[General] Quiz ISTQB - CT-AI - Certified Tester AI Testing Exam Perfect Latest Training
98
【General】 Quiz ISTQB - CT-AI - Certified Tester AI Testing Exam Perfect Latest Training
Posted at 2/5/2026 06:29:09      View:143 | Replies:1        Print      Only Author   [Copy Link] 1#
BONUS!!! Download part of Prep4sures CT-AI dumps for free: https://drive.google.com/open?id=16z9COrMdMyxCZgkGPmiN4GSH4IEZDDkD
Our company is a professional certificate exam materials provider, and we have occupied in this field for years. Our company is in the leading position in exam materials providing. CT-AI exam materials of us have high pass rate, and you can pass it by using them, and money back guarantee for your failure. CT-AI Exam Materials have the questions and answers and therefore you can practice the question and check the answers in a quite convenient way. We also offer you free update for one year, and you can get the latest version timely if you buy the CT-AI exam dumps from us.
ISTQB CT-AI Exam Syllabus Topics:
  • Using AI for Testing: In this section, the exam topics cover categorizing the AI technologies used in software testing.
  • systems from those required for conventional systems.
  • ML Functional Performance Metrics: In this section, the topics covered include how to calculate the ML functional performance metrics from a given set of confusion matrices.
  • Testing AI-Based Systems Overview: In this section, focus is given to how system specifications for AI-based systems can create challenges in testing and explain automation bias and how this affects testing.
Topic 5
  • Testing AI-Specific Quality Characteristics: In this section, the topics covered are about the challenges in testing created by the self-learning of AI-based systems.
Topic 6
  • Quality Characteristics for AI-Based Systems: This section covers topics covered how to explain the importance of flexibility and adaptability as characteristics of AI-based systems and describes the vitality of managing evolution for AI-based systems. It also covers how to recall the characteristics that make it difficult to use AI-based systems in safety-related applications.
Topic 7
  • Introduction to AI: This exam section covers topics such as the AI effect and how it influences the definition of AI. It covers how to distinguish between narrow AI, general AI, and super AI; moreover, the topics covered include describing how standards apply to AI-based systems.
Topic 8
  • Machine Learning ML: This section includes the classification and regression as part of supervised learning, explaining the factors involved in the selection of ML algorithms, and demonstrating underfitting and overfitting.
ISTQB CT-AI Features of PDFOnly to find a way to success, not to make excuses for failure. Prep4sures's CT-AI exam certification training materials include CT-AI exam dumps and answers. The data is worked out by our experienced team of IT professionals with their own exploration and continuous practice. Prep4sures's CT-AI Exam Certification training materials have high accuracy and wide coverage. It will be a grand helper that will accompany you to prepare for CT-AI certification exam.
ISTQB Certified Tester AI Testing Exam Sample Questions (Q83-Q88):NEW QUESTION # 83
Upon testing a model used to detect rotten tomatoes, the following data was observed by the test engineer, based on certain number of tomato images.
For this confusion matrix which combinations of values of accuracy, recall, and specificity respectively is CORRECT?
SELECT ONE OPTION
  • A. 1,0.9, 0.8
  • B. 0.84.1,0.9
  • C. 1,0.87,0.84
  • D. 0.87.0.9. 0.84
To calculate the accuracy, recall, and specificity from the confusion matrix provided, we use the following formulas:
* Confusion Matrix:
* Actually Rotten: 45 (True Positive), 8 (False Positive)
* Actually Fresh: 5 (False Negative), 42 (True Negative)
* Accuracy:
* Accuracy is the proportion of true results (both true positives and true negatives) in the total population.
* Formula: Accuracy=TP+TNTP+TN+FP+FN        ext{Accuracy} = rac{TP + TN}{TP + TN + FP + FN}Accuracy=TP+TN+FP+FNTP+TN
* Calculation: Accuracy=45+4245+42+8+5=87100=0.87        ext{Accuracy} = rac{45 + 42}{45 + 42
+ 8 + 5} = rac{87}{100} = 0.87Accuracy=45+42+8+545+42=10087=0.87
* Recall (Sensitivity):
* Recall is the proportion of true positive results in the total actual positives.
* Formula: Recall=TPTP+FN        ext{Recall} = rac{TP}{TP + FN}Recall=TP+FNTP
* Calculation: Recall=4545+5=4550=0.9        ext{Recall} = rac{45}{45 + 5} = rac{45}{50} = 0.9 Recall=45+545=5045=0.9
* Specificity:
* Specificity is the proportion of true negative results in the total actual negatives.
* Formula: Specificity=TNTN+FP        ext{Specificity} = rac{TN}{TN + FP}Specificity=TN+FPTN
* Calculation: Specificity=4242+8=4250=0.84        ext{Specificity} = rac{42}{42 + 8} = rac{42}
{50} = 0.84Specificity=42+842=5042=0.84
Therefore, the correct combinations of accuracy, recall, and specificity are 0.87, 0.9, and 0.84 respectively.
ISTQB CT-AI Syllabus, Section 5.1, Confusion Matrix, provides detailed formulas and explanations for calculating various metrics including accuracy, recall, and specificity.
"ML Functional Performance Metrics" (ISTQB CT-AI Syllabus, Section 5).
NEW QUESTION # 84
Consider an AI-system in which the complex internal structure has been generated by another software system. Why would the tester choose to do black-box testing on this particular system?
