[General] Valid Salesforce Analytics-DA-201 Exam Fee & Analytics-DA-201 New Exam Brain
89
【General】 Valid Salesforce Analytics-DA-201 Exam Fee & Analytics-DA-201 New Exam Brain
Posted at 2/6/2026 13:33:13      View:115 | Replies:0        Print      Only Author   [Copy Link] 1#
If you have bad mood in your test every time you should choose our Soft test engine or App test engine of Analytics-DA-201 dumps torrent materials. Both of these two versions have one function is simulating the real test scene. You can set timed exam and practice many times. You can feel exam pace and hold time to test with our Salesforce Analytics-DA-201 Dumps Torrent. You should take advantage of the time and opportunities you have to do the things you want. Our Analytics-DA-201 dumps torrent files provide you to keep good mood for the test.
Our Analytics-DA-201 exam questions are valuable and useful and if you buy our Analytics-DA-201 study materials will provide first-rate service to you to make you satisfied. We provide not only the free download and try out of the Analytics-DA-201 Practice Guide but also the immediate download after your purchase successfully. To see whether our Analytics-DA-201 training dumps are worthy to buy, you can have a try on our product right now.
Analytics-DA-201 New Exam Braindumps, Analytics-DA-201 Valid TorrentLearning is just a part of our life. We do not hope that you spend all your time on learning the Analytics-DA-201 certification materials. Life needs balance, and productivity gives us a sense of accomplishment and value. So our Analytics-DA-201 real exam dumps have simplified your study and alleviated your pressure from study. It is our goal that you study for a short time but can study efficiently. At present, thousands of candidates have successfully passed the Analytics-DA-201 Exam with less time input. In fact, there is no point in wasting much time on invalid input. As old saying goes, all work and no play makes jack a dull boy. Our Analytics-DA-201 certification materials really deserve your choice. Contact us quickly. We are waiting for you.
Salesforce Analytics-DA-201 Exam Syllabus Topics:
  • SAP Clean Core Extensibility and ABAP Cloud: This part of the exam targets the SAP S
  • 4HANA Technical Consultant and covers concepts of clean core extensibility using ABAP in the cloud. The focus is on in-app and side-by-side extensibility techniques, ensuring that custom code complies with cloud-readiness principles and does not compromise the upgrade stability of core systems.
  • Core ABAP Programming: This part of the exam assesses the foundational programming skills of the SAP S
  • 4HANA Technical Consultant. It includes knowledge of syntax, control structures, modularization, and internal tables in ABAP. The section aims to validate the candidate’s proficiency in writing clean, efficient ABAP code using best practices.
  • Object-Oriented Design: This section of the exam evaluates the SAP ABAP Cloud Developer's understanding of object-oriented principles in the ABAP context. It focuses on class-based programming, inheritance, interfaces, and polymorphism, all crucial for building modular and maintainable ABAP cloud applications.
Salesforce Certified Tableau Data Analyst Sample Questions (Q143-Q148):NEW QUESTION # 143
A Data Analyst has the following dataset:
The analyst wants to create a new calculated dimension field named Category that meets the following conditions:
When Subject is Computer Science or Science, the Category must be Sciences.
When Subject is English or Social Studies, the Category must be Humanities.
Which two logical functions achieve this goal? (Choose two.)
  • A. IIF((CONTAINS([Subject], 'Science') = TRUE), 'Humanities', 'Sciences')
  • B. CASE [Subject]
    WHEN 'Computer Science' THEN 'Sciences'
    WHEN 'English' THEN 'Humanities'
    WHEN 'Social Studies' THEN 'Humanities'END
  • C. IF [Subject] = 'Science' THEN 'Sciences'
    ELSEIF [Subject] = 'English' THEN 'Humanities'
    ELSEIF [Subject] = 'Social Studies' THEN 'Humanities'
    ELSEIF [Subject] = 'Computer Science' THEN 'Sciences'
    END
  • D. IF ENDSWITH([Subject], 'Computer Science') THEN 'Sciences' ELSE 'Humanities' END
NEW QUESTION # 144
A Data Analyst has received a request to provide a dashboard related to employee time logs. The employees are entering their time using mobile devices throughout the day and data is stored in a cloud-based database.
The end users would like to receive data on their dashboard in as close to real-time as possible.
How should the analyst best create a data source to meet these requirements?
  • A. Create a connection to the database using Tableau Desktop. Publish the data source to Tableau Cloud using a live connection, ensuring the database firewall has been configured to allow connections from Tableau Cloud.
  • B. Create a connection to the database using Tableau Desktop and retrieve an extract of the data. Publish the data source from Tableau Desktop to Tableau Cloud and schedule the refresh of the extract.
  • C. Create a connection to the database to retrieve the data using Tableau Bridge. Schedule the refresh of the data extract to 15 minutes.
  • D. Create a connection to the database using Tableau Desktop. Publish the data source to Tableau Cloud using a live connection and disable any firewalls on the database.
