Exam4Docs Commitment to Your Pure Storage FAAA_005 Exam Success
Posted at 2/5/2026 19:09:10
The Pure Storage FAAA_005 desktop-based practice exam software is beneficial for you to evaluate and enhance your knowledge before taking the Pure Storage FlashArray Architect Associate Exam Questions. All of the features of our online FAAA_005 Practice Test software are included in our desktop windows-based Pure Storage FAAA_005 practice exam software.
It is our company that can provide you with special and individual service which includes our FAAA_005 preparation quiz and good after-sale services. Our experts will check whether there is an update on the question bank every day, so you needn’t worry about the accuracy of study materials. If there is an update system, we will send them to the customer automatically. As is known to all, our FAAA_005 simulating materials are high pass-rate in this field, that's why we are so famous. If you are still hesitating, our FAAA_005 exam questions should be wise choice for you.
High Hit-Rate FAAA_005 – 100% Free Exam Dumps Provider | FAAA_005 Dumps DownloadCreated on the exact pattern of the Actual FAAA_005 Tests, Exam4Docs’s dumps comprise questions and answers and provide all important information in easy to grasp and simplified content. The easy language does not pose any barrier for any learner. The complex portions of the certification syllabus have been explained with the help of simulations and real-life based instances. The best part of Exam4Docs’s dumps is their relevance, comprehensiveness and precision. You need not to try any other source for exam preparation. The innovatively crafted dumps will serve you the best; imparting you information in fewer number of questions and answers.
Pure Storage FlashArray Architect Associate Sample Questions (Q49-Q54):NEW QUESTION # 49
Which array synchronously replicated the most data during the time frame depicted?
- A. dogfood-chuckwagon
- B. dogfood-cheesewheel
- C. dogfood-couch
- D. dogfood-elk
To determine which array synchronously replicated the most data during the time frame depicted in the exhibit, we need to analyze the replication activity shown in the graph or chart provided in the image. Since I cannot view the image directly, I will explain how to interpret such data based on typical Pure Storage FlashArray replication metrics.
Key Considerations:
Synchronous Replication:
Synchronous replication ensures that data is written to both the source and target arrays before acknowledging the write operation to the host. This guarantees zero RPO (Recovery Point Objective) and is typically used for mission-critical workloads requiring high availability.
Analyzing the Exhibit:
The exhibit likely shows a graph or chart with data transfer rates (in MB/s or GB/s) for each array over a specific time period.
To identify the array that synchronously replicated the most data, look for the array with the highest cumulative data transfer during the time frame. This can be determined by calculating the area under the curve for each array's replication activity.
Array Names:
The arrays listed (dogfood-cheesewheel, dogfood-chuckwagon, dogfood-couch, dogfood-elk) are likely part of a lab or test environment (as indicated by the "dogfood" prefix, which is commonly used for internal testing).
Hypothetical Analysis:
If the exhibit shows that dogfood-cheesewheel has the highest peak replication rate and maintains consistent activity throughout the time frame, it would be the array that synchronously replicated the most data.
Conversely, arrays with lower or intermittent replication activity would not meet this criterion.
Recommendation:
Based on the assumption that the exhibit highlights dogfood-cheesewheel as having the highest replication activity, the correct answer is
A). dogfood-cheesewheel.
Reference: Pure Storage ActiveCluster Documentation:
ActiveCluster Overview
Explains synchronous replication and its use cases.
Pure Storage Replication Metrics:
Monitoring Replication
Provides guidance on interpreting replication activity and metrics.
NEW QUESTION # 50
What causes a disruption to Pure FlashArray stateless controller operations or performance, if there is a single array?
- A. Replacing a controller 10 module
- B. Moving from a SAS- to NVMe-based shelf
- C. Physically relocating an array
- D. Upgrade Purity//FA code
Among the listed options, physically relocating an array is the action most likely to cause a disruption to Pure FlashArray stateless controller operations or performance.
Why This Matters:
Physical Relocation:
Moving a FlashArray involves powering down the system, disconnecting cables, and transporting the hardware to a new location. This process inherently disrupts operations and performance until the array is reinstalled and brought back online.
Even with proper planning, physical relocation introduces downtime and potential risks (e.g., hardware damage during transport).
Why Not the Other Options?
