[General] 試験の準備方法-最高の300-540復習教材試験-有難い300-540関連日本語版問題集
98
【General】 試験の準備方法-最高の300-540復習教材試験-有難い300-540関連日本語版問題集
Posted at 2/5/2026 12:15:18      View:119 | Replies:1        Print      Only Author   [Copy Link] 1#
ちなみに、CertJuken 300-540の一部をクラウドストレージからダウンロードできます:https://drive.google.com/open?id=1dFdA4x2HkA57aE4lU1KbhQv-wj-epQz1
Ciscoの300-540試験にリラクスで合格するのも可能性があります。我々CertJukenの提供するCiscoの300-540試験のソフトを利用した多くのお客様はこのような感じがあります。弊社の無料デモをダウンロードしてあなたはもっと真実に体験することができます。我々は弊社の商品を選ぶお客様に責任を持っています。あなたの利用しているCiscoの300-540試験のソフトが最新版のを保証しています。
Cisco 300-540 認定試験の出題範囲:
トピック出題範囲
トピック 1
  • Service Assurance and Optimization: This section of the exam measures the skills of Cloud Operations Engineers and covers assurance mechanisms used to maintain performance, stability, and visibility across NFVI environments. It includes network assurance concepts such as MANO frameworks, VNF workload monitoring, VIM control plane KPIs, and streaming telemetry with gRPC and gNMI. Candidates must understand cloud infrastructure performance monitoring tools, including SR-PM, NetFlow, IPFIX, syslog, SNMP traps, RMON, cloud agents, and automated fault management systems. The domain also touches on diagnosing NFVI-related errors and optimizing VNFs using techniques such as SR-IOV and software-accelerated virtual switching technologies like DPDK and VPP.
トピック 2
  • High Availability: This section of the exam measures the skills of Cloud Infrastructure Architects and covers the design and implementation of redundancy and resiliency mechanisms in virtualized network functions and distributed cloud platforms. It includes data plane redundancy for VNFs, high availability within a single VIM control plane, and resilient compute, vNIC, and top-of-rack switching. The exam requires an understanding of multi-homing, EVLAG configurations, virtual private cloud deployment, and ECMP strategies for NFVI integrations with physical routing protocols such as BGP, OSPF, and IS-IS. Candidates must also recommend suitable high-availability models involving DNS, routing, and load balancing.
トピック 3
  • Security: This section of the exam measures the skills of Network Security Engineers and covers the implementation of infrastructure-level protection in cloud and NFVI ecosystems. It includes topics such as ACLs, uRPF, RTBH, router hardening, BGP flowspec, TACACS, and MACSEC. Candidates should understand DoS mitigation methods and apply security practices within NFVI, focusing on API protection, securing the control and management plane, and segmentation strategies in service provider cloud environments. The domain also evaluates basic knowledge of TLS, mTLS, and general cloud security solutions related to DNS protection, zero-day defenses, and malware detection.
トピック 4
  • Cloud Interconnect: This section of the exam measures the skills of Service Provider Network Engineers and covers how large networks interconnect with cloud platforms and carrier-neutral facilities. Candidates are expected to understand various connectivity options to cloud providers, customer sites, and other neutral facilities, as well as evaluate WAN connectivity models such as direct connect, MPLS or segment routing, and IPsec VPN links. The domain also includes the ability to troubleshoot advanced data center interconnect solutions, including EVPN VXLAN, EVPN over SR
  • MPLS, ACI-based connectivity, and pseudowire architectures supporting cloud-to-cloud and cloud-to-edge communication.
トピック 5
  • Virtualized Architecture: This section of the exam measures the skills of Cloud Network Engineers and covers the foundational concepts of virtualized infrastructures used in modern service provider and cloud environments. Candidates are expected to understand constraints in IaaS designs, determine appropriate cloud service models, and demonstrate awareness of container orchestration compared to traditional virtual machines. The exam also evaluates the ability to implement key virtualization functions such as NFV, VNF, NSO, and virtualized Cisco platforms. Learners must be able to deploy NFV with automation tools, manage VNF onboarding, work with NSO-driven orchestration, and use protocols like NETCONF, RESTCONF, REST APIs, and gNMI within automated cloud ecosystems. A general understanding of supporting platforms such as OpenStack also forms part of the required knowledge in this domain.
300-540復習教材はDesigning and Implementing Cisco Service Provider Cloud Network Infrastructureをパスのに役立ちます今日、知識は精神労働よりも多くの富を生み出すことができるため、知識能力と精神労働は肉体労働よりも価値があります。ある分野で専門知識の能力を高めれば、多くの価値を生み出し、高収入で良い仕事を得ることができます。 300-540認定試験に合格すると、その達成に役立ちます。300-540トレーニング資料は、300-540テストの準備に最適な学習資料です。 300-540ガイド資料では、重要な情報を組み合わせて、クライアントが基盤を固め、時代とともに前進するのを支援します。
Cisco Designing and Implementing Cisco Service Provider Cloud Network Infrastructure 認定 300-540 試験問題 (Q138-Q143):質問 # 138
What does enabling gRPC allow in Cisco NFVI Assurance and Monitoring?
