged browser-driven request. This is achieved by requiring at least one of the following headers:
X-Requested-With: Commonly used by AJAX libraries like jQuery. Its presence indicates the request was made via a script, which is generally not possible for a standard cross-site CSRF attack.
Accept-API-Version: This header serves two purposes. First, it ensures the client is targeting a specific version of the PingAM REST API (e.g., resource=2.0, protocol=1.0). Second, since custom headers cannot be set in simple cross-site <form> submissions, it acts as a CSRF token.
If a POST request is sent to the REST API without one of these headers, PingAM will reject the request with a 403 Forbidden error, even if the user has a valid session cookie.
Option B (If-Match: _rev) is used for concurrency control (preventing "lost updates" in IDM or AM configuration), but it is not the primary CSRF defense. Options A and D are headers sometimes used for "Zero-Page Login" or legacy authentication, but they do not provide protection against CSRF for the general REST API. Therefore, the combination of X-Requested-With or Accept-API-Version is the correct answer for default CSRF protection in PingAM 8.0.2.
NEW QUESTION # 78
Which of the following would be a possible combination of fields in the JSON body when making a policy evaluation via REST?
  • A. subject, application, advices
  • B. resources, application, advices
  • C. resources, subject, application
  • D. resources, subject, advices
In PingAM 8.0.2, requesting policy decisions via the REST API involves sending a POST request to the policies endpoint with the _action=evaluate parameter. To receive an accurate decision, the request body must provide the context of the access attempt.
According to the "Request policy decisions over REST" documentation, the JSON body typically includes the following core fields:
resources: (Required) An array of strings representing the URIs the user is attempting to access.
application: (Required) This field specifies the name of the Policy Set (formerly known as the application) that contains the relevant policies for the evaluation.
subject: (Optional, but usually required for user-specific policies) This object identifies the user or entity requesting access. It can include the user's ssoToken or a set of claims if using JWT-based subjects.
Why other options are incorrect: Advices (Options A and C) are not inputs for a policy evaluation request. Instead, advices are returned by PingAM in the response if a policy condition fails (e.g., an AuthLevelConditionAdvice requesting the user to provide MFA). A request cannot "evaluate" an advice; it triggers one. Option D is incorrect because the resources field is a mandatory requirement for any evaluation; without a target resource, the engine has nothing to compare against the defined policy rules. Therefore, the combination of resources, subject, and application represents the standard, valid structure for a policy decision request in PingAM 8.0.2.
NEW QUESTION # 79
The pass rate is 98.75% for PT-AM-CPE study materials, and if you choose us, we can ensure you pass the exam successfully. In addition, PT-AM-CPE exam dumps of us are edited by professional experts, they are quite familiar with the exam center, therefore PT-AM-CPE study materials cover most of knowledge points. We also pass guarantee and money back guarantee if you fail to pass the exam. We will refund your money to your payment account. Online service stuff for PT-AM-CPE Exam Braindumps is available, and if you have any questions, you can have a chat with us.
Exam PT-AM-CPE Quick Prep: https://www.real4dumps.com/PT-AM-CPE_examcollection.html
These formats are PT-AM-CPE desktop practice test software, PT-AM-CPE Certified Professional - PingAM Exam web-based practice exam, and Ping Identity PT-AM-CPE PDF dumps file, Ping Identity Exam PT-AM-CPE Quick Prep Exam PT-AM-CPE Quick Prep has great effect in this field, Our Ping Identity Certifications PT-AM-CPE valid braindumps can be your best and honest assistant which can help you achieve the certification with less time and less energy, Our IT experts check the updating of PT-AM-CPE exam questions everyday to ensure the high accuracy of our PT-AM-CPE exam pdf.
Page completes loading, If your system still PT-AM-CPE fails to start, it is likely that your bootloader is broken, These formats are PT-AM-CPE desktop practice test software, PT-AM-CPE Certified Professional - PingAM Exam web-based practice exam, and Ping Identity PT-AM-CPE PDF dumps file.
PT-AM-CPE Pass-for-Sure Materials - PT-AM-CPE Study Materials & PT-AM-CPE Exam TorrentPing Identity Ping Identity Certifications has great effect in this field, Our Ping Identity Certifications PT-AM-CPE valid braindumps can be your best and honest assistant which can help you achieve the certification with less time and less energy.
Our IT experts check the updating of PT-AM-CPE exam questions everyday to ensure the high accuracy of our PT-AM-CPE exam pdf, So you have no the necessity to worry that you don't have latest PT-AM-CPE exam torrent to practice.
Posted at 2/16/2026 02:48:29        Only Author  2#
Um der Anforderung des aktuellen realen Test gerecht zu werden, aktualisiert das Technik-Team von DeutschPrüfung rechtzeitig die Fragen und Antworten zur Amazon SCS-C03 Zertifizierungsprüfung. Wir akzeptieren immer Rückmeldungen von Benutzern und nehmen viele ihre Vorschläge an, was zu einer perfekten Schulungsmaterialien zur Amazon SCS-C03 Prüfung macht. Dies ermöglicht DeutschPrüfung, immer Produkte von bester Qualität zu besitzen.
Posted at 2/21/2026 03:34:06        Only Author  3#
I felt like I walked away from that article with so much more knowledge. Boost your IT skills and enjoy free Platform-App-Builder reliable source. Best of luck to you!
