[General] New Snowflake GES-C01 Braindumps - GES-C01 Exams Collection
96
General New Snowflake GES-C01 Braindumps - GES-C01 Exams Collection
Posted at 2/5/2026 22:00:36      View147 | Replies1        Print      Only Author   [Copy Link] 1#
2026 Latest ExamBoosts GES-C01 PDF Dumps and GES-C01 Exam Engine Free Share: https://drive.google.com/open?id=1rrhJvthxXTsxCNjGQ0N-0ixtu31X-jdI
There are rare products which can rival with our products and enjoy the high recognition and trust by the clients like our products. Our products provide the GES-C01 study materials to clients and help they pass the test GES-C01 certification which is highly authorized and valuable. Our company is a famous company which bears the world-wide influences and our GES-C01 Study Materials are recognized as the most representative and advanced study materials among the same kinds of products. Whether the qualities and functions or the service of our product, are leading and we boost the most professional expert team domestically.
Maybe most of people prefer to use the computer when they are study, but we have to admit that many people want to learn buy the paper, because they think that studying on the computer too much does harm to their eyes. GES-C01 test questions have the function of supporting printing in order to meet the need of customers. You can print our GES-C01 Exam Question on papers after you have downloaded it successfully. It not only can help you protect your eyes, but also it will be very convenient for you to make notes. We believe that you will like our GES-C01 exam prep.
100% Pass Quiz Snowflake - GES-C01 - SnowPro® Specialty: Gen AI Certification Exam Unparalleled New BraindumpsYou can adjust the speed and keep vigilant by setting a timer for the simulation test. At the same time online version of GES-C01 test preps also provides online error correction through the statistical reporting function, it will help you find the weak links and deal with them. Of course, you can also choose two other versions. The contents of the three different versions of GES-C01 learn torrent is the same and all of them are not limited to the number of people/devices used at the same time.
Snowflake SnowPro® Specialty: Gen AI Certification Exam Sample Questions (Q117-Q122):NEW QUESTION # 117
A Snowflake administrator is designing a new role, 'doc_ai_pipeline_creator' , intended to configure and deploy Document AI extraction pipelines. This role needs the ability to ensure that the designated virtual warehouse, 'analytics_wh', can be reliably started and stopped as needed for Document AI tasks. Which of the following SQL statements grants the privilege that directly enables the 'doc ai_pipeline_creator' role to control the operational state of 'analytics_wh'?
  • A.
  • B.
  • C.
  • D.
  • E.
For Document AI operations, including setting up model builds and running extraction pipelines, the associated virtual warehouse must be available and its operational state managed effectively. The 'OPERATE' privilege on a virtual warehouse specifically grants the ability to start and stop (resume and suspend) the warehouse. - Option A USAGE ON WAREHOUSE) allows a role to select and use a warehouse but does not provide control over its active state. Both 'USAGE* and *OPERATE* are required for Document AI. - Options B, D, and E CMONITOR , MODIFY , "CONTROL") are not the specific privilege described in the sources for controlling the operational state of a warehouse in the context of Document AI setup.
NEW QUESTION # 118
A data engineering team is designing a Snowflake data pipeline to automatically enrich a 'customer issues' table with product names extracted from raw text-based 'issue_description' columns. They want to use a Snowflake Cortex function for this extraction and integrate it into a stream and task-based pipeline. Given the 'customer_issues' table with an 'issue_id' and (VARCHAR), which of the following SQL snippets correctly demonstrates the use of a Snowflake Cortex function for this data enrichment within a task, assuming is a stream on the 'customer issues' table?
  • A. Option C
  • B. Option B
  • C. Option D
  • D. Option A
  • E. Option E
Option B correctly uses to pull specific information (product name) from unstructured text, which is a common data enrichment task. It also integrates with a stream ('issue_stream') by filtering for 'METADATA$ACTION = 'INSERT" and uses a 'MERGE statement, which is suitable for incremental updates in a data pipeline by inserting new extracted data based on new records in the stream. Option A uses for generating a response, not for specific entity extraction, and its prompt is less precise for this task than 'EXTRACT_ANSWER. Option C uses 'SNOWFLAKE.CORTEX.CLASSIFY_TEXT for classification, not direct entity extraction of a product name, and attempts to update the source table directly, which is not ideal for adding new columns based on stream data. Option D proposes a stored procedure and task, which is a valid pipeline structure. However, the EXTRACT ANSWER call within the procedure only returns a result set and does not demonstrate the final insertion or merging step required to persist the extracted data into an 'enriched_issues' table. Option E uses to generate vector embeddings, which is a form of data enrichment, but the scenario specifically asks for 'product names' (a string value), not embeddings for similarity search.
NEW QUESTION # 119
  • A. The 'ACCOUNTADMIN' must execute the SQL command:
  • B. If a user attempts to call an LLM not explicitly listed in the via the Cortex LLM Playground, Snowflake will automatically fall back to the 'snowflake-arctic' model for that request.
  • C. Users with 'ds_team_role' will still be able to successfully call
  • D. Enabling Cortex Guard for 'AI_COMPLETE through the 'guardrails' option automatically bypasses the 'CORTEX_MODELS_ALLOWLIST to ensure all LLMs can be used for content safety filtering.
