Test MS-102 Dates - Reliable MS-102 Exam Materials
Posted at 2/5/2026 04:06:44
View166
Replies2
What's more, part of that Actual4Dumps MS-102 dumps now are free: https://drive.google.com/open?id=12A52qRpwPRb6WEtJGLrE4TFSmN61i_98
As is known to us, the MS-102 Certification has been increasingly important for a lot of modern people in the rapid development world. Why is the MS-102 certification so significant for many people? Because having the certification can help people make their dreams come true, including have a better job, gain more wealth, have a higher social position and so on. We believe that you will be fond of our products.
Microsoft MS-102 Exam Syllabus Topics:| Topic | Details | | Topic 1 | - Manage security and threats by using Microsoft Defender XDR: This topic discusses how to use Microsoft Defender portal to manage security reports and alerts. It also focuses on usage of Microsoft Defender for Office 365 to implement and manage email and collaboration protection. Lastly, it discusses the usage of Microsoft Defender for Endpoint for the implementation and management of endpoint protection.
| | Topic 2 | - Manage compliance by using Microsoft Purview: Implementation of Microsoft Purview information protection and data lifecycle management is discussed in this topic. Moreover, questions about implementing Microsoft Purview data loss prevention (DLP) also appear.
| | Topic 3 | - Deploy and manage a Microsoft 365 tenant: Management of roles in Microsoft 365 and management of users and groups are discussion points of this topic. It also focuses on implementing and managing a Microsoft 365 tenant.
| | Topic 4 | - Implement and manage Microsoft Entra identity and access: In this topic, questions about Microsoft Entra tenant appear. Moreover, it delves into implementation and management of authentication and secure access.
Experience The Real Environment With The Help Of Microsoft MS-102 Exam QuestionsIn today's Microsoft world getting the Microsoft 365 Administrator (MS-102) certification exam is very crucial. With the growing popularity of credentials, the demand for MS-102 certification exam holders has increased. Success in the MS-102 Exam has become the need of time. People who fail the Microsoft MS-102 certification exam face loss of time and money.
Microsoft 365 Administrator Sample Questions (Q320-Q325):NEW QUESTION # 320
You have a Microsoft 365 E5 subscription.
You need to configure Privileged Identity Management (PIM) for the User Administrator role in Microsoft Entr a. Eligible users must meet the following requirements:
* Always be able to request the User Administrator role.
* Must provide a reason when requesting the User Administrator role
* Must require multi-factor authentication (MFA} when activating the User Administrator role The solution must minimize administrative effort.
NEW QUESTION # 321
HOTSPOT
You have a Microsoft 365 E5 subscription that contains the users shown in the following table.
You add the following assignment for the User Administrator role:
Scope type: Directory
Selected members: Group1
Assignment type: Active
Assignment starts: Mar 15, 2023
Assignment ends: Aug 15, 2023
You add the following assignment for the Exchange Administrator role:
Selected members: Group2
Assignment type: Eligible
Assignment starts: Jun 15, 2023
Assignment ends: Oct 15, 2023
Box 1: Yes
Admin1 is member of Group1.
The User Administrator role assignment has Group1 as a member.
The assignment type: Active
July 15, 2023 is with the assignment period.
A User Administrator can manage all aspects of users and groups, including resetting passwords for limited admins.
Box 2: No
Admin2 is member of Group2.
The Exchange Administrator role assignment has Group2 as a member.
The assignment type: Eligible
June 20, 2023 is with the assignment period.
The assignment must be approved.
Note: Eligible assignment requires member or owner to perform an activation to use the role. Activations may also require providing a multi-factor authentication (MFA), providing a business justification, or requesting approval from designated approvers.
Box 3: Yes
Admin3 is member of Gropu1 and Group2.
May 1, 2023 is with the assignment period.
https://learn.microsoft.com/en-u ... rmissions-reference
https://learn.microsoft.com/en-u ... ment/groups-assign- member-owner
NEW QUESTION # 322
HOTSPOT
You have a new Microsoft 365 E5 tenant.
Enable Security defaults is set to Yes.
A user signs in to the tenant for the first time.
Which multi-factor authentication (MFA) method can the user use, and how many days does the user have to register for MFA? To answer, select the appropriate options in the answer area.
Box 1: Notification to Microsoft Authenticator app
Do users have 14 days to register for Azure AD Multi-Factor Authentication?
Users have 14 days to register for MFA with the Microsoft Authenticator app from their smart phones, which begins from the first time they sign in after security defaults has been enabled. After 14 days have passed, the user won't be able to sign in until MFA registration is completed.
Box 2: 14
Azure AD Identity Protection will prompt your users to register the next time they sign in interactively and they'll have 14 days to complete registration. During this 14-day period, they can bypass registration if MFA isn't required as a condition, but at the end of the period they'll be required to register before they can complete the sign-in process.
https://learn.microsoft.com/en-u ... tely-secure-sign-in
https://learn.microsoft.com/en-u ... otection-configure-
NEW QUESTION # 323
Several users have iOS devices.
