[General] Reliable GICSP Exam Pattern - Test GICSP Questions
102
General Reliable GICSP Exam Pattern - Test GICSP Questions
Posted at 2/6/2026 10:39:21      View125 | Replies0        Print      Only Author   [Copy Link] 1#
People who want to pass the exam have difficulty in choosing the suitable GICSP study materials. They do not know which study materials are suitable for them, and they do not know which the study materials are best. Our company can promise that the GICSP Study Materials from our company are best among global market. As is known to us, the GICSP study materials from our company are the leading practice materials in this dynamic market.
Our GICSP study braindumps for the overwhelming majority of users provide a powerful platform for the users to share. Here, the all users of the GICSP exam questions can through own ID number to log on to the platform and other users to share and exchange, each other to solve their difficulties in study or life. The GICSP Prep Guide provides user with not only a learning environment, but also create a learning atmosphere like home. And our GICSP exam questions will help you obtain the certification for sure.
Test GICSP Questions - GICSP Clear ExamWith online test engine, you will feel the atmosphere of GIAC valid test. You can set limit-time when you do the GICSP test questions so that you can control your time in GICSP practice exam. Online version can point out your mistakes and remind you to practice it every day. What's more, you can practice GICSP Pdf Torrent anywhere and anytime.
GIAC Global Industrial Cyber Security Professional (GICSP) Sample Questions (Q32-Q37):NEW QUESTION # 32
What do the following protocols have in common?
  • A. Use of IPv6 in the network layer
  • B. Use in RF mesh networks
  • C. Ability to tunnel legacy protocols
  • D. Ability to use asymmetric join methods
WirelessHART, ISA100.11a, and ZigBee are all wireless communication protocols commonly used in industrial automation and control systems. A key characteristic they share is:
They use RF (Radio Frequency) mesh networking (B) to enable devices to communicate through multiple hops, improving reliability and coverage. Mesh networks allow devices to relay messages, creating a robust wireless infrastructure.
Use of IPv6 (A) is specific to some protocols but not common to all three.
Asymmetric join methods (C) and tunneling legacy protocols (D) are not shared features of all three.
The GICSP materials emphasize mesh network topology as a key feature of these protocols in enabling reliable and secure wireless ICS communications.
GICSP Official Study Guide, Domain: ICS Security Architecture & Design
WirelessHART, ISA100.11a, ZigBee Protocol Specifications
GICSP Training on Wireless ICS Protocols and Security
NEW QUESTION # 33
How is a WirelessHART enabled device authenticated?
  • A. Using the vendor hard-coded master key to obtain a link key
  • B. Using a PIN combined with the device MAC address
  • C. Using a join key to send an encrypted request for the shared network key
  • D. Using a WPA2 pre-shared key entered by an administrator
WirelessHART is a secure, industrial wireless protocol widely used in process control. Its security architecture uses a layered approach including encryption and authentication mechanisms to protect communications.
WirelessHART devices authenticate by first using a join key, which is a shared secret configured in both the device and the network manager. The device uses this join key to send an encrypted request to the network manager.
Upon successful authentication, the device receives the network key, which is used for encrypting ongoing communications within the network.
This method ensures that only authorized devices can join the network and participate in secure communications.
WPA2 (A) is a Wi-Fi standard, not used in WirelessHART; the vendor hard-coded master key (C) is discouraged due to security risks; and PIN plus MAC address (D) is not a WirelessHART authentication method.
This procedure is detailed in the GICSP's ICS Security Architecture domain, highlighting wireless device authentication protocols as per WirelessHART specifications.
WirelessHART Specification (HART Communication Foundation)
GICSP Training Module on Wireless Security and Protocols
NEW QUESTION # 34
An attacker writes a program that enters a large number of characters into the password field of a website, followed by a command. The website gave him administrative access, even though he did not use a valid username or password.
What is the name of this attack?
  • A. Man-in-the-Middle
  • B. Fuzzing
  • C. Buffer overflow
  • D. Cross-site scripting
This is a classic description of a buffer overflow attack (B), where an attacker inputs excessive data into a field to overwrite memory and inject commands, potentially gaining unauthorized access.
