[General] Valid 3V0-21.23 Test Discount, 3V0-21.23 New Real Test
96
General Valid 3V0-21.23 Test Discount, 3V0-21.23 New Real Test
Posted at 2/5/2026 04:23:27      View218 | Replies3        Print      Only Author   [Copy Link] 1#
It is a common sense that only high quality and accuracy 3V0-21.23 practice materials can relive you from those worries. It is our communal wish to reap successful fruits. So our company did a lot to make sure that happen. Our 3V0-21.23 practice materials compiled by the most professional experts can offer you with high quality and accuracy results for your success. If you are unfamiliar with our 3V0-21.23 practice materials, please download the free demos for your reference, and to some unlearned exam candidates, you can master necessities by our 3V0-21.23 practice materials quickly.
VMware 3V0-21.23 Exam Syllabus Topics:
  • VMware Products and Solutions: Targeting VMware Engineers, this section describes VMware Cloud Foundation architecture, its components like vSphere and NSX, benefits such as automation and scalability, and use cases like hybrid cloud environments. It assesses understanding of VMware Validated Solutions.
  • Plan and Design the VMware Solution: This part targets Solution Designers, evaluating their ability to gather business objectives, create conceptual models based on these objectives, develop logical designs, and translate them into physical designs that meet specific requirements like manageability or security.
  • IT Architectures, Technologies, Standards: This section of the exam measures the skills of IT Architects and covers differentiating between business and technical requirements, as well as conceptual, logical, and physical design. A key skill measured is "Designing System Availability."
3V0-21.23 New Real Test & 3V0-21.23 Valid Test PreparationIf you use the ActualTestsIT VMware 3V0-21.23 Study Materials, you can reduce the time and economic costs of the exam. It can help you to pass the exam successfully. Before you decide to buy our VMware 3V0-21.23 exam materials, you can download our free test questions, including the PDF version and the software version. If you need software versions please do not hesitate to obtain a copy from our customer service staff.
VMware vSphere 8.x Advanced Design Sample Questions (Q18-Q23):NEW QUESTION # 18
An architect is working on a security design for a shared storage environment. The storage array provides connectivity by the NFS protocol.
Which two design decisions could the architect include for this solution? (Choose two.)
  • A. Create a challenge handshake authentication protocol (CHAP) password to prevent unauthorized access
  • B. Create dedicated volumes for sensitive data
  • C. Create a dedicated storage network
  • D. Create a dedicated Fibre Channel network
  • E. Create a dedicated VLAN
Answer: C,E
Create a dedicated storage network:
Creating a dedicated storage network ensures that storage traffic is isolated from general network traffic, improving both security and performance. This design choice helps prevent unauthorized access, minimizes the potential for network congestion, and ensures that storage traffic is not impacted by other workloads or services on the network.
Create a dedicated VLAN:
By placing storage traffic on its own VLAN, the architect ensures further network segmentation. This VLAN can be used exclusively for NFS traffic, improving both security and performance. It also allows for easier management and monitoring of storage traffic, while helping prevent unauthorized access from other parts of the network.
NEW QUESTION # 19
Which VMware product offers a software-defined storage solution, providing distributed storage architecture that spans multiple vSphere clusters?
  • A. VMware Workstation
  • B. NSX-T
  • C. vSphere Replication
  • D. vSAN
NEW QUESTION # 20
An architect is designing storage for a new vSphere environment to meet the following requirements:
- Asynchronous replication is required between two sites.
- The impact on the storage layer should not impact the performance of the compute layer.
- Each application tier will require different replication attributes.
- Virtual machine live migration across compute and storage must be supported.
- Virtual machine aware back up will be leveraged. Operational management overhead should be minimized.
- Operational automation should be supported.
Which storage design recommendations would meet the requirements?
  • A. Two new vSphere clusters enabled with vSAN will be deployed, one at either site.vSAN will be used to provide policy-based management for each application tier. vSphere Replication will be used to replicate the virtual machine data in an asynchronous configuration.
  • B. Two new Fibre Channel storage arrays will be deployed, one at either site. Each application tier will be initially provisioned a new LUN. Data replication will be offloaded to the new arrays.
  • C. Two new storage arrays will be deployed, one at either site. vSphere Volumes (vVOLs) will be used to provide policy-based management for each application tier. Data replication will be offloaded to the new arrays.
  • D. Two new ISCSI storage arrays will be deployed, one at either site. Each application tier will be initially provisioned a new LUN. Data replication will be offloaded to the new arrays.
NEW QUESTION # 21
An architect is designing a new vSphere cluster. The requirement is to provide a total of 96 CPU cores and 1.5 TB RAM across all hosts.
The following information has been provided:
1. Two different physical hardware profiles are available for the ESXi hosts in the cluster.
- Profile 1: 16 CPU cores and 256 GB RAM
- Profile 2: 32 CPU cores and 512 GB RAM
2. Profile 2 is twice as expensive to purchase as Profile 1.
Which two aspects should the architect consider when selecting the hardware profile? (Choose two.)
  • A. The number of virtual machines that will be running within the cluster
  • B. The cost to procure and maintain the hardware
  • C. The downtime allowed for virtual machines that will be running within the cluster
  • D. The manufacturer and model of the CPUs in the hosts
  • E. The amount of capacity available for failover of virtual machines within the cluster
Answer: A,E
NEW QUESTION # 22
A company has a requirement that all production applications must have a maximum tolerable downtime (MTD) of one hour per month.
Which statement would be included in the physical design to support this requirement?
  • A. vSphere Fault Tolerance (FT) will not be enabled for the production applications.
  • B. vSphere HA will be enabled on all clusters.
  • C. vSphere HA Host Failure Response will be set to Restart VMs.
  • D. Server hardware has already been purchased for the production applications.
To meet the requirement of a maximum tolerable downtime (MTD) of one hour per month for production applications, the solution must ensure high availability and quick recovery of virtualmachines (VMs) in the event of a host failure. Enabling vSphere High Availability (HA) with the Host Failure Response set to Restart VMs will automatically restart VMs on other hosts within the cluster in the event of a host failure.
This minimizes downtime and helps meet the MTD requirement by ensuring minimal disruption to production workloads.
NEW QUESTION # 23
It is no longer an accident for you to pass 3V0-21.23 exam after you have use our 3V0-21.23 exam software. You will have thorough training and exercises from our huge question dumps, and master every question from the detailed answer analysis. The exam software with such guarantees will clear your worries about 3V0-21.23 Exam.
3V0-21.23 New Real Test: https://www.actualtestsit.com/VMware/3V0-21.23-exam-prep-dumps.html
Posted at 2/18/2026 11:40:29        Only Author  2#
DumpTOP에서 CMAA Construction-Manager 덤프를 다운받아 공부하시면 가장 적은 시간만 투자해도CMAA Construction-Manager시험패스하실수 있습니다. DumpTOP에서CMAA Construction-Manager시험덤프를 구입하시면 퍼펙트한 구매후 서비스를 제공해드립니다. CMAA Construction-Manager덤프가 업데이트되면 업데이트된 최신버전을 무료로 제공해드립니다. 시험에서 불합격성적표를 받으시면 덤프구매시 지불한 덤프비용은 환불해드립니다.
Posted at 2/22/2026 21:23:24        Only Author  3#
I was deeply moved by the article. Heres the Exam sample CCMP questions test that helped me secure my promotion and salary raise. Its free today for all. Good luck in your career growth!
Posted at 3/9/2026 01:34:26        Only Author  4#
I couldnt resist liking this content. Here are the Valid test Workday-Pro-Integrations topics pdf materials, free of charge. Good luck!
