[General] ServiceNow CIS-SPM PDF Questions Format
90
【General】 ServiceNow CIS-SPM PDF Questions Format
Posted at 2/6/2026 02:00:46      View:141 | Replies:1        Print      Only Author   [Copy Link] 1#
What's more, part of that PracticeTorrent CIS-SPM dumps now are free: https://drive.google.com/open?id=1phVvvB7Vir7NqWPrZr7F60Xi7IcJFXMp
ServiceNow CIS-SPM certification exam is very important for every IT person. With this certification you will not be eliminated, and you will be a raise. Some people say that to pass the ServiceNow CIS-SPM exam certification is tantamount to success. Yes, this is true. You get what you want is one of the manifestations of success. PracticeTorrent of ServiceNow CIS-SPM Exam Materials is the source of your success. With this training materials, you will speed up the pace of success, and you will be more confident.
ServiceNow CIS-SPM Exam Syllabus Topics:
  • Security Architecture and Engineering: This section examines security models and design principles, system and application security, as well as cryptography and key management.
  • Asset Security: This section focuses on information and asset classification, data security controls, privacy protection measures, and intellectual property protection.
  • Identity and Access Management: This section explores authentication methods and technologies, authorization and access control models, and the identity management lifecycle.
  • Information Security Governance: This section of the exam delves into security management concepts and principles, examining organizational structures and roles in security. It also covers developing and implementing security policies, standards, and procedures.
Topic 5
  • Security Operations: In this section, the focus is on security monitoring and analytics, incident response and management, forensics and investigations, and patch and vulnerability management.
Topic 6
  • Security Assessment and Testing: This section focuses on security audit principles and methodologies, penetration testing techniques, and the use of security metrics and reporting.
Topic 7
  • Software Development Security: This section emphasizes securing the software development lifecycle, including application security testing, code review, secure coding practices, and third-party software management.
Topic 8
  • Privacy Management: This section covers privacy principles and regulations, privacy impact assessments, data protection techniques, and the concepts of privacy by design.
Topic 9
  • Regulatory Compliance and Legal Issues: This section addresses risk management and risk assessment methodologies, including threat modeling and vulnerability assessment. It also explores various risk mitigation strategies.
CIS-SPM Reliable Test Test | Testking CIS-SPM Exam QuestionsPracticeTorrent will provides the facility of online chat to all prospective customers to discuss any issue regarding, different vendors’ certification tests, CIS-SPM exam materials, discount offers etc. Our efficient staff is always prompt to respond you. If you need detailed answer, you send emails to our customers’ care department, we will help you solve your problems as soon as possible. You will never regret to choose CIS-SPM Exam Materials.
ServiceNow Certified Implementation Specialist - Strategic Portfolio Management Sample Questions (Q52-Q57):NEW QUESTION # 52
When creating a project from demand, what related records are moved and copied upon Project Creation?
  • A. Cost Plan and Assessment.
  • B. Idea and Demand.
  • C. Resource Plan and Change Requests.
  • D. Resource Plan and Cost Plan.
According to the Create a customer project from a demand document, when creating a project from demand, the resource plan and the cost plan are moved and copied upon project creation. The resource plan defines the resources required for the project, and the cost plan defines the estimated and actual costs for the project. The other options are not correct, as they are not related records that are moved and copied upon project creation. The change requests, the idea, and the demand are not moved or copied to the project, but they are linked to the project as references. The assessment is not a record that is associated with the project, but with the demand.
NEW QUESTION # 53
How many WBS levels can be shown on the planning console?
  • A. Three.
  • B. Two.
  • C. One.
  • D. No Limit.
According to the ServiceNow documentation1, the planning console can show as many WBS levels as desired, starting from the level 1 to the lowest system components. The WBS levels can be expanded or collapsed by clicking the plus or minus icons next to the task names. The planning console also allows users to create, edit, and delete tasks, as well as add dependencies, assign resources, and track progress.
1: https://docs.servicenow.com/bund ... lanningConsole.html
NEW QUESTION # 54
The project property to update actual effort from time card is controlled at what level?
  • A. Program Level.
  • B. Portfolio Level.
  • C. Application Level (Global).
  • D. Project Level.
According to the ServiceNow documentation1, the project property to update actual effort from time card is controlled at the project level. This property is called Update actual effort from time card and it determines if the Actual effort field on the Dates tab should be updated based on the hours entered from time cards for the project. If set to Yes, the Actual effort field is read-only on the Project and Project Task forms. If set to No, the Actual effort field is editable on the Project and Project Task forms.
1:
https://docs.servicenow.com/bund ... ct-management/refer
NEW QUESTION # 55
The color band at the top of the project card in Project Workspace displays what project attribute?
  • A. State
  • B. Risk
  • C. Issues
  • D. Status
According to the ServiceNow documentation1, the color band at the top of the project card in Project Workspace displays the project status. The project status is a calculated field that indicates the health of the project based on the schedule, cost, and scope variance. The color band can be green, yellow, or red, depending on the status value. The other options are incorrect because:
B . Risk: The risk is a potential problem that could affect the project or its outcome. The risk level is displayed as a circle icon on the project card, not as a color band2.
C . State: The state is the current phase of the project, such as Draft, Planning, Work in Progress, or Closed. The state is displayed as a text field on the project card, not as a color band3.
D . Issues: The issues are the actual problems that affect the project or its outcome. The number of issues is displayed as a badge icon on the project card, not as a color band4.
1: https://docs.servicenow.com/bund ... ojectWorkspace.html 2: https://docs.servicenow.com/bund ... /t_CreateARisk.html 3: https://docs.servicenow.com/bund ... r_ProjectTable.html 4: https://docs.servicenow.com/bund ... _CreateAnIssue.html
NEW QUESTION # 56
Which role should be assigned to a user so they can read and retrieve data from any table of the Release Management application to generate reports?
  • A. Project manager
  • B. Release user
  • C. Business stakeholder
  • D. Release admin
According to the Product Documentation for ServiceNow, the business stakeholder role (rm_business_stakeholder) can read and retrieve data from any table of the Release Management application to generate reports. This role can also view the release dashboard, release calendar, and release roadmap. The other roles have different levels of access and permissions for the Release Management application. You can find more information about the roles and responsibilities for Release Management in the Product Documentation for ServiceNow.
NEW QUESTION # 57
Our product backend port system is powerful, so it can be implemented even when a lot of people browse our website can still let users quickly choose the most suitable for his CIS-SPM qualification question, and quickly completed payment. Once the user finds the CIS-SPM learning material that best suits them, only one click to add the CIS-SPM Study Tool to their shopping cart, and then go to the payment page to complete the payment, our staff will quickly process user orders online. In general, users can only wait about 5-10 minutes to receive our CIS-SPM learning material,
CIS-SPM Reliable Test Test: https://www.practicetorrent.com/CIS-SPM-practice-exam-torrent.html
P.S. Free 2026 ServiceNow CIS-SPM dumps are available on Google Drive shared by PracticeTorrent: https://drive.google.com/open?id=1phVvvB7Vir7NqWPrZr7F60Xi7IcJFXMp
Posted at 2/22/2026 08:41:20        Only Author  2#
I’m absolutely amazed by your article, thank you for sharing it with me! The 1z0-1033-25 exam score resources are free and very helpful.
