[General] FAAA_005 Valid Exam Vce Free - Pdf FAAA_005 Exam Dump
97
General FAAA_005 Valid Exam Vce Free - Pdf FAAA_005 Exam Dump
Posted at 2/6/2026 10:12:02      View139 | Replies2        Print      Only Author   [Copy Link] 1#
BONUS!!! Download part of BraindumpQuiz FAAA_005 dumps for free: https://drive.google.com/open?id=1ib7MhRt6tuyctqfRZNwGnlm7ZUoDxEGE
Our online staff is professionally trained and they have great knowledge on the FAAA_005 study guide. So they can clearly understand your requirements and ideas and then help you make the right choices. When you have purchased our FAAA_005 exam practice, but you do not know how to install it, we can also provide remote guidance to help you complete the installation. All in all, we will always be there to help you until you pass the FAAA_005 Exam and get a certificate.
This way you can save money even if Pure Storage FAAA_005 introduces fresh Pure Storage FAAA_005 exam updates. So why are you delaying? Purchase the Pure Storage FAAA_005 Preparation material to get certified on the first attempt.
Pdf FAAA_005 Exam Dump | FAAA_005 PDF Dumps FilesWhereas the other two Pure Storage FlashArray Architect Associate (FAAA_005) exam questions formats are concerned both are the easy-to-use and compatible mock FAAA_005 exam that will give you a real-time environment for quick Pure Storage Exams preparation. Now choose the right Pure Storage FlashArray Architect Associate (FAAA_005) exam questions format and start this career advancement journey.
Pure Storage FlashArray Architect Associate Sample Questions (Q16-Q21):NEW QUESTION # 16
A customer running FlashArray//X70R3 in production just purchased a FlashArray//C60R3 Array for a secondary site. The customer wants to have the lowest RPO (Recovery Point Objective) possible for the data.
Which FlashArray feature will meet the requirements?
  • A. Async Replication
  • B. ActiveDR
  • C. ActiveCluster
The customer wants to achieve the lowest RPO (Recovery Point Objective) possible for their data when replicating between a FlashArray//X70R3 in production and a FlashArray//C60R3 at a secondary site. The best feature to meet this requirement is ActiveDR.
Why This Matters:
ActiveDR:
ActiveDR is an asynchronous replication solution designed for disaster recovery scenarios. It provides low RPOs, typically in the range of seconds to minutes, depending on network conditions and workload characteristics.
While it is asynchronous, ActiveDR achieves much lower RPOs compared to traditional async replication methods like snapshot replication.
It also supports fast failover and failback, ensuring minimal downtime during a disaster recovery event.
Why Not the Other Options?
A). ActiveCluster:
ActiveCluster provides synchronous replication with zero RPO and near-zero RTO. However, it requires both sites to be within a low-latency range (typically <10 ms). Since the customer has not specified that the secondary site is within synchronous distance, ActiveCluster is not feasible in this scenario.
C). Async Replication:
Traditional asynchronous replication (e.g., snapshot replication) typically results in higher RPOs compared to ActiveDR. It does not provide the same level of optimization for low RPOs as ActiveDR.
Key Points:
ActiveDR: Provides the lowest RPO possible for asynchronous replication, making it ideal for geographically distant secondary sites.
Network Latency: ActiveDR is designed to work efficiently over longer distances and higher latencies compared to synchronous solutions like ActiveCluster.
Disaster Recovery: Ensures protection against site failures with minimal data loss and downtime.
Reference: Pure Storage FlashArray Documentation: "ActiveDR for Disaster Recovery" Pure Storage Whitepaper: "Meeting RPO and RTO Requirements with FlashArray" Pure Storage Knowledge Base: "Choosing the Right Replication Solution for High Latency"
NEW QUESTION # 17
What is the minimally required FlashArray model that includes the DirectCompress Accelerator (DCA)?
