¡¾General¡¿
Quiz Nutanix - NCP-US-6.5¨CThe Best Reliable Guide Files
Posted at 2/4/2026 16:11:04
View£º143
Replies£º1
What's more, part of that Exam4Docs NCP-US-6.5 dumps now are free: https://drive.google.com/open?id=1vnvQCeTVb62_6dh4QfJCJxjFTQCUAJOf
The Exam4Docs is one of the leading platforms that have been offering valid, updated, and real Channel Partner Program NCP-US-6.5 exam dumps for many years. The Channel Partner Program Nutanix Certified Professional - Unified Storage (NCP-US) v6.5 NCP-US-6.5 Practice Test questions offered by the Exam4Docs are designed and verified by experienced Nutanix Certified Professional - Unified Storage (NCP-US) v6.5 NCP-US-6.5 certification exam trainers.
Nutanix NCP-US-6.5 Exam Syllabus Topics:| Topic | Details | | Topic 1 | - Configure Nutanix Files with advanced features
- Determine the appropriate method to ensure data availability
- recoverability
| | Topic 2 | - Identify the steps to deploy Nutanix Files
- Given a scenario, determine product and sizing parameters
| | Topic 3 | - Configure Nutanix Objects
- Describe how to monitor performance and usage
| | Topic 4 | - Deploy and Upgrade Nutanix Unified Storage
- Perform upgrades
- maintenance for Files
- Objects implementations
| | Topic 5 | - Configure and Utilize Nutanix Unified Storage
- Identify the steps to deploy Nutanix Objects
| | Topic 6 | - Utilize File Analytics for data security
- Troubleshoot Nutanix Unified Storage
- Configure Nutanix Volumes
| | Topic 7 | - Given a scenario, configure shares, buckets, and
- or Volume Groups
- Troubleshoot a failed upgrade for Files
- Objects
Accurate NCP-US-6.5 Test - New NCP-US-6.5 Exam BootcampThere are multiple choices on the versions of our NCP-US-6.5 learning guide to select according to our interests and habits since we have three different versions of them: the PDF, the Software and the APP online. The PDF version of our NCP-US-6.5 exam dumps can be printed. And the Software and APP online versions of our NCP-US-6.5 Preparation materials can be practiced on computers or phones. They are new developed for the reason that electronics products have been widely applied to our life and work style.
Nutanix Certified Professional - Unified Storage (NCP-US) v6.5 Sample Questions (Q90-Q95):NEW QUESTION # 90
Which metric is utilized when sizing a Files deployment based on performance requirements?
- A. NFS concurrent connections
- B. Quantity of NFS exports
- C. Quantity of SMB shares
- D. SMB concurrent connections
This metric indicates the number of active clients that are accessing the Files cluster via SMB protocol, which affects the performance of the Files cluster. NFS concurrent connections is also a relevant metric, but it is not the best answer, as it only applies to NFS protocol, not SMB. The quantity of SMB shares or NFS exports does not directly affect the performance of the Files cluster, as they are logical entities that do not consume resources. Reference: Nutanix Files Sizing Guide
NEW QUESTION # 91
An administrator is attempting to create a share that will provide user access via SMB and NFS. However, the Enable multiprosotocol accounts for NFS clients settings is not available.
What would cause this issue?
- A. The file server instance was only configured with SMB.
- B. The connection to Active Directory has not been configured.
- C. The incorrect Files license has been applied.
- D. NFS configured to use unmanaged authentication.
The cause of this issue is that the connection to Active Directory has not been configured. Active Directory is a service that provides centralized authentication and authorization for Windows-based clients and servers. To create a share that will provide user access via SMB and NFS, the administrator must first configure the connection to Active Directory in the Files Console. This will allow the administrator to enable multiprotocol accounts for NFS clients, which are accounts that map NFS users to SMB users and groups for consistent access control across both protocols. Reference: Nutanix Files Administration Guide, page 32; Nutanix Files Solution Guide, page 6
NEW QUESTION # 92
An administrator has created a distributed share on the File cluster. The administrator connects to the share using Windows Explorer and starts creating folders in the share. The administrator observes that none of the created folder can be renamed as the company naming convention requires.
How should the administrator resolve this issue?
- A. Modify the Files shares to use the NFS protocol.
- B. Use the Files MMC Snapln and rename the folders.
- C. Modify the read/write permissions on the created folders.
- D. Use the Microsoft Shared Folder MMC Snapln.
The administrator should resolve this issue by using the Files MMC Snap-in and renaming the folders. The Files MMC Snap-in is a tool that allows administrators to manage Files shares and exports from a Windows machine. The administrator can use the Files MMC Snap-in to connect to a distributed share or export and rename the top-level directories that are hosted by different FSVMs. Renaming the directories from Windows Explorer will not work because Windows Explorer does not recognize the distributed nature of the share or export and will try to rename all directories on the same FSVM, which will fail. Reference: Nutanix Files Administration Guide, page 35; Nutanix Files MMC Snap-in User Guide
NEW QUESTION # 93
An administrator ha having difficulty enabling Data Lens for a file server.