NEW QUESTION # 145
You have the following two datasets:
* A Microsoft Excel worksheet that has two columns named Employee Name and Department
* A Microsoft SQL Server table that has three columns named Employee Name. Pay Grade and Team Size.
You want to use Tableau Prep to join the two datasets.
Which three actions should you perform in order? (Place the three correct options in order.)
The correct order of the three actions is:
* From the connections pane, connect to both data sources
* Join both datasets and select the join type
* Specify Employee Name as the join key
The first action is to connect to both data sources from the connections pane in Tableau Prep. The connections pane is where you can access and add data sources to your flow. You can connect to various types of data sources, such as Excel, SQL Server, or Tableau Server. In this case, you want to connect to an Excel worksheet and a SQL Server table.
The second action is to join both datasets and select the join type. A join is a way of combining data from two or more tables based on a common field. You can join datasets by dragging one table to the canvas and dropping it on top of another table. This will create a join step in your flow. You can select the join type from the drop-down list on the join step. The join type determines which rows are returned from the tables.
The third action is to specify Employee Name as the join key. A join key is a field that is used to match rows from different tables. You can specify the join key by clicking on the field name in each table and dragging it to the center of the join step. This will create a join clause that shows the field name and the operator. In this case, you want to use Employee Name as the join key, because it is a common field between the two datasets.
The other options are not relevant for this scenario. Specifying Department and Team Size as a join condition will not work, because they are not common fields between the two datasets. Opening both data sources in Tableau Desktop will not help you join them in Tableau Prep. Adding a step to aggregate the data in the SQL Server table will not affect the join, but it may change the level of detail of your data. References: https://help.
tableau.com/current/prep/en-us/prep_connect.htm https://help.tableau.com/current/prep/en-us/prep_join.htm
https://help.tableau.com/current/prep/en-us/prep_join_types.htm
NEW QUESTION # 146
You have the following dataset.
You want to create a new calculated dimension field named Category that meets the following conditions:
. When Subject is Computer Science or Science, Category must be Sciences.
. When Subject is English or Social Studies, Category must be Humanities.
Which two logical functions achieve the goal? Choose two.
  • A. IF [Subject]- 'Science' THEN 'Sciences'
    ELSEIF [Subject]='English' THEN 'Humanities'
    ELSEIF [Subject]-'Social Studies' THEN 'Humanities'
    ELSEIF [Subject]= 'Computer Science' THEN 'Sciences'
    END
  • B. CASE [Subject]
    WHEN 'Science' THEN 'Sciences'
    End
  • C. IF ENDSWITH ( [Subject], 'Computer Science') THEN 'Sciences' ELSE 'Humanities' END
  • D. IIF(( CONTAINS ([Subject], 'Science') = TRUE) , 'Humanities', 'Sciences')
To create a new calculated dimension field named Category that meets the given conditions, you can use either the IF or the CASE logical function. Both functions allow you to evaluate an expression and return a value based on different scenarios. Option A uses the IF function with multiple ELSEIF clauses to check the value of the Subject field and assign it to either 'Sciences' or 'Humanities'. Option D uses the CASE function with multiple WHEN clauses to do the same thing. Both options will produce the same result, but the CASE function is more concise and easier to read. Option B is incorrect because it will assign 'Humanities' to any subject that contains 'Science' in its name, which is not the desired outcome. Option C is incorrect because it will only check if the subject ends with 'Computer Science' and ignore the other subjects. References:
* Logical Functions - Tableau
* Tableau Certified Data Analyst Study Guide
NEW QUESTION # 147
You are creating an annual report in Microsoft Word.
In Tableau Desktop, you build a chart in a worksheet.
You want to create an image of the chart that you can add to the annual report.
What are two ways to create the image? Choose two.
  • A. From the Worksheet menu, use the Copy option.
  • B. From the Dashboard menu, use the Export Image option.
  • C. From the Dashboard menu, use the Copy Image option.
  • D. From the Worksheet menu, use the Export option.
  • E. From the File menu, use the Export As Version option.
To create an image of the chart that you can add to the annual report, you can use either the Export option or the Copy option from the Worksheet menu. The Export option will allow you to save the image as a file in a specified location, name, and format. The Copy option will allow you to copy the image to the clipboard and paste it into another application, such as Microsoft Word. Both options will let you choose which elements to include in the image, such as title, caption, legend, etc. References:
* Export Views from Tableau Desktop to Another Application
* Copy and Paste Views from Tableau Desktop to Another Application
NEW QUESTION # 148
More and more people look forward to getting the Analytics-DA-201 certification by taking an exam. However, the exam is very difficult for a lot of people. Especially if you do not choose the correct study materials and find a suitable way, it will be more difficult for you to pass the exam and get the Analytics-DA-201 related certification. If you want to get the related certification in an efficient method, please choose the Analytics-DA-201 Study Materials from our company. We can guarantee that the study materials from our company will help you pass the exam and get the certification in a relaxed and efficient method.
Analytics-DA-201 New Exam Braindumps: https://www.lead2passexam.com/Salesforce/valid-Analytics-DA-201-exam-dumps.html