  • A. Black-box testing eliminates the need for the tester to understand the internal structure of the AI-system
  • B. Test automation can be built quickly and easily from the test cases developed during black-box testing
  • C. The tester wishes to better understand the logic of the software used to create the internal structure
  • D. The black-box testing method will allow the tester to check the transparency of the algorithm used to create the internal structure
The syllabus explains:
"Where the internal structure of an AI-based system is too complex for humans to understand, the system can only be tested as a black box. Even when the internal structure is visible, this provides no additional useful information to help with testing." This confirms that black-box testing is chosen because the tester does not need to understand the system's internal structure.
(Reference: ISTQB CT-AI Syllabus v1.0, Section 8.5, page 61 of 99)
NEW QUESTION # 85
Which challenge to testing self-learning systems puts you at risk of a data attack?
Choose ONE option (1 out of 4)
  • A. Insufficient testing time
  • B. Inadequate specification of the operating environment
  • C. Complex test environment
  • D. Unexpected changes
The ISTQB CT-AI syllabus describes thatself-learning systems continuously adjust their behaviorduring operation as new data arrives. Section4.1 - Challenges of Testing AI-Based Systemshighlights that such systems are vulnerable todata attacks, particularly through adversarial inputs, poisoning, or malicious drift.
The risk arises because unexpected changes in the input distribution may alter the learned model in harmful ways. OptionD - Unexpected changescorresponds directly to this syllabus-defined risk.
Option A refers to system specification issues but does not relate to data attacks. Option B discusses environment complexity, which makes testing difficult but is not tied to adversarial threats. Option C (insufficient testing time) affects quality but does not specifically increase vulnerability to malicious data manipulation.
Unexpected changes-including data drift, poisoned samples, or maliciously constructed training data-pose the greatest risk. When a self-learning system adapts to altered data patterns, it may unknowingly learn incorrect associations, causing model degradation or manipulation. Therefore,Option Dcorrectly identifies the challenge that increases exposure to data attacks.
NEW QUESTION # 86
Which of the following statements about the structure and function of neural networks is true?
  • A. The input layer of a deep neural network must have at least as many neurons as its output layer
  • B. Training a neural network only changes the values of the weights at the connections between neurons
  • C. A single-layer perceptron is NOT a neural network
  • D. The bias of a neuron is determined by the activation values of the neurons in the previous layer
Section1.7 - Neural Networksof the ISTQB CT-AI syllabus explains that neural networks consist of neurons connected by weighted links. During training,learning occurs by adjusting the weights on these connections. This is the essence of gradient descent and backpropagation. Option B correctly states this behavior: only theweightsare modified, not the activation functions, neuron counts, or architectural structure.
Option A is incorrect because a neuron'sbiasis not determined by previous activations; it is an independent trainable parameter added to the weighted input sum. Option C is incorrect because the syllabus states that a single-layer perceptron is a valid type of neural network, although limited to linearly separable problems.
Option D is incorrect because no rule requires the number of input neurons to exceed or equal the number of output neurons. Instead, input neurons correspond to thenumber of features, while output neurons correspond totasks or classes.
Therefore,Option Bprecisely reflects the syllabus definition of what changes during neural network training.
NEW QUESTION # 87
Which statement about automation bias is correct?
  • A. Automation bias is tested with representative users, but human input quality is irrelevant
  • B. When testing AI-based systems, automation bias does not play a role in supporting test activities such as boundary value analysis
  • C. Automation bias affects the testing of AI-based systems that support users in their actions or decisions
  • D. Automation bias particularly affects testing of autonomous systems
Automation bias is defined in Section4.4 - Human Factors in AI Testingof the ISTQB CT-AI syllabus. It refers to the human tendency to overly trust, rely on, or defer to automated system outputs. The syllabus explains that this bias arises especially indecision-support systems, where humans may accept AI judgments without adequate verification. This aligns directly with Option B.
Option A is incorrect: automation biasdoesinfluence testing, especially when testers rely excessively on AI outputs. The syllabus cautions about testers adopting the same cognitive biases as end users. Option C is incorrect because autonomous systems are not the primary context; rather,systems supporting human decisionsare most impacted. Option D is incorrect because the quality of human inputmatters significantly, and poorly designed user studies can mask or distort automation bias.
Thus,Option Bis the syllabus-accurate description of automation bias.
NEW QUESTION # 88
Prep4sures is a website that provide the counseling courses for IT professionals to participate in ISTQB certification CT-AI exam and help them get the ISTQB CT-AI certification. The courses of Prep4sures is developed by experienced experts' extensive experience and expertise and the quality is very good and have a very fast update rate. Besides, exercises we provide are very close to the real exam questions, almost the same. When you select Prep4sures, you are sure to 100% pass your first time to participate in the difficult and critical ISTQB Certification CT-AI Exam.
CT-AI Dumps PDF: https://www.prep4sures.top/CT-AI-exam-dumps-torrent.html
P.S. Free 2026 ISTQB CT-AI dumps are available on Google Drive shared by Prep4sures: https://drive.google.com/open?id=16z9COrMdMyxCZgkGPmiN4GSH4IEZDDkD
Posted at 2/16/2026 22:42:26        Only Author  2#
Your article is astonishing, I truly appreciate you sharing it! Ready for the Exam MB-280 exercise exam – hope I pass with flying colors!
