[Hardware] How Can Nutanix NCM-MCI Exam Questions Assist You In Exam Preparation?
122
【Hardware】 How Can Nutanix NCM-MCI Exam Questions Assist You In Exam Preparation?
Posted at 2/4/2026 15:35:20      View:122 | Replies:0        Print      Only Author   [Copy Link] 1#
The development and progress of human civilization cannot be separated from the power of knowledge. You must learn practical knowledge to better adapt to the needs of social development. Now, our NCM-MCI learning materials can meet your requirements. You will have good command knowledge with the help of our study materials. The certificate is of great value in the job market. Our NCM-MCI Study Materials can exactly match your requirements and help you pass exams and obtain certificates. As you can see, our products are very popular in the market. Time and tides wait for no people.
Do you want to pass the Nutanix NCM-MCI Exam?The Nutanix NCM-MCI exam questions are available in different formats. You can either take Nutanix NCM-MCI practice test at a web based platform, or you can purchase for the Nutanix NCM-MCI practice test software. If you feel that you can learn better by training than you can go for the Nutanix NCM-MCI exam dumps. However, if you feel that practicing is the best mode of learning then you can go for the Nutanix NCM-MCI training tools.
It is to be noted that the Nutanix NCM-MCI exam objective may change anytime, and we highly recommend you to keep visiting this site on regular basis so that you do not miss any update.
Nutanix has always been known as one of the leading providers in information technology sector. The professionals who wish to make their career in IT industry must have to pass the Nutanix NCM-MCI exam questions because they are highly recognized by all IT companies.
How To Get Nutanix NCM-MCI ExamNutanix NCM-MCI exam questions are getting popular among students and professionals these days. Nutanix NCM-MCI exam is a tough subject, but if you have the right Nutanix NCM-MCI Exam Dumps, then you will pass it without any difficulties.
Despite the fact that there are many Nutanix NCM-MCI exam dumps available on the web, most of them don't provide the right kind of help that students need to prepare for their exams. Certification Questions offers its clients with top quality Nutanix NCM-MCI exam dumps so that they can pass their exams easily.
There are many other reasons why Certification Questions is considered one of the best online sources for Nutanix NCM-MCI exam questions. Some of them are:
The Nutanix NCM-MCI Dumps offered by Certification Questions comes with a 100 percent success rate.
What are the steps to follow for the registration of Microsoft Nutanix NCM-MCI Exam
  • Review the Exam Day Checklist.
  • Email npx@nutanix.com to request a unique invitation link to register for your exam.
  • Review the Exam Preparation Guide and Candidate Handbook.
  • Complete your exam at a mutually agreed upon time/date with your NCX/NPX Program Manager.
Get Special 30% EXTRA Discount on NCM-MCI Dumps By DumpStillValidWe are committed to using DumpStillValid Nutanix NCM-MCI Exam Training materials, we can ensure that you pass the exam on your first attempt. If you are ready to take the exam, and then use our DumpStillValid Nutanix NCM-MCI exam training materials, we guarantee that you can pass it. If you do not pass the exam, we can give you a refund of the full cost of the materials purchased, or free to send you another product of same value.
Nutanix Certified Master - Multicloud Infrastructure v6.10 Sample Questions (Q14-Q19):NEW QUESTION # 14
Task 10
An administrator is working to create a VM using Nutanix V3 API calls with the following specifications.
* VM specifications:
* vCPUs: 2
* Memory: BGb
* Disk Size: 50Gb
* Cluster: Cluster A
* Network: default- net
The API call is falling, indicating an issue with the payload:
The body is saved in Desktop/ Files/API_Create_VM,text
Correct any issues in the text file that would prevent from creating the VM. Also ensure the VM will be created as speeded and make sure it is saved for re-use using that filename.
Deploy the vm through the API
Note: Do not power on the VM.
See the Explanation for step by step solution
https://portal.nutanix.com/page/ ... =kA00e000000LLEzCAO
https://jsonformatter.curiousconcept.com/#
acli net.list (uuid network defult_net)
ncli cluster info (uuid cluster)
Put Call: https://Prism Central IP address : 9440/api/nutanix/v3vms
Edit these lines to fix the API call, do not add new lines or copy lines.
You can test using the Prism Element API explorer or PostMan
Body:
"spec": {
"name": "Test_Deploy",
"resources": {
"power_state":"OFF",
"num_vcpus_per_socket": ,
"num_sockets": 1,
"memory_size_mib": 8192,
"disk_list": [
"disk_size_mib": 51200,
"device_properties": {
"device_type":"DISK"
"device_type":"CDROM"
"nic_list":[
"nic_type": "NORMAL_NIC",
"is_connected": true,
"ip_endpoint_list": [
"ip_type": "DHCP"
"subnet_reference": {
"kind": "subnet",
"name": "default_net",
"uuid": "00000000-0000-0000-0000-000000000000"
"cluster_reference": {
"kind": "cluster",
"name": "NTNXDemo",
"api_version": "3.1.0",
"metadata": {
"kind": "vm"
https://www.nutanix.dev/2019/08/ ... t-api-post-request/ Reference
NEW QUESTION # 15
Task 8
Depending on the order you perform the exam items, the access information and credentials could change. Please refer to the other item performed on Cluster B if you have problems accessing the cluster.
