[General] MS-700 Exam Materials and MS-700 Test Braindumps - MS-700 Dumps Torrent - Actual
102
【General】 MS-700 Exam Materials and MS-700 Test Braindumps - MS-700 Dumps Torrent - Actual
Posted at 2/6/2026 18:57:03      View:111 | Replies:0        Print      Only Author   [Copy Link] 1#
P.S. Free 2026 Microsoft MS-700 dumps are available on Google Drive shared by ActualVCE: https://drive.google.com/open?id=1ww5wLKCAnhzMg-xMd14KH45PNJJP3ZGW
Wanting to upgrade yourself, are there plans to take Microsoft MS-700 exam? If you want to attend MS-700 exam, what should you do to prepare for the exam? Maybe you have found the reference materials that suit you. And then are what materials your worthwhile option? Do you have chosen ActualVCE Microsoft MS-700 Real Questions and answers? If so, you don't need to worry about the problem that can't pass the exam.
When you are eager to pass the MS-700 real exam and need the most professional and high quality practice material, we are willing to offer help. Our MS-700 training prep has been on the top of the industry over 10 years with passing rate up to 98 to 100 percent. By practicing our MS-700 Learning Materials, you will get the most coveted certificate smoothly. Our MS-700 study quiz will guide you throughout the competition with the most efficient content compiled by experts.
Free PDF Quiz 2026 MS-700: Perfect Managing Microsoft Teams New Study PlanTo do this you just need to pass MS-700 exam, which is quite challenging and demands thorough Managing Microsoft Teams (MS-700) exam preparation. For the complete, comprehensive and quick MS-700 Exam Preparation, the ActualVCE MS-700 Dumps questions are ideal. You should not ignore it and must try ActualVCE MS-700 exam questions for preparation today.
Microsoft Managing Microsoft Teams Sample Questions (Q367-Q372):NEW QUESTION # 367
Your company has a Microsoft 365 subscription and a Virtual Desktop Infrastructure (VDI) solution.
The company's Microsoft Teams upgrade policy is set to Teams only coexistence mode.
You deploy the Microsoft Installer (MSI) package for Microsoft Teams to the VDI solution.
Several months later, users of the VDI solution report that their workstation is missing several new Microsoft Teams features.
You need to ensure that the VDI solution users can use the new Microsoft Teams features.
Solution: From the Microsoft Teams admin center, you modify the Microsoft Teams upgrade policy.
Does this meet the goal?
  • A. No
  • B. Yes
https://docs.microsoft.com/en-us ... teams-client-update
NEW QUESTION # 368
You have a Microsoft 365 subscription that uses Microsoft Teams.
You need to meet the following requirements:
Users must be able to join meetings by dialing a phone number.
Users must be able to apply custom branded meeting lobbies.
Auto attendants and call queues must be implemented.
Which Microsoft Teams feature should you configure for each requirement? To answer, select the appropriate options in the answer area.
https://docs.microsoft.com/en-us ... nced-communications
NEW QUESTION # 369
Your company has a Microsoft 365 subscription that uses Microsoft Office 365 E5 licenses and Azure Active Directory Premium Plan 1 licenses.
You have a team named Sales that contains all the users in the company's sales department.
You hire several new users in the sales department.
You discover that the new employees are never added to the team.
You need to ensure that when new sales department users are hired, they are added automatically to the team.
What should you do?
  • A. From the Microsoft 365 admin center, modify the settings of the Sales group.
  • B. From the Microsoft Teams admin center, modify the properties of the Sales team.
  • C. From the Azure Active Directory admin center, modify the membership type of the Sales group.
  • D. From the Microsoft Teams client, modify the settings of the Sales team.
Explanation/Reference:
https://docs.microsoft.com/en-us ... dynamic-memberships
https://docs.microsoft.com/en-us ... /groups-change-type
NEW QUESTION # 370
You need to recommend which inbound ports to the network and outbound ports to Office 365 must be allowed on the company's firewall after the planned upgrade. The solution must meet the security requirements.
Which inbound and outbound ports should you recommend? To answer, select the appropriate options in the answer area.
https://docs.microsoft.com/en-us ... s-online-call-flows
Topic 2, Litware, inc
Case study
This is a case study. Case studies are not timed separately. You can use as much exam time as you would like to complete each case. However, there may be additional case studies and sections on this exam. You must manage your time to ensure that you are able to complete all questions included on this exam in the time provided.
To answer the questions included in a case study, you will need to reference information that is provided in the case study. Case studies might contain exhibits and other resources that provide more information about the scenario that is described in the case study. Each question is independent of the other questions in this case study.
At the end of this case study, a review screen will appear. This screen allows you to review your answers and to make changes before you move to the next section of the exam. After you begin a new section, you cannot return to this section.