  • A. FlashArray//X90 R4
  • B. FlashArray//XL130
  • C. FlashArray//X70 R4
  • D. FlashArray//X70 R3
The DirectCompress Accelerator (DCA) is a hardware component introduced in certain FlashArray models to enhance inline data compression performance. To determine the minimally required FlashArray model that includes DCA, let's analyze the options:
Analysis of Options:
A). FlashArray//X70 R4:
The FlashArray//X70 R4 was the first model to include the DirectCompress Accelerator (DCA). This makes it the minimally required model for DCA support.
B). FlashArray//X70 R3:
The FlashArray//X70 R3 does not include the DCA. It relies on software-based compression, which is less efficient than hardware-accelerated compression.
C). FlashArray//X90 R4:
The FlashArray//X90 R4 includes DCA but is a higher-tier model than the X70 R4. While it supports DCA, it is not the minimal requirement.
D). FlashArray//XL130:
The FlashArray//XL130 is a high-performance model that includes DCA, but it is overkill for this requirement and not the minimal model.
Recommendation:
The correct answer is
A). FlashArray//X70 R4, as it is the first model to include the DirectCompress Accelerator (DCA).
Reference: FlashArray Hardware Specifications:
FlashArray Models
Details the features and capabilities of each FlashArray model.
DirectCompress Accelerator Overview:
Explains the benefits and availability of DCA.
NEW QUESTION # 18
A customer has two data centers: one in North America and one in England. The customer wants to replicate their production data across data centers, with as low an RPO as possible.
What Pure Storage feature meets their requirements?
  • A. ActiveDR
  • B. ActiveCluster
  • C. Asynchronous snapshot replication
The customer wants to replicate production data across two data centers (North America and England) with as low an RPO as possible. The best Pure Storage feature to meet this requirement is ActiveDR.
Why This Matters:
ActiveDR:
ActiveDR is an asynchronous replication solution designed for disaster recovery scenarios where the secondary site may be geographically distant (e.g., across continents).
ActiveDR supports fast failover and failback capabilities, ensuring minimal data loss and downtime during a disaster recovery event.
A). ActiveCluster:
ActiveCluster provides synchronous replication between two sites within a stretched cluster, ensuring zero RPO and near-zero RTO. However, it requires both sites to be within a low-latency range (typically <10 ms). Given the geographic distance between North America and England, ActiveCluster is not feasible due to high latency impacting performance.
C). Asynchronous snapshot replication:
Traditional asynchronous snapshot replication typically results in higher RPOs compared to ActiveDR.
Key Points:
ActiveDR: Provides the lowest RPO possible for asynchronous replication, making it ideal for geographically distant sites.
NEW QUESTION # 19
A customer wants to store 100 TiB of Oracle data and 200 TiB of VDI data onto a FlashArray. When checking the data reduction ratio, the given data reduction ratios are 4:1 for Oracle and 5:1 for VDI.
What is the minimum useable capacity needed on the FlashArray?
  • A. 750TiB
  • B. 40TiB
  • C. 65TiB
  • D. 300TiB
To calculate the minimum usable capacity needed on the FlashArray, we must account for the data reduction ratios provided for Oracle and VDI workloads.
Here's the step-by-step calculation:
Given Data:
Oracle data: 100 TiB with a 4:1 data reduction ratio.
VDI data: 200 TiB with a 5:1 data reduction ratio.
Calculation:
Oracle Data Reduction:
Effective capacity after reduction = 100 TiB 4 = 25 TiB.
VDI Data Reduction:
Effective capacity after reduction = 200 TiB 5 = 40 TiB.
Total Usable Capacity Needed:
Total effective capacity = 25 TiB (Oracle) + 40 TiB (VDI) = 65 TiB.
Recommendation:
The minimum usable capacity needed on the FlashArray is 65 TiB. However, since the question asks for the minimum usable capacity and the options include 40 TiB, it appears there may be a misunderstanding in the question phrasing. Assuming the intent is to find the total usable capacity, the correct answer is 65 TiB.
Reference: Pure Storage Data Reduction Overview:
Explains how data reduction ratios impact storage capacity planning.
FlashArray Capacity Planning Guide:
Provides guidance on calculating usable capacity based on data reduction ratios.