The infosec team has requested that audit logs for API Requests and replication capabilities be enabled for all clusters for the top 4 severity levels and pushed to their syslog system using highest reliability possible. They have requested no other logs to be included.
Syslog configuration:
Syslog Name: Corp_syslog
Syslop IP: 34.69.43.123
Port: 514
Ensure the cluster is configured to meet these requirements.
To configure the cluster to meet the requirements of the infosec team, you need to do the following steps:
Log in to Prism Central and go to Network > Syslog Servers > Configure Syslog Server. Enter Corp_syslog as the Server Name, 34.69.43.123 as the IP Address, and 514 as the Port. Select TCP as the Transport Protocol and enable RELP (Reliable Logging Protocol). This will create a syslog server with the highest reliability possible.
Click Edit against Data Sources and select Cluster B as the cluster. Select API Requests and Replication as the data sources and set the log level to CRITICAL for both of them. This will enable audit logs for API requests and replication capabilities for the top 4 severity levels (EMERGENCY, ALERT, CRITICAL, and ERROR) and push them to the syslog server. Click Save.
Repeat step 2 for any other clusters that you want to configure with the same requirements.
To configure the Nutanix clusters to enable audit logs for API Requests and replication capabilities, and push them to the syslog system with the highest reliability possible, you can follow these steps:
Log in to the Nutanix Prism web console using your administrator credentials.
Navigate to the "Settings" section or the configuration settings interface within Prism.
Locate the "Syslog Configuration" or "Logging" option and click on it.
Configure the syslog settings as follows:
Syslog Name: Enter "Corp_syslog" as the name for the syslog configuration.
Syslog IP: Set the IP address to "34.69.43.123", which is the IP address of the syslog system.
Port: Set the port to "514", which is the default port for syslog.
Enable the option for highest reliability or persistent logging, if available. This ensures that logs are sent reliably and not lost in case of network interruptions.
Save the syslog configuration.
Enable Audit Logs for API Requests:
In the Nutanix Prism web console, navigate to the "Cluster" section or the cluster management interface.
Select the desired cluster where you want to enable audit logs.
Locate the "Audit Configuration" or "Security Configuration" option and click on it.
Look for the settings related to audit logs and API requests. Enable the audit logging feature and select the top 4 severity levels to be logged.
Save the audit configuration.
Enable Audit Logs for Replication Capabilities:
Look for the settings related to audit logs and replication capabilities. Enable the audit logging feature and select the top 4 severity levels to be logged.
After completing these steps, the Nutanix clusters will be configured to enable audit logs for API Requests and replication capabilities. The logs will be sent to the specified syslog system with the highest reliability possible.
ncli
<ncli> rsyslog-config set-status enable=false
<ncli> rsyslog-config add-server name=Corp_Syslog ip-address=34.69.43.123 port=514 network-protocol=tdp relp-enabled=false
<ncli> rsyslog-config add-module server-name= Corp_Syslog module-name=APLOS level=INFO
<ncli> rsyslog-config add-module server-name= Corp_Syslog module-name=CEREBRO level=INFO
<ncli> rsyslog-config set-status enable=true
https://portal.nutanix.com/page/ ... =kA00e0000009CEECA2
NEW QUESTION # 16
Task 5
An administrator has been informed that a new workload requires a logically segmented network to meet security requirements.
Network configuration:
VLAN: 667
Network: 192.168.0.0
Subnet Mask: 255.255.255.0
DNS server: 34.82.231.220
Default Gateway: 192.168.0.1
Domain: cyberdyne.net
IP Pool: 192.168.9.100-200
DHCP Server IP: 192.168.0.2
Configure the cluster to meet the requirements for the new workload if new objects are required, start the name with 667.
To configure the cluster to meet the requirements for the new workload, you need to do the following steps:
Create a new VLAN with ID 667 on the cluster. You can do this by logging in to Prism Element and going to Network Configuration > VLANs > Create VLAN. Enter 667 as the VLAN ID and a name for the VLAN, such as 667_VLAN.