What is the most likely cause of this issue?
- A. The file server has been cloned.
- B. The file server has blacklisted file types.
- C. The file server is in a Protection Domain.
- D. SSR is enabled on the file server.
The most likely cause of this issue is that the file server has been cloned. Cloning a file server is not a supported operation and can cause various problems, such as Data Lens not being able to enable or disable for the cloned file server. To avoid this issue, the administrator should use the scale-out feature to add more FSVMs to an existing file server, or create a new file server from scratch. References: Nutanix Files Administration Guide, page 28; Nutanix Files Troubleshooting Guide, page 11
NEW QUESTION # 94
After configuring Smart DR, an administrator is unable to see the policy in the Policies tab. The administrator has confirmed that all FSVMs are able to connect to Prism Central via port 9440 bidirectionally. What is the possible reason for this issue?
- A. Port 7515 should be open for all External/Client IPs of FSVMs on the Source and Target cluster.
- B. Port 7515 should be open for all Internal/Storage IPs of FSVMs on the Source and Target cluster.
- C. The primary and recovery file servers do not have the same protocols.
- D. The primary and recovery file servers do not have the same version.
Smart DR in Nutanix Files, part of Nutanix Unified Storage (NUS), is a disaster recovery (DR) solution that simplifies the setup of replication policies between file servers (e.g., using NearSync, as seen in Question 24).
After configuring a Smart DR policy, the administrator expects to see it in the Policies tab in Prism Central, but it is not visible despite confirmed connectivity between FSVMs and Prism Central via port 9440 (used for Prism communication, as noted in Question 21). This indicates a potential mismatch or configuration issue.
Analysis of Options:
* Option A (The primary and recovery file servers do not have the same version): Correct. Smart DR requires that the primary and recovery file servers (source and target) run the same version of Nutanix Files to ensure compatibility. If the versions differ (e.g., primary on Files 4.0, recovery on Files 3.8), the Smart DR policy may fail to register properly in Prism Central, resulting in it not appearing in the Policies tab. This is a common issue in mixed-version environments, as Smart DR relies on consistent features and APIs across both file servers.
* Option B (Port 7515 should be open for all External/Client IPs of FSVMs on the Source and Target cluster): Incorrect. Port 7515 is not a standard port for Nutanix Files or Smart DR communication. The External/Client network of FSVMs (used for SMB/NFS traffic) communicates with clients, not between FSVMs or with Prism Central for policy management. Smart DR communication between FSVMs and Prism Central uses port 9440 (already confirmed open), and replication traffic between FSVMs typically uses other ports (e.g., 2009, 2020), but not 7515.
* Option C (The primary and recovery file servers do not have the same protocols): Incorrect.
Nutanix Files shares can support multiple protocols (e.g., SMB, NFS), but Smart DR operates at the file server level, not the protocol level. The replication policy in Smart DR replicates share data regardless of the protocol, and a protocol mismatch would not prevent the policy from appearing in the Policies tab-it might affect client access, but not policy visibility.
* Option D (Port 7515 should be open for all Internal/Storage IPs of FSVMs on the Source and Target cluster): Incorrect. Similar to option B, port 7515 is not relevant for Smart DR or Nutanix Files communication. The Internal/Storage network of FSVMs is used for communication with the Nutanix cluster's storage pool, but Smart DR policy management and replication traffic do not rely on port
7515. The key ports for replication (e.g., 2009, 2020) are typically already open, and the issue here is policy visibility, not replication traffic.
Why Option A?
Smart DR requires compatibility between the primary and recovery file servers, including running the same version of Nutanix Files. A version mismatch can cause the Smart DR policy to fail registration in Prism Central, preventing it from appearing in the Policies tab. Since port 9440 connectivity is already confirmed, the most likely issue is a version mismatch, which is a common cause of such problems in Nutanix Files DR setups.
Exact Extract from Nutanix Documentation:
From the Nutanix Files Administration Guide (available on the Nutanix Portal):
"Smart DR requires that the primary and recovery file servers run the same version of Nutanix Files to ensure compatibility. A version mismatch between the source and target file servers can prevent the Smart DR policy from registering properly in Prism Central, resulting in the policy not appearing in the Policies tab."
Nutanix Files Administration Guide, Version 4.0, Section: "Smart DR Configuration Requirements" (Nutanix Portal).
