[Hardware] Dumps AP-209 Questions, AP-209 New Exam Camp
97
【Hardware】 Dumps AP-209 Questions, AP-209 New Exam Camp
Posted at 2/5/2026 14:40:57      View:122 | Replies:1        Print      Only Author   [Copy Link] 1#
DOWNLOAD the newest Pass4SureQuiz AP-209 PDF dumps from Cloud Storage for free: https://drive.google.com/open?id=1n4QIJvIfDGqJ7paZiSP7Zz9gGEj8AB1Z
With our AP-209 exam questions, you can adjust yourself to the exam speed and stay alert according to the time-keeper that we set on our AP-209 training materials. Therefore, you can trust on our products for this effective simulation function will eventually improve your efficiency and assist you to succeed in the AP-209 Exam. If you are ready, the AP-209 exam will just be a piece of cake in front of you. And our AP-209 exam questions are the right tool to help you get ready.
Salesforce AP-209 Exam Syllabus Topics:
  • Mobile: This domain covers offline functionality in the Field Service Mobile app, mobile customization and extension options, technician management capabilities, and communication features between dispatchers, technicians, and customers.
  • Resource Management: This domain focuses on managing resource availability, Service Territory Management capabilities, handling different resource types, and implementing optimal scheduling strategies for field service personnel.
  • Implementation Strategies and Design: This domain covers the full consulting project lifecycle from planning and requirements gathering through deployment, and determining appropriate deployment strategies and licensing needs for Field Service implementations.
  • Optimization: This domain covers using service objectives for automated scheduling, global optimization engine capabilities, troubleshooting optimization issues, and strategies to improve scheduling quality and efficiency.
New Salesforce AP-209 Dumps Get Ready With AP-209 Exam QuestionsIf you are determined to get the certification, our AP-209 question torrent is willing to give you a hand; because the study materials from our company will be the best study tool for you to get the certification. Now I am going to introduce our AP-209 Exam Question to you in detail, please read our introduction carefully, we can make sure that you will benefit a lot from it. If you are interest in it, you can buy it right now.
Salesforce Advanced Field Service Accredited Professional Sample Questions (Q17-Q22):NEW QUESTION # 17
Universal Containers has a job that requires two technicians, and both must possess the skills defined as
'Required' for that job. They need to show up at the same time and work through the entire job duration together. The technicians will also need to be able to be assigned to individual jobs later that day.
Which option should an architect recommend to support this scenario?
  • A. Service Crew Resource related to one Crew and two Crew Members assigned for the whole day
  • B. One Work Order, one child Service Appointment with one Assigned Resource and a Work Order Line Item to store the second resource. Set Resource Absence on the second resource for the duration of the joint service
  • C. One Work Order, two child Service Appointments with Appointment Dependency of 'Same Start' between them
  • D. One Work Order, one child Service Appointment and two Assigned Resources
This is a classic "Double-Booking" vs. "Complex Work" scenario.
* Option B is correct.To book two distinct people for the same work at the same time, you createtwo Service Appointments. You link them using aComplex Workdependency of typeSame Start4. This tells the optimization engine: "Find a time where Resource A (Appointment 1) and Resource B (Appointment 2) are BOTH free, and book them simultaneously."
* Option Ais incorrect because a single Service Appointment can typically only have oneactiveAssigned Resource for scheduling purposes in the standard optimization model (unless using Crew Management, but Crews are forstaticteams, not ad-hoc pairs).
* Option Dis incorrect because the requirement states they need to be assigned to "individual jobs later that day"5.Service Crewsare designed for resources who stay together all day. Breaking a crew apart for half a day is administratively difficult.
* Option Cis a hack (Resource Absence) that blocks the second tech's time but doesn't link them to the actual job details properly.
NEW QUESTION # 18
Universal Containers would like the Service Appointment times that are displayed on the 'Dispatcher Console' to reflect the actual times a field worker starts and completes the work. That way, if they finish early, they might be able to add additional work to the new white space.
What implementation approach should the Field Service consultant recommend?
  • A. Create a Service Appointment action for 'Check In' for the field worker to manually update the 'Status',
    'Scheduled Start' and 'Actual Start' fields. Create another Service Appointment action for 'Check Out' for the field worker to manually update the 'Status', 'Scheduled End' and 'Actual End' fields
  • B. Tell Universal Containers that it is not a best practice to change the 'Scheduled Start' and 'Scheduled End' fields. It would be good for Universal Containers to know what the original 'Scheduled Start' and the original 'Scheduled End' values were and compare them with the 'Actual Start' and 'Actual End' fields for reporting scheduling efficacy
  • C. Create a Field Service Mobile flow that will allow a field worker to update the 'Scheduled Start' and
    'Actual Start' fields when they change the 'Status' to 'In Progress' and updates the 'Scheduled End' and
    'Actual End' fields when they change the 'Status' to 'Completed'
  • D. Create two custom date/time fields to track the original scheduled times. Create a Field Service Mobile flow that will allow a field worker to update the 'Scheduled Start' and 'Actual Start' fields when they change the 'Status' to 'In Progress' and updates the 'Scheduled End' and 'Actual End' fields when they change the 'Status' to 'Completed'. Advise Universal Containers that there could be instances where the
    'Dispatcher Console' will not update right away if the field worker is offline
The requirement is specifically to free up white space on the Gantt when a tech finishes early.
* Option D is correct.The Gantt chart visual blocks are drawn based on Scheduled Start and Scheduled End. If a tech finishes a 2-hour job in 30 minutes, the Gantt bar will remain 2 hours long unless the Scheduled End is updated. By using aMobile Flowto updateboththe Actuals (for reporting) and the Scheduled (for the Gantt), the bar shrinks, revealing 1.5 hours of open availability for the dispatcher to utilize.