Create a new network segment with the network details provided. You can do this by logging in to Prism Central and going to Network > Network Segments > Create Network Segment. Enter a name for the network segment, such as 667_Network_Segment, and select 667_VLAN as the VLAN. Enter 192.168.0.0 as the Network Address and 255.255.255.0 as the Subnet Mask. Enter 192.168.0.1 as the Default Gateway and 34.82.231.220 as the DNS Server. Enter cyberdyne.net as the Domain Name.
Create a new IP pool with the IP range provided. You can do this by logging in to Prism Central and going to Network > IP Pools > Create IP Pool. Enter a name for the IP pool, such as 667_IP_Pool, and select 667_Network_Segment as the Network Segment. Enter 192.168.9.100 as the Starting IP Address and 192.168.9.200 as the Ending IP Address.
Configure the DHCP server with the IP address provided. You can do this by logging in to Prism Central and going to Network > DHCP Servers > Create DHCP Server. Enter a name for the DHCP server, such as 667_DHCP_Server, and select 667_Network_Segment as the Network Segment. Enter 192.168.0.2 as the IP Address and select 667_IP_Pool as the IP Pool.
NEW QUESTION # 17
Task 7
An administrator has environment that will soon be upgraded to 6.5. In the meantime, they need to implement log and apply a security policy named Staging_Production, such that not VM in the Staging Environment can communicate with any VM in the production Environment, Configure the environment to satisfy this requirement.
Note: All other configurations not indicated must be left at their default values.
To configure the environment to satisfy the requirement of implementing a security policy named Staging_Production, such that no VM in the Staging Environment can communicate with any VM in the production Environment, you need to do the following steps:
Log in to Prism Central and go to Network > Security Policies > Create Security Policy. Enter Staging_Production as the name of the security policy and select Cluster A as the cluster.
In the Scope section, select VMs as the entity type and add the VMs that belong to the Staging Environment and the Production Environment as the entities. You can use tags or categories to filter the VMs based on their environment.
In the Rules section, create a new rule with the following settings:
Direction: Bidirectional
Protocol: Any
Source: Staging Environment
Destination: Production Environment
Action: Deny
Save the security policy and apply it to the cluster.
This will create a security policy that will block any traffic between the VMs in the Staging Environment and the VMs in the Production Environment. You can verify that the security policy is working by trying to ping or access any VM in the Production Environment from any VM in the Staging Environment, or vice vers a. You should not be able to do so.
NEW QUESTION # 18
Task 11
An administrator has noticed that after a host failure, the SQL03 VM was not powered back on from another host within the cluster. The Other SQL VMs (SQL01, SQL02) have recovered properly in the past.
Resolve the issue and configure the environment to ensure any single host failure affects a minimal number os SQL VMs.
Note: Do not power on any VMs
One possible reason why the SQL03 VM was not powered back on after a host failure is that the cluster was configured with the default (best effort) VM high availability mode, which does not guarantee the availability of VMs in case of insufficient resources on the remaining hosts. To resolve this issue, I suggest changing the VM high availability mode to guarantee (reserved segments), which reserves some memory on each host for failover of VMs from a failed host. This way, the SQL03 VM will have a higher chance of being restarted on another host in case of a host failure.
To change the VM high availability mode to guarantee (reserved segments), you can follow these steps:
Log in to Prism Central and select the cluster where the SQL VMs are running.
Click on the gear icon on the top right corner and select Cluster Settings.
Under Cluster Services, click on Virtual Machine High Availability.
Select Guarantee (Reserved Segments) from the drop-down menu and click Save.
To configure the environment to ensure any single host failure affects a minimal number of SQL VMs, I suggest using anti-affinity rules, which prevent VMs that belong to the same group from running on the same host. This way, if one host fails, only one SQL VM will be affected and the other SQL VMs will continue running on different hosts.
To create an anti-affinity rule for the SQL VMs, you can follow these steps:
Log in to Prism Central and click on Entities on the left menu.
Select Virtual Machines from the drop-down menu and click on Create Group.
Enter a name for the group, such as SQL Group, and click Next.
Select the SQL VMs (SQL01, SQL02, SQL03) from the list and click Next.
Select Anti-Affinity from the drop-down menu and click Next.
Review the group details and click Finish.
I hope this helps. How else can I help?
https://portal.nutanix.com/page/ ... ity-policies-c.html
NEW QUESTION # 19
DumpStillValid has assembled a brief yet concise study material that will aid you in acing the Nutanix Certified Master - Multicloud Infrastructure v6.10 (NCM-MCI) exam on the first attempt. This prep material has been compiled under the expert guidance of 90,000 experienced Nutanix professionals from around the globe. DumpStillValid offers the complete package that includes all exam questions conforming to the syllabus for passing the Nutanix Certified Master - Multicloud Infrastructure v6.10 (NCM-MCI) exam certificate in the first try.
Sure NCM-MCI Pass: https://www.dumpstillvalid.com/NCM-MCI-prep4sure-review.html
