[Hardware] Precise H12-821_V1.0 Exam Questions offer you high-efficient Study Materials - D
94
【Hardware】 Precise H12-821_V1.0 Exam Questions offer you high-efficient Study Materials - D
Posted at 2/6/2026 13:46:03      View:120 | Replies:1        Print      Only Author   [Copy Link] 1#
BONUS!!! Download part of DumpsQuestion H12-821_V1.0 dumps for free: https://drive.google.com/open?id=1gflPKDrTxUJx7ZwwNzVXmY1LXqY-AsJo
The latest H12-821_V1.0 exam prep is created by our IT experts and certified trainers who are dedicated to Huawei braindumps pdf for a long time. All questions of our H12-821_V1.0 PDF VCE are written based on the real questions. Besides, we always check the updating of H12-821_V1.0 exam questions to make sure exam preparation smoothly.
The Huawei H12-821_V1.0 exam covers a range of topics related to data communication, including network architecture principles, network protocols and technologies, network security, network management, and network troubleshooting. It is intended for network engineers, network administrators, and other professionals who are involved in the design, implementation, and maintenance of data communication networks.
Huawei H12-821_V1.0 Exam is designed to test the candidate's knowledge and skills in a variety of areas related to data communication. H12-821_V1.0 exam covers topics such as network architecture, transmission technology, IP technology, and routing technology. H12-821_V1.0 exam is designed to be challenging and requires candidates to have a deep understanding of the subject matter.
Huawei H12-821_V1.0 Reliable Exam Registration, Study H12-821_V1.0 PlanOur professional experts are very excellent on the compiling the content of the H12-821_V1.0 exam questions and design the displays. Moreover, they impart you information in the format of the H12-821_V1.0 questions and answers that is actually the format of your real certification test. Hence not only you get the required knowledge, but also you find the opportunity to practice real exam scenario. We have three versions of the H12-821_V1.0 Training Materials: the PDF, Software and APP online. And the Software version can simulate the real exam.
Huawei H12-821_V1.0 (HCIP-Datacom-Core Technology V1.0) certification exam is an industry-recognized certification that is highly regarded by many organizations. HCIP-Datacom-Core Technology V1.0 certification exam is designed to test the knowledge and skills of candidates in the area of datacom core technology. It is a great opportunity for professionals who are interested in advancing their careers in the field of datacom core technology. By obtaining this certification, candidates will be able to demonstrate their expertise and knowledge in the latest technologies and best practices in datacom core technology.
Huawei HCIP-Datacom-Core Technology V1.0 Sample Questions (Q704-Q709):NEW QUESTION # 704
BGP can select routes based on the AS_Path attribute. Therefore, in some cases, a route-policy needs to be used to modify the AS_Path attribute for route selection. Which of the following parameters can be specified in the apply as-path command for a route-policy to modify this attribute?
  • A. Delete
  • B. Copy
  • C. Overwrite
  • D. Additive
Answer: A,C,D
Comprehensive and Detailed Step-by-Step Explanation:
1. Overview of AS_Path Attribute Modification:
The apply as-path command in a route-policy is used to modify the AS_Path attribute of routes. This is often required to influence the selection of routes or to adjust routing policies for incoming or outgoing BGP updates.
2. Parameters of the apply as-path Command:
Option A: Delete
* Correct.
* The delete parameter removes specific AS numbers from the AS_Path attribute. This is used to simplify or manipulate the AS_Path for specific routing policies.
Option B: Additive
* Correct.
* The additive parameter appends an AS number to the existing AS_Path attribute, instead of overwriting it. This is useful when you want to prepend AS numbers to influence route selection without removing the original AS_Path.
Option C: Copy
* Incorrect.
* The copy parameter is not supported in the apply as-path command for modifying AS_Path attributes.
Option D: Overwrite
* Correct.
* The overwrite parameter replaces the existing AS_Path with a new one. This provides complete control over the AS_Path attribute but removes the original AS_Path entirely.
3. Summary:
The valid parameters for the apply as-path command are delete, additive, and overwrite.
Huawei HCIA-Datacom Study Guide, Chapter "BGP Route Policies."
BGP Attribute Modification in Huawei Documentation.
NEW QUESTION # 705
An enterprise administrator wants to configure single-hop BFD to implement fast detection of direct links.
Which of the following configurations are mandatory?
  • A. Configure a multicast IP address for BFD.
  • B. Enable BFD globally.
  • C. Configure the remote discriminator of a BFD session.
  • D. Configure the local discriminator of a BFD session.
Answer: B,C,D
For single-hop BFD (Bidirectional Forwarding Detection), the configuration must include the local and remote discriminators to uniquely identify the session endpoints. Additionally, enabling BFD globally is a prerequisite for initiating BFD sessions. Configuring multicast IP addresses is unnecessary for single-hop BFD, as it operates over direct links. Huawei's configuration guidelines specify these requirements to ensure effective deployment and operation of BFD.
Understanding BFD (Bidirectional Forwarding Detection):
* BFD is a protocol used to detect link faults quickly between two routers.
* Single-hop BFD operates on directly connected links and is commonly used for fast fault detection in routing protocols like OSPF and BGP.
NEW QUESTION # 706
On a WLAN, the HSB service sets up an HSB channel between two devices that back up each other, maintains the channel status, and backs up data.
Which of the following can HSB back up in real time?
  • A. CAPWAP tunnel information
  • B. AP entries
  • C. DHCP address information
  • D. User data information
Answer: A,B,D
HSB (Hot Standby Backup) Service:
HSB is used on WLAN controllers to back up critical information in real time to a backup device, ensuring service continuity in case of failures.
Backed-Up Information:
CAPWAP Tunnel Information (A): Essential for maintaining connections between APs and controllers.
AP Entries (C): Information about connected APs is backed up.
User Data Information (D): Includes client authentication and session details.
NEW QUESTION # 707
Which of the following descriptions about IGMP Proxy are correct? (Multiple choice)
  • A. IGMP Proxy can be deployed on a Layer 2 device between the IGMP querier and member hosts
  • B. IGMP Proxy cannot be deployed on a Layer 3 device between the IGMP querier and member hosts
  • C. The IGMP Proxy function can reduce the number of IGMP membership reports received by the IGMP querier
  • D. The IGMP Proxy function cannot reduce the number of IGMP member leave messages received by the IGMP querier
NEW QUESTION # 708
The Interface P address and VRRP virtual IP address can be the same.
  • A. FALSE
  • B. TRUE
NEW QUESTION # 709
H12-821_V1.0 Reliable Exam Registration: https://www.dumpsquestion.com/H12-821_V1.0-exam-dumps-collection.html
Posted at 2/15/2026 20:43:59        Only Author  2#
I’m sincerely grateful for your article, it really stood out to me. MS-700 certification exam provides excellent materials, and they are free to access.