NEW QUESTION # 20
What allows for array upgrades without any degradation in performance?
  • A. Non-disruptive upgrades
  • B. Right-Size Guarantee
  • C. ActiveCluster
  • D. Protection groups
The feature that allows for array upgrades without any degradation in performance is non-disruptive upgrades.
Why This Matters:
Non-Disruptive Upgrades:
Pure Storage FlashArray supports rolling upgrades, enabling software updates (e.g., Purity//FA) and hardware upgrades (e.g., controllers) without interrupting operations.
During a controller upgrade, the active/active architecture ensures that one controller continues handling I/O operations while the other is upgraded, maintaining consistent performance.
A). ActiveCluster:
ActiveCluster provides synchronous replication for high availability but does not directly relate to non-disruptive upgrades.
C). Right-Size Guarantee:
The Right-Size Guarantee ensures customers receive the expected effective capacity based on their workload's data reduction profile. It is unrelated to upgrades or performance.
D). Protection groups:
Protection groups are used for replication and snapshot management but do not impact the ability to perform non-disruptive upgrades.
Key Points:
Non-Disruptive Upgrades: Ensure seamless updates without impacting performance or availability.
Active/Active Architecture: Enables continuous I/O processing during upgrades.
Customer Experience: Minimizes downtime and disruption during maintenance or upgrades.
Reference: Pure Storage FlashArray Documentation: "Non-Disruptive Operations with FlashArray" Pure Storage Whitepaper: "Evergreen Architecture and Non-Disruptive Upgrades" Pure Storage Knowledge Base: "Performing Non-Disruptive Upgrades on FlashArray"
NEW QUESTION # 21
FAAA_005 practice material contains questions & answers together with explanations. You can do your FAAA_005 study plan according to your actual test condition. If your time is limited, you can remember the questions and answers for the FAAA_005 preparation. While, if your time is enough for well preparation, you can study and analyze the answers with the help of the FAAA_005 Exam explanations. No matter in which way you study for the Pure Storage certification, our FAAA_005 valid pdf dumps will ensure you 100% pass.
Pdf FAAA_005 Exam Dump: https://www.braindumpquiz.com/FAAA_005-exam-material.html
Pure Storage FAAA_005 Valid Exam Vce Free Please add it to your shopping cart, If you search for the best high pass-rate study materials, our FAAA_005 practice test questions will be your best select, And we will update our FAAA_005 training guide from time to time, once we update our FAAA_005 study guide, we will auto send it to our customers, Pdf FAAA_005 Exam Dump for Finance and Operations, Financials Exam questions for Best Results.
Having defined the threads and established their allowed FAAA_005 bindings to processors, we can begin to assess processor loading and analyze the schedulability of the system.
Testing Wireless Equipment in the Lab, Please add it to your shopping cart, If you search for the best high pass-rate study materials, our FAAA_005 Practice Test questions will be your best select.
Pure Storage FlashArray Architect Associate exam pdf guide & FAAA_005 prep sure examAnd we will update our FAAA_005 training guide from time to time, once we update our FAAA_005 study guide, we will auto send it to our customers, FlashBlade Architect Professional for Finance and Operations, Financials Exam questions for Best Results.
FAAA_005 pdf dumps file will help you to immediately prepare well for the actual Pure Storage Pure Storage FlashArray Architect Associate.
2026 Latest BraindumpQuiz FAAA_005 PDF Dumps and FAAA_005 Exam Engine Free Share: https://drive.google.com/open?id=1ib7MhRt6tuyctqfRZNwGnlm7ZUoDxEGE
Posted at 2/10/2026 13:14:56        Only Author  2#
After reading this article, Ive gained a new perspective on how to look at the problem. Get free Valid HPE2-W12 learning materials to level up your IT knowledge. Wishing you success!
Posted at 2/17/2026 05:06:44        Only Author  3#
I'm giving this a like without even thinking twice. Upgrade your IT skills with free Exam Associate-Cloud-Engineer introduction. Best wishes for your success!
