[General] New JN0-224 Exam Pass4sure, JN0-224 Valid Dumps Ebook
70
【General】 New JN0-224 Exam Pass4sure, JN0-224 Valid Dumps Ebook
Posted at 2/6/2026 12:17:57      View:106 | Replies:0        Print      Only Author   [Copy Link] 1#
Our JN0-224 study tool boost three versions for you to choose and they include PDF version, PC version and APP online version. Each version is suitable for different situation and equipment and you can choose the most convenient method to learn our JN0-224 test torrent. For example, APP online version is printable and boosts instant access to download. You can study the JN0-224 Guide Torrent at any time and any place. The PC version of JN0-224 study tool can stimulate the real exam's scenarios. We provide 365-days free update and free demo available.
Juniper JN0-224 Exam Syllabus Topics:
  • Data Serialization: This domain addresses YAML and JSON formats used for structured data representation and exchange in network automation workflows.
  • Rest API: This domain covers Junos REST API implementation, REST API Explorer tool, and cURL usage for HTTP-based device management and configuration.
  • NETCONF
  • XML API: This domain focuses on XML syntax, XPath expressions, NETCONF protocol, and XML API functionality for programmatic device configuration and communication.
  • Python
  • PyEZ: This domain examines Python programming with PyEZ library for Junos automation, including JSNAPy, Jinja2 templates, RPC calls, exception handling, and device configuration management.
Topic 5
  • Junos Automation Stack and DevOps Concepts: This domain covers fundamental automation tools, frameworks, APIs, and DevOps culture applicable to Junos platform operations and network management.
Realistic New JN0-224 Exam Pass4sure - 100% Pass JN0-224 ExamThe pressure is not terrible, and what is terrible is that you choose to evade it. You clearly have seen your own shortcomings, and you know that you really should change. Then, be determined to act! Buying our JN0-224 exam questions is the first step you need to take. Only with our JN0-224 Practice Guide, then you will totally know your dream clearly and have enough strenght to make it come true. Our JN0-224 learning materials have became a famous brand which can help you succeed by your first attempt.
Juniper Automation and DevOps, Associate (JNCIA-DevOps) Sample Questions (Q56-Q61):NEW QUESTION # 56
Which two statements are correct about a Python list data type? (Choose two.)
  • A. The data contained in a list data type cannot be modified.
  • B. The data contained in a list data type can be modified.
  • C. The data contained in a list data type is sequenced and indexed starting from 0.
  • D. The data contained in a list data type is not sequenced or indexed.
Python lists have the following characteristics:
Modifiable Data (A): Lists are mutable, meaning you can change, add, or remove elements after the list has been created.
Sequenced and Indexed (B): Lists maintain the order of their elements and are indexed starting from 0. This means you can access elements by their position in the list.
Option C is incorrect because lists are mutable, allowing modifications. Option D is incorrect because lists are indeed sequenced and indexed, unlike dictionaries.
Python Official Documentation: Covers the properties of lists, including mutability and indexing.
Python Data Structures Guide: Explains list operations and how to manipulate them.
NEW QUESTION # 57
Which two statements about NETCONF are true? (Choose two.)
  • A. It uses the operations layer to lock the configuration of a Junos device.
  • B. It uses the messages layer to commit the configuration of a Junos device.
  • C. It uses the operations layer to commit the configuration of a Junos device.
  • D. It uses the messages layer to lock the configuration of a Junos device.
NETCONF (Network Configuration Protocol) operates through different layers, with the operations layer being particularly important for managing configurations:
Operations Layer (A & D): This layer is responsible for actions like locking and committing the configuration on a Junos device. The lock operation prevents other sessions from modifying the configuration, and the commit operation applies the configuration changes to the device.
Options B and C are incorrect because the messages layer handles the communication aspects, such as exchanging data between the client and server, not performing configuration operations like locking and committing.
IETF RFC 6241 (NETCONF): Describes the protocol layers and their functions, with a focus on the operations layer.
Juniper Networks NETCONF Documentation: Provides insights into how NETCONF operations are managed in Junos
NEW QUESTION # 58
Which two standard logical operators does XPath support? (Choose two.)
  • A. NOT
  • B. MAMD
  • C. AND
  • D. IOR
XPath is a query language used for selecting nodes from an XML document. It supports various logical operators that can be used to create complex queries. The two standard logical operators supported by XPath are:
NOT: This operator negates a condition, returning true if the condition is false, and vice versa.
AND: This operator is used to combine two conditions, and it returns true only if both conditions are true.
Option A (IOR) and Option D (MAMD) are not standard XPath operators.
Supporting Reference:
XPath Documentation: The W3C XPath specification lists the standard operators supported in XPath, including AND and NOT.
NEW QUESTION # 59
Which two statements are valid regarding Junos automation? (Choose two.)
  • A. The jsd process handles XML API calls.
  • B. The jsd process handles JET API requests.
  • C. The mgd process handles JET API requests.
  • D. The mod process handles XML API calls.
In Junos automation, several processes handle API requests, and understanding which process handles what is crucial:
jsd Process:
XML API Calls (A): The jsd process is responsible for handling XML API calls, which are a significant part of Junos automation. XML API allows for structured and standardized communication with Junos devices, enabling automation scripts to query and configure devices.
JET API Requests (C): The jsd process also handles JET (Junos Extension Toolkit) API requests. JET provides a more modern, programmable interface for interacting with Junos OS, and jsd is the process that manages these interactions.
mgd Process (Incorrect Option):
Not for JET API Requests: The mgd process handles general management operations, such as CLI commands and managing the configuration database, but it does not handle JET API requests. That role is fulfilled by jsd.
mod Process (Incorrect Option):
Not for XML API Calls: The mod process deals with managing chassis components and is not involved in handling XML API calls.
Juniper Networks JET and XML API Documentation: Describes the roles of jsd in handling both XML and JET API requests.
Junos Automation and DevOps Documentation: Provides insights into how different processes interact with Junos APIs.
NEW QUESTION # 60
Which statement about the NETCONF content layer is true?
  • A. It uses XML for RPC request and response payloads.
  • B. It uses JSON for RPC request and response payloads.
  • C. It uses HTML for RPC request and response payloads.
  • D. It uses YAML for RPC request and response payloads.
NEW QUESTION # 61
People always do things that will benefit them, so as get a certificate of the JN0-224 test dumps. Obtaining a certificate means more opportunity, a good job, a better salary, and a bright. The benefits are numerous, and we give you a quicker method to achieve this. Our JN0-224 Questions and answers list the knowledge point for you, and you just need to speed some of your time to practice. We are pass guarantee and money back guarantee. And the pass rate is98.
JN0-224 Valid Dumps Ebook: https://www.guidetorrent.com/JN0-224-pdf-free-download.html