Nutanix Certified Professional - Unified Storage (NCP-US) Study Guide, Section: "Nutanix Files Disaster Recovery".===========
NEW QUESTION # 95
Having been handling in this line for more than ten years, we can assure you that our NCP-US-6.5 study questions are of best quality and reasonable prices for your information. We offer free demos of the latest version covering all details of our NCP-US-6.5 Exam Braindumps available at present as representatives. So NCP-US-6.5 practice materials come within the scope of our business activities. Choose our NCP-US-6.5 learning guide, you won't regret!
Accurate NCP-US-6.5 Test: https://www.exam4docs.com/NCP-US-6.5-study-questions.html
- Pass Guaranteed Nutanix Marvelous NCP-US-6.5 Reliable Guide Files 🍇 Easily obtain free download of ➤ NCP-US-6.5 ⮘ by searching on ⮆ [url]www.troytecdumps.com ⮄ ✡NCP-US-6.5 Examcollection Vce[/url]
- NCP-US-6.5 Visual Cert Test 😇 NCP-US-6.5 Advanced Testing Engine 👡 Hottest NCP-US-6.5 Certification 🦃 Search for ➥ NCP-US-6.5 🡄 on ⇛ [url]www.pdfvce.com ⇚ immediately to obtain a free download 👘Flexible NCP-US-6.5 Learning Mode[/url]
- Fast and Effective Preparation With NCP-US-6.5 Nutanix Certified Professional - Unified Storage (NCP-US) v6.5 Exam Questions 😆 Easily obtain [ NCP-US-6.5 ] for free download through ⏩ [url]www.prepawayexam.com ⏪ 🚅NCP-US-6.5 Advanced Testing Engine[/url]
- NCP-US-6.5 Dumps Guide 💦 Dump NCP-US-6.5 Collection 🍧 NCP-US-6.5 Advanced Testing Engine 🟪 Open ➽ [url]www.pdfvce.com 🢪 and search for ⮆ NCP-US-6.5 ⮄ to download exam materials for free 🍙NCP-US-6.5 Examcollection Vce[/url]
- Study NCP-US-6.5 Test 🌷 Hottest NCP-US-6.5 Certification 🤯 Dump NCP-US-6.5 Collection 🎐 The page for free download of ➠ NCP-US-6.5 🠰 on ☀ [url]www.prepawaypdf.com ️☀️ will open immediately 🕸Study NCP-US-6.5 Test[/url]
- High Pass-Rate NCP-US-6.5 Reliable Guide Files Help You to Get Acquainted with Real NCP-US-6.5 Exam Simulation 🕕 Easily obtain free download of ▷ NCP-US-6.5 ◁ by searching on ¡¸ [url]www.pdfvce.com ¡¹ 🚵NCP-US-6.5 Test Questions Vce[/url]
- NCP-US-6.5 Examcollection Vce 🎂 NCP-US-6.5 Visual Cert Test 🦹 NCP-US-6.5 Valid Mock Exam 🏮 Easily obtain ▷ NCP-US-6.5 ◁ for free download through ⏩ [url]www.vce4dumps.com ⏪ 💂Valid NCP-US-6.5 Test Labs[/url]
- Nutanix NCP-US-6.5 torrent - Pass4sure NCP-US-6.5 exam - NCP-US-6.5 torrent files 🆚 Search for ▷ NCP-US-6.5 ◁ and download it for free immediately on ➽ [url]www.pdfvce.com 🢪 🦐NCP-US-6.5 Test Dumps Pdf[/url]
- NCP-US-6.5 Visual Cert Test 🍿 Hottest NCP-US-6.5 Certification 💂 NCP-US-6.5 Test Centres 😊 Search on ⇛ [url]www.examcollectionpass.com ⇚ for ¡° NCP-US-6.5 ¡± to obtain exam materials for free download 🧃Dumps NCP-US-6.5 Free[/url]
- High Pass-Rate NCP-US-6.5 Reliable Guide Files Help You to Get Acquainted with Real NCP-US-6.5 Exam Simulation 👦 Enter ⇛ [url]www.pdfvce.com ⇚ and search for ⏩ NCP-US-6.5 ⏪ to download for free 🕍New NCP-US-6.5 Test Papers[/url]
- Nutanix NCP-US-6.5 Exam | NCP-US-6.5 Reliable Guide Files - Professional Offer of Accurate NCP-US-6.5 Test 🥥 The page for free download of ⮆ NCP-US-6.5 ⮄ on ¡¾ [url]www.vce4dumps.com ¡¿ will open immediately ↕NCP-US-6.5 Practice Test Fee[/url]
- www.stes.tyc.edu.tw, qiita.com, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, Disposable vapes
P.S. Free & New NCP-US-6.5 dumps are available on Google Drive shared by Exam4Docs: https://drive.google.com/open?id=1vnvQCeTVb62_6dh4QfJCJxjFTQCUAJOf
