[General] 100% Pass Quiz 2026 High-quality Salesforce Reliable Analytics-DA-201 Exam Book
85
General 100% Pass Quiz 2026 High-quality Salesforce Reliable Analytics-DA-201 Exam Book
Posted at 2/6/2026 04:41:20      View103 | Replies0        Print      Only Author   [Copy Link] 1#
BTW, DOWNLOAD part of Actual4Dumps Analytics-DA-201 dumps from Cloud Storage: https://drive.google.com/open?id=11tMQzcLx9yujkUDsB0fVL__0zDftBif0
Our Analytics-DA-201 practice dumps enjoy popularity throughout the world. So with outstanding reputation, many exam candidates have a detailed intervention with our staff before and made a plea for help. We totally understand your mood to achieve success at least the Analytics-DA-201 Exam Questions right now, so our team makes progress ceaselessly in this area to make better Analytics-DA-201 study guide for you. We supply both goods which are our Analytics-DA-201 practice materials as well as high quality services.
In our study, we found that many people have the strongest ability to use knowledge for a period of time at the beginning of their knowledge. As time goes on, memory fades. Our Analytics-DA-201 training materials are designed to help users consolidate what they have learned, will add to the instant of many training, the user can test their learning effect in time after finished the part of the learning content, have a special set of wrong topics in our Analytics-DA-201 Guide dump, enable users to find their weak spot of knowledge in this function, iterate through constant practice, finally reach a high success rate. As a result, our Analytics-DA-201 study questions are designed to form a complete set of the contents of practice can let users master knowledge as much as possible, although such repeated sometimes very boring, but it can achieve good effect of consolidation.
Analytics-DA-201 Exam Questions Pdf - Exam Analytics-DA-201 FeeI wonder if you noticed that there are three versions of our Analytics-DA-201 test questionsPDF, software on pc, and app online, which can bring you the greatest convenience. Imagine that if you feel tired or simply do not like to use electronic products to learn, the PDF version of Analytics-DA-201 test torrent is best for you. Just like reading, you can print it, annotate it, make your own notes, and read it at any time. Analytics-DA-201 latest torrents simulate the real exam environment and does not limit the number of computer installations, which can help you better understand the details of the exam. The online version of Analytics-DA-201 Test Questions also support multiple devices and can be used offline permanently after being opened for the first time using the network. On buses or subways, you can use fractional time to test your learning outcomes with Analytics-DA-201 test torrent, which will greatly increase your pro forma efficiency.
Salesforce Analytics-DA-201 Exam Syllabus Topics:
  • ABAP Core Data Services and Data Modeling: This section of the exam measures the skills of the SAP ABAP Cloud Developer and covers the fundamental understanding of core data services (CDS) and how to design data models in the SAP ABAP environment. Candidates are expected to know how to define, consume, and optimize CDS views effectively to support application development in the cloud.
  • ABAP RESTful Application Programming Model: This section of the exam evaluates the capabilities of the SAP S
  • 4HANA Technical Consultant in using the ABAP RESTful Application Programming Model (RAP). It focuses on understanding the structure and components of RAP, including behavior definitions, service bindings, and metadata extension. The goal is to validate the ability to develop modern and scalable applications using RAP.
  • ABAP SQL and Code Pushdown: This section of the exam measures the competencies of the SAP ABAP Cloud Developer related to performance optimization through ABAP SQL and code pushdown techniques. It ensures that the developer understands how to shift logic to the database layer using efficient SQL scripting to enhance performance in data-intensive applications.
Salesforce Certified Tableau Data Analyst Sample Questions (Q78-Q83):NEW QUESTION # 78
Open the link to Book1 found on the desktop. Open the Movie Durations worksheet.
Replace the existing data source with the Netflix_2019 data source.
check the steps below in explanation.
To replace the existing data source with the Netflix_2019 data source, you need to do the following steps:
* Open the link to Book1 found on the desktop. This will open the Tableau workbook that contains the Movie Durations worksheet.
* Click on the Movie Durations tab at the bottom of the workbook to open the worksheet. You will see a bar chart that shows the number of movies by duration for the existing data source.
* Go to the Data Source tab at the bottom of the workbook to see the data source page. You will see a table that shows the fields and values from the existing data source.
* Click on the drop-down arrow next to the data source name at the top of the page and select Replace Data Source from the menu. This will open a dialog box that allows you to replace your data source with another one.
