Quiz Salesforce - Latest AP-204 - Consumer Goods Cloud Accredited Professional V
Posted at 2/5/2026 02:36:49
View136
Replies1
To some extent, to pass the AP-204 exam means that you can get a good job. The AP-204 exam materials you master will be applied to your job. The possibility to enter in big and famous companies is also raised because they need outstanding talents to serve for them. Our AP-204 Test Prep is compiled elaborately and will help the client a lot. To get a better and full understanding of our AP-204 quiz torrent, please read the introduction of the features and the advantages of our product as follow.
The passing rate of our AP-204 exam materials are very high and about 99% and so usually the client will pass the AP-204 exam successfully. If any questions or doubts on the AP-204 training material exist, the client can contact our online customer service or send mails to contact us and we will solve them as quickly as we can. We always want to let the clients be satisfied and provide the best AP-204 Test Torrent and won't waste their money and energy. As long as you bought our AP-204 practice guide, you will love it for sure.
AP-204 Valid Test Testking - Realistic Salesforce Consumer Goods Cloud Accredited Professional Valid Test TestkingTo be the best global supplier of electronic AP-204 study materials for our customers through innovation and enhancement of our customers' satisfaction has always been our common pursuit. The advantages of our AP-204 guide dumps are too many to count. And the most important point is that the pass rate of our AP-204 learning quiz is preety high as 98% to 99%. I guess this is also the candidates care most as well. You can totally trust in our AP-204 exam questions!
Salesforce Consumer Goods Cloud Accredited Professional Sample Questions (Q38-Q43):NEW QUESTION # 38
ABC Telecom is using Communications Cloud for their enterprise customers. ABC Telecom has a requirement wherein assets must be synchronized to the assurance platform as soon as the sale or MACD order completes fulfillment for wholesale products. There are about 5,000 orders placed by each reseller throughout the day. There are hundreds of active reseller users present in the system.
How should a Consultant recommend that ABC Telecom integrate Communications Cloud with their assurance platform?
- A. Use an on-demand data pull from Communications Cloud using the REST API from Service assurance
- B. Use Industries Order Management to inform the assurance platform as part of the orchestration plan
- C. Use a Bulk API connector via middleware
- D. Use Platform Events and GetAsset API
ABC Telecom requires that assets be synchronized to their assurance platform immediately after fulfillment, and they operate in a high-volume wholesale environment (5,000+ orders per reseller/day and hundreds of concurrent users). Salesforce recommends event-driven, near-real-time integration for high-scale fulfillment notifications.
Platform Events are Salesforce's native, scalable publish/subscribe mechanism designed for high throughput and low latency. When an order completes fulfillment, Communications Cloud can publish an event that external systems subscribe to. The assurance platform can then call the GetAsset API to retrieve the exact asset structure needed for assurance workflows.
This pattern is explicitly recommended in Salesforce high-throughput integration architectures because it:
Eliminates polling
Handles large transaction volume
Provides near-real-time sync
Decouples fulfillment from assurance systems
Scales horizontally across resellers
Option A (using OM orchestration) is synchronous and not optimal for high throughput.
Option B (on-demand REST pull) causes latency and excessive polling.
Option C (Bulk API) is batch-oriented, not real-time, and unsuitable for near-immediate updates.
NEW QUESTION # 39
Which two standard capabilities are available when executing a promotion check in the field?
- A. Taking a photo of the promotion
- B. Viewing which products are included in the protection
- C. Changing the promotion planning dates
- D. Changing the discounts on the products included in the promotion
- E. Marking the promotion as complete
A promotion check is a type of action plan task that allows a field rep to verify if a promotion is running correctly at a retail store. When executing a promotion check in the field, two standard capabilities are available: viewing which products are included in the promotion and taking a photo of the promotion. These capabilities help to ensure compliance and capture evidence of promotional execution. Verified Reference: [Salesforce Consumer Goods Cloud Implementation Guide], page 27-28.
NEW QUESTION # 40
Sales Managers would like a map that shows which stores are running a promotion within their vicinity. Which solution meets their requirement and also involves the least amount of custom development?
- A. An unmanaged package from the AppExchange modified to meet the requirements
- B. A visual mashup that displays the required map on the promotions page
- C. The nearby map component on the promotion records page
- D. The map component added to the home page
The nearby map component on the promotion records page allows a user to see which stores are running a promotion within their vicinity. This solution meets the requirement and also involves the least amount of custom development, as it is a standard feature of Consumer Goods Cloud. Verified Reference: [Salesforce Consumer Goods Cloud Implementation Guide], page 32.
NEW QUESTION # 41
Universal Containers has a requirement to establish dependencies between independent commercial products, such as ensuring that the 'Roaming Service' cannot be activated without first activating the 'Voice Service.' The provisioning system insists on receiving a single request for the activation of both products.
Which approach should the consultant recommend to ensure seamless integration and streamlined operations while addressing these business requirements?
- A. Create a Relies-On Relationship between products and set the decomposition scope to Relies-On
- B. Create a Bundle Product and Multilevel Decomposition for fulfillment
- C. Create a Relies-On Relationship between products and set the decomposition scope to OrderItem
- D. Create a Relies-On Relationship between product and set the decomposition scope to Account
Salesforce Communications Cloud supports product dependencies through Relies-On Relationships. These relationships enforce commercial dependencies (e.g., Roaming requires Voice Service) and guide technical decomposition so that dependent products are fulfilled together.
To satisfy the requirement that the provisioning system receive a single activation request for both Voice Service and Roaming, the dependency must be modeled using:
✔ Relies-On Relationship
This ensures the commercial cart enforces prerequisite activation rules-Roaming cannot be purchased or activated without Voice Service.
