[General] Latest 300-715 Exam Dumps - Latest 300-715 Exam Papers
76
【General】 Latest 300-715 Exam Dumps - Latest 300-715 Exam Papers
Posted at 2/5/2026 23:05:05      View:159 | Replies:1        Print      Only Author   [Copy Link] 1#
DOWNLOAD the newest DumpStillValid 300-715 PDF dumps from Cloud Storage for free: https://drive.google.com/open?id=1evg_wyYtb0hLfQgmrmIJHMD1y-ymfsgT
DumpStillValid proudly says that its product is accurate and trustworthy because it was formulated according to the prescribed content of the Cisco 300-715 actual test. We offer Cisco 300-715 Exam Questions free updates for up to 12 months after purchasing. These free updates of actual 300-715 questions will follow the fresh updates in the exam content.
PrerequisitesThis certification exam has no official prerequisites. However, it is recommended that the candidates know about Cisco IOS Software Command-Line Interface, Cisco AnyConnect Secure Mobility Client, 802.1X, and Microsoft Windows OS. The intended audience for the test is ISE Administrators, Cisco Integrators and Partners, Wireless Network Security Engineers, and Network Security Engineers.
Pass-Sure Cisco Latest 300-715 Exam Dumps | Try Free Demo before PurchaseOur 300-715 guide questions have the most authoritative test counseling platform, and each topic in 300-715 practice engine is carefully written by experts who are engaged in researching in the field of professional qualification exams all the year round. They have a very keen sense of change in the direction of the exam, so that they can accurately grasp the important points of the 300-715 Exam. And you will pass the exam for the 300-715 exam questions are all keypoints.
What Topics Does 300-715 SISE Gauge?This test will address a range of areas related to IT such as:
  • BYOD — in this part, applicants will have to explain the different features of Cisco BYOD including BYOD flow, solution tools, requirements, and cases for use, incorporate wireless LAN controllers & switches alongside internal CA to set up BYOD device on-boarding, change whitelists & blacklists, and adjust certificates for BYOD.
  • Deployment & Architecture — here, students must show that they can explain the different types of deployment approaches available and tweak personas.
  • Endpoint Agreements — in such a section, examinees will have to show they can explain posture services, elaborate endpoint agreements, describe client provisioning, set up client provisioning, posture conditions, function modes, and ISE posture agents, explain IT elements such as servers, authenticators, and supplicants, and lastly, adjust the agreement module.
Cisco Implementing and Configuring Cisco Identity Services Engine Sample Questions (Q265-Q270):NEW QUESTION # 265
What occurs when a Cisco ISE distributed deployment has two nodes and the secondary node is deregistered?
  • A. Both nodes restart.
  • B. The primary node restarts
  • C. The primary node becomes standalone
  • D. The secondary node restarts.
https://www.cisco.com/c/en/us/td ... ide/ise_deploy.html if your deployment has two nodes and you deregister the secondary node, both nodes in this primary-secondary pair are restarted. (The former primary and secondary nodes become standalone.)
NEW QUESTION # 266
An administrator is configuring a switch port for use with 802 1X What must be done so that the port will allow voice and multiple data endpoints?
  • A. Connect the data devices to the port, then attach the phone behind them.
  • B. Configure the port with the authentication host-mode multi-auth command
  • C. Use the command authentication host-mode multi-domain on the port
  • D. Connect a hub to the switch port to allow multiple devices access after authentication
NEW QUESTION # 267
An administrator is configuring new probes to use with Cisco ISE and wants to use metadata to help profile the endpoints. The metadata must contain traffic information relating to the endpoints instead of industry-standard protocol information Which probe should be enabled to meet these requirements?
  • A. DHCP probe
  • B. DNS probe
  • C. NetFlow probe
  • D. SNMP query probe
http://www.network-node.com/blog/2016/1/2/ise-20-profiling
NEW QUESTION # 268
Drag the steps to configure a Cisco ISE node as a primary administration node from the left into the correct order on the night.
https://www.cisco.com/c/en/us/td ... 4/b_ise_admin_guide Step 1 Choose Administration > System > Deployment.
The Register button will be disabled initially. To enable this button, you must configure a Primary PAN.
Step 2
Check the check box next to the current node, and click Edit.
Step 3
Click Make Primary to configure your Primary PAN.
Step 4
Enter data on the General Settings tab.
Step 5
Click Save to save the node configuration.
NEW QUESTION # 269
An engineer is configuring a new Cisco ISE node. Context-sensitive information must be shared between the Cisco ISE and a Cisco ASA. Which persona must be enabled?
  • A. pxGrid
  • B. Monitoring
  • C. Administration
  • D. Policy Service
NEW QUESTION # 270
Latest 300-715 Exam Papers: https://www.dumpstillvalid.com/300-715-prep4sure-review.html
BONUS!!! Download part of DumpStillValid 300-715 dumps for free: https://drive.google.com/open?id=1evg_wyYtb0hLfQgmrmIJHMD1y-ymfsgT
Posted at 5/1/2026 17:04:02        Only Author  2#
300-715 cleared successfully, CERTS4SURE questions gave me a better idea of exam patterns.
https://www.certs4sure.com/cisco/300-715.html
