[General] SAP C_TFG61_2405在線考題 - C_TFG61_2405通過考試
81
【General】 SAP C_TFG61_2405在線考題 - C_TFG61_2405通過考試
Posted at 2/6/2026 00:47:23      View:168 | Replies:2        Print      Only Author   [Copy Link] 1#
此外,這些VCESoft C_TFG61_2405考試題庫的部分內容現在是免費的:https://drive.google.com/open?id=1V7aovfjKe-yFCtcnkWB044eLQ-ibULLw
有很多方法,以備你的 SAP的C_TFG61_2405的考試,本站提供了可靠的培訓工具,以準備你的下一個SAP的C_TFG61_2405的考試認證,我們VCESoft SAP的C_TFG61_2405的考試學習資料包括測試題及答案,我們的資料是通過實踐檢驗的軟體,我們將滿足所有的有關IT認證。
SAP C_TFG61_2405 考試大綱:
主題簡介
主題 1
  • Users: In this topic, SAP Fieldglass administrators will be tested on their abilities to create and manage users in SAP Fieldglass, along with handling access issues and setting up signature authority. SAP C_TFG61_2405 exam candidates must ensure they are confident with troubleshooting user access, delegation, and supervisor functionality.
主題 2
  • Supplier and Workflow: SAP Fieldglass administrators will need to demonstrate expertise in creating and managing suppliers, understanding buyer-supplier activities, and configuring workflows. Expect questions on supplier qualification templates, inactivation, and setting up approval workflows, including amount-based approvals. Lastly, the topic focuses on limiting the PMO dashboard view and setting up approval groups.
主題 3
  • Services Procurement Transactions: SAP Fieldglass administrators will be evaluated on their understanding of the services module transactions, including SOW characteristics, statuses, and invoicing processes. Expect questions on creating and managing SOW bids and understanding their key concepts.
主題 4
  • Company Structure and Financial Data: This C_TFG61_2405 topic measures the knowledge of administrators about setting up legal entities, corporate calendars, and financial data, such as master data, currency conversion, and general ledger setup. Your understanding of expense codes and task codes is also critical.
主題 5
  • Configuration, System Tools, and Messaging: Prepare for questions related to the configuration manager, key terms associated with the configuration menu, contextual help, reason codes and list views. SAP Fieldglass administrators will be tested on using the system audit trail and email notification status, creating a home page announcement, and messaging configuration options.
主題 6
  • Rate Structures: In this C_TFG61_2405 topic, the exam will test SAP Fieldglass administrators on assessing program requirements for rate structures, configure rates and rate schedules, and explain the use cases for these rates.
快速下載C_TFG61_2405在線考題 & SAP C_TFG61_2405通過考試:SAP Certified Associate - Administrator - SAP Fieldglass Services Procurement終於通過了VCESoft 是專門給全世界的IT認證的考生提供培訓資料的,購買我們所有的資料能保證考生一次性通過 C_TFG61_2405 考試,讓考生信心百倍的通過 C_TFG61_2405 考試認證,給自己的職業生涯帶來重大影響,用自己專業的頭腦和豐富的考試經驗來滿足考生們的需求。本題庫網用超低的價格和高品質的 SAP C_TFG61_2405 考古題真試題和答案來奉獻給廣大考生。
最新的 SAP Certified Associate C_TFG61_2405 免費考試真題 (Q45-Q50):問題 #45
Which kind of configuration are Alerts and Escalations examples of?
  • A. Thresholds
  • B. Activity Item
  • C. Wizard
  • D. Decision Form Template
  • E. None
答案:A
問題 #46
When should the Integration Connector Wizard be used?
  • A. If you know the data to be integrated but are not sure which transfer method to use.
  • B. If you know the data to be integrated but are not sure which connector to use.
  • C. If you know the connector to be used but are not sure which transfer method to use
  • D. If you know the connector to be used but are not sure which version to use.
答案:B
問題 #47
Which of the following are characteristics of report folders? Note: There are 2 correct answers to this question
  • A. Report folders are used to group together similar reports
  • B. There is a minimum number of report folders required in SAP Fieldglass
  • C. Report folders are associated to user roles, which define specific user permissions
  • D. Any user can view a report after it is associated to a report folder
答案:A,C
問題 #48
You need to create a Corporate Calendar that allows for regional differences in standard work schedules. What details can the Corporate Calendar include? Note: There are 2 correct answers to this question.
  • A. Recurring non-working days
  • B. Specific non-working days
  • C. Core hours when workers are expected to be in the office, or on-site
  • D. On-boarding and off-boarding activities
答案:A,B
問題 #49
Why would you associate proxy roles to a user role?
  • A. To select proxies for multiple user roles that could serve as proxies for all
  • B. To select a single user who can perform the role of a proxy
  • C. To select proxies for a single user that could serve as a proxy
  • D. To select the roles that could serve as proxies for that role
答案:D
問題 #50
很多IT人士都想通過SAP C_TFG61_2405 認證考試,從而在IT行業中獲取更好的提升機會,使他們的工資生活水準都有所提升。但是好多人為了通過SAP C_TFG61_2405 認證考試花了大量時間和精力來鞏固相關知識卻沒有通過考試。這樣是很不划算。如果你選擇VCESoft的產品,你可以為你節約很多時間和精力來鞏固知識,但是卻可以通過SAP C_TFG61_2405 認證考試。因為VCESoft的關於SAP C_TFG61_2405 認證考試的針對性的資料可以幫助你100%通過考試。如果你考試失敗,VCESoft會全額退款給你。
C_TFG61_2405通過考試: https://www.vcesoft.com/C_TFG61_2405-pdf.html
順便提一下,可以從雲存儲中下載VCESoft C_TFG61_2405考試題庫的完整版:https://drive.google.com/open?id=1V7aovfjKe-yFCtcnkWB044eLQ-ibULLw
Posted at 2/10/2026 23:34:27        Only Author  2#
Your article has truly left me speechless, thank you for sharing! Free Study MS-102 Test questions for everyone. Wishing you success in your exams!
Posted at 2/24/2026 09:18:54        Only Author  3#
使用PDFExamDumps ARDMS的AE-Adult-Echocardiography考試認證培訓資料, 想過ARDMS的AE-Adult-Echocardiography考試認證是很容易的,我們網站設計的培訓工具能幫助你第一次嘗試通過測試,你只需要下載PDFExamDumps ARDMS的AE-Adult-Echocardiography考試認證培訓資料也就是試題及答案,很輕鬆很容易,包你通過考試認證,如果你還在猶豫,試一下我們的使用版本就知道效果了,不要猶豫,趕緊加入購物車,錯過了你將要遺憾一輩子的。
