[General] New Release Microsoft AZ-120 Exam Questions: Right Preparation Method [2026]
74
General New Release Microsoft AZ-120 Exam Questions: Right Preparation Method [2026]
Posted at 2/5/2026 22:59:36      View118 | Replies0        Print      Only Author   [Copy Link] 1#
BONUS!!! Download part of BraindumpsVCE AZ-120 dumps for free: https://drive.google.com/open?id=1i5VUVWZ0k42wbkaQZcircm1XsfYUD3U9
Our AZ-120 study materials are widely read and accepted by people. Through careful adaption and reorganization, all knowledge will be integrated in our AZ-120 real exam. The explanations of our AZ-120 exam materials also go through strict inspections. So what you have learned are absolutely correct. All in all, we have invested many efforts on compiling of the AZ-120 Practice Guide. At last, we will arrange proofreaders to check the study materials.
With over a decades business experience, our AZ-120 test torrent attached great importance to customers purchasing rights all along. There is no need to worry about virus on buying electronic products. For we make endless efforts to assess and evaluate our AZ-120 exam prep reliability for a long time and put forward a guaranteed purchasing scheme, we have created an absolutely safe environment and our AZ-120 Exam Question are free of virus attack. If there is any doubt about it, professional personnel will handle this at first time, and you can also have their remotely online guidance to install and use our AZ-120 test torrent.
Certificate AZ-120 Exam - Certification AZ-120 Test QuestionsBy keeping minimizing weak points and maiming strong points, our Microsoft AZ-120 exam materials are nearly perfect for you to choose. As a brand now, many companies strive to get our Planning and Administering Microsoft Azure for SAP Workloads AZ-120 practice materials to help their staffs achieve more certifications for our quality and accuracy.
Microsoft Planning and Administering Microsoft Azure for SAP Workloads Sample Questions (Q308-Q313):NEW QUESTION # 308
You are migrating SAP to Azure. The ASCS application servers are in one Azure zone, and the SAP database server in in a different Azure zone. ASCS/ERS is configured for high availability.
During performance testing, you discover increased response times in Azure, even though the Azure environment has better computer and memory configurations than the on-premises environment.
During the initial analysis, you discover an increased wait time for Enqueue.
What are three possible causes of the increased wait time? Each correct answer presents a complete solution.
  • A. a missing Enqueue profile
  • B. misconfigured load balancer rules and health check probes for Enqueue and ASCS
  • C. disk I/O during Enqueue backup operations
  • D. active Enqueue replication
  • E. network latency between the database server and the SAP application servers
Answer: B,D,E
E: The network latency across Availability Zones is not the same in all Azure regions. In some cases, you can deploy and run the SAP application layer across different zones because the network latency from one zone to the active DBMS VM is acceptable. But in some Azure regions, the latency between the active DBMS VM and the SAP application instance, when deployed in different zones, might not be acceptable for SAP business processes.
https://docs.microsoft.com/en-us ... -availability-zones
NEW QUESTION # 309
You have An Azure subscription that contains an availability set named AS1 and a virtual machine named VM1. VM1 hosts an SAP NetWeavef application You need to ensure that AS1 includes VM1.
Which four PowerShell cmdlets should you run in sequence? To answer, move the appropriare actions from the list of actions to the answer area and arrange them m the correct order.
To ensure that AS1 includes VM1, you will need to run the following four PowerShell cmdlets in sequence:
Set-AzVMOSDisk -VMName VM1 -AvailabilitySetName AS1
Remove-AzVM -VMName VM1
New-AzVMConfig -VMName VM1 -AvailabilitySetName AS1
Update-AzAvailabilitySet -Name AS1
NEW QUESTION # 310
1. No
Oracle Data Guard running in Maximum Availability mode. Currently, Oracle Real Application Clusters (RAC) is not supported in Azure - either for high availability or for scalability
2. Yes
3. No
The following OS versions are supported with the Oracle Database on Microsoft Azure:
Windows Server 2019 (only from Oracle Database 19.5.0 on)
Windows Server 2016 (only from Oracle Database 12.2.0.1 on)
Windows Server 2012 (no support for Oracle Database 19c)
Windows Server 2012 R2
Windows Server 2008 R2 Service Pack 1 (no support for Oracle 12.2.0.1)
Oracle Linux 7
Oracle Linux 8 (only from Oracle Database 19.7.0 on)
https://techcommunity.microsoft. ... ow-generally-availa
NEW QUESTION # 311
You deploy SAP HANA by using SAP HANA on Azure (Large Instances).
Box 1: No
Box 2: Yes
The SAP Azure Enhanced Monitoring Extension allows for collecting diagnostic data including OS and Application performance counters from Azure VMs running SAP workloads.
Box 3: No
http://www.deployazure.com/compu ... nitoring-extension/
NEW QUESTION # 312
You have an SAP landscape on Azure that contains the virtual machines shown in the following table.
You need to ensure that the Application Server role is available if a single Azure datacenter fails.
What should you include in the solution?
  • A. Azure Load Balancer Standard
  • B. Azure Private Link
  • C. Azure Application Gateway v2
  • D. a local network gateway
NEW QUESTION # 313
The price of Microsoft AZ-120 updated exam dumps is affordable. You can try the free demo version of any Microsoft AZ-120 exam dumps format before buying. For your satisfaction, BraindumpsVCE gives you a free demo download facility. You can test the features and then place an order.
Certificate AZ-120 Exam: https://www.braindumpsvce.com/AZ-120_exam-dumps-torrent.html
What's more, you can acquire the latest version of AZ-120 study guide materials checked and revised by our IT department staff, Our help is available to you 24/7 and you can forward us any queries that you face with the AZ-120 exam products, Microsoft Azure-Dumps Microsoft Azure AZ-120 real dumps cover all the exam topics and objectives and will prepare you for success quickly and efficiently, It semms that it's a terrible experience for some candicates to prepare and take part in the AZ-120 exam, we will provide you the AZ-120 training materials to help you pass it succesfully.
How often do you offer your AZ-120 products updates, Vertex shaders, their special variables, and their use in per-vertex lighting, skinning, and other applications.
What's more, you can acquire the latest version of AZ-120 Study Guide materials checked and revised by our IT department staff, Our help is available to you 24/7 and you can forward us any queries that you face with the AZ-120 exam products.
Fast Download AZ-120 Exam Questions Answers & Pass-Sure Certificate AZ-120 Exam & Useful Certification AZ-120 Test QuestionsMicrosoft Azure-Dumps Microsoft Azure AZ-120 real dumps cover all the exam topics and objectives and will prepare you for success quickly and efficiently, It semms that it's a terrible experience for some candicates to prepare and take part in the AZ-120 exam, we will provide you the AZ-120 training materials to help you pass it succesfully.
If you want to pass your practice exam, AZ-120 we believe that our learning engine will be your indispensable choices.
P.S. Free 2026 Microsoft AZ-120 dumps are available on Google Drive shared by BraindumpsVCE: https://drive.google.com/open?id=1i5VUVWZ0k42wbkaQZcircm1XsfYUD3U9