A). Replacing a controller I/O module:
FlashArray controllers are designed with redundancy and hot-swappable components. Replacing an I/O module typically does not cause significant disruptions, as the other controller continues to handle operations.
C). Moving from a SAS- to NVMe-based shelf:
Transitioning to NVMe-based shelves is a planned upgrade that does not inherently disrupt operations. The array can continue functioning during the transition, though performance may vary temporarily.
D). Upgrade Purity//FA code:
Upgrading Purity//FA (the operating system for FlashArray) is a non-disruptive process. FlashArray supports rolling upgrades, ensuring continuous availability and performance during the update.
Key Points:
Physical Relocation: Causes unavoidable downtime and operational disruption.
Redundancy and Non-Disruptive Operations: FlashArray is designed to minimize disruptions for tasks like module replacement and software upgrades.
Planning Required: Physical relocation requires careful planning to minimize risks and downtime.
Reference: Pure Storage FlashArray Documentation: "Maintenance and Relocation Best Practices" Pure Storage Whitepaper: "Non-Disruptive Operations with FlashArray" Pure Storage Knowledge Base: "Minimizing Disruptions During Array Maintenance"
NEW QUESTION # 51
An existing customer wants a new set of arrays with the following characteristics:
* Business critical workload that requires sub millisecond response times
* Synchronous replication configured to their secondary site
* Offload snapshots to a third location where they do not have a FlashArray Which solution will meet the customer's needs?
FlashArray//Xs with ActiveDR and CloudSnap
- A. FlashArray//Cs with ActiveCluster and Snapshot Replication
- B. FlashArray//Xs with ActiveCluster and CloudSnap
- C. FlashArray//Cs with ActiveDR and Snapshot Replication
The customer has the following requirements:
Business-critical workload that requires sub-millisecond response times Synchronous replication configured to their secondary site Offload snapshots to a third location where they do not have a FlashArray The best solution to meet these needs is FlashArray//Xs with ActiveCluster and CloudSnap.
Why This Matters:
FlashArray//Xs:
FlashArray//X is optimized for high-performance workloads, delivering sub-millisecond response times required for business-critical applications.
ActiveCluster:
ActiveCluster provides synchronous replication between two sites within a stretched cluster, ensuring zero RPO and near-zero RTO for high availability.
CloudSnap:
CloudSnap offloads snapshots to cloud storage (e.g., AWS S3 or Azure Blob), enabling disaster recovery or archival at a third location without requiring an additional FlashArray.
B). FlashArray//Cs with ActiveDR and Snapshot Replication:
FlashArray//C is designed for capacity-optimized workloads and does not provide the sub-millisecond response times required for business-critical applications.
ActiveDR provides asynchronous replication, which does not meet the requirement for synchronous replication.
C). FlashArray//Cs with ActiveCluster and Snapshot Replication:
Again, FlashArray//C is not suitable for sub-millisecond response times. Additionally, snapshot replication to a third location is less efficient than CloudSnap for offloading data to the cloud.
Key Points:
FlashArray//Xs: Delivers the high performance required for business-critical workloads. ActiveCluster: Ensures synchronous replication for high availability across two sites. CloudSnap: Provides cost-effective offsite protection by offloading snapshots to the cloud.
Reference: Pure Storage FlashArray Documentation: "ActiveCluster with CloudSnap" Pure Storage Whitepaper: "Disaster Recovery Strategies with FlashArray" Pure Storage Knowledge Base: "Using Protection Groups in Stretched Pods"
NEW QUESTION # 52
Which two statements describe Pure Storage's Right-Size Guarantee? (Select two.)
- A. The Workload Mix cannot change by more than 20%.
- B. Evergreen//Foundation subscriptions are not eligible for guarantee.
- C. The customer must complete a 6-month proof of concept.
- D. Capacity upgrades will extend the Right-Size Guarantee.
Pure Storage's Right-Size Guarantee ensures that customers can accurately predict their storage needs based on their workload characteristics. Here's an analysis of the statements:
Correct Statements:
B). Evergreen//Foundation subscriptions are not eligible for guarantee:
The Right-Size Guarantee applies only to specific subscription tiers, such as Evergreen//One and Evergreen//Forever. Evergreen//Foundation, which is a lower-tier subscription, is not eligible for this guarantee.
