[General] NCP-US-6.10 Guide Covers 100% Composite Exams
102
General NCP-US-6.10 Guide Covers 100% Composite Exams
Posted at 2/6/2026 19:06:18      View123 | Replies0        Print      Only Author   [Copy Link] 1#
P.S. Free 2026 Nutanix NCP-US-6.10 dumps are available on Google Drive shared by PassTorrent: https://drive.google.com/open?id=1M2bzkMKNeF7tia4egrk60muoO_GYqbVZ
If you want to constantly improve yourself and realize your value, if you are not satisfied with your current state of work, if you still spend a lot of time studying and waiting for NCP-US-6.10 qualification examination, then you need our NCP-US-6.10 material, which can help solve all of the above problems. I can guarantee that our study materials will be your best choice. Our NCP-US-6.10 Study Materials have three different versions, including the PDF version, the software version and the online version.
Under the tremendous stress of fast pace in modern life, this version of our NCP-US-6.10 test prep suits office workers perfectly. It can match your office software and as well as help you spare time practicing the NCP-US-6.10 exam. As for its shining points, the PDF version can be readily downloaded and printed out so as to be read by you. Its really a convenient way for those who are fond of paper learning. With this kind of version, you can flip through the pages at liberty and quickly finish the check-up NCP-US-6.10 Test Prep. Whats more, a sticky note can be used on your paper materials, which help your further understanding the knowledge and review what you have grasped from the notes.
Reliable Nutanix NCP-US-6.10 Test Cram - Exam NCP-US-6.10 MaterialBy offering you excellent NCP-US-6.10 dumps files, PassTorrent make you career bright and successful. We will offer you discount in buying NCP-US-6.10 exam pdf. Once you buy our Nutanix practice questions, you will receive the download link immediately. Our aim is to provide our customers with latest exam study guide and the best-quality service. The up-to-date NCP-US-6.10 Practice Questions and answers are right here.
Nutanix Certified Professional - Unified Storage (NCP-US) v6.10 Sample Questions (Q85-Q90):NEW QUESTION # 85
Which Nutanix Objects metric provides the total input requests per second of a bucket?
  • A. Gets
  • B. NFS Reads
  • C. Puts
  • D. Throughput
In Nutanix Objects metrics:
* Puts: Measures PUT requests per second (object uploads), representing input operations.
* Gets (Option C): Measures output (download) requests.
* Throughput (Option B): Reports bandwidth (MB/s), not request rate.
* NFS Reads (Option D): Specific to NFS access, not general bucket input.
Reference:Nutanix Objects Administration Guide:
"The Puts metric tracks the number of successful object write operations (PUTs) per second to a bucket, indicating input request volume."(Chapter: "Monitoring Object Store Performance") Nutanix Unified Storage (NCP-US) Study Material:
"Use the 'Puts' metric to monitor ingress request rates for capacity planning and performance tuning."(Section:
"Objects Performance Analysis")
NEW QUESTION # 86
Question:
During a Windows 2019 Failover Cluster deployment, an administrator is unable to deploy a Nutanix Files witness share.
The Nutanix Files cluster environment is as follows:
* SMB shares need to be highly available
* DFS is enabled for the cluster
* Three FSVMs are deployed
* General share type is used
* WORM is disabled
What should the administrator do to resolve the issue?
  • A. Use NFS for shares.
  • B. Enable WORM.
  • C. Use homes as the share type.
  • D. Disable DFS on the share.
Thewitness sharein a Windows Failover Cluster environment (for cluster quorum) requires a highly available and consistent SMB share.
In the NUSA course, it's highlighted thatDistributed File System (DFS)is not compatible with witness share deployments because:
"When DFS is enabled on a Nutanix Files share, it redirects and abstracts file paths across multiple servers for redundancy and load balancing. However, Windows Failover Clustering requires direct access to a highly available SMB share without DFS interference to maintain strict cluster quorum consistency." Therefore, to deploy awitness share:
DFS must be disabled on the shareused for the cluster witness.
