High Pass-Rate 300-740 Free Dumps Help You to Get Acquainted with Real 300-740 E
68
Posted at 2/6/2026 10:26:42      View122 | Replies1        Print      Only Author   [Copy Link] 1#
What's more, part of that ExamcollectionPass 300-740 dumps now are free: https://drive.google.com/open?id=1QyZnKwxCfQkAeDWfmnYGSgrxoJNmqoT7
We promise to provide a high-quality simulation system with advanced 300-740 study materials. With the simulation function, our 300-740 training guide is easier to understand and have more vivid explanations to help you learn more knowledge. You can set time to test your study efficiency, so that you can accomplish your test within the given time when you are in the Real 300-740 Exam. You will be confident if you have more experience on the 300-740 exam questions!
As long as you face problems with the 300-740 exam, our company is confident to help you solve. Give our 300-740 practice quiz a choice is to give you a chance to succeed. We are very willing to go hand in hand with you on the way to preparing for 300-740 Exam. And we have three different versions of our 300-740 learning materials, you will find that it is so interesting and funny to study with our study guide.
Exam 300-740 Demo & Vce 300-740 FreeThe punishment received by laziness is not only its own failure, but also the success of others. No one wants to be inferior to others. So, it's time to change yourself and make yourself better! Our 300-740 study materials want to give you some help on your dream journey. Believe me, the help you get is definitely what you need. On one hand, you can easily pass the 300-740 Exam and get the according 300-740 certification. On the other hand, you will be definitely encouraged to make better progress from now on.
Cisco Designing and Implementing Secure Cloud Access for Users and Endpoints Sample Questions (Q187-Q192):NEW QUESTION # 187
Upon detecting a user or application compromise, the first action should be to:
  • A. Ignore the incident
  • B. Disconnect the entire network
  • C. Immediately delete all compromised accounts
  • D. Contain the threat to prevent further spread
NEW QUESTION # 188
SAML and OIDC are both standards used for:
  • A. User and device authentication in single sign-on scenarios
  • B. Physical security of devices
  • C. Web filtering
  • D. Encrypting data on a device
NEW QUESTION # 189
Which of the following is a use case for visibility and assurance automation?
  • A. Decreasing the speed of security operations
  • B. Automating the response to security incidents
  • C. Increasing manual intervention in security processes
  • D. Reducing the accuracy of threat detection
NEW QUESTION # 190
Refer to the exhibit. An engineer must implement a remote access VPN solution that provides user and device verification. The company uses Active Directory for user authentication and ID certificates for device identity. Users are currently able to connect using only a valid username and password, even if their computer is missing the required certificate.
Which command from the Cisco ASA tunnel-group completes the requirement of verifying device identity in addition to user identity?
  • A. authentication mfa
  • B. ldap-attribute-map PolicyAllow
  • C. authentication aaa certificate
  • D. webvpn authorize-device
To enforce both user-based and device-based authentication on Cisco ASA, the tunnel group must include the command: authentication aaa certificate. This configuration requires that both a valid username/password (authenticated via AAA, such as Active Directory) and a trusted certificate (device identity) are present before allowing VPN access. Without this directive, only username/password credentials are validated, which leads to the scenario described in the question.
Reference: Designing and Implementing Secure Cloud Access for Users and Endpoints (SCAZT), Section 2:
User and Device Security, Pages 40-44.
NEW QUESTION # 191
A network administrator uses Cisco Umbrella to protect internal users from malicious content. A customer is using an IPsec tunnel to connect to an Umbrella Organization. The administrator was informed about a zero- day vulnerability that infects user machines and uploads sensitive data through the RDP port. The administrator must ensure that no users are connected to the internet using the RDP protocol. Which Umbrella configuration must the administrator apply?
  • A. DNS policy to block Remote Desktop Manager application type
  • B. Web policy to block Remote Desktop Manager application type
  • C. Firewall policy and set port 3389 to be blocked for all outgoing traffic
  • D. Data loss prevention policy to block all file uploads with RDP application mime type
The Remote Desktop Protocol (RDP) uses TCP port 3389. Cisco Umbrella includes a cloud-delivered firewall that can be used to block outbound traffic by port. In this case, since the RDP communication needs to be prevented regardless of application name resolution, the best approach is to use a Firewall policy in Umbrella to block port 3389 traffic across the tunnel.
Reference: Designing and Implementing Secure Cloud Access for Users and Endpoints (SCAZT), Section 3:
Network and Cloud Security, Pages 72-75.
NEW QUESTION # 192
Our veteran professional generalize the most important points of questions easily tested in the 300-740 practice exam into our practice questions. Their professional work-skill paid off after our 300-740 training materials being acceptable by tens of thousands of exam candidates among the market. They have delicate perception of the 300-740 study quiz over ten years. So they are dependable. You will have a big future as long as you choose us!
Exam 300-740 Demo: https://www.examcollectionpass.com/Cisco/300-740-practice-exam-dumps.html
If you are also worried about the exam at this moment, please take a look at our 300-740 study materials which have became the leader in this career on the market, Cisco 300-740 Free Dumps The instructor can also provide you with tips and best practices for taking the exam, Once any new question is found, we will send you a link to download a new version of the 300-740 training materials, Cisco 300-740 Free Dumps In the past ten years, we have overcome many difficulties and never give up.
These are usually R&D projects for which the risk 300-740 of failure is very high, Set the type of var to be integer, If you are also worried about the exam at this moment, please take a look at our 300-740 Study Materials which have became the leader in this career on the market.
Believable 300-740 Guide Materials: Designing and Implementing Secure Cloud Access for Users and Endpoints Present You the Most Popular Exam Dumps - ExamcollectionPassThe instructor can also provide you with tips and best practices for taking the exam, Once any new question is found, we will send you a link to download a new version of the 300-740 training materials.
In the past ten years, we have overcome many difficulties Valid 300-740 Exam Testking and never give up, After we use our study materials, we can get the Cisco certification faster.
P.S. Free 2026 Cisco 300-740 dumps are available on Google Drive shared by ExamcollectionPass: https://drive.google.com/open?id=1QyZnKwxCfQkAeDWfmnYGSgrxoJNmqoT7
Posted at 4/20/2026 04:22:51        Only Author  2#
Your article is so inspiring, thank you for sharing! C-BCBTP-2502 online version offers detailed content for free, designed to help with your studies.
