[General] Exam 2V0-15.25 VCE
105
【General】 Exam 2V0-15.25 VCE
Posted at 2/6/2026 07:07:07      View:126 | Replies:1        Print      Only Author   [Copy Link] 1#
P.S. Free 2026 VMware 2V0-15.25 dumps are available on Google Drive shared by PDFDumps: https://drive.google.com/open?id=19ziU_RwtaLI-ZPFhopz0IL1Fy9kR8Ni6
After successful competition of the 2V0-15.25 certification, the certified candidates can put their career on the right track and achieve their professional career objectives in a short time period. However, to pass the 2V0-15.25 Exam you have to prepare well. For the quick 2V0-15.25 exam preparation the 2V0-15.25 Questions are the right choice.
PDFDumps has been going through all ups and downs tested by the market, and now our 2V0-15.25 exam questions have become perfectly professional. We never circumvent the difficulties of our 2V0-15.25 study materials happened on the road as long as there is bright at the end, and it is the satisfactory results you want. And we have helped so many of our customers achieve their certifications according to our 2V0-15.25 learning guide.
2026 2V0-15.25 New Study Materials | High Pass-Rate VMware 2V0-15.25: VMware Cloud Foundation 9.0 Support 100% PassThe 2V0-15.25 study quiz is made from various experts for examination situation in recent years in the field of systematic analysis of finishing, meet the demand of the students as much as possible, at the same time have a professional staff to check and review 2V0-15.25 practice materials, made the learning of the students enjoy the information of high quality. Due to the variety of examinations, so that students can find the information on 2V0-15.25 guide engine they need quickly.
VMware Cloud Foundation 9.0 Support Sample Questions (Q29-Q34):NEW QUESTION # 29
An administrator is responsible for managing a remote VMware Cloud Foundation (VCF) fleet with the following configuration:
* A single VCF instance with a single Workload Domain.
* The Workload Domain has a single VMware vSAN Express Storage Architecture (ESA) cluster.
* VCF is licensed using the disconnected mode.
The administrator discovers a notification in VCF Operations showing that the VCF licenses have expired.
Which three steps should the administrator take to resolve the issue? (Choose three.)
  • A. Import the license file into VCF Operations and assign to the SDDC Manager.
  • B. Export the usage file from VCF Operations and upload to the VCF Business Services console.
  • C. Use the VCF Business Services console to export a new VCF license file.
  • D. Restart SDDC Lifecycle Manager Service in the VCF Operations console.
  • E. Increase the license core count in SDDC Manager.
  • F. Import the license file into VCF Operations and assign to the workload domain vCenter.
Answer: A,B,C
In VMware Cloud Foundation (VCF) 9.0 usingdisconnected mode licensing, VCF Operations does not automatically synchronize license status with VMware's cloud services. Instead, the administrator must periodically refresh the license file using amanual offline workflow. When the VCF Operations console reports that licenses have expired, it means the license entitlement in theVCF Business Services portalis out of date, and therefore VCF Operations cannot validate the current usage.
The VMware-documented offline licensing workflow requires the following steps:
* Export the usage filefrom VCF Operations.This usage file contains consumption details needed to generate a new offline license.#C is correct.
* Upload the usage file to the VCF Business Services consoleand generate a new offline license file.In disconnected mode, the Business Services portal is the only mechanism to create updated license entitlements.#D is correct.
* Import the updated VCF license file into VCF Operations, specifically assigning it to theSDDC Manager.SDDC Manager is the system that validates and enforces licensing across workload domains, so the new license must be applied there-not only to a vCenter.#F is correct.
Options A and B do not affect license validation.
Option E is incorrect because workload-domain vCenter licensing is independent and not the root cause of VCF license expiration.
NEW QUESTION # 30
A VMware NSX Edge node is present in the inventory but shows "Not Ready" status In NSX Manager UI.
What should the administrator check first?
  • A. The NSX Edge has been added to an Edge cluster
  • B. The NSX Edge node's uplink network configuration
  • C. The NSX Edge node's CPU reservation
  • D. The license key in NSX Manager UI
The status"Node Not Ready"in the NSX Manager UI (specifically in theConfiguration Statecolumn of the Edge Transport Nodes view) indicates that the NSX Manager has failed to push or validate the necessary configuration to the Edge VM.
