[General] Exam CWDP-305 Certification Cost & Exam CWDP-305 Bible
【General】 Exam CWDP-305 Certification Cost & Exam CWDP-305 Bible
Posted at 2/5/2026 05:57:19      View:103 | Replies:0        Print      Only Author   [Copy Link] 1#
DOWNLOAD the newest PracticeTorrent CWDP-305 PDF dumps from Cloud Storage for free: https://drive.google.com/open?id=127Y6GRW9_6qI-goArsElb1UW_YJ0SMly
Only 20-30 hours are needed for you to learn and prepare our CWDP-305 test questions for the exam and you will save your time and energy. No matter you are the students or the in-service staff you are busy in your school learning, your jobs or other important things and can’t spare much time to learn. But you buy our CWDP-305 exam materials you will save your time and energy and focus your attention mainly on your most important thing. You only need several hours to learn and prepare for the exam every day. We choose the most typical questions and answers which seize the focus and important information and the questions and answers are based on the real exam. So you can master the most important CWDP-305 Exam Torrent in the shortest time and finally pass the exam successfully.
Every browser such as Chrome, Mozilla Firefox, MS Edge, Internet Explorer, Safari, and Opera supports this format of Certified Wireless Design Professional (CWDP-305) mock exam. You can attempt the Certified Wireless Design Professional (CWDP-305) test multiple times to relieve exam stress and boosts confidence. Besides Windows, PracticeTorrent CWNP CWDP-305 web-based practice exam works on iOS, Android, Linux, and Mac.
Free PDF Quiz CWNP - CWDP-305 - Useful Exam Certified Wireless Design Professional Certification CostOur exam prep material is famous among CWDP-305 exam candidates which help to polish the knowledge required to pass the CWNP CWDP-305 exam. The certification is organized by CWDP-305 internationally. Our CWNP CWDP-305 exam questions are the most cost-effective as we understand that you need low-cost material but are authentic and updated. PracticeTorrent provides its CWNP CWDP-305 Exam Questions in three forms, one is PDF eBook, the second is practice exam software for Windows-based systems, and the third is an online practice test.
CWNP Certified Wireless Design Professional Sample Questions (Q273-Q278):NEW QUESTION # 273
After deploying a 5 GHz-only WLAN infrastructure in the USA, using 20 MHz channel-widths and all 25 available channels, one of the managers of the company brings his 802.11n tablet to the office to test the Guest SSID. While testing, there were several spots where he would get poor RSSI (below -80 dBm) or none at all. You checked the WLAN infrastructure and all APs are up and running and you've validated coverage after deployment. What is causing this issue?
  • A. His tablet does not support one or more of the 5 GHz channels
  • B. His tablet doesn't support the 5 GHz band
  • C. His tablet only supports a 40 MHz channel-width
  • D. His tablet doesn't support MU-MIMO
Not all client devices support the full range of 5 GHz channels.Some devices, especially older ones, may only support the lower UNII-1 band (channels 36-48) and not the higher channels like UNII-2 or UNII-3.If the WLAN infrastructure utilizes channels that the client's device does not support, the device will not detect the SSID on those channels, leading to poor or no connectivity in certain areas.This explains the manager's experience of poor RSSI or lack of connection in specific spots, despite the APs functioning correctly.
Reference: CWDP-305 Official Study and Reference Guide, Chapter on Post-Design ValidationandTroubleshooting
NEW QUESTION # 274
What service must be implemented on your customer's network to authenticate users against an LDAP database before granting access to the WLAN infrastructure?
  • A. SSH
  • B. RADIUS
  • C. TLS
  • D. SFTP
To authenticate users against an LDAP database for WLAN access, a RADIUS (Remote Authentication Dial- In User Service) server must be implemented. RADIUS acts as an intermediary between the WLAN infrastructure and the LDAP directory, facilitating authentication requests. When a user attempts to connect to the WLAN, the access point forwards the authentication request to the RADIUS server, which then queries the LDAP directory to verify the user's credentials. This integration ensures centralized authentication and enhances security by leveraging existing directory services.
Reference: CWDP-305 Official Study and Reference Guide, Chapter on Designing for Specific Applications
NEW QUESTION # 275
Looking at a client radio specification sheet that states Receive Sensitivity of #82 dBm @ 18 Mbps would mean:
  • A. It would need to hear a signal <#82 dBm in order to use the 24 Mbps PHY rate.
