[General] SD-WAN-Engineer Authentic Exam Hub & Valid SD-WAN-Engineer Exam Fee
70
General SD-WAN-Engineer Authentic Exam Hub & Valid SD-WAN-Engineer Exam Fee
Posted at 2/5/2026 13:06:23      View149 | Replies3        Print      Only Author   [Copy Link] 1#
Our practice exams are designed solely to help you get your SD-WAN-Engineer certification on your first try. A Palo Alto Networks SD-WAN-Engineer practice test will help you understand the exam inside out and you will get better marks overall. It is only because you have practical experience of the exam even before the exam itself. TrainingQuiz offers authentic and up-to-date study material that every candidate can rely on for good preparation. Our top priority is to help you pass the Palo Alto Networks SD-WAN Engineer (SD-WAN-Engineer) exam on the first try. The key to passing the SD-WAN-Engineer exam on the first try is vigorous practice. And that's exactly what you'll get when you prepare from our material. Each format excels in its own way and helps you get success on the first attempt.
Palo Alto Networks SD-WAN-Engineer Exam Syllabus Topics:
  • Unified SASE: This domain covers Prisma SD-WAN integration with Prisma Access, ADEM configuration, IoT connectivity via Device-ID, Cloud Identity Engine integration, and User
  • Group-based policy implementation.
  • Planning and Design: This domain covers SD-WAN planning fundamentals including device selection, bandwidth and licensing planning, network assessment, data center and branch configurations, security requirements, high availability, and policy design for path, security, QoS, performance, and NAT.
  • Troubleshooting: This domain focuses on resolving connectivity, routing, forwarding, application performance, and policy issues using co-pilot data analysis and analytics for network optimization and reporting.
  • Operations and Monitoring: This domain addresses monitoring device statistics, controller events, alerts, WAN Clarity reports, real-time network visibility tools, and SASE-related event management.
Topic 5
  • Deployment and Configuration: This domain focuses on Prisma SD-WAN deployment procedures, site-specific settings, configuration templates for different locations, routing protocol tuning, and VRF implementation for network segmentation.
Valid SD-WAN-Engineer Exam Fee - Simulations SD-WAN-Engineer PdfDo you always feel boring and idle in you spare time? And having nothing to do is also making you feel upset? If the answer is yes, then you can make use of your spare time to learn our SD-WAN-Engineer practice quiz. No only that you will be bound to pass the exam and achieve the SD-WAN-Engineer Certification. In the meantime, you can obtain the popular skills to get a promotion in your company. In short, our SD-WAN-Engineer exam questions are the most convenient learning tool for diligent people.
Palo Alto Networks SD-WAN Engineer Sample Questions (Q23-Q28):NEW QUESTION # 23
Which component of Prisma SD-WAN is responsible for distributing User-IP and user-group mappings to branch devices that match the corresponding source IPs?
  • A. Controller
  • B. DC ION
  • C. Cloud Identity Engine
  • D. NGFW
In the Prisma SD-WAN architecture, the Controller serves as the centralized management and control plane for the entire fabric. While the Cloud Identity Engine (CIE) is the component responsible for collecting and consolidating user-to-IP mappings from various identity providers (such as Active Directory, Okta, or Azure AD), it does not directly manage the distribution of this operational data to the individual ION devices at the branch level.
Instead, the Prisma SD-WAN Controller integrates with the Cloud Identity Engine to ingest these identity mappings. Once the Controller has synchronized the User-IP and user-group information, it acts as the primary orchestrator. It is responsible for distributing these mappings down to the ION devices across all sites. This distribution ensures that when an ION device sees traffic from a specific source IP, it can accurately associate that traffic with a specific user or group based on the metadata provided by the Controller.
By centralizing this distribution through the Controller, Prisma SD-WAN ensures consistency across the network. Branch ION devices can then apply Application-Based Path Selection and security policies based on user identity rather than just IP addresses. This architectural design offloads the processing requirements of maintaining direct connections to identity providers from the branch hardware, allowing the Controller to handle the heavy lifting of orchestration and global synchronization of identity data.
NEW QUESTION # 24
An ION 3000 device at a remote branch has suffered a critical hardware failure and must be replaced via the RMA process. The administrator has received the replacement unit.
What is the correct procedure to transfer the configuration and license from the defective unit to the replacement unit to ensure minimal downtime and retention of historical data?
  • A. Delete the old device from the portal, create a new site for the replacement device, and rebuild the policies manually.
  • B. Backup the configuration of the old device to a USB drive and restore it to the new device using the local console.
  • C. Manually configure the new device from scratch, then open a support ticket to transfer the license.
  • D. Use the "Replace Device" workflow in the Prisma SD-WAN portal, which automatically transfers the configuration (Device Shell) and re-associates the site to the new serial number.
Comprehensive and Detailed Explanation
The RMA replacement process in Prisma SD-WAN is designed to be seamless, leveraging the decoupling of logical configuration from physical hardware.
Replace Device Workflow: The administrator should use the "Replace Device" (or RMA) function within the portal. This workflow allows you to select the "Defective" device (old serial) and the "Replacement" device (new serial).
Configuration Transfer: Once executed, the system automatically binds the existing Device Shell (which contains all interface configs, routing policies, and site associations) to the new hardware's serial number. The new device, once connected to the internet, will "call home," identify itself, and download the exact configuration of the previous unit.
License Transfer: While the configuration moves automatically, the Support License transfer typically requires a specific step in the Customer Support Portal (CSP) or happens automatically if processed as a formal RMA order. Options A and D are incorrect because they involve manual reconfiguration, which is unnecessary and error-prone. Option C is incorrect as the ION platform relies on cloud-based config management, not local USB backups for hardware swaps.
