[General] Valid AWS-Developer Exam Answers - AWS-Developer Reliable Test Preparation
89
General Valid AWS-Developer Exam Answers - AWS-Developer Reliable Test Preparation
Posted at 2/6/2026 13:08:21      View174 | Replies2        Print      Only Author   [Copy Link] 1#
P.S. Free & New AWS-Developer dumps are available on Google Drive shared by Prep4away: https://drive.google.com/open?id=1opA1w21pBfcdZae4QhNoXBvs5FGLxfoj
We believe our AWS-Developer exam questions will meet all demand of all customers. If you long to pass the exam and get the certification successfully, you will not find the better choice than our AWS-Developer preparation questions. Now you can have a chance to try our AWS-Developer study braindumps before you pay for them. There are the free demos on our website for you download to check the quality and validity of our AWS-Developer practice engine. Just have a try, then you will fall in love with our AWS-Developer learning quiz!
Amazon AWS-Certified-Developer-Associate exam is a valuable certification for developers who work with AWS services on a regular basis. It validates the skills and knowledge necessary to design, develop, and deploy cloud-based solutions using AWS services. AWS Certified Developer Associate Exam (DVA-C02) certification can help developers advance their careers and increase their earning potential, while also helping organizations identify qualified developers who can help them build and maintain cloud-based solutions using AWS services.
Amazon AWS-Developer Certification Exam is designed for developers who want to demonstrate their ability to develop and maintain applications on the Amazon Web Services (AWS) platform. AWS Certified Developer Associate Exam (DVA-C02) certification validates the skills and knowledge necessary to build, deploy, and manage scalable and secure applications on AWS. The AWS-Developer certification is one of the most popular certifications in the AWS certification family, and it is a great way to showcase your AWS expertise to employers.
AWS-Developer Reliable Test Preparation & AWS-Developer Online Lab SimulationLiving in such a world where competitiveness is a necessity that can distinguish you from others, every one of us is trying our best to improve ourselves in every way. It has been widely recognized that the AWS-Developer Exam can better equip us with a newly gained personal skill, which is crucial to individual self-improvement in today's computer era. With the certified advantage admitted by the test Amazon certification, you will have the competitive edge to get a favorable job in the global market.
Amazon AWS Certified Developer Associate Exam (DVA-C02) Sample Questions (Q129-Q134):NEW QUESTION # 129
A developer is creating an AWS Lambda function. The Lambda function needs an external library to connect to a third-party solution The external library is a collection of files with a total size of 100 MB The developer needs to make the external library available to the Lambda execution environment and reduce the Lambda package space Which solution will meet these requirements with the LEAST operational overhead?
  • A. Create an Amazon S3 bucket Upload the external library into the S3 bucket. Mount the S3 bucket folder in the Lambda function Import the library by using the proper folder in the mount point.
  • B. Create a Lambda layer to store the external library Configure the Lambda function to use the layer
  • C. Load the external library to the Lambda function's /tmp directory during deployment of the Lambda package. Import the library from the /tmp directory.
  • D. Create an Amazon Elastic File System (Amazon EFS) volume. Upload the external library to the EFS volume Mount the EFS volume in the Lambda function. Import the library by using the proper folder in the mount point.
* Lambda Layers: These are designed to package dependencies that you can share across functions.
* How to Use:
* Create a layer, upload your 100MB library as a zip.
* Attach the layer to your function.
* In your function code, import the library from the standard layer path.
Lambda Layers: https://docs.aws.amazon.com/lamb ... uration-layers.html
NEW QUESTION # 130
A developer is migrating code to an AWS Lambda function that will access an Amazon Aurora MySQL database.
What is the MOST secure way to authenticate the function to the database?
  • A. Store the database credentials as encrypted parameters in AWS Systems Manager Parameter Store Obtain the credentials from Systems Manager when the Lambda function needs to connect to the database
  • B. Store the database credentials in an Amazon S3 bucket that has a restrictive bucket policy for the Lambda role only when accessing the credentials Use AWS KMS to encrypt the data
  • C. Create a policy with rds-db connect access to the database and attach it to the role assigned to the Lambda function
  • D. Store the database credentials in AWS Secrets Manager Let Secrets Manager handle the rotation of the credentials, as required
NEW QUESTION # 131
A developer is deploying an AWS Lambda function The developer wants the ability to return to older versions of the function quickly and seamlessly.
How can the developer achieve this goal with the LEAST operational overhead?
  • A. Use AWS CodePipeline for deployments and rollbacks.
  • B. Use AWS OpsWorks to perform blue/green deployments.
  • C. Maintain deployment packages for older versions in Amazon S3.
  • D. Use a function alias with different versions.
A function alias is a pointer to a specific Lambda function version. You can use aliases to create different environments for your function, such as development, testing, and production. You can also use aliases to perform blue/green deployments by shifting traffic between two versions of your function gradually. This way, you can easily roll back to a previous version if something goes wrong, without having to redeploy your code or change your configuration. Reference: AWS Lambda function aliases
NEW QUESTION # 132
An application is processing clickslream data using Amazon Kinesis. The clickstream data feed into Kinesis experiences periodic spikes. The PutRecords API call occasionally fails and the logs show that the failed call returns the response shown below.
Which techniques will help mitigate this exception? (Select TWO.)
  • A. Implement retries with exponential backoff
  • B. Use a PutRecord API instead of PutRecords
  • C. Reduce the frequency and/or size of the requests
  • D. Reduce the number of KCL consumers.
  • E. Use Amazon SNS instead of Kinesis.
NEW QUESTION # 133
What are the steps to using the AWS CLI to launch a templatized serverless application?
  • A. Use AWS CloudFormation package then CloudFormation deploy.
  • B. Use AWS CloudFormation validate-template then CloudFormation create-change-set.
  • C. Use AWS CloudFormation get-template then CloudFormation execute-change-set.
  • D. Use AWS CloudFormation create-stack then CloudFormation update-stack.
Explanation/Reference: https://github.com/awslabs/aws-sam-cli
NEW QUESTION # 134
Compared with paper version of exam torrent, our AWS-Developer exam dumps are famous for instant download, and you can get your downloading link and password within ten minutes. If you dont receive, just contact with our service stuff by email, we will solve the problem for you. Besides AWS-Developer exam torrent of us is high quality, and you can pass the exam just one time. We are pass guaranteed and money back guaranteed. If you fail to pass the exam, we will refund you money. We have online chat service stuff, we are glad to answer all your questions about the AWS-Developer Exam Dumps.
AWS-Developer Reliable Test Preparation: https://www.prep4away.com/Amazon-certification/braindumps.AWS-Developer.ete.file.html
DOWNLOAD the newest Prep4away AWS-Developer PDF dumps from Cloud Storage for free: https://drive.google.com/open?id=1opA1w21pBfcdZae4QhNoXBvs5FGLxfoj
Posted at 2/16/2026 13:31:15        Only Author  2#
Great content, without a doubt, I'm clicking that like button. C-TS4FI-2023 valid braindumps ebook offers rich material, available for free to support your learning goals.
Posted at 3/5/2026 12:51:26        Only Author  3#
The content of this article has been very helpful to my personal growth. The HCL-HWA-ADM-102 reliable exam labs content is highly useful, and it's offered free of charge.