* Check Uplink Network Configuration (Option C):This is the most common cause for a "Node Not Ready" state during deployment or operation. For an Edge Node to be "Ready" (Success/Up), it must have a validTransport Nodeconfiguration, which includes theUplink Profile,IP Pool(for TEPs), and mapping to theFastpath Interfaces(N-VDS). If the uplink configuration is missing, incorrect, or the management plane cannot communicate with the edge to apply it, the node remains in a "Not Ready" state.
* Why not Option A?While an Edge must be in anEdge Clusterto beutilizedby a Tier-0 Gateway, a standalone Edge Node should still report a status of "Success" (Configuration) and "Up" (Node Status) if it is healthy. Adding a "Not Ready" (unhealthy/unconfigured) node to a cluster will not fix the underlying configuration issue.
* Why not Option D?Missing CPU reservations typically lead to a"Degraded"status or service crashes (Dataplane down), but "Node Not Ready" is the specific indicator of an incomplete or stalled configuration workflow, usually tied to the transport/uplink setup.
NEW QUESTION # 31
An administrator is adding a vSphere Supervisor using VMware NSX classic to an existing VMware Cloud Foundation (VCF) cluster using Distributed Connectivity. When attempting to enable the vSphere Supervisor for the domain the cluster shows up as incompatible with the reason:
No valid edge cluster for VDS 50 Ob 4d 9a cb 32 62 4d - 76 78 6b 92 cd 87 c4 5a Why is the cluster showing up as incompatible?
  • A. The WCPReady tag has not been been assigned to the NSX Edge Cluster.
  • B. AVI load balancing has not been enabled for the NSX Edge Cluster.
  • C. vSphere Supervisor requires Central Connectivity.
  • D. The NSX Edge transport nodes have been deployed as large.
A Comprehensive and Detailed Explanation: When enabling vSphere Supervisor with NSX Classic (using the traditional NSX-T Data Center networking stack rather than the newer NSX VPC mode), the vSphere Workload Management wizard filters the list of available NSX Edge Clusters to ensure they are explicitly designated for use with Kubernetes workloads.
The "WCPReady" Tag Requirement: The primary mechanism vCenter uses to identify a valid, compatible Edge Cluster for Workload Management is a specific tag on the NSX Edge Cluster object. This tag must be WCPReady (case-sensitive).
Symptoms: If this tag is missing-which often happens if the Edge Cluster was created manually in NSX Manager rather than through the SDDC Manager automation-the validation process will fail to find any usable clusters. This results in the specific error message: "No valid edge cluster for VDS [UUID]", or simply an empty list of compatible clusters in the wizard.
Resolution: The administrator must log in to the NSX Manager, navigate to System > Fabric > Nodes > Edge Clusters, select the target cluster, and manually add the tag WCPReady (often with the scope "Created for", though the tag itself is the critical filter).
B: Large Edge nodes are actually a requirement for vSphere Supervisor (Small/Medium are typically unsupported for this role), so deploying them as Large would make the cluster compatible, not incompatible.
C: vSphere Supervisor fully supports Distributed Connectivity (connecting directly to the VDS), so Central Connectivity is not a hard requirement causing this specific error.
D: While AVI (NSX Advanced Load Balancer) is a supported load balancer, the "No valid edge cluster" error occurs during the Edge Cluster discovery phase, preceding the load balancer configuration.
NEW QUESTION # 32
An administrator attempts to update the VMware vCenter root account password through VMware Cloud Foundation (VCF) Operations. The attempt fails with the following error message, "Failed to authenticate with the guest operating system using the supplied credentials." What is the cause of the failure?
  • A. The SSH service is not running.
  • B. The password was previously updated on the vCenter directly.
  • C. The password does not meet policy requirements.
  • D. vCenter is down.
VMware Cloud Foundation 9.0 Operations manages credentials for integrated components such as vCenter Server through its internal password vault. When administrators modify passwordsdirectly on the component
-such as manually changing thevCenter rootpassword-VCF Operations is no longer able to authenticate using its stored credentials. As a result, any password rotation or update operation initiated through VCF Operations fails during the validation step.