NEW QUESTION # 25
Which configuration requirement must be met to allow two branch ION devices to automatically establish a direct Dynamic VPN (branch-to-branch) connection for traffic flow, bypassing the Data Center?
  • A. The Data Center ION must be offline to trigger the dynamic failover.
  • B. A static "Gre Tunnel" must be manually configured between the two sites.
  • C. The "Standard VPN" path policy must be selected.
  • D. Both ION devices must be members of the same VPN Cluster.
Dynamic VPNs (also known as ION-to-ION or Branch-to-Branch VPNs) allow Prisma SD-WAN devices to establish direct, on-demand secure tunnels between branch sites to optimize latency for peer-to-peer traffic (e.
g., VoIP calls between offices).
To enable this capability, the primary architectural requirement is the configuration of VPN Clusters.
A VPN Cluster defines a logical group of devices that are authorized to communicate with one another.
* By default, or if devices are in different clusters without peering, the topology typically defaults to Hub- and-Spoke, where branches only talk to the Data Center.
* When two branch ION devices are placed into the same VPN Cluster (or peered clusters), the controller shares the necessary reachability and cryptographic information between them.
Once in the same cluster, the ION devices monitor traffic. If a user at Branch A tries to contact a server at Branch B, the ION devices detect this interest. If a direct path is available (e.g., via public internet), they will dynamically negotiate a direct VPN tunnel, bypassing the Data Center hub. This offloads the hub and reduces latency. Option B is incorrect because SD-WAN eliminates manual GRE config. Option C is incorrect because dynamic VPNs are a performance feature, not just a disaster recovery feature.
NEW QUESTION # 26
How can a network administrator detect a site outage or a service-level agreement (SLA) violation using controller-generated incidents?
  • A. Device logs, alerts, and incidents
  • B. Incidents, alerts, statistics, and audit logs
  • C. Incidents, SNMP traps, and audits
  • D. Priority alerts, informational alerts, and audit logs
In the Prisma SD-WAN ecosystem, the centralized cloud controller provides a robust multi-layered visibility framework to ensure network reliability. To effectively detect critical events like site outages or application performance issues (SLA violations), the controller aggregates several types of operational data. Incidents are the primary mechanism for high-level alerting; they are automatically generated when the system detects significant state changes, such as an ION device going offline (site outage) or a path failing to meet the required performance metrics.
While Incidents provide the "what" and "where," Alerts offer granular notifications for specific events that may not yet have escalated to a full-scale incident. To provide deep context, the controller also utilizes Statistics, which include real-time and historical telemetry regarding bandwidth, latency, jitter, and packet loss. These statistics allow administrators to visualize the specific SLA violation as it occurs. Furthermore, Audit logs are essential for tracking configuration changes or administrative actions that might have preceded an outage, helping engineers correlate human intervention with network behavior.
By combining these four elements-Incidents for major events, Alerts for specific notifications, Statistics for performance validation, and Audit logs for change tracking-a network administrator gains a 360-degree view of the fabric. This comprehensive approach moves beyond simple "up/down" monitoring, allowing for
"Day 2" operational excellence where performance degradation is identified and remediated before it impacts the end-user experience.
NEW QUESTION # 27
An administrator needs to generate a monthly report showing the "Top Applications" by bandwidth usage across all branch sites to justify a bandwidth upgrade.
Which specific component of the Prisma SD-WAN interface is designed to create, schedule, and email these PDF summaries?
  • A. Media Analytics
  • B. Activity Charts
  • C. Flow Browser
  • D. Reports
Prisma SD-WAN separates real-time visibility from historical summarization.
Reports (C): The Reports section is the dedicated engine for generating historical summaries. Administrators can create custom report templates (e.g., "Monthly Executive Summary") that include specific widgets like "Top Applications by Volume," "Site Availability," or "Circuit Utilization." Crucially, this feature allows for Scheduling, where the system automatically generates the PDF report at a set interval (e.g., first day of the month) and emails it to a distribution list.
Activity Charts (A) / Media Analytics (B): These provide interactive, visual graphs for ad-hoc analysis but are not designed for generating downloadable, scheduled PDF summaries for management.
Flow Browser (D): This is for deep-dive troubleshooting of individual sessions, not for high-level aggregate reporting.
NEW QUESTION # 28
You can learn SD-WAN-Engineer quiz torrent skills and theory at your own pace, and you are not necessary to waste your time on some useless books or materials and you will save more time and energy that you can complete other thing. We also provide every candidate who wants to get certification with free Demo to check our materials. No other SD-WAN-Engineer Study Materials or study dumps can bring you the knowledge and preparation that you will get from the SD-WAN-Engineer study materials available only from TrainingQuiz.
Valid SD-WAN-Engineer Exam Fee: https://www.trainingquiz.com/SD-WAN-Engineer-practice-quiz.html
Posted at 2/14/2026 16:28:09        Only Author  2#
The article gave me so many new ideas. The Valid C_P2W52_2410 test guide materials material is outstanding, and its free for you to use.
Posted at 2/19/2026 06:04:50        Only Author  3#
This content is worth every like. Im facing the Valid HPE7-A01 test question exam. Lets hope for a good result!
Posted at 2/21/2026 12:18:33        Only Author  4#
I feel like Ive gained so much from it. This Valid AZ-140 exam questions vce set helped me climb the career ladder and get a salary raise. Now, its available for free to all. Wishing you all the best in your professional growth!