* Option C is the "urist" data view (don't change scheduled), but it fails the specific business requirement of allowing new work to be added immediately.
* Option A suggests creating custom fields for the original times, which is a valid part of the solution (to keep a history), but Option D describes the core functional mechanism (Flow updating the standard fields) required to achieve the Gantt behavior. The "Offline" warning in A is true but D is the more direct configuration answer.
NEW QUESTION # 19
Which parts of the 'Dispatcher Console' support adding Custom Actions? (Choose 3 options)
  • A. Individual Service Appointments in the Appointment list
  • B. Multiple Service Appointments in the Appointment list
  • C. Individual Service Resources in the Gantt
  • D. Multiple Service Resources in the Gantt
  • E. Child Service Territories in the Gantt
Answer: A,B,C
Custom Actions (configured in Field Service Settings) allow dispatchers to trigger Apex classes or Visualforce pages/components from the console.
* Option B is correct:You can add custom actions to theResource Liston the Gantt (e.g., right-click a technician's name to "Send SMS" or "Show on Map").
* Option E is correct:You can add custom actions to individualService Appointments(e.g., right-click an appointment bar or list item to "Reschedule" or "rint Label").
* Option D is correct:You can addMass Actionsto the Appointment List (select multiple checkboxes -> Actions -> "Bulk Dispatch").
* Note: You generally cannot perform custom actions on the "Service Territory" grouping headers (Option A) or multiple resources simultaneously (Option C) in the standard UI.
NEW QUESTION # 20
What is the best practice to upload a photo that is taken by the mobile worker to a Work Order? (Choose 2 options)
  • A. Post the photo via the 'Feed' tab
  • B. Use a quick action of type 'Attach File'
  • C. Leverage the Field Service Mobile flow and add image upload component
  • D. Use a quick action of type 'Upload Photo'
  • E. Edit the Work Order record through the SFS Mobile App and add the photo as an attachment
Salesforce Field Service provides specific tools for capturing rich media in a structured way.
* Option B is correct (Mobile Flow):This is the modern best practice. By using aFlowwith theFile Upload(or Image) screen component, you can guide the technician to take a photo at a specific step in the process (e.g., "Take a photo of the completed installation"). This ensures consistency.
* Option A is correct (Quick Action):You can configureQuick Actions(specifically Global or Object- Specific actions for File Uploads) in the Field Service Mobile app extension settings. This provides a one-tap button for technicians to launch the camera and attach a file directly to the record.
* Note: While Option D (Chatter Feed) is possible, it is unstructured data. Options A and B are the "Best Practice" recommendations for process adherence.
NEW QUESTION # 21
Universal Containers (UC) sell Service Contracts to their customers. One of the terms of the Service Contract determines that a UC technician will perform annual maintenance on all the customer's Assets until the contract expires.
UC would like to ensure that when a technician is sent to the customer, the maintenance work is completed in a single visit, and all covered Assets are listed on the Work Order's Service Report.
What Maintenance Plan configuration should a consultant recommend UC?
  • A. 'Work Order Generation Method' is set to blank and 'Service Appointment Generation Method' is set to
    'One Service Appointment per Work Order'
  • B. 'Work Order Generation Method' is set to 'One Work Order Line Item per Asset' and 'Service Appointment Generation Method' is set to 'One Service Appointment per Work Order'
  • C. 'Work Order Generation Method' is set to 'One Work Order per Asset' and 'Service Appointment Generation Method' is set to 'One Service Appointment per Work Order'
  • D. 'Work Order Generation Method' is set to 'One Work Order Line Item per Asset' and 'Service Appointment Generation Method' is set to 'One Service Appointment per Work Order Line Item'
This question tests the Maintenance Plan generation logic.
* Option D is correct.The requirement isSingle Visit(One Appointment) forMultiple Assets.
* One Work Order Line Item per Asset:This groups all the assets under asingleparent Work Order. Each asset gets its own line item (WOLI) for tracking purposes.
* One Service Appointment per Work Order:This creates asingleappointment for the parent Work Order. The technician arrives once and works through the list of line items (Assets).
* Option B("One Work Order per Asset") would create separate Work Orders (and likely separate Appointments) for every single asset, resulting in multiple visits or a cluttered schedule.
* Option C("One SA per WOLI") would explicitly create a separate appointment for every single asset line item, causing massive double-booking/overlap.
NEW QUESTION # 22
Thousands of Advanced Field Service Accredited Professional (AP-209) exam applicants are satisfied with our AP-209 practice test material because it is according to the latest Advanced Field Service Accredited Professional (AP-209) exam syllabus and we also offer up to 1 year of free Salesforce Dumps updates. Visitors of Pass4SureQuiz can check the Advanced Field Service Accredited Professional (AP-209) product by trying a free demo. Buy the AP-209 test preparation material now and start your journey towards success in the Advanced Field Service Accredited Professional (AP-209) examination.
AP-209 New Exam Camp: https://www.pass4surequiz.com/AP-209-exam-quiz.html
What's more, part of that Pass4SureQuiz AP-209 dumps now are free: https://drive.google.com/open?id=1n4QIJvIfDGqJ7paZiSP7Zz9gGEj8AB1Z
Posted at 3/6/2026 22:43:40        Only Author  2#
Fantastic work, instantly deserving of a like. MB-330 latest exam vce free test questions available for free—get ready for promotions and salary growth!
