[General] Mock 300-510 Exam, 300-510 Exam Demo
106
【General】 Mock 300-510 Exam, 300-510 Exam Demo
Posted at 2/6/2026 16:56:28      View:134 | Replies:0        Print      Only Author   [Copy Link] 1#
P.S. Free 2026 Cisco 300-510 dumps are available on Google Drive shared by ExamTorrent: https://drive.google.com/open?id=1G81OzQmkLQ2MhaxmBbimWBjHTq9AxW01
After a short time's studying and practicing with our 300-510 exam questions, you will easily pass the examination. We can claim that if you study with our 300-510 learning quiz for 20 to 30 hours, then you will be confident to attend the exam. God helps those who help themselves. If you choose our 300-510 Study Materials, you will find God just by your side. The only thing you have to do is just to make your choice and study. Isn't it very easy? So know more about our 300-510 practice guide right now!
Earning the Cisco Certified Specialist - Service Provider Advanced Routing Implementation certification is a valuable achievement for IT professionals who are looking to advance their careers in the service provider industry. Implementing Cisco Service Provider Advanced Routing Solutions certification demonstrates a high level of expertise and knowledge in advanced routing solutions and is recognized by employers and industry professionals worldwide.
Cisco 300-510 exam is designed to test the candidate's knowledge and skills in implementing advanced routing solutions in a service provider network environment. 300-510 Exam is intended for network engineers, network administrators, and other IT professionals who have experience working with Cisco routers and switches. Successful completion of the Cisco 300-510 exam leads to the Cisco Certified Specialist - Service Provider Advanced Routing Implementation certification.
100% Pass Quiz 2026 Cisco 300-510 – Valid Mock ExamWith the rapid development of the world economy and frequent contacts between different countries, the talent competition is increasing day by day, and the employment pressure is also increasing day by day. If you want to get a better job and relieve your employment pressure, it is essential for you to get the 300-510 Certification. However, due to the severe employment situation, more and more people have been crazy for passing the 300-510 exam by taking examinations, the exam has also been more and more difficult to pass.
Cisco 300-510 exam is a 90-minute test comprising of 60-70 questions. 300-510 exam is available in English and Japanese languages and can be taken at any Pearson VUE testing center. 300-510 Exam is designed to assess the understanding and knowledge of candidates in implementing advanced routing technologies and solutions in a service provider environment.
Cisco Implementing Cisco Service Provider Advanced Routing Solutions Sample Questions (Q113-Q118):NEW QUESTION # 113
Refer to the exhibit. Which statement about this configuration is true?
  • A. Router 1 sends and receives multiple best paths from neighbor 192.168.1.1
  • B. Router 1 receives only the best path from neighbor 192.168.1.1
  • C. Router 1 receives up to two paths from neighbor 192.168.1.1 for all routes in the same AS
  • D. Router 1 sends up to two paths to neighbor 192.168.1.1 for all routes
https://www.cisco.com/c/en/us/td ... on/xe-16/irg-xe-16- book/bgp-additional-paths.html#GUID-3B53DD71-EA19-401F-93CC-79E92ADFB915
NEW QUESTION # 114
Refer to the exhibit. While configuring router 2 with all the default values, a network engineer cannot see any route received in router 1. How should the engineer solve the issue?
  • A. Set the network type in S1/0 to point-to-point.
  • B. Set up a priority different than 0 in the interface.
  • C. Modify the IP address or mask of the interface to a valid one.
  • D. Modify the router ID to be the interface IP on the serial.
NEW QUESTION # 115
An engineer is troubleshooting IS-IS configuration between two areas. IS-IS Area-A network 30.1.1.0/24 is leaked into IS-IS Area-#. R2 is failing to filter the route updates from network 10.1.1.0/24. Which configuration must the engineer apply to resolve the issue?
  • A. R2(config)# ip prefix-list List1 seq 3 deny 10.1.1.0/24
    R2(config)# ip prefix-list List1 seq 5 permit 30.1.1.0/24 ge 25 1e
    R2(config)# ip prefix-list List1 seq 10 permit 0.0.0.0/le 32
    R2(config)# interface fastethernet 0/0
    R2(config-if)# ip router isis 122
    R2(config-if)# router isis 122
    R2(config-router)# distribute-list prefix List1 in
  • B. R2(config)# ip prefix-list List2 seq 5 deny 10.1.1.0/24
    R2(config-if)# ip router isis 100
    R2(config-if)# router isis 100
    R2(config-router)# distribute-list gateway List2 in
  • C. R2(config)# access-list 101 deny ip any 10.1.1.0 0.0.0.127
    R2(config)# access-list 101 permit ip any 30.1.1.0 0.0.0.63
    R2(config)# access-list 101 deny ip any 0.0.0.0 0.0.0.0
    R2(config-if)# ip router isis 121
    R2(config-if)# router isis 121
    R2(config-router)# distribute-list 101 in
  • D. R1(config)# ip prefix-list List2 seq 5 deny 10.1.1.0/24
    R1(config)# interface fastethernet 0/0
    R1(config-if)# ip router isis 100
    R1(config-if)# router isis 100
    R1(config-router)# distribute-list gateway List2 in
    R (config-if)# router isis 150
    R1(config-router)# distribute-list route-map Map1 in
NEW QUESTION # 116
Refer to the exhibit. All routers on this network have been configured with PIM-SM, and R1 is the rendezvous point. However, when asymmetric routing is implemented to modify link usage, the network begins to drop certain multicast traffic. Which action corrects the problem?
  • A. Add a static Mroute for routes that are failing.
  • B. Place the routes affected by asymmetric routing in a VRF.
  • C. Configure the routers to use PIM-DM instead of PIM-SM.
  • D. Remove the asymmetric routing and use spanning tree to manage link usage.
NEW QUESTION # 117
An engineer has successfully fixed BGP peering issue. R1 has an established eBGP peering with R2 and R3. Which mechanism should the engineer apply in order to steer the traffic correctly?
  • A. The local preference attribute can be applied on R3 to influence AS 65513 to use AS 65515 as the secondary path.
  • B. The MED attribute can be applied on R2 to influence R1 to use it as the primary path.
  • C. The IGP metric can be manipulated on R1 to allow traffic to be load balanced between R2 and R3.
  • D. The weight attribute can be applied on R2 to influence AS 65513 to use AS 65515 as the primary path.
NEW QUESTION # 118
300-510 Exam Demo: https://www.examtorrent.com/300-510-valid-vce-dumps.html
P.S. Free & New 300-510 dumps are available on Google Drive shared by ExamTorrent: https://drive.google.com/open?id=1G81OzQmkLQ2MhaxmBbimWBjHTq9AxW01
