[General] Latest OmniStudio-Developer Test Simulator & New OmniStudio-Developer Test M
108
General Latest OmniStudio-Developer Test Simulator & New OmniStudio-Developer Test M
Posted at 2/4/2026 23:03:07      View122 | Replies0        Print      Only Author   [Copy Link] 1#
P.S. Free & New OmniStudio-Developer dumps are available on Google Drive shared by FreeCram: https://drive.google.com/open?id=1ylW5WM_VaoYATtL6Gi0Jk7LyHqWMITJj
After buying the Salesforce OmniStudio-Developer practice material, FreeCram offers a full refund guarantee in case of unsatisfactory Salesforce OmniStudio-Developer test results which are highly unlikely. We also offer a free demo version of the Salesforce OmniStudio-Developer exam prep material.
The Salesforce Certified OmniStudio Developer certification exam consists of 60 multiple-choice questions, and candidates have 105 minutes to complete it. OmniStudio-Developer Exam is administered at a testing center or online through the Salesforce certification website. Candidates must achieve a passing score of 68% to receive certification. Salesforce Certified OmniStudio Developer certification is valid for two years, after which the candidate must pass a recertification exam to maintain their certification status.
New Salesforce OmniStudio-Developer Test Materials - Valid OmniStudio-Developer Test ForumThe accuracy rate of OmniStudio-Developer test training materials of FreeCram is high with wide coverage. It will be the most suitable OmniStudio-Developer test training materials and the one you need most to pass OmniStudio-Developer exam. We promise that we will provide renewal service freely as long as one year after you purchase our OmniStudio-Developer Dumps; if you fail OmniStudio-Developer test or there are any quality problem of our OmniStudio-Developer exam dumps and training materials, we will give a full refund immediately.
Salesforce OmniStudio-Developer Certification Exam is a great way for developers to demonstrate their skills and knowledge in Salesforce development. Salesforce Certified OmniStudio Developer certification exam is highly respected in the industry, and those who pass the exam are recognized as experts in their field. Salesforce Certified OmniStudio Developer certification also provides developers with access to a range of resources, including online training, community forums, and peer support. By passing OmniStudio-Developer Exam, developers can enhance their career prospects and demonstrate their commitment to professional development. Whether you are a seasoned Salesforce developer or just starting your career in this field, the Salesforce OmniStudio-Developer Certification Exam is a valuable investment in your future.
Salesforce Certified OmniStudio Developer Sample Questions (Q90-Q95):NEW QUESTION # 90
A developer needs to limit the of a DataRaptorExtract to a maximum of one result.
How should the developer configure this?
  • A. Use a Custom Output Type when creating the DataRaptor
  • B. Set the Limit Propertyon the Action that calls the DataRaptor Extract.
  • C. Use the LIMIT filter on the Extract definition
  • D. Define a formula with the Filter function
Using the LIMIT filter on the Extract definition allows the developer to specify the maximum number of results to return from the DataRaptor Extract. Defining a formula with the Filter function is used to filter the results based on a condition. Using a Custom Output Type when creating the DataRaptor is used to define the structure of the output data. Setting the Limit Property on the Action that calls the DataRaptor Extract has no effect on limiting the results.
NEW QUESTION # 91
A developer examines data received from an external data source. The data is nested two levels down in the JSON structure.
Which OmniStudio tool could the developer use to simplify this data?
  • A. An HTTP Action Element
  • B. An integration Procedure
  • C. A guided workflow
  • D. A DataRaptor Transform
A DataRaptor Transform can simplify nested data by transforming it into a flat structure. The developer can use JSON paths to map the input data to the output data and define the output structure.
NEW QUESTION # 92
The OmniScript must retrieve device details stored in the Assetobject and then call an external system to send troubleshooting commands via REST API to the device.
Which two OmniScript element should the developer use to configure this functionality?
  • A. HTTP Action
  • B. DataRaptor Extract Action
  • C. SOQL Action
  • D. REST API Action
  • E. Navigation Action
According to the OmniScript Action Elements page, a DataRaptor Extract Action can be used to "get data from one or more Salesforce records" and an HTTP Action can be used to "get, save, or delete data through a web application programming interface (API)".
NEW QUESTION # 93
An integration procedure contains a Remote Action element that calls a method of an APEXclass. The method requires two fields are input: Accountid and ProductId. The integration Procedure data JSON contains the following nodes:
How should the Remote Action element be configured to pass the data correctly to the method?
  • A. Add the following to Send JSON Path: accountId: %Accountd% ProductId% Details Products%
  • B. Check the Send OnlyAdditional Input checkbox, and the following/ value pairs to Additional input:
  • C. Set Return Only Additional Output to true, and add the following Key/Value pairs to additional input.
  • D. Check the DataRaptor Transform checkbox, and add the following Key/Value pairs to Output JSON Path:
Checking the Send Only Additional Input checkbox allows the Remote Action element to send only the key/value pairs specified in Additional input to the Apex method. The Additional input should have the same keys as the method parameters, and the values should be set to {{InputData.node}} for each node. For example, AccountId: {{InputData.AccountId}} and ProductId: {{InputData.Details.Products}}.
NEW QUESTION # 94
Refer to theexhibit.
What JSON from the DRGetAccountDetails action would display all six values correctly in the OmniScript structure shown? BlkContacts is a Repeat Block.
A)
B)
C)
D)
  • A. Option C
  • B. Option A
  • C. Option D
  • D. Option B
NEW QUESTION # 95
New OmniStudio-Developer Test Materials: https://www.freecram.com/Salesforce-certification/OmniStudio-Developer-exam-dumps.html
BONUS!!! Download part of FreeCram OmniStudio-Developer dumps for free: https://drive.google.com/open?id=1ylW5WM_VaoYATtL6Gi0Jk7LyHqWMITJj