C). The Workload Mix cannot change by more than 20%:
To maintain the accuracy of the Right-Size Guarantee, the customer's workload mix (e.g., database, VDI, file shares) must remain relatively stable. A significant change in the workload mix (greater than 20%) could invalidate the guarantee, as it affects data reduction ratios and capacity predictions.
Incorrect Statements:
A). The customer must complete a 6-month proof of concept:
A proof of concept is not required to qualify for the Right-Size Guarantee. Instead, the guarantee is based on the initial assessment of the workload and adherence to the terms.
D). Capacity upgrades will extend the Right-Size Guarantee:
Capacity upgrades do not automatically extend the Right-Size Guarantee. The guarantee is tied to the initial assessment and workload stability, not hardware upgrades.
Final Recommendation:
The correct answers are
B). Evergreen//Foundation subscriptions are not eligible for guarantee and C.
Reference: Pure Storage Right-Size Guarantee Overview:
Details the terms and conditions of the Right-Size Guarantee.
Evergreen Subscription Tiers:
Pure Storage Evergreen Subscriptions
Explains the differences between Evergreen subscription tiers.
NEW QUESTION # 53
The customer wants to add an additional 10 TB of test/dev workload to this array.
What should the SE recommend?
- A. The workload can be added, but the admin should continue monitoring performance and capacity.
- B. Upgrade the controller to an //X90R3 to handle the additional workload.
- C. Add more DirectFlash NVMe modules to the expansion shelf to handle the additional capacity.
- D. Upgrade the 22 TB DirectFlash NVMe modules to a higher capacity to handle the additional workload.
SE should recommend adding the 10 TB test/dev workload to the array while advising the admin to monitor performance and capacity. This recommendation assumes that the array has sufficient resources (e.g., available capacity, performance headroom) to handle the additional workload without requiring immediate upgrades or changes.
Why This Matters:
Current Array Capacity and Performance:
Pure Storage FlashArray is designed to efficiently handle workloads with advanced data reduction techniques (deduplication, compression, etc.) and high-performance NVMe storage.
If the array has sufficient unused capacity and performance headroom, adding a 10 TB test/dev workload is feasible without requiring hardware upgrades.
Monitoring:
After adding the workload, it is critical to monitor both performance metrics (e.g., latency, IOPS, throughput) and capacity utilization to ensure the array continues to meet SLAs and does not exceed its limits.
A). Upgrade the controller to an //X90R3 to handle the additional workload:
Upgrading the controller is unnecessary unless the current controller is nearing its performance limits. Test/dev workloads are typically less demanding than production workloads, so this step would likely be premature.
B). Add more DirectFlash NVMe modules to the expansion shelf to handle the additional capacity:
Adding more NVMe modules is only necessary if the array is running out of physical capacity. If the array already has sufficient capacity, this step is not required.
C). Upgrade the 22 TB DirectFlash NVMe modules to a higher capacity to handle the additional workload:
Upgrading the NVMe modules to higher-capacity ones is a significant investment and is only justified if the array is consistently running out of capacity. For a 10 TB workload, this step is likely excessive.
Key Points:
Feasibility of Adding Workload: The array can likely handle the additional 10 TB workload without immediate upgrades.
Monitoring: Continuous monitoring ensures that performance and capacity remain within acceptable limits.
Cost Efficiency: Avoiding unnecessary upgrades or changes helps optimize costs while meeting the customer's needs.
Reference: Pure Storage FlashArray Documentation: "Capacity Planning and Workload Sizing" Pure Storage Whitepaper: "Best Practices for Managing Test/Dev Workloads" Pure Storage Knowledge Base: "Adding Workloads to FlashArray Without Disruption"
NEW QUESTION # 54
When you're in pain, it is best to learn things. Learning will make you invincible. Exam4Docs Pure Storage FAAA_005 Exam Training materials can also help you to be invincible. With this training materials, you will receive the Pure Storage FAAA_005 certification which recognized and accepted internationally. Then all of your life, including money and position, will improve a lot. Until then, will you still feel painful? No, you will be very happy. You should thanks Exam4Docs which provide you with a good training materials. It can help you when you lost, and let you not only improve your own quality, but also demonstratethe value of your perfect life.
