Realistic Reliable EAEP2201 Test Cost & Leader in Qualification Exams &
Posted at 2/5/2026 19:11:51
View88
Replies0
BTW, DOWNLOAD part of Actual4Dumps EAEP2201 dumps from Cloud Storage: https://drive.google.com/open?id=1v-ic4WxhcwgztK7dgji5MSu2-yBvwua3
Actual4Dumps is an authoritative study platform to provide our customers with different kinds of EAEP2201 exam material to learn, and help them pass the EAEP2201 exam as well as get their expected scores. There are three different versions of our EAEP2201 study preparation: PDF, Software and APP online. To avoid their loss for choosing the wrong EAEP2201 learning questions, we offer related three kinds of free demos for our customers to download before purchase. Just come and try!
Esri EAEP2201 Exam consists of 85 multiple-choice questions and has a time limit of 2.5 hours. The passing score for the exam is 75%. Candidates who successfully pass the exam will receive a certificate and digital badge, which can be used to showcase their skills and knowledge in administering ArcGIS Enterprise systems. Enterprise Administration Professional 2201 certification is valid for three years, after which candidates can renew their certification by taking an exam or by earning qualifying continuing education credits.
Esri EAEP2201 Certification Exam is designed for professionals who are seeking to demonstrate their expertise in administering and managing enterprise GIS deployments. EAEP2201 exam covers a wide range of topics that are essential for effective administration of GIS systems, including database management, security measures, server configuration, and performance optimization. It is a comprehensive exam that requires a thorough understanding of Esri software and technologies, as well as industry best practices.
Esri EAEP2201 DUMPS - PERFECT CHOICE FOR FAST PREPARATIONThe authority of Actual4Dumps in Esri EAEP2201 exam questions rests on its being high-quality and prepared according to the latest pattern. Actual4Dumps is proud to announce that our Esri EAEP2201 Exam Dumps help the desiring candidates of Esri EAEP2201 certification to climb the ladder of success by grabbing the Esri Exam Questions.
Esri EAEP2201 Certification Exam is intended for experienced GIS professionals who have a deep understanding of the Esri platform and its capabilities. Candidates who pass EAEP2201 exam will have the skills and knowledge required to manage large and complex GIS systems, administer enterprise geodatabases, configure and optimize ArcGIS Server, and troubleshoot issues that may arise in an enterprise GIS environment. Enterprise Administration Professional 2201 certification is ideal for professionals who work in industries such as government, utilities, telecommunications, and transportation, where GIS is used to support critical business processes.
Esri Enterprise Administration Professional 2201 Sample Questions (Q23-Q28):NEW QUESTION # 23
A GIS administrator must configure ArcGIS Server so that onlyspecific groups and roles from the identity storecan administer it.
Which action should the administrator perform?
- A. Configure role-based access through the ArcGIS Server Manager
- B. Disable the primary administrator account
- C. Define the shared key used to generate an ArcGIS token
- D. Use a group-managed service account to administer the server
Theprimary site administrator accountin ArcGIS Server is abuilt-in accountthat bypasses external identity store configurations. To ensureonly users from a configured identity store(e.g., Active Directory) can administer the site, the primary site admin account must bedisabledafter alternative administrative access has been confirmed.
From ArcGIS Server documentation:
"After you configure your ArcGIS Server to use users and roles from an identity store (LDAP or Active Directory), you can disable the primary site administrator account to prevent bypassing the identity store."
* OptionBrelates to token security, not access control.
* OptionCis about running the service securely, not defining user permissions.
Reference:ArcGIS Enterprise -Managing Access Using Identity Stores and Disabling the Primary Site Administrator Account
NEW QUESTION # 24
An organization expects a large influx of users who use the standard analysis tools in the portal Map Viewer.
The organization is concerned with the hosting server's available resources.
Which system resource should be closely monitored?
- A. Network utilization
- B. Disk activity
- C. CPU utilization
When users perform standard analysis tasks in the portal Map Viewer, the hostingserver executes geoprocessing operations that are computationally intensive. These operations require significant CPU resources. Monitoring CPU utilization helps ensure that the server can handle the increased load without performance degradation.
While disk activity and network utilization are important, they are less directly impacted by standard analysis tasks compared to CPU usage. Therefore, CPU utilization is the primary resource to monitor in this scenario.
Reference Source:ArcGIS Enterprise documentation on system performance monitoring.
NEW QUESTION # 25
ArcGIS Server is installed with its Web Adaptor on the same server. The configuration is as follows:
* ArcGIS Server is federated with Portal for ArcGIS
* Portal is set up to use Integrated Windows Authentication
* The environment was set up using a domain certificate
* The attempted login account is a Windows account with admin privileges A GIS administrator tries to connect to ArcGIS Server Manager through ArcGIS Web Adaptor but the connection fails. Why did the connection fail?
- A. The Web Adaptor was not set to allow administrative access to the server
- B. The connection must be made with an internal admin account and not a Windows account
- C. The certificate must come from a valid Certificate Authority and not a Domain Certificate Authority
NEW QUESTION # 26
An organization's portal license file provides for 30 Editor user type and 15 GIS Professional user type licenses. After performing a needs assessment, the GIS administrator discovers that the organization requires
10 Viewer, 40 Editor, and 20 GIS Professional user type licenses.
When downloading a new license file, how many of each user type license should the administrator specify?
