[General] Microsoft MS-102 Study Guides, MS-102 Pass Guarantee
55
General Microsoft MS-102 Study Guides, MS-102 Pass Guarantee
Posted at 2/5/2026 09:10:19      View133 | Replies0        Print      Only Author   [Copy Link] 1#
What's more, part of that PassExamDumps MS-102 dumps now are free: https://drive.google.com/open?id=1jSH_BBPLFw6idDtyYU8KFvvvP_KXWb4m
There are numerious MS-102 exam dumps for the candidates to select for their preparation the exams, some candidates may get confused by so many choice. Our MS-102 learning materials have free demo for the candidates, and they will have a general idea about the MS-102 Learning Materials. You can obtain the MS-102 learning materials for about ten minutes. The payment is also quite easy: online payment with credit card, and the private information of the you is also guaranteed.
Microsoft MS-102 Exam Syllabus Topics:
  • Manage security and threats by using Microsoft Defender XDR: This topic discusses how to use Microsoft Defender portal to manage security reports and alerts. It also focuses on usage of Microsoft Defender for Office 365 to implement and manage email and collaboration protection. Lastly, it discusses the usage of Microsoft Defender for Endpoint for the implementation and management of endpoint protection.
  • Implement and manage Microsoft Entra identity and access: In this topic, questions about Microsoft Entra tenant appear. Moreover, it delves into implementation and management of authentication and secure access.
  • Deploy and manage a Microsoft 365 tenant: Management of roles in Microsoft 365 and management of users and groups are discussion points of this topic. It also focuses on implementing and managing a Microsoft 365 tenant.
  • Manage compliance by using Microsoft Purview: Implementation of Microsoft Purview information protection and data lifecycle management is discussed in this topic. Moreover, questions about implementing Microsoft Purview data loss prevention (DLP) also appear.
Microsoft 365 Administrator exam dumps & MS-102 training pdf & Microsoft 365 Administrator valid torrentIf you want to pass the exam smoothly buying our MS-102 study materials is your ideal choice. They can help you learn efficiently, save your time and energy and let you master the useful information. Our passing rate of MS-102 study materials is very high and you neednt worry that you have spent money and energy on them but you gain nothing. We provide the great service after you purchase our MS-102 Study Materials and you can contact our customer service at any time during one day.
Microsoft 365 Administrator Sample Questions (Q102-Q107):NEW QUESTION # 102
HOTSPOT
You have a Microsoft 365 subscription that contains the users shown in the following table.
You need to configure a dynamic user group that will include the guest users in any department that contains the word Support.
How should you complete the membership rule? To answer, select the appropriate options in the answer area.
Box 1: -eq "Guest"
Dynamic membership rules for groups in Azure Active Directory
Supported expression operators
The following table lists all the supported operators and their syntax for a single expression. Operators can be used with or without the hyphen (-) prefix. The Contains operator does partial string matches but not item in a collection matches.
* Equals
-eq
* Contains
-contains
* Etc.
Box 2: -contains "Support"
Incorrect:
* -in
If you want to compare the value of a user attribute against multiple values, you can use the -in or -notIn operators.
https://learn.microsoft.com/en-u ... -dynamic-membership
NEW QUESTION # 103
Your network contains an on-premises Active Directory domain named contoso.com. The domain contains 1,000 Windows 10 devices.
You perform a proof of concept (PoC) deployment of Microsoft Defender for Endpoint for 10 test devices. During the onboarding process, you configure Microsoft Defender for Endpoint-related data to be stored in the United States.
You plan to onboard all the devices to Microsoft Defender for Endpoint.
You need to store the Microsoft Defender for Endpoint data in Europe.
What should you do first?
  • A. Delete the workspace.
  • B. Offboard the test devices.
  • C. Create a workspace.
  • D. Onboard a new device.
Storage locations
Understand where Defender for Cloud stores data and how you can work with your data:
* Machine information
- Stored in a Log Analytics workspace.
- You can use either the default Defender for Cloud workspace or a custom workspace. Data is stored in accordance with the workspace location.
https://learn.microsoft.com/en-u ... vers-data-workspace
NEW QUESTION # 104
You have a Microsoft 365 E5 subscription.
You need to configure Microsoft Defender for Office 365 to meet the following requirements:
* A user's email sending patterns must be used to minimize false positives for spoof protection.
* Documents uploaded to Microsoft Teams, SharePoint Online, and OneDrive must be protected by using Defender for Office 365.
What should you configure for each requirement? To answer, select the appropriate options in the answer area.
NEW QUESTION # 105
You have a Microsoft Azure Active Directory (Azure AD) tenant named Contoso.com.
You create a Microsoft Defender for identity instance Contoso.
The tenant contains the users shown in the following table.
You need to modify the configuration of the Defender for identify sensors.
Solutions: You instruct User3 to modify the Defender for identity sensor configuration.
Does this meet the goal?
  • A. No
  • B. Yes
NEW QUESTION # 106
You have a Microsoft 365 subscription.
You have the retention policies shown in the following table.
Both policies are applied to a Microsoft SharePoint site named Site1 that contains a file named File1.docx.
File1.docx was created on January 1, 2022 and last modified on January 31,2022. The file was NOT modified again.
When will File1.docx be deleted automatically?
  • A. January 31, 2024
  • B. January 1,2024
  • C. never
  • D. January 1,2023
  • E. January 31, 2023
Retention wins over deletion.
Note:
Explanation for the four different principles:
1. Retention wins over deletion. Content won't be permanently deleted when it also has retention settings to retain it. While this principle ensures that content is preserved for compliance reasons, the delete process can still be initiated (user-initiated or system-initiated) and consequently, might remove the content from users' main view. However, permanent deletion is suspended.
2. Etc.
https://learn.microsoft.com/en-u ... ompliance/retention
NEW QUESTION # 107
We often regard learning as a torture. Actually, learning also can become a pleasant process. With the development of technology, learning methods also take place great changes. Take our MS-102 practice material for example. All of your study can be completed on your computers because we have developed a kind of software which includes all the knowledge of the MS-102 exam. The simulated and interactive learning environment of our test engine will greatly arouse your learning interests. You will never feel boring and humdrum. Your strong motivation will help you learn effectively. If you are tired of memorizing the dull knowledge point, our MS-102 Test Engine will assist you find the pleasure of learning. Time is priceless. Learn something when you are still young. Then you will not regret when you are growing older.
MS-102 Pass Guarantee: https://www.passexamdumps.com/MS-102-valid-exam-dumps.html
P.S. Free 2026 Microsoft MS-102 dumps are available on Google Drive shared by PassExamDumps: https://drive.google.com/open?id=1jSH_BBPLFw6idDtyYU8KFvvvP_KXWb4m