  • B. It must hear a signal <#82 dBm in order to demodulate the 18 Mbps PHY rate.
  • C. It is only capable of transmitting at 18 Mbps PHY rates at #82 dBm.
  • D. It must hear a signal >#82 dBm in order to demodulate the 18 Mbps PHY rate.
Receive sensitivity indicates the minimum signal strength at which a device can successfully receive and demodulate a signal at a specified data rate.In this case, a receive sensitivity of #82 dBm @ 18 Mbps means that the device requires a signal stronger than #82 dBm to reliably demodulate data at 18 Mbps.Therefore, the device must receive a signal with a strength greater than #82 dBm (i.e., closer to 0 dBm) to maintain that data rate.
NEW QUESTION # 276
Main Topic:Infrastructure Design
Question:
To increase capacity in a coverage-based wireless network, which of the following techniques are typically recommended? (Choose all that apply.)
  • A. Add additional APs and use directional antennas.
  • B. Turn up power on the access points.
  • C. Lower power on the access points and, after careful planning, add more APs.
  • D. Maximize airtime usage by disabling lower data rates.
Answer: A,C,D
Increasing capacity in a coverage-based wireless network involves optimizing the network to handle more clients and traffic efficiently. The recommended techniques include:
A: Maximize airtime usage by disabling lower data ratesisabling lower data rates (e.g., 1 Mbps, 2 Mbps) reduces the time the medium is occupied by slower transmissions, thereby increasing overall network efficiency and capacity.
B: Add additional APs and use directional antennaseploying more access points (APs) with directional antennas helps in segmenting the coverage area, reducing co-channel interference, and increasing capacity by allowing more simultaneous transmissions in different directions.
D: Lower power on the access points and, after careful planning, add more APs:Reducing the transmit power of APs minimizes overlap and interference between cells. After careful planning, adding more APs ensures coverage continuity and increases capacity by distributing the load among more APs.
C: Turn up power on the access points:Increasing the transmit power can lead to excessive overlap between cells, causing interference and reducing overall network capacity. Therefore, this is not a recommended practice for increasing capacity.
Reference:CWDP-305 Study Guide, Chapter on Infrastructure Design - Capacity Planning Techniques.
NEW QUESTION # 277
What are the three biggest WLAN enterprise verticals?(Choose all that apply.) Response:
  • A. Education
  • B. Office environments
  • C. Retail
  • D. Healthcare
  • E. Warehouses
Answer: A,C,D
NEW QUESTION # 278
With pass rate reaching 98.75%, CWDP-305 exam torrent has received great popularity among candidates, and they think highly of the exam dumps. In addition, CWDP-305 exam braindumps are high-quality and accuracy, because we have professionals to verify the answers to ensure the accuracy. CWDP-305 exam dumps have most of knowledge points for the exam, and you can mater the major points through practicing. In addition, we have online and offline chat service for CWDP-305 Exam Dumps, and they posse the professional knowledge for the exam. If you have any questions about CWDP-305 exam materials, you can have a conversation with us.
Exam CWDP-305 Bible: https://www.practicetorrent.com/CWDP-305-practice-exam-torrent.html
Our reliable CWDP-305 best questions will be an easy way to help them get success, Our CWDP-305 exam cram pdf usually don't contain hundreds of questions and dumps, Our experts made significant contribution to their excellence of the CWDP-305 study materials, CWNP Exam CWDP-305 Certification Cost As one of the exam candidates of the exam, we assure you know the importance of picking up the most perfect practice material, CWNP Exam CWDP-305 Certification Cost If you have encountered some problems in using our products, you can always seek our help.
For exam candidates of this area, we suggest that certificates CWDP-305 are one of the essential factors to help you stand out, You can adjust the test pattern according to your weakness points and pay attention to the questions you make mistake frequently with the help of CWDP-305 valid online test engine.
CWDP-305 reliable test collection & CWDP-305 latest exam guide & CWDP-305 exam study solutionsOur reliable CWDP-305 best questions will be an easy way to help them get success, Our CWDP-305 exam cram pdf usually don't contain hundreds of questions and dumps.
Our experts made significant contribution to their excellence of the CWDP-305 study materials, As one of the exam candidates of the exam, we assure you know the importance of picking up the most perfect practice material.
If you have encountered some problems Exam CWDP-305 Certification Cost in using our products, you can always seek our help.