- A. 30 Viewer, 30 Editor, and 15 GIS Professional user type licenses
- B. 40 Editor and 20 GIS Professional user type licenses
- C. 10 Viewer, 40 Editor, and 20 GIS Professional user type licenses
- D. 10 Viewer, 10 Editor, and 5 GIS Professional user type licenses
When downloading a new license file fromMy Esrito accommodate the organization's user needs, administrators should request theexact quantitiesidentified in the internal needs assessment:
* 10 Viewer
* 40 Editor
* 20 GIS Professional
These quantities will be used to generate the new license file, which reflects theactual number of entitlements needed. Esri licensing is flexible in this regard, and the administrator can request different counts per type within their entitlements.
From the ArcGIS Enterprise Licensing documentation:
"When generating a new license file for your deployment, you can specify the number of each user type and role needed. The license file will reflect these values, and must match the needs of your organization."
* OptionAprovides insufficient licenses.
* OptionBomits the necessary Viewer licenses.
* OptionDreflects original entitlements, not the updated requirement.
Reference:ArcGIS Enterprise Administration -User Types and Licensing Model
NEW QUESTION # 27
A client develops a tiered approach to back up their ArcGIS Enterprise base deployment using the webgisdrtool. The client has no map service or hosted tile layer caches All spatial data is stored in the ArcGIS Data Store (relational) The client will perform full webgisdr backups every Sunday and incremental webgisdr backups Monday through Saturday. The default settings of an ArcGIS Enterprise deployment must be modified to support this Which action should the administrator perform?
- A. Decrease the max connections during backups to reduce the number of users connected.
- B. Enable point-in-time recovery on the ArcGIS Data Store to support daily backups
- C. Increase the heap size of the ArcGIS Data Store to support incremental backups
NEW QUESTION # 28
EAEP2201 Test Collection: https://www.actual4dumps.com/EAEP2201-study-material.html
- 100% Pass Quiz 2026 Valid Esri Reliable EAEP2201 Test Cost 🌹 Search on ✔ [url]www.vce4dumps.com ️✔️ for ➡ EAEP2201 ️⬅️ to obtain exam materials for free download 📣EAEP2201 Valid Exam Guide[/url]
- 2026 Fantastic Esri EAEP2201: Reliable Enterprise Administration Professional 2201 Test Cost 🤕 Open website [ [url]www.pdfvce.com ] and search for ⏩ EAEP2201 ⏪ for free download 🤞EAEP2201 Latest Exam Experience[/url]
- 2026 Fantastic Esri EAEP2201: Reliable Enterprise Administration Professional 2201 Test Cost 🌭 Download EAEP2201 for free by simply searching on ⏩ [url]www.prep4sures.top ⏪ 🏔Exam EAEP2201 Price[/url]
- 2026 100% Free EAEP2201 CLatest 100% Free Reliable Test Cost | EAEP2201 Test Collection 🚨 Download ▶ EAEP2201 ◀ for free by simply entering ⏩ [url]www.pdfvce.com ⏪ website 🏅Valid Test EAEP2201 Vce Free[/url]
- 2026 Fantastic Esri EAEP2201: Reliable Enterprise Administration Professional 2201 Test Cost 🐐 Search for EAEP2201 and download it for free immediately on [url]www.testkingpass.com 👄EAEP2201 PDF Questions[/url]
- Esri EAEP2201 Dumps - Try Free EAEP2201 Exam Questions and Answer ✔️ Easily obtain free download of EAEP2201 by searching on ➤ [url]www.pdfvce.com ⮘ ❤Reliable EAEP2201 Test Sims[/url]
- Valid Test EAEP2201 Vce Free 📼 EAEP2201 Test Voucher 😠 Reliable EAEP2201 Dumps Questions 🧙 Download ⏩ EAEP2201 ⏪ for free by simply searching on ▷ [url]www.easy4engine.com ◁ 🕵Reliable EAEP2201 Exam Bootcamp[/url]
- 2026 100% Free EAEP2201 CLatest 100% Free Reliable Test Cost | EAEP2201 Test Collection 🦸 Easily obtain ⮆ EAEP2201 ⮄ for free download through ▷ [url]www.pdfvce.com ◁ 🦢Latest EAEP2201 Test Prep[/url]
- 2026 100% Free EAEP2201 CLatest 100% Free Reliable Test Cost | EAEP2201 Test Collection 🍈 Open [url]www.examcollectionpass.com and search for EAEP2201 to download exam materials for free 🏉Valid EAEP2201 Exam Vce[/url]
- Pass Guaranteed Quiz 2026 Esri EAEP2201: Enterprise Administration Professional 2201 C Professional Reliable Test Cost 🤛 Easily obtain EAEP2201 for free download through ➡ [url]www.pdfvce.com ️⬅️ 🍦EAEP2201 Valid Exam Guide[/url]
- 2026 100% Free EAEP2201 CLatest 100% Free Reliable Test Cost | EAEP2201 Test Collection 📨 Easily obtain ▛ EAEP2201 ▟ for free download through [url]www.pdfdumps.com 👸EAEP2201 Latest Exam Experience[/url]
- www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, steenhardallgier216.blogspot.com, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, Disposable vapes
DOWNLOAD the newest Actual4Dumps EAEP2201 PDF dumps from Cloud Storage for free: https://drive.google.com/open?id=1v-ic4WxhcwgztK7dgji5MSu2-yBvwua3