  • A. telemetry streaming
  • B. IPFIX monitoring
  • C. system logging
  • D. Cisco IOS NetFlow monitoring
Comprehensive and Detailed Explanation
In Cisco NFV Infrastructure (NFVI) Assurance and Monitoring, enabling gRPC activates the device's ability to support model-driven telemetry streaming.
Key points from Cisco SP Cloud/NFVI design principles:
gRPC is used as the transport protocol for model-driven telemetry.
Telemetry replaces traditional polling methods (SNMP, CLI scraping) with continuous, push-based updates.
It allows NFVI components to stream real-time operational data (CPU, memory, interfaces, VM metrics, fabric state) to collectors such as Cisco Crosswork, InfluxDB, Prometheus, or other analytic systems.
gRPC does not provide NetFlow/IPFIX export or syslog itself; those are separate subsystems.
Evaluation of options:
A). telemetry streaming - Correct. gRPC enables model-driven streaming telemetry.
B). IPFIX monitoring - Incorrect; IPFIX uses UDP exports, not gRPC.
C). Cisco IOS NetFlow monitoring - Incorrect; uses NetFlow export protocols.
D). system logging - Incorrect; syslog uses UDP/TCP, not gRPC.
質問 # 139
Logging with syslog supports network assurance by:
  • A. Enhancing physical network speeds
  • B. Enabling detailed event logging and analysis
  • C. Facilitating real-time performance adjustments
  • D. Reducing the need for automatic fault management
質問 # 140
Virtual Machines and Containers are both used to virtualize resources.
Which statement is true?
  • A. Containers virtualize the operating system, whereas VMs virtualize the hardware.
  • B. Containers are less isolated than VMs.
  • C. VMs are more lightweight than containers.
  • D. VMs can be deployed faster than containers.
質問 # 141
Yang models are utilized in NFV for what purpose?
  • A. To increase the complexity of network configurations
  • B. To decrease data model standardization
  • C. To define network elements and configurations
  • D. To manualize the configuration process
質問 # 142
Refer to the exhibit. An engineer must configure dual-homing with single active redundancy in a BGP EVPN VXLAN fabric. Which command must be run on the leaf router to complete the EVPN Ethernet segment configuration?
  • A. default-gateway advertise
  • B. vlan configuration 101
  • C. redundancy single-active
  • D. replication-type static
In a BGP EVPN VXLAN multi-homing design, Ethernet Segment Identifiers (ESIs) are used to represent a set of links from one or more leaf switches to the same downstream device (such as a CE, firewall, or aggregation switch). By default, when multiple leafs share the same ESI, the EVPN design supportsall-active redundancy, where all participating leafs can forward traffic for that Ethernet segment simultaneously.
However, some use cases-like connecting to devices that do not support multipath forwarding or for strict active/standby redundancy-requiresingle-activemulti-homing. In single-active mode, only one leaf in the Ethernet segment forwards traffic at any time; the other leaf(s) act as standby and only take over if the active node fails. This behavior is explicitly controlled in the EVPN Ethernet-segment configuration.
On Cisco platforms for EVPN VXLAN fabrics, this is configured under thel2vpn evpn ethernet-segment stanza using the command:
l2vpn evpn ethernet-segment 1
identifier type 0 01.01.01.10.10.10.10.10.10.10
* identifier type 0 ... defines the ESI for the multi-homed connection.
* redundancy single-active specifies that only one leaf in that ESI is allowed to be active at a time, thus enablingdual-homing with single-active redundancy.
The other options do not relate to Ethernet-segment redundancy mode:
* B. default-gateway advertiseis used in EVPN anycast gateway configurations to advertise the default gateway MAC/IP, not for ESI redundancy.
* C. replication-type staticis associated with multicast or ingress replication behavior for VXLAN VTEPs, not Ethernet-segment redundancy.
* D. vlan configuration 101is a VLAN configuration context command and has no effect on EVPN ESI redundancy.
質問 # 143
初心者でも経験豊富な人でも、CertJuken学習教材は、長年にわたる試験概要の変化と業界の傾向に基づいて編集された専門家にとって最適な選択です。 300-540テストトレントは、学習の効率を向上させるのに役立つだけでなく、レビュー時間を最大数か月から1か月、さらには2週間または3週間に短縮するのにも役立ちます。 最大の改善を得る。 そして、300-540試験問題により、Cisco、あなたのDesigning and Implementing Cisco Service Provider Cloud Network Infrastructure成功が保証されます。
300-540関連日本語版問題集: https://www.certjuken.com/300-540-exam.html
BONUS!!! CertJuken 300-540ダンプの一部を無料でダウンロード:https://drive.google.com/open?id=1dFdA4x2HkA57aE4lU1KbhQv-wj-epQz1
Posted at 2/15/2026 09:54:39        Only Author  2#
Liking this instantly, it’s that good! This is the Free INSTC_V8 vce dumps exam I took to get my promotion and pay raise, now available to you for free today. I hope you reach your professional goals soon!