* Enabling DFS causes redirection and breaks direct share connections that Failover Clustering needs.
* WORM and share type are irrelevant here-DFS is the critical factor.
* NFS is not suitable because Windows Failover Clustering requires SMB for witness shares.
Thus, to resolve the deployment issue, the administrator shoulddisable DFS on the shareintended for the witness role.
NEW QUESTION # 87
Question:
An administrator is preparing to deploy Nutanix Objects on an AHV-based Nutanix cluster in a multi-cluster environment. The Virtual IP address and Data Services IP address have already been configured on the AHV cluster.
Which additional IP address should be configured for successful Objects deployment?
  • A. Fallback Virtual IP on cluster where Prism Central is deployed
  • B. Data Services IP on cluster where Prism Central is deployed
  • C. IPv6 address of Prism Element on AHV cluster
  • D. Fallback Virtual IP of Prism Element on AHV cluster
When deploying Nutanix Objects in amulti-cluster environment, Prism Central coordinates deployment across clusters.
In the NUSA deployment module, it's emphasized:
"Prism Central requires a Fallback Virtual IP (VIP) on the cluster it manages to ensure management traffic can be redirected even if a CVM or Prism Element service fails." Thus, theFallback Virtual IP on the cluster where Prism Central is deployedis a critical additional IP address for:
Ensuring management continuity
Supporting Object service deployment across clusters
The other options (like IPv6 or DSIP on Prism Central's cluster) are not required specifically for Nutanix Objects deployment.
NEW QUESTION # 88
An administrator is required to provide a summary of metrics to the Security team.
The entity information being asked for by the Security team is as follows:
* Total folders where permissions are tracked
* Size of those folders
* Total unique users
* Total unique groups
In which product and dashboard would the administrator find all the requested data?
  • A. Data Lens - Recommendations
  • B. Data Lens Footprint Widget
  • C. File Analytics File Operations
  • D. File Analytics - Top Users
As per the official Nutanix Unified Storage Administration (NUSA) course documentation, the Data Lens Footprint Widget provides comprehensive insights regarding folder-level data usage, permissions tracking, and user/group access details. Specifically, it offers metrics such as:
* Total number of folders being tracked, including security and access control data
* Size of the folders monitored
* Total unique users and groups with access to the folders
This aligns with the requirements listed by the Security team in the question, namely:
The Data Lens Footprint Widget was specifically highlighted in the NUSA course module"Monitoring and Analyzing Data with Data Lens", under the section"Using Data Lens for Security and Compliance", which explicitly states:
"The Footprint Widget offers a consolidated view of folder usage, access control metadata, and group/user- level data. This includes unique user and group counts, as well as overall folder count and size, making it ideal for security teams needing access-level information and usage metrics." Therefore, based on this authoritative reference, the correct product and dashboard that would provide all the requested data to the Security team is theData Lens Footprint Widget.
Nutanix Unified Storage Administration (NUSA) course - Module: Monitoring and Analyzing Data with Data Lens - Section: Using Data Lens for Security and Compliance.
Nutanix Unified Storage (NCP-US) Study Guide - Topic: Data Lens Dashboards and Metrics.
NEW QUESTION # 89
How many IP addresses are required by the storage network when deploying Nutanix Files?
  • A. Same number of IP addresses as the number of FSVMs
  • B. One less IP address than the number of FSVMs
  • C. One additional IP address than the number of FSVMs
  • D. Twice as many IP addresses as the number of FSVMs
When deploying Nutanix Files, the storage network requires **one additional IP address than the number of File Server Virtual Machines (FSVMs)**. Nutanix Files is a scale-out file storage solution that uses a distributed architecture, where each FSVM handles file services and communicates with clients and the Nutanix cluster. The IP address requirements include one IP address for each FSVM plus an additional virtual IP address (VIP) that serves as the client-facing endpoint for the file server.