  • E. The parameter provides granular control at the database or schema level, allowing administrators to define different sets of approved models for different data contexts.
NEW QUESTION # 120
A data engineer is working with Snowflake Cortex Analyst to improve its ability to answer natural language questions by precisely identifying product names for filtering. They have decided to integrate a Cortex Search Service with their semantic model to enhance literal search for the 'product_name' dimension. Which of the following configurations within the semantic model's YAML file are valid and effective for this purpose?
  • A. Setting true' for the 'product_name' dimension and providing an exhaustive list of to restrict the model to only those values.
  • B. Including in the semantic model's 'metrics' section, referencing 'product_name'.
  • C. Only specifying 'sample_valueS for the 'product_name' dimension without a entry.
  • D. Adding a 'cortex_search_service' entry to the 'product_name' dimension with only the 'service' field:
  • E. Adding a entry to the 'product_name' dimension, including 'literal_column' and ensuring the search service is configured to index the physical column:
Answer: A,E
Option C is correct because integrating a Cortex Search Service with Cortex Analyst for literal search improvement involves adding a entry to the relevant dimension. Specifying the 'literal_column' explicitly helps map the semantic dimension to the underlying column indexed by the search service, ensuring the correct values are used for semantic search. Option D is also correct. For dimensions with relatively low-cardinality values, setting 'is_enum: true and providing 'sample_values' tells the model to choose only from that predefined list, which is an effective way to improve literal usage without requiring an external Cortex Search Service. Option A is incorrect because while 'sample_valueS are used for semantic similarity search for low-cardinality dimensions, they don't leverage the full capabilities of a Cortex Search Service for 'fuzzy' search over potentially high-cardinality data. Option B is incomplete. While specifying the 'service' name is a start, it's beneficial to explicitly define the 'literal_column' if it differs from the dimension's expression or if precision is critical. Option E is incorrect because is a configuration for a 'dimension', not a 'metric'.
NEW QUESTION # 121
A legal department uses Snowflake to manage and review large volumes of contracts. They need to automate the process of finding specific pieces of information, such as the effective_date or involved_parties, from these unstructured contract texts. They are considering using SNOWFLAKE. CORTEX. EXTRACT_ANSWER. Which characteristic correctly describes the primary intent or behavior of SNOWFLAKE. CORTEX. EXTRACT_ANSWER, distinguishing it from other LLM functions?
  • A. It evaluates a text and returns a numeric score indicating the overall positive or negative sentiment.
  • B. It focuses on identifying and returning a direct answer to a specific question contained within the provided source document.
  • C. It classifies an input text into one of several predefined categories provided by the user.
  • D. It transforms an input document into a summarized version, reducing its length while preserving key information.
  • E. It is primarily designed to generate entirely new text based on a given prompt, much like a conversational AI.
Option D is correct. The 'SNOWFLAKE.CORTEX.EXTRACT_ANSWER function is specifically designed to extract an answer to a given question from a text document. Option A describes the 'COMPLETE function. Option B describes the 'SENTIMENT function. Option C describes the 'CLASSIFY_TEXT function. Option E describes the 'SUMMARIZE function.
NEW QUESTION # 122
For customers who are bearing pressure of work or suffering from career crisis, GES-C01 learn tool of inferior quality will be detrimental to their life, render stagnancy or even cause loss of salary. So choosing appropriate GES-C01 test guide is important for you to pass the exam. One thing we are sure, that is our GES-C01 Certification material is reliable. With our high-accuracy GES-C01 test guide, our candidates can become sophisticated with the exam content. You only need to spend 20-30 hours practicing with our GES-C01 learn tool, passing the exam would be a piece of cake.
GES-C01 Exams Collection: https://www.examboosts.com/Snowflake/GES-C01-practice-exam-dumps.html
Snowflake New GES-C01 Braindumps We have been trying to tailor to exam candidates needs since we found the company ten years ago, Which kind of GES-C01 certificate is most authorized, efficient and useful, Exam Collection GES-C01 bootcamp materials offer three versions for each exam code which satisfy all kinds of demand, Most people who want to gain the Snowflake GES-C01 Exams Collection certificate have bought our products.
Having direct access to the equipment is best, but if that GES-C01 is not an option, I would find a remote resource and use it extensively, Understanding the System File Structure.
We have been trying to tailor to exam candidates needs since we found the company ten years ago, Which kind of GES-C01 certificate is most authorized, efficient and useful?
Quiz GES-C01 - Authoritative New SnowPro® Specialty: Gen AI Certification Exam BraindumpsExam Collection GES-C01 bootcamp materials offer three versions for each exam code which satisfy all kinds of demand, Most people who want to gain the Snowflake certificate have bought our products.
By far, our Snowflake exam braindumps are the industries finest.
BTW, DOWNLOAD part of ExamBoosts GES-C01 dumps from Cloud Storage: https://drive.google.com/open?id=1rrhJvthxXTsxCNjGQ0N-0ixtu31X-jdI
Posted at 2/16/2026 19:17:59        Only Author  2#
This article is incredibly thought-provoking, thank you for sharing! Sharpen your IT skills and access free PDF CWNA-109 Download. Best of luck to you!