✔ Decomposition Scope = Order Item
When decomposition scope is set to Order-Item for the technical product relationship, both commercial products decompose into a single technical activation request for fulfillment. This is the exact Salesforce-recommended pattern when dependent commercial products must trigger one consolidated orchestration/activation flow.
A (Scope = Account): would merge across the whole account, not just the order.
C (Scope = Relies-On): no such decomposition scope exists; invalid choice.
D (Bundle Product + Multilevel Decomposition): bundling is not required, and it changes the commercial product structure unnecessarily.
NEW QUESTION # 42
How can a Field Sales Manager access a photo taken by a Field Rep of a defective In-store asset
- A. The photo is sent directly to the manager's email
- B. The photo is linked to the visit record
- C. The photos Inked to the asset record
- D. The photo is linked to the asset check task
Field Sales Managers can access photos taken by Field Reps of defective in-store assets through the asset record to which the photos are linked. This provides a direct association between the asset and its condition.
NEW QUESTION # 43
Through our investigation and analysis of the real problem over the years, our AP-204 prepare questions can accurately predict the annual AP-204 exams. In the actual exam process, users will encounter almost half of the problem is similar in our products. Even if the syllabus is changing every year, the AP-204 quiz guides experts still have the ability to master propositional trends. Believe that such a high hit rate can better help users in the review process to build confidence, and finally help users through the qualification examination to obtain a certificate. All in all, we want you to have the courage to challenge yourself, and our AP-204 Exam Prep will do the best for the user's expectations.
AP-204 Valid Exam Tutorial: https://www.torrentvalid.com/AP-204-valid-braindumps-torrent.html
Salesforce AP-204 Valid Test Testking The value generated from the IT industry has accounted for a very large proportion, Both practice tests simulate the Salesforce AP-204 real exam environment and produce results of your attempts on the spot, Salesforce AP-204 Valid Test Testking Then you can begin your new learning journey of our study materials, Salesforce AP-204 Valid Test Testking It no needs any extra software to run.
This is particularly true with identity theftCrelated crimes, Configuration AP-204 Management in Agile Development, The value generated from the IT industry has accounted for a very large proportion.
AP-204 Valid Test Testking | 100% Free Newest Consumer Goods Cloud Accredited Professional Valid Exam TutorialBoth practice tests simulate the Salesforce AP-204 Real Exam environment and produce results of your attempts on the spot, Then you can begin your new learning journey of our study materials.
It no needs any extra software to run, The pass rate is 98.75% for AP-204 exam braindumps, and you can pass your exam in your first attempt if you choose us.
- AP-204 Latest Dumps Ppt 🧦 Unlimited AP-204 Exam Practice ↪ AP-204 Valid Exam Pass4sure 👵 Search for AP-204 and easily obtain a free download on [url]www.easy4engine.com 😢Valuable AP-204 Feedback[/url]
- Instant AP-204 Access ☣ Exam AP-204 Introduction 🙄 Valid Dumps AP-204 Files 🐌 Search for AP-204 and easily obtain a free download on ➠ [url]www.pdfvce.com 🠰 ⚽Valid Test AP-204 Braindumps[/url]
- Pass Guaranteed 2026 High-quality Salesforce AP-204: Consumer Goods Cloud Accredited Professional Valid Test Testking 🍿 Easily obtain ⇛ AP-204 ⇚ for free download through ➽ [url]www.testkingpass.com 🢪 🏄Interactive AP-204 Questions[/url]
- Free Sample AP-204 Questions 💂 AP-204 Valid Exam Pass4sure ⛽ AP-204 Latest Test Practice 🦜 Open [url]www.pdfvce.com and search for AP-204 to download exam materials for free 🧧Valid Test AP-204 Braindumps[/url]
- New AP-204 Exam Discount 🌈 Interactive AP-204 Questions ❇ Reliable AP-204 Test Topics 💯 Search for ▛ AP-204 ▟ and obtain a free download on ▛ [url]www.practicevce.com ▟ 👌AP-204 Exam Price[/url]
- Free PDF Salesforce - AP-204 Useful Valid Test Testking 🦆 ⏩ [url]www.pdfvce.com ⏪ is best website to obtain ☀ AP-204 ️☀️ for free download 🐙Valid Test AP-204 Braindumps[/url]
- Instant AP-204 Access 🛌 Clearer AP-204 Explanation 🎯 Unlimited AP-204 Exam Practice 🚬 Copy URL ✔ [url]www.troytecdumps.com ️✔️ open and search for ➽ AP-204 🢪 to download for free 🚄AP-204 Exam Price[/url]
- Exam AP-204 Introduction 🐲 AP-204 Valid Exam Pass4sure 🤖 Clearer AP-204 Explanation 🔽 Download AP-204 for free by simply entering [url]www.pdfvce.com website 🏌AP-204 Reliable Exam Review[/url]
- Get Success in Salesforce AP-204 Exam Dumps with Good Scores 🙀 Download ➡ AP-204 ️⬅️ for free by simply entering ➡ [url]www.practicevce.com ️⬅️ website 💗Reliable AP-204 Test Topics[/url]
- Unlimited AP-204 Exam Practice ▛ AP-204 Dump Torrent 💒 Valuable AP-204 Feedback 🌷 Search for ⮆ AP-204 ⮄ and obtain a free download on ➥ [url]www.pdfvce.com 🡄 💕Valid Dumps AP-204 Files[/url]
- Valid Test AP-204 Braindumps 🦇 Interactive AP-204 Questions 🔼 Exam AP-204 Certification Cost 🌿 [url]www.validtorrent.com is best website to obtain ➤ AP-204 ⮘ for free download 🍧New AP-204 Test Question[/url]
- www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, writeablog.net, Disposable vapes
