Quiz Salesforce - PDII - Perfect Platform Developer II Real Brain Dumps
Posted at 2/4/2026 22:01:33
DOWNLOAD the newest VCE4Dumps PDII PDF dumps from Cloud Storage for free: https://drive.google.com/open?id=1QQRFOXRF3RO2LcNrsPkWbqegFN_NM-F2
You have seen VCE4Dumps's Salesforce PDII Exam Training materials, it is time to make a choice. You can choose other products, but you have to know that VCE4Dumps can bring you infinite interests. Only VCE4Dumps can guarantee you 100% success. VCE4Dumps allows you to have a bright future. And allows you to work in the field of information technology with high efficiency.
Salesforce PDII (Salesforce Certified Platform Developer II) certification exam is a highly respected certification in the field of Salesforce development. Platform Developer II certification is designed for developers who have advanced skills in Salesforce development and are looking to enhance their career prospects. The PDII Certification Exam is intended to test the candidate's knowledge of advanced Salesforce development concepts, including Apex programming, Lightning Components, and application design.
Importance of Salesforce PDII Certification ExamThere is no shortcut to PDII exam questions success except hard work. You cannot expect your dream of earning the Salesforce CERTIFICATION EXAM come true without using updated study material Platform Developer II (PDII) exam questions. Success in the PDII exam adds more value to your resume and helps you land the best jobs in the industry.
Salesforce PDII (Salesforce Certified Platform Developer II) is an advanced-level certification program designed for experienced Salesforce developers who want to take their skills and knowledge to the next level. The PDII certification is the second level of certification in the Salesforce Certified Platform Developer series and is recognized globally as a benchmark for excellence in Salesforce development. Platform Developer II certification exam evaluates a candidate's ability to design, develop, and implement advanced business logic and complex programming solutions on the Salesforce platform.
To earn the PDII certification, candidates must have a solid understanding of the Salesforce platform and be able to develop custom solutions that meet the business requirements of their organization. Platform Developer II certification exam consists of multiple-choice questions and performance-based scenarios that test the candidate's ability to design, develop, and implement solutions on the Salesforce platform. PDII Exam is designed to assess the candidate's ability to apply their knowledge of Apex and Visualforce to real-world scenarios. The PDII certification is a valuable asset for developers who want to showcase their skills and knowledge to potential employers and advance their careers in the Salesforce ecosystem.
Salesforce Platform Developer II Sample Questions (Q128-Q133):NEW QUESTION # 128
Assuming the CreateOneAccount class creates one account and implements the Queueable interface, which syntax properly tests the Apex code?
The correct syntax to test the Apex code that implements the Queueable interface is Option B. This option uses the Test.startTest() and Test.stopTest() methods to mark the boundaries of the test execution, and the Test.enqueueJob() method to execute the queueable job and get the job ID. The option also uses the System.assert() method to verify the expected result. Option A is incorrect, as it does not use the Test.enqueueJob() method, but the System.enqueueJob() method, which is not valid. Option C is incorrect, as it does not use the Test.stopTest() method, which is necessary to ensure that the asynchronous job is completed before the assertion. Option D is incorrect, as it does not use the Test.startTest() method, which is recommended to isolate the test context from the setup context. Reference: [Queueable Apex], [Testing Asynchronous Apex], [Apex Developer Guide]
NEW QUESTION # 129
Consider the following code snippet:
Which governor limit is likely to be exceeded when the trigger runs when a scope of 200 newly inserted accounts?
- A. Total number of SOQL queries issued
- B. Total number of DML statements issued
- C. Total number of SOQL queries issued
- D. Total number of records processed as a result of DML
NEW QUESTION # 130
A developer created a Lightning web component that uses a lightning-record-edit-form to collect information about Leads. Users complain that they only see one error message at a time about their input when trying to save a Lead record.
What is the recommended approach to perform validations on more than one field, and display multiple error messages simultaneously with minimal JavaScript intervention?
- A. Validation rules
- B. External JavaScript library
- C. Try/catch/finally block
- D. Apex trigger
Salesforce validation rules are declarative and can be used to validate more than one field on an object and display multiple error messages. This approach requires minimal JavaScript code and uses Salesforce's built- in validation framework. References:
* Validation Rules
NEW QUESTION # 131
The Salesforce admin at Cloud Kicks created a custom object called Region__c to store all postal zip codes in the United States and the Cloud Kicks sales region the zip code belongs to.
Cloud Kicks wants a trigger on the Lead to populate the Region based on the Lead's zip code.