* Select Netflix_2019 from the list of available data sources and click OK. This will replace your existing data source with the Netflix_2019 data source and update your worksheet accordingly. You may need to fix any broken fields or calculations that result from the replacement.
References: https://help.tableau.com/current ... asource_replace.htm https://help.tableau.com/current ... eplace_workbook.htm
NEW QUESTION # 79
A Data Analyst has the following dataset:
The analyst wants to create a new calculated dimension field named Category that meets the following conditions:
When Subject is Computer Science or Science, the Category must be Sciences.
When Subject is English or Social Studies, the Category must be Humanities.
Which two logical functions achieve this goal? (Choose two.)
  • A. IF [Subject] = 'Science' THEN 'Sciences'
    ELSEIF [Subject] = 'English' THEN 'Humanities'
    ELSEIF [Subject] = 'Social Studies' THEN 'Humanities'
    ELSEIF [Subject] = 'Computer Science' THEN 'Sciences'
    END
  • B. IF ENDSWITH([Subject], 'Computer Science') THEN 'Sciences' ELSE 'Humanities' END
  • C. CASE [Subject]
    WHEN 'Computer Science' THEN 'Sciences'
    WHEN 'English' THEN 'Humanities'
    WHEN 'Social Studies' THEN 'Humanities'END
  • D. IIF((CONTAINS([Subject], 'Science') = TRUE), 'Humanities', 'Sciences')
NEW QUESTION # 80
You have a line chart on a worksheet.
You want to add a comment to March 2020 as shown in the following visualization.
What should you do?
  • A. Add a tooltip
  • B. Enable captions
  • C. Annotate March 2020
  • D. Drag the growth rate to Text on the Marks card
To add a comment to March 2020 on a line chart, you need to annotate that mark. You can right-click on the mark and select Annotate > Mark from the menu. This will open a dialog box where you can type your comment and format it as you like. You can also drag and drop the annotation to position it on the worksheet.
Dragging the growth rate to Text on the Marks card will add a label to every mark on the line chart, enabling captions will show a description of the worksheet at the bottom, and adding a tooltip will show a text box when users hover over a mark. References: https://help.tableau.com/current/pro/desktop/en-us
/formatting_annotations.htm https://help.tableau.com/current/pro/desktop/en-us
/formatting_annotations_create.htm
To add a comment to a specific point on a line chart, such as March 2020 in the provided visualization, you would use the 'Annotate' feature. Right-clicking on the data point for March 2020 and selecting 'Annotate' allows you to add a text annotation directly to the chart, which can be used to highlight and comment on that particular data point.
NEW QUESTION # 81
You want to add a draft watermark to a dashboard as shown in the following exhibit.
Which type of object should you use?
  • A. Sheet
  • B. Horizontal
  • C. Web page
  • D. Image
References: https://help.tableau.com/current/pro/desktop/en-us/dashboards.htm https://help.tableau.com
/current/pro/desktop/en-us/dashboards_create_layouts.htm https://help.tableau.com/current/pro/desktop/en-us
/dashboards_create_watermarks.htm
To add a draft watermark to a Tableau dashboard, you would use an image object. You can overlay this image across your dashboard, possibly with some transparency, to achieve the watermark effect without interfering with the readability of the dashboard content.
NEW QUESTION # 82
When a Data Analyst needs to format workbook settings, which options are available in the Format Workbook panel?
  • A. Fonts and Lines
  • B. Dashboard Height and Width pixel settings
  • C. Fonts and Color Palette
  • D. Number format and Shading
NEW QUESTION # 83
The Analytics-DA-201 pdf format of the Actual4Dumps product is easy-to-use. It contains actual Salesforce Certified Tableau Data Analyst (Analytics-DA-201) exam questions. You can easily download and use Salesforce Analytics-DA-201 pdf on laptops, tablets, and smartphones. Actual4Dumps regularly updates Analytics-DA-201 Exam Questions' pdf version so that you always have the latest material. Furthermore, the Salesforce Analytics-DA-201 pdf can be printed enabling paper study.
Analytics-DA-201 Exam Questions Pdf: https://www.actual4dumps.com/Analytics-DA-201-study-material.html
P.S. Free & New Analytics-DA-201 dumps are available on Google Drive shared by Actual4Dumps: https://drive.google.com/open?id=11tMQzcLx9yujkUDsB0fVL__0zDftBif0