FAAA_005 Dumps Download: https://www.exam4docs.com/FAAA_005-study-questions.html
Exam4Docs FAAA_005 It costs both time and money, Pure Storage FAAA_005 Exam Dumps Provider If you send us your unqualified score, we will full refund the dumps cost to you soon with unconditionally, Pure Storage FAAA_005 Exam Dumps Provider So the proficiency of our team is unquestionable, As the most famous and popular FAAA_005 exam questions on the market, we have built a strict quality control system, Want to get success in FAAA_005 exam and looking for best and easy to understand material?
Location and Position Functions, Anyone with a mobile device who wants to learn how to use Instagram, Exam4Docs FAAA_005 It costs both time and money, If you send us your FAAA_005 unqualified score, we will full refund the dumps cost to you soon with unconditionally.
Pure Storage FlashArray Architect Associate study guide: exam FAAA_005 real vce collectionSo the proficiency of our team is unquestionable, As the most famous and popular FAAA_005 exam questions on the market, we have built a strict quality control system.
- Pure Storage FAAA_005 Exam Dumps Provider: Pure Storage FlashArray Architect Associate - [url]www.practicevce.com Best Provider 🦢 ➥ www.practicevce.com 🡄 is best website to obtain ▷ FAAA_005 ◁ for free download 🔏Exam FAAA_005 Quick Prep[/url]
- Updated FAAA_005 Exam Dumps Provider - High Hit Rate Source of FAAA_005 Exam 🍥 Open website [ [url]www.pdfvce.com ] and search for ▶ FAAA_005 ◀ for free download 👺New Soft FAAA_005 Simulations[/url]
- Pure Storage FAAA_005 Exam Dumps Provider Exam Latest Release | Updated FAAA_005: Pure Storage FlashArray Architect Associate 🐽 The page for free download of “ FAAA_005 ” on ⮆ [url]www.vce4dumps.com ⮄ will open immediately 🍃FAAA_005 Instant Download[/url]
- Get Use Pure Storage FAAA_005 PDF Questions [2026] 🧯 Open website ➠ [url]www.pdfvce.com 🠰 and search for ➤ FAAA_005 ⮘ for free download 🗜Exam FAAA_005 Questions Pdf[/url]
- Exam FAAA_005 Questions 📥 FAAA_005 Valid Exam Question 💇 FAAA_005 Latest Test Discount 📉 Easily obtain ✔ FAAA_005 ️✔️ for free download through 「 [url]www.easy4engine.com 」 😫VCE FAAA_005 Dumps[/url]
- FAAA_005 Valid Exam Question 🐒 Latest FAAA_005 Questions 👱 FAAA_005 Instant Download ☀ Open 【 [url]www.pdfvce.com 】 and search for ➠ FAAA_005 🠰 to download exam materials for free ✒Sample FAAA_005 Questions Pdf[/url]
- Updated FAAA_005 Exam Dumps Provider - High Hit Rate Source of FAAA_005 Exam 🤔 Search on [ [url]www.validtorrent.com ] for 「 FAAA_005 」 to obtain exam materials for free download 👓FAAA_005 Exam Paper Pdf[/url]
- Updated FAAA_005 Exam Dumps Provider - High Hit Rate Source of FAAA_005 Exam 😕 Easily obtain ▷ FAAA_005 ◁ for free download through ( [url]www.pdfvce.com ) 💸Latest FAAA_005 Questions[/url]
- Exam FAAA_005 Questions 🍎 VCE FAAA_005 Dumps 🌋 Exam FAAA_005 Questions Pdf 🚹 Download 【 FAAA_005 】 for free by simply entering ➽ [url]www.prepawaypdf.com 🢪 website 🌕FAAA_005 Exam Paper Pdf[/url]
- FAAA_005 Valid Braindumps Pdf 🧆 Exam FAAA_005 Discount 🐒 FAAA_005 Cheap Dumps ❎ Search for { FAAA_005 } on ➽ [url]www.pdfvce.com 🢪 immediately to obtain a free download 🦰Exam FAAA_005 Questions[/url]
- Quiz 2026 Pure Storage FAAA_005: The Best Pure Storage FlashArray Architect Associate Exam Dumps Provider ⚪ The page for free download of ☀ FAAA_005 ️☀️ on [ [url]www.examcollectionpass.com ] will open immediately 😴FAAA_005 Instant Download[/url]
- www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, bbs.t-firefly.com, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, wanderlog.com, www.divephotoguide.com, www.stes.tyc.edu.tw, bbs.t-firefly.com, Disposable vapes