A)
B)
D)
- A. Option B
- B. Option C
- C. Option A
- D. Option D
NEW QUESTION # 132
A developer is writing a Lightning Web component that queries accounts in the system and presents a lightning-datatable with the results. The users want to be able to filter the results based on up to five fields, that will vary according to their selections when running the page. Which feature of Apex code is required to facilitate this solution?
- A. describeSObjects()
- B. SOSL queries
- C. Dynamic SOQL
- D. REST API
When the structure of a query-such as the number of filters or the specific fields in the WHERE clause-is not known at compile-time and must be determined at runtime based on user input, "Dynamic SOQL" is the required feature. Unlike static SOQL, which is written directly in the Apex code and validated during compilation, Dynamic SOQL allows a developer to construct a query as a string.14 In this scenario, the user might choose to filter by 'Industry' and 'AnnualRevenue' in one session, but only by
'BillingCity' in another. By using Database.query(queryString), the developer can programmatically append WHERE clauses to the base query string based on the selections made in the Lightning Web component. This provides the flexibility to handle the varying number of fields (up to five) without writing dozens of different static queries or complex "if-else" blocks that are difficult to maintain.
While describeSObjects() (Option A) can be used to get metadata about the fields, it doesn't execute the query. SOSL (Option C) is for text-based searching across multiple objects and is less efficient for specific field filtering on a single object. The REST API (Option B) is an external interface and not a feature of Apex used to solve internal filtering logic within an LWC controller. Therefore, Dynamic SOQL is the standard tool for building highly flexible, user-driven search interfaces on the platform.
NEW QUESTION # 133
PDII Test Questions Fee: https://www.vce4dumps.com/PDII-valid-torrent.html
- Instant PDII Access 🖌 Authentic PDII Exam Hub 🐆 Knowledge PDII Points 🤵 Search for 【 PDII 】 and download it for free immediately on ➡ [url]www.practicevce.com ️⬅️ 💌
DII Latest Test Answers[/url] - 100% Pass Quiz 2026 Salesforce Efficient PDII: Platform Developer II Real Brain Dumps 🏹 Open website ▶ [url]www.pdfvce.com ◀ and search for ⏩ PDII ⏪ for free download 📿Authentic PDII Exam Hub[/url]
- Exam PDII Revision Plan 🎆 Review PDII Guide 🔅 PDII Valid Test Sims 🔷 Easily obtain free download of [ PDII ] by searching on ⇛ [url]www.verifieddumps.com ⇚ 🟣
DII Valid Test Sims[/url] - New PDII Test Syllabus 🏹 Download PDII Fee 🤩 PDII Exams Torrent 💿 Open ➽ [url]www.pdfvce.com 🢪 and search for ➡ PDII ️⬅️ to download exam materials for free 🥛
DII Examcollection Free Dumps[/url] - Study Through Online Salesforce PDII Practice Test 🎩 { [url]www.practicevce.com } is best website to obtain ⮆ PDII ⮄ for free download 🆕Download PDII Fee[/url]
- Reliable PDII Test Vce 🍑 Knowledge PDII Points 🎽 Review PDII Guide ↘ Search for ➥ PDII 🡄 and download exam materials for free through ▶ [url]www.pdfvce.com ◀ 🎪Review PDII Guide[/url]
- New PDII Test Syllabus 🦗 PDII 100% Accuracy 🐅 Exam Dumps PDII Free 🦀 Enter ▛ [url]www.prepawaypdf.com ▟ and search for { PDII } to download for free 👼Reliable PDII Dumps Pdf[/url]
- Pass Guaranteed PDII - Latest Platform Developer II Real Brain Dumps 🕜 Search for ▶ PDII ◀ and download it for free on ➽ [url]www.pdfvce.com 🢪 website 🔬
DII Reliable Dumps Ebook[/url] - 100% Pass Quiz Salesforce - PDII The Best Real Brain Dumps 🛐 Search for ➤ PDII ⮘ and download it for free immediately on ☀ [url]www.examcollectionpass.com ️☀️ 🕦Exam Dumps PDII Free[/url]
- 100% Pass Quiz 2026 Salesforce Efficient PDII: Platform Developer II Real Brain Dumps 🔍 ⇛ [url]www.pdfvce.com ⇚ is best website to obtain ( PDII ) for free download 👯Knowledge PDII Points[/url]
- PDII Latest Test Answers 🏯 PDII Exams Torrent 🔩 PDII Latest Test Answers 🚂 Easily obtain free download of ▛ PDII ▟ by searching on { [url]www.prepawayexam.com } 👾Review PDII Guide[/url]
- www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.mixcloud.com, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, Disposable vapes