To start the case study
To display the first question in this case study, click the   button. Use the buttons in the left pane to explore the content of the case study before you answer the questions. Clicking these buttons displays information such as business requirement, existing environment, and problem statements. If the case study has an All Information tab, note that the information displayed is identical to the information displayed on the subsequent tabs. When you are ready to answer a question, click the   button to return to the question.
Overview
General overview
Litware, Inc. is an international manufacturing company that has 4,000 users. The company has the following four departments:
* IT
* HR
* R&D
* Sales
Physical locations
Litware has two main offices. The offices are located in New York and London.
All offices connect to each other by using a WAN link. Each office connects directly to the Internet.
Existing environment
All user accounts have an Azure Active Directory Premium Plan P1 license.
Litware has a Microsoft 365 subscription that has Office 365 Enterprise E3 licenses for all users. All the E3 products and services are enabled for each user.
Litware uses Microsoft Skype for Business Online.
Requirements
Planned Upgrade
Litware identifies the following requirements for a planned upgrade from Skype for Business Online to Microsoft Teams:
* Provide high quality audio, video, and online meeting experience for Microsoft Teams end users.
* Implement a data retention solution in Microsoft Teams.
* Minimize costs and administrative effort.
* Use the principle of least privilege.
For the sales department, Litware plans to create a team that dynamically updates its membership when users leave and join the department.
Department Upgrade Requirements
Litware plans to implement upgrade requirements for the departments as shown in the following table.
Microsoft Teams Requirements
All teams must meet the following requirements:
* Only users in a partner company that uses a domain named fabrikam.com must be able to collaborate in teams by using guest accounts.
* Only users in the compliance department of Litware must be able to create teams.
Planned Network Tasks
Litware identifies the following network validation tasks:
* An administrator named Admin5 must be able to review the required bandwidth to support audio conferencing, video conferencing, and screen sharing in Microsoft Teams.
* An administrator named Admin6 must be able to review network issues that cause poor call quality reported by users.
Data Retention Requirements
Litware identifies the following data retention requirements:
* Requirement1: All messages in team collaborations must be deleted after seven years.
* Requirement2: all files used in team collaborations must be retained for five years.
* Requirement3: All files used in personal chats must be retained for five years.
Device Requirements
You provide Microsoft Teams-certified IP phones to users in the IT and R&D departments. Each device must meet the following requirements:
* The time zone on the phones used by the R&D department must be set to UTC-8.
* The time zone on the phones used by the IT department must be set to UTC-5.
* All phones must lock automatically after 60 seconds of inactivity.
Voice Pilot Requirements
Litware wants to pilot Phone System as a calling solution for 20 IT department users. The pilot project will receive phone numbers from Microsoft Teams.
Collaboration and Meeting Requirements
Litware identifies the following collaboration and meeting requirements:
* Cloud recording must be disabled for all Microsoft Teams meetings organized by users in the HR departments only.
* Meeting email invitations must be customized to include the Logo URL, Legal URL, and Help URL of Litware.
NEW QUESTION # 371
You open the Microsoft Call Quality Dashboard as shown in the following exhibit.
NEW QUESTION # 372
If you have been very panic sitting in the examination room, our MS-700 actual exam allows you to pass the exam more calmly and calmly. After you use our products, our MS-700 study materials will provide you with a real test environment before the MS-700 Exam. After the simulation, you will have a clearer understanding of the exam environment, examination process, and exam outline. And our MS-700 learning guide will be your best choice.
Test MS-700 Result: https://www.actualvce.com/Microsoft/MS-700-valid-vce-dumps.html
Test MS-700 Result - Managing Microsoft Teams study guide, the most powerful assistant, High efficiency service has won reputation for us among multitude of customers, so choosing our MS-700 real study dumps we guarantee that you won't be regret of your decision, We Promise we will very happy to answer your question on our MS-700 exam braindumps with more patience and enthusiasm and try our utmost to help you out of some troubles, Microsoft MS-700 New Study Plan You will have prior experience in answering questions with adjustable time.
Responsible staffs for prefect MS-700 practice test materials, Owning a PC can in some ways be comparable to owning an automobile: both require routine maintenance, system checks, and preventative services.
Pass Guaranteed Quiz 2026 MS-700: Managing Microsoft Teams Useful New Study PlanManaging Microsoft Teams study guide, the most powerful assistant, High efficiency service has won reputation for us among multitude of customers, so choosing our MS-700 real study dumps we guarantee that you won't be regret of your decision.
We Promise we will very happy to answer your question on our MS-700 exam braindumps with more patience and enthusiasm and try our utmost to help you out of some troubles.
You will have prior experience in answering questions with adjustable time, If you still have doubts about MS-700 exam quiz, you can be allowed to download our free demo for try.