You plan to enroll the iOS devices in Microsoft Endpoint Manager.
You need to ensure that you can create an iOS/iPadOS enrollment profile in Microsoft Endpoint Manager.
https://docs.microsoft.com/en-us ... ush-certificate-get
NEW QUESTION # 324
You have an Azure Active Directory (Azure AD) tenant named contoso.com that contains the users shown in the following table.
You integrate Microsoft Intune and contoso.com as shown in the following exhibit.
You purchase a Windows 10 device named Device1.
https://docs.microsoft.com/en-us ... ment/windows-enroll
NEW QUESTION # 325
You will need to pass the Microsoft MS-102 exam to achieve the Microsoft 365 Administrator (MS-102) certification. Due to extremely high competition, passing the Microsoft 365 Administrator (MS-102) exam is not easy; however, possible. You can use Actual4Dumps products to pass the Microsoft 365 Administrator (MS-102) exam on the first attempt. The Microsoft 365 Administrator (MS-102) practice exam gives you confidence and helps you understand the criteria of the testing authority and pass the Microsoft 365 Administrator (MS-102) exam on the first attempt.
Reliable MS-102 Exam Materials: https://www.actual4dumps.com/MS-102-study-material.html
- 100% Pass MS-102 - Latest Test Microsoft 365 Administrator Dates 🗳 Search for ▶ MS-102 ◀ on [url]www.prepawayexam.com immediately to obtain a free download 🪒MS-102 Certification Dumps[/url]
- Latest Microsoft 365 Administrator pass review - MS-102 getfreedumps study materials 🧝 Go to website [url]www.pdfvce.com open and search for ▛ MS-102 ▟ to download for free 😤Reliable Study MS-102 Questions[/url]
- MS-102 Valid Test Pdf ⛄ MS-102 Exam Training 🥣 Exam MS-102 Questions Answers 📶 Download ⮆ MS-102 ⮄ for free by simply entering ➠ [url]www.pdfdumps.com 🠰 website 🥏MS-102 Valid Test Pdf[/url]
- Latest MS-102 Exam Preparation 🧏 MS-102 Exam Training 🛂 MS-102 Valid Test Pattern 🔲 Search for ➠ MS-102 🠰 and obtain a free download on [ [url]www.pdfvce.com ] 🥑Reliable Study MS-102 Questions[/url]
- Latest Microsoft 365 Administrator pass review - MS-102 getfreedumps study materials 🐁 Easily obtain free download of { MS-102 } by searching on [url]www.examcollectionpass.com 🚔New MS-102 Exam Discount[/url]
- MS-102 Valid Test Pattern 🦐 Hot MS-102 Spot Questions 🍆 MS-102 Advanced Testing Engine ❤️ Search on ➠ [url]www.pdfvce.com 🠰 for ➥ MS-102 🡄 to obtain exam materials for free download 🎒MS-102 Exam Training[/url]
- MS-102 Exam Dumps Free 📮 Latest MS-102 Exam Vce 🧍 Reliable MS-102 Learning Materials 📿 Copy URL ▷ [url]www.testkingpass.com ◁ open and search for ☀ MS-102 ️☀️ to download for free 🔋Valid MS-102 Exam Cram[/url]
- 100% Pass Quiz Microsoft - Unparalleled MS-102 - Test Microsoft 365 Administrator Dates 🍻 Simply search for ☀ MS-102 ️☀️ for free download on ➡ [url]www.pdfvce.com ️⬅️ IMS-102 Certification Dumps[/url]
- 100% Pass MS-102 - Latest Test Microsoft 365 Administrator Dates 🧮 Search for ⏩ MS-102 ⏪ and easily obtain a free download on ▶ [url]www.examcollectionpass.com ◀ 💨Exam MS-102 Duration[/url]
- 2026 MS-102 C 100% Free Test Dates | Professional Reliable Microsoft 365 Administrator Exam Materials 🐶 { [url]www.pdfvce.com } is best website to obtain ▛ MS-102 ▟ for free download 🧾Exam MS-102 Questions Answers[/url]
- Efficient Microsoft Test MS-102 Dates Are Leading Materials - The Best MS-102: Microsoft 365 Administrator 🏮 Open [url]www.examcollectionpass.com and search for ▷ MS-102 ◁ to download exam materials for free 🌿MS-102 Valid Test Pattern[/url]
- www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, mecabricks.com, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, writeablog.net, Disposable vapes
BTW, DOWNLOAD part of Actual4Dumps MS-102 dumps from Cloud Storage: https://drive.google.com/open?id=12A52qRpwPRb6WEtJGLrE4TFSmN61i_98