The **Nutanix Unified Storage Administration (NUSA)** course explains that Nutanix Files deployment involves configuring a file server with a minimum of three FSVMs for high availability and scalability. Each FSVM requires a unique IP address on the storage network to handle internal communication and data operations. Additionally, a single VIP is configured for the file server to provide a unified access point for clients using protocols like SMB or NFS. This VIP is load-balanced across the FSVMs, ensuring seamless failover and scalability.
The **Nutanix Certified Professional - Unified Storage (NCP-US)** study guide specifies that "the storage network for Nutanix Files requires one IP address per FSVM plus one additional IP address for the file server VIP." For example, a Nutanix Files deployment with three FSVMs would require four IP addresses: three for the FSVMs and one for the VIP. This configuration ensures that clients can access the file server through a single IP address, while the FSVMs handle the backend storage operations.
The other options are incorrect:
- **Same number of IP addresses as the number of FSVMs**: This does not account for the additional VIP required for client access, which is a critical component of the Nutanix Files architecture.
- **One less IP address than the number of FSVMs**: This is not feasible, as each FSVM requires its own IP address, and the VIP adds an additional requirement.
- **Twice as many IP addresses as the number of FSVMs**: This overestimates the IP address needs, as only one additional VIP is needed, not double the number of FSVMs.
The NUSA course documentation further clarifies that "the VIP is used to abstract the file server from the individual FSVMs, providing a single point of access for clients and enabling features like load balancing and failover." The storage network must be configured with sufficient IP addresses to accommodate both the FSVMs and the VIP during deployment.
- Nutanix Unified Storage Administration (NUSA) Course, Section on Nutanix Files: "Deployment and network configuration for Nutanix Files, IP address requirements."
- Nutanix Certified Professional - Unified Storage (NCP-US) Study Guide, Topic 1: Deploy and Upgrade Nutanix Unified Storage, Subtopic: "Nutanix Files architecture and network setup."
- Nutanix Documentation (https://www.nutanix.com), Nutanix Files Administration Guide: "Configuring storage network and VIP for Nutanix Files deployment."
NEW QUESTION # 90
PassTorrent is a trusted platform that is committed to helping Nutanix NCP-US-6.10 exam candidates in exam preparation. The Nutanix NCP-US-6.10 exam questions are real and updated and will repeat in the upcoming Nutanix NCP-US-6.10 Exam. By practicing again and again you will become an expert to solve all the NCP-US-6.10 exam questions completely and before the exam time.
Reliable NCP-US-6.10 Test Cram: https://www.passtorrent.com/NCP-US-6.10-latest-torrent.html
Nutanix NCP-US-6.10 Test Engine If you indeed have other questions, just contact us, Luckily for all the Nutanix NCP-US-6.10 experts, PassTorrent is now here to help you with your Nutanix IT certification problems, as we are the best Nutanix Certified Professional (NCP) exam questions training material providing vendor, Download free Nutanix Nutanix Certified Professional (NCP) NCP-US-6.10 braindumps from our site and get familiarity with the most simplified Nutanix Certified Professional (NCP) exam preparation material that guarantees you passing.
Using the Precision Editor, To Multithread or Not to Multithread, If you indeed have other questions, just contact us, Luckily for all the Nutanix NCP-US-6.10 experts, PassTorrent is now here to help you with your Nutanix NCP-US-6.10 IT certification problems, as we are the best Nutanix Certified Professional (NCP) exam questions training material providing vendor.
Free PDF 2026 Valid Nutanix NCP-US-6.10 Test EngineDownload free Nutanix Nutanix Certified Professional (NCP) NCP-US-6.10 braindumps from our site and get familiarity with the most simplified Nutanix Certified Professional (NCP) exam preparation material that guarantees you passing.
With professional backup and all-out effort from experts group, our NCP-US-6.10 quiz materials are truly useful with utility which can help you get desirable outcome in limited time.
No useless and interminable message in it.
2026 Latest PassTorrent NCP-US-6.10 PDF Dumps and NCP-US-6.10 Exam Engine Free Share: https://drive.google.com/open?id=1M2bzkMKNeF7tia4egrk60muoO_GYqbVZ