(A) Man-in-the-Middle intercepts communications but doesn't involve input fields directly.
(C) Cross-site scripting involves injecting malicious scripts into web pages viewed by other users.
(D) Fuzzing is a testing technique, not an attack that grants access.
GICSP highlights buffer overflows as a critical vulnerability affecting ICS software and web interfaces.
NEW QUESTION # 35
A plant is being retrofitted with new cyber security devices in Purdue Level 3. What should the network security architect suggest for the installation?
  • A. Place the cyber security devices on their own subnet
  • B. Add a firewall to segregate the cyber security devices
  • C. Move the cyber security devices to a DMZ
In Purdue Level 3, which typically houses operations management systems and network devices, best practices for retrofitting security devices include placing those devices on their own subnet (B). This segmentation:
Limits broadcast domains and reduces unnecessary traffic
Enables easier management of security policies specific to cybersecurity devices Provides isolation that helps protect security devices from general network traffic and potential attacks Adding a firewall (A) is useful but does not replace subnet segregation. Moving devices to a DMZ (C) is typically reserved for systems that bridge between enterprise and ICS networks (often at Purdue Level 3 to Level 4 boundaries), not internal device placement within Level 3.
This approach is emphasized in GICSP's ICS Security Architecture & Network Segmentation domain as a fundamental network design principle.
NIST SP 800-82 Rev 2, Section 5.5 (Network Segmentation and Security Devices) GICSP Training on Network Security Architecture
NEW QUESTION # 36
Which of the following types of network devices sends traffic only to the intended recipient node?
  • A. Wireless access point
  • B. Ethernet hub
  • C. Wireless bridge
  • D. Ethernet switch
An Ethernet switch (C) is a network device that learns the MAC addresses of connected devices and forwards packets only to the port associated with the destination node, reducing unnecessary traffic and improving security and efficiency.
An Ethernet hub (A) broadcasts incoming packets to all ports, not selectively.
A wireless access point (B) broadcasts signals to multiple wireless clients within range.
A wireless bridge (D) connects two network segments wirelessly but forwards traffic according to device types, not necessarily selectively to single nodes.
GICSP's ICS network segmentation and architecture domain underline the use of switches to limit broadcast traffic and reduce attack surfaces.
NIST SP 800-82 Rev 2, Section 5.5 (Network Architecture)
GICSP Training on Network Devices and Traffic Management
NEW QUESTION # 37
However, preparing for the Global Industrial Cyber Security Professional (GICSP) (GICSP) exam is not an easy job until they have real Global Industrial Cyber Security Professional (GICSP) (GICSP) exam questions that are going to help them achieve this target. They have to find a trusted source such as BraindumpStudy to reach their goals. Get GIAC GICSP Certified, and then apply for jobs or get high-paying job opportunities.
Test GICSP Questions: https://www.braindumpstudy.com/GICSP_braindumps.html
BraindumpStudy is an invisible assent that can give your advantage and get better life higher than your current situation and help you stand out among the average with the best and most accurate GICSP study braindumps, In addition, GICSP exam dumps are high-quality, and you can improve your efficiency if you use them, Are you preparing for the GICSP certification recently?
What could account for this, By default, Windows spaces GICSP icons evenly on an invisible grid, BraindumpStudy is an invisible assent that can give your advantage and get better life higher than your current situation and help you stand out among the average with the best and most accurate GICSP study braindumps.
Reliable GICSP Exam Pattern Free PDF | Latest Test GICSP Questions: Global Industrial Cyber Security Professional (GICSP)In addition, GICSP exam dumps are high-quality, and you can improve your efficiency if you use them, Are you preparing for the GICSP certification recently?
So our GICSP latest exam torrent has been designed elaborately in order to meet customers' requirement, Of course, the first time when you use our GICSP exam guide materials to learn, you need to make sure that the internet is available, and after that, you can have access to the GICSP training materials: Global Industrial Cyber Security Professional (GICSP) provided by our APP even when you are offline.