The error"Failed to authenticate with the guest operating system using the supplied credentials"is a direct symptom of this condition. VCF Operations attempts to log in to vCenter using thepreviously stored credential, which no longer matches the actual root password. Documentation describes this as an "out-of- sync credential state," and the resolution is to performpassword remediationto re-synchronize VCF Operations with the system.
Option A (password complexity) is irrelevant because complexity is validated only after authentication.
Option C (vCenter down) would generate connectivity errors, not authentication errors.
Option D (SSH disabled) does not prevent password rotation because VCF Operations uses VMware Tools guest operations, not SSH, for authentication.
NEW QUESTION # 33
An administrator is troubleshooting a problem with NSX.
Which command can be used to validate installed NSX VIBs on the ESX host?
  • A. esxcli software vib list
  • B. esxcfg software list
  • C. nsxcli get version
  • D. esxtop -b -d 2 -n 100
When troubleshooting NSX on an ESXi host, VMware requires verification that NSX VIBs (vSphere Installation Bundles) are installed and in the correct state. VIBs are responsible for NSX datapath, control- plane modules, and kernel extensions on ESXi. The authoritative and documented method to list VIBs on an ESXi host is the command:
This command displays all installed kernel modules, version numbers, NSX packages, and their installation status. For NSX-T (now part of VCF networking), administrators expect to see VIBs such asnsx-aggservice, nsx-bridge,nsx-esx-datapath, and others. If any required NSX VIBs are missing or inconsistent, the ESXi host will fail to join NSX transport nodes or will show "Not Ready." Option A (esxtop) is for performance monitoring and does not show VIB information.
Option C (nsxcli get version) checks NSX version on Edge Nodes or host transport nodes butdoes not list VIBs.
Option D (esxcfg software list) is an outdated and invalid command.
NEW QUESTION # 34
PDFDumps believes in customer satisfaction and strives hard to make the entire 2V0-15.25 exam preparation process simple, smart, and successful. To achieve this objective PDFDumps is offering the top-rated and real VMware Certification Exams preparation material in three different VMware 2V0-15.25 Exam study material formats. These VMware Cloud Foundation 9.0 Support exam questions formats are 2V0-15.25 PDF dumps file, desktop practice test software and web-based practice test software.
Valid 2V0-15.25 Exam Papers: https://www.pdfdumps.com/2V0-15.25-valid-exam.html
Have you ever imagined that you only need to spend 20 to 30 hours on preparing for the 2V0-15.25 exam but still can get the best results, Our 2V0-15.25 latest dumps: VMware Cloud Foundation 9.0 Support offer free demo, which you can download before purchasing, VMware 2V0-15.25 New Study Materials Therefore, it is less likely for you to take part in the test in the second time, which of course saves a lot of money for you, Our 2V0-15.25 exam valid questions give the candidates one-year free update.
Denning is Professor of Computer Science 2V0-15.25 at Georgetown University, An administrator should create organizational units if the departments will be administered separately New 2V0-15.25 Exam Sample and/or policies will be applied differently to the various departments.
2026 Valid 2V0-15.25 New Study Materials | VMware Cloud Foundation 9.0 Support 100% Free Valid Exam PapersHave you ever imagined that you only need to spend 20 to 30 hours on preparing for the 2V0-15.25 Exam but still can get the best results, Our 2V0-15.25 latest dumps: VMware Cloud Foundation 9.0 Support offer free demo, which you can download before purchasing.
Once our researchers regard it possible to realize, we will try our best to perfect the details of the 2V0-15.25 learning prep.
BTW, DOWNLOAD part of PDFDumps 2V0-15.25 dumps from Cloud Storage: https://drive.google.com/open?id=19ziU_RwtaLI-ZPFhopz0IL1Fy9kR8Ni6
Posted at 2/19/2026 05:26:14        Only Author  2#
This article has helped me understand many complex concepts, and I’ve gained a lot. The rich content of Advanced-Administrator pdf demo download is available for free, designed to assist you in your studies.
